    4. Test Adapter Bosch Indego
      tombox last edited by
      @mike2712 Wenn du eine ständige aktuelle Position haben willst dann sollte der Interval bei 1minute liegen
      Mein Stand ist auch nur eine ValueList in der vis bei der man die wichtigsten states definiert.
        mike2712 last edited by mike2712
        @tombox ok, das teste ich gleich mal, das mit der value list ist aber echt kompliziert und unübersichtlicht, habe es mit einen html widget gelöst:
        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{v:boschindego.0.121604023.state.state; v ==   0 ? 'Reading status' : v == 257 ? 'Charging' : v == 258 ? 'Docked' : v == 259 ? 'Docked - Software update' : v == 260 ? 'Docked' : v == 261 ? 'Docked' : v == 262 ? 'Docked - Loading map' : v == 263 ? 'Docked - Saving map' : v == 513 ? 'Mowing' : v == 514 ? 'Relocalising' : v == 515 ? 'Loading map' : v == 516 ? 'Learning lawn' : v == 517 ? 'Paused' : v == 518 ? 'Border cut' : v == 519 ? 'Idle in lawn' : v == 769 ? 'Returning to Dock' : v == 770 ? 'Returning to Dock' : v == 771 ? 'Returning to Dock - Battery low' : v == 772 ? 'Returning to dock - Calendar timeslot ended' : v == 773 ? 'Returning to dock - Battery temp range' : v == 774 ? 'Returning to dock' : v == 775 ? 'Returning to dock - Lawn complete' : v == 776 ? 'Returning to dock - Relocalising' : v == 1025 ? 'Diagnostic mode' : v == 1026 ? 'EOL Mode' : v == 1281 ? 'Software update' : v == 1537 ? 'Low power mode' : v == 64513 ? 'Docked - Waking up'  : '---'}\n"},"style":{"left":"1340px","top":"690px","color":"#FFFFFF"},"widgetSet":"basic"}]
          tombox @mike2712 last edited by
          @mike2712 naja value list html kannst du den max value wert eintragen und dann für die bestimmten wert die Beschreibung besser als die Wertenliste
            JohannesF @tombox last edited by
            Bzgl Abfragezeit 1 Minute:
            Hat jemand Erfahrung wie schnell/oft Bosch das abfragen zulässt?
            Ich wollte eine Karte mitzeichnen und hatte das irgendwo im Sekundenbereich. Irgendwann kam dann (auch in der App) eine Fehlermeldung. Am nächsten Tag ging es dann wieder.
            Johannes
            • pfried
              pfried last edited by pfried
              Ich bin ja so was von begeistert, dass der Adapter nun wieder funktioniert! Vielen, vielen Dank!
              Edit: Abfragezeit: 1 Minute
                JohannesF @pfried last edited by
                hat sich jemand die 'battery' Informationen schon mal näher angeschaut?
                Bei mir geht 'voltage' runter bis 1,8 und rauf bis 9,4. Was sind das für Werte? Das ist ein 18V LiIon Akku. Ich nehm mal an 4 Zellen. Also sollte der Spannungsbereich ca. 14,4 V bis 16,8V oder so sein.
                Gleichzeitig liefert Percent immer genau den 10 fachen Wert von Voltage.
                Also 5V sind 50% ???
                Wie ist das bei euch?
                  JohannesF @JohannesF last edited by
                  @johannesf Nachtrag: Es sind 5 Zellen in Reihe. also nochmal 4v mehr als oben angegeben.
                  pfried 1 Reply Last reply Reply Quote 0
                  • pfried
                    pfried @JohannesF last edited by pfried
                    Hallo @tombox, bin ich mit der Fehlermeldung alleine? Tritt bei mir seit einer Woche auf:
                    • Codierknecht
                      Codierknecht Developer Most Active @pfried last edited by
                      @pfried sagte in Test Adapter Bosch Indego:
                      Nö - häng Dich dran ...
                      https://github.com/iobroker-community-adapters/ioBroker.boschindego/issues/73
                      jbeenenga created this issue in iobroker-community-adapters/ioBroker.boschindego
                      closed Login is not work anymore #73
                      • Codierknecht
                        Codierknecht Developer Most Active last edited by
                        Die neue Version 1.2.2 fixt das Problem mit dem nicht mehr funktionierenden Login.
                        Als Experte von NPM installierbar.
                        • mcm1957
                          mcm1957 @Codierknecht last edited by
                          @codierknecht said in Test Adapter Bosch Indego:
                          Oder ganz normal über das LATEST Repository installieren:
                          • Codierknecht
                            Codierknecht Developer Most Active @mcm1957 last edited by
                            @mcm1957 sagte in Test Adapter Bosch Indego:
                            ... und anschließend nicht vergessen, das Repo wieder auf "stable" zurück zu stellen 😉
                            pfried 1 Reply Last reply Reply Quote 1
                            • pfried
                              pfried @Codierknecht last edited by
                              @codierknecht @tombox Geht es nur mir so, oder haben die schon wieder etwas geändert?
                              integer63 1 Reply Last reply Reply Quote 0
                              • integer63
                                integer63 @pfried last edited by
                                @pfried Nein, wir sind schon mal mindestes zwei 😉
                                • mcm1957
                                  @integer63
                                  TA2k war do offensichtlich schon aktiv - DANKE:
                                  https://github.com/iobroker-community-adapters/ioBroker.boschindego?tab=readme-ov-file#132-2024-11-28
                                  1.3.2 sollte spätestens morgen via LATEST verfügbar sein.
                                  Wenn ich hier lese dass sie funktioniert (und mich ggF wer dran dran erinnert) kann / werde ich sie prior ins stable schieben.
                                  • integer63
                                    integer63 @mcm1957 last edited by
                                    @mcm1957 1.3.2 funktioniert bei mir - vielen dank!
                                    • pfried
                                      pfried @integer63 last edited by
                                      Danke für das schnelle Update - geht wieder bei mir!
                                        Dosierkappe last edited by
                                        ich habe mir vor kurzem eine VIS zusammengebaut. Ich kann nur den letzten Fehler nicht löschen. Wenn ich richtig in der Annahme bin braucht man doch nur reset_alerts auf true setzen oder?Screenshot 2024-12-31 104240.jpg
                                        Ich bekomme den Fehler nicht gelöscht.
                                        LG
                                          Ok voller vorfreude in den Keller den Mäher geholt aktiviert und Adapter ist wieder rot.😥
                                          • integer63
                                            Bei mir leider auch:
                                            143
                                            18927
