    4. Node-Red
    5. [Gelöst] Alexa - Geräte reagieren nicht mehr
    • Samson71
      Samson71 Global Moderator @Hant0r last edited by
      @hant0r
      Um überhaupt irgendwas sagen zu können das Übliche. Ein vollständiges iob diag in Code-Tags (</>)
      Hant0r 1 Reply Last reply Reply Quote 0
      • Hant0r
        Hant0r @Samson71 last edited by
        @samson71
        Danke dir, hier das Log:
        ℹ ioBroker läuft in einem Docker auf einer Diskstation
                                v.2024-10-19
        model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.1
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               CEST +0200
        User-ID:                0
        Display-Server:         false
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        Recommended versions are nodejs 20.18.0 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:             12G        5.9G        377M        148M        6.6G        6.5G
        Swap:           9.6G         49M        9.5G
        Total:           21G        6.0G        9.9G
        Active iob-Instances:   42
        Upgrade policy: patch
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                26969
        States:                 23419
        Size of iob-Database:
        38M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/objects.json.bak2
        19M     /opt/iobroker/iobroker-data/objects.json.migrated
        19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        23M     /opt/iobroker/iobroker-data/states.jsonl
        4.8M    /opt/iobroker/iobroker-data/states.json.migrated
        4.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        da_Woody Samson71 2 Replies Last reply Reply Quote 0
        • da_Woody
          da_Woody @Hant0r last edited by
          @hant0r was ist so schwer zu verstehen? Full iobdiag, nicht die summery.
          • Samson71
            @hant0r sagte in Alexa - Geräte reagieren nicht mehr:
            Ist "nur" der Summary, nicht das vollständige iob diag, aber
            Da bin ich dann auch vermutlich raus.
            • Hant0r
              Hant0r @da_Woody last edited by
              @da_woody
              mia culpa
              ========== Start marking the full check here ===========
              Script v.2024-10-19
              *** BASE SYSTEM ***
              Hardware Vendor : Synology
              Kernel          : x86_64
              Userland        : 64 bit
              Docker          : v9.1.1
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** TIME AND TIMEZONES ***
              Mon Oct 21 09:02:48 UTC 2024
              Mon Oct 21 11:02:48 CEST 2024
              CEST +0200
              Etc/UTC
              *** Users and Groups ***
              User that called 'iob diag':
              root
              HOME=/root
              GROUPS=root
              iobroker
              HOME=/opt/iobroker
              GROUPS=iobroker tty dialout audio video plugdev
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             12G        6.0G        278M        148M        6.6G        6.4G
              Swap:           9.6G         51M        9.5G
              Total:           21G        6.1G        9.8G
                      11822 M total memory
                       5720 M used memory
                       5573 M active memory
                       4202 M inactive memory
                        265 M free memory
                         15 M buffer memory
                       6273 M swap cache
                       9143 M total swap
                         49 M used swap
                       9094 M free swap
              top - 11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
              Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  11822.1 total,    263.8 free,   5722.7 used,   6289.3 buff/cache
              MiB Swap:   9143.9 total,   9094.5 free,     49.4 used.   6099.5 avail Mem
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem             Type   Size  Used Avail Use% Mounted on
              /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /
              tmpfs                  tmpfs   64M     0   64M   0% /dev
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
              shm                    tmpfs   64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/iobroker
              /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /etc/hosts
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
              [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
              [Mon Oct 21 09:32:14 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
              Show mounted filesystems:
              TARGET             SOURCE        FSTYPE OPTIONS
              /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3717,subvol=/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250
              |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/ioBroker_data]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/ioBroker_data
              |-/opt/userscripts /dev/mapper/cachedev_0[/@syno/docker/userscripts]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/userscripts
              |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf
              |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname
              `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts
              /var:
              39M     /var/
              37M     /var/lib
              19M     /var/lib/apt/lists
              19M     /var/lib/apt
              18M     /var/lib/dpkg
              /opt/iobroker/backups:
              629M    /opt/iobroker/backups/
              339M    /opt/iobroker/backups/Doorbird
              323M    /opt/iobroker/backups/Doorbird/Motion
              17M     /opt/iobroker/backups/Doorbird/Doorbell
              1.5M    /opt/iobroker/backups/scripts
              /opt/iobroker/iobroker-data:
              1.6G    /opt/iobroker/iobroker-data/
              1.1G    /opt/iobroker/iobroker-data/files
              615M    /opt/iobroker/iobroker-data/files/javascript.admin
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              556M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              29M     /opt/iobroker/iobroker-data/states.jsonl
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyUSB0
              *** NodeJS-Installation ***
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              nodejs:
                Installed: 18.20.4-1nodesource1
                Candidate: 18.20.4-1nodesource1
                Version table:
               *** 18.20.4-1nodesource1 1001
                     1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.20.3-1nodesource1 1001
                   18.20.2-1nodesource1 1001
                   18.20.1-1nodesource1 1001
                   18.20.0-1nodesource1 1001
                   18.19.1-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                   18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 1673)
              iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 1657)
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     8
              +-- iobroker.jablotron@0.1.3 (git+ssh://git@github.com/DEV2DEV-DE/ioBroker.jablotron.git#dc1b1e9d33abbd52148eb75e0a6d64f0cefbef19)
              +-- iobroker.javascript@8.8.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#840d03855636c4271971afc202532d008c22d264)
              +-- iobroker.mbus@2.7.0 (git+ssh://git@github.com/Apollon77/ioBroker.mbus.git#98a7dec9f646d76637fceca690092e6175665472)
              +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#9ae450bb73048774252ab422c33750af4f6f3904)
              +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
              +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
              +-- iobroker.tibberlink@3.5.1 (git+ssh://git@github.com/Hombach/ioBroker.tibberlink.git#6352b26d3016d46845aff2d6d5b81a7041794292)
              +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
                system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
                system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                system.adapter.devices.0                : devices               : iobroker-slave                           -  enabled
              + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
                system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
              + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
              + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
              + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
              + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
              + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
              + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
                system.adapter.node-red.1               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
              + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
              + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
                system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
              + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
              + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
              + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
              + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
              + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
              + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
              + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
              + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
              + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
                system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 -  enabled
                system.adapter.vis-players.0            : vis-players           : ioBroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
              + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
              + instance is alive
              ioBroker-Repositories
              │ (index) │        name        │                           url                           │ auto upgrade │
              │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │     true     │
              │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
              │    2    │       'List'       │        'http://download.iobroker.net/list.html'         │    false     │
              Active repo(s): Stable (default)
              Installed ioBroker-Instances
              Used repository: Stable (default)
              Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": aborted
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "cameras"      : 2.1.2    , installed 2.1.2
              Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
              Adapter    "dysonairpurifier": 3.2.3 , installed 3.2.3
              Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
              Adapter    "followthesun" : 0.5.1    , installed 0.5.1
              Adapter    "hs100"        : 2.2.0    , installed 2.2.0
              Adapter    "hue"          : 3.12.0   , installed 3.12.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "jablotron"    : 0.1.3    , installed 0.1.3
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "mbus"         : 2.7.0    , installed 2.7.0
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "nut"          : 1.6.0    , installed 1.6.0
              Adapter    "openknx"      : 0.9.0    , installed 0.7.0  [Updatable]
              Adapter    "openweathermap": 1.1.2   , installed 1.1.2
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "tibberlink"   : 3.4.10   , installed 3.5.1
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        26969
              States:         23347
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       845424     -
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       742643     -
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       739941     -
              tcp        0      0 127.0.0.11:44407        0.0.0.0:*               LISTEN      0          734875     -
              tcp6       0      0 :::3500                 :::*                    LISTEN      1000       749767     -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       740119     -
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       760148     -
              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       762097     -
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       750748     -
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       755103     -
              udp        0      0 127.0.0.11:45913        0.0.0.0:*                           0          734874     -
              udp        0      0 0.0.0.0:54315           0.0.0.0:*                           1000       751514     -
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       755873     -
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       760072     -
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       760073     -
              2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.wochentag
              2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.datum
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.uhrzeit
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxadresse
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxport
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxuser
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxpassword
              2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdbname
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdaylight
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdblokal
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxssl
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.demodaten
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.homeassistant.status
              2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.test
              2024-10-21 10:47:31.598  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.test.test
              2024-10-21 10:47:32.169  - info: mqtt.0 (1671) All states published
              2024-10-21 10:49:16.192  - info: javascript.0 (202) script.js.Doorbird.OpenDoor: Tür wurde geöffnet von: Kathi
              2024-10-21 11:00:00.037  - info: host.ioBroker instance system.adapter.ical.0 in version "1.15.0" started with pid 3312
              2024-10-21 11:00:00.162  - info: javascript.0 (202) script.js.common.Zentralfunktionen.Astrozeiten_in_Datenpunkte: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
              2024-10-21 11:00:10.900  - info: host.ioBroker instance system.adapter.ical.0 having pid 3312 terminated with code 0 (NO_ERROR)
              2024-10-21 11:00:23.035  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3355
              2024-10-21 11:00:35.974  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3355 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-10-21 11:01:38.078  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
              2024-10-21 11:01:38.550  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
              2024-10-21 11:01:48.542  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
              iob diag has finished.
              Samson71 da_Woody 2 Replies Last reply Reply Quote 0
              • Samson71
                @hant0r
                Das Einzige was ich Dir sagen kann ist, dass Du Dein Docker-Image von 9.1.1 auf 10.0.0 anheben musst für Nodejs 20 (latest v9 wäre auch 9.1.2). Ob das aber das Problem löst, kann ich nicht beurteilen.
                • Hant0r
                  @samson71 Danke dir, schaue ich mir mal an und hebe es auf die v10
                  • Hant0r
                    @samson71
                    So bin nun auf Version 10 🙂
                    NodeRed lässt sich innerhalb von ioBroker aber immer noch nicht öffnen.
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Docker          : v10.0.0
                    Kernel          : x86_64
                    Userland        : 64 bit
                     12:28:51 up  2:58,  0 user,  load average: 2.51, 2.39, 2.18
                    CPU threads: 4
                    Mon Oct 21 10:28:51 UTC 2024
                    Mon Oct 21 12:28:51 CEST 2024
                    CEST +0200
                    Etc/UTC
                    root
                    HOME=/root
                    GROUPS=root
                    iobroker
                    HOME=/opt/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:             12G        5.3G        319M        147M        7.3G        7.1G
                    Swap:           9.6G         95M        9.5G
                    Total:           21G        5.3G        9.8G
                             5008 M used memory
                             5857 M active memory
                             4104 M inactive memory
                              303 M free memory
                               20 M buffer memory
                             6942 M swap cache
                             9143 M total swap
                               90 M used swap
                             9053 M free swap
                    top - 12:28:52 up  2:58,  0 user,  load average: 2.47, 2.38, 2.18
                    Tasks:  46 total,   2 running,  44 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  11822.1 total,    302.4 free,   5009.0 used,   6963.5 buff/cache
                    MiB Swap:   9143.9 total,   9053.1 free,     90.8 used.   6813.1 avail Mem
                    *** FILESYSTEM ***
                    /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/userscripts
                    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3981,subvol=/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0
                    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf
                    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname
                    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts
                    /var:
                    34M     /var/
                    32M     /var/lib
                    19M     /var/lib/apt
                    13M     /var/lib/dpkg
                    29M     /opt/iobroker/iobroker-data/objects.jsonl
                    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyUSB0
                    /usr/bin/nodejs         v20.18.0
                    /usr/bin/node           v20.18.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.29.3
                    nodejs:
                      Installed: 20.18.0-1nodesource1
                      Candidate: 20.18.0-1nodesource1
                      Version table:
                     *** 20.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 726)
                    iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 3136)
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        26969
                    States:         23419
                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       1671508    -
                    tcp        0      0 127.0.0.11:35365        0.0.0.0:*               LISTEN      0          1650777    -
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1651429    -
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1657631    -
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1653573    -
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1659405    -
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1671493    -
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1677436    -
                    udp        0      0 127.0.0.11:34303        0.0.0.0:*                           0          1650776    -
                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1664540    -
                    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       1665311    -
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1665591    -
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1671412    -
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1671413    -
                    udp        0      0 0.0.0.0:56567           0.0.0.0:*                           1000       1664947    -
                    2024-10-21 12:19:41.529  - info: energiefluss.0 (971) starting. Version 3.6.1 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.18.0, js-controller: 6.0.11
                    2024-10-21 12:19:41.563  - info: energiefluss.0 (971) Starting Energiefluss Adapter
                    2024-10-21 12:19:42.114  - info: energiefluss.0 (971) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                    2024-10-21 12:19:42.126  - info: energiefluss.0 (971) Adapter started and listening to 18 States
                    2024-10-21 12:19:42.801  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#208C4F#1.Relay0.gesamt successfully
                    2024-10-21 12:19:42.804  - info: sourceanalytix.0 (807) Initialising (5 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt"
                    2024-10-21 12:19:45.653  - info: tapo.0 (911) Start first Update
                    2024-10-21 12:19:46.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt successfully
                    2024-10-21 12:19:46.351  - info: sourceanalytix.0 (807) Initialising (6 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt"
                    2024-10-21 12:19:48.792  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt successfully
                    2024-10-21 12:19:48.793  - info: sourceanalytix.0 (807) Initialising (7 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt"
                    2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt successfully
                    2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialising (8 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt"
                    2024-10-21 12:19:52.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt successfully
                    2024-10-21 12:19:52.351  - info: sourceanalytix.0 (807) Initialising (9 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt"
                    2024-10-21 12:19:53.535  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt successfully
                    2024-10-21 12:19:53.544  - info: sourceanalytix.0 (807) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me!
                    2024-10-21 12:19:58.405  - info: alexa2.0 (436) Subscribing to states...
                    2024-10-21 12:20:00.139  - info: alexa2.0 (436) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-10-21 12:20:11.758  - info: pvforecast.0 (949) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                    2024-10-21 12:20:23.112  - info: alexa2.0 (436) Initialization Done ...
                    2024-10-21 12:23:31.035  - info: host.ioBroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1212
                    2024-10-21 12:23:34.216  - info: openweathermap.0 (1212) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
                    2024-10-21 12:23:49.101  - info: openweathermap.0 (1212) Terminated (NO_ERROR): Without reason
                    2024-10-21 12:23:49.627  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 1212 terminated with code 0 (NO_ERROR)
                    • da_Woody
                      @hant0r schon ok, mit nodered kann ich dir nicht helfen.
                      systemupdate sollte aber immer vorrangig sein.
                      allerdings verstehe ich auch nicht, warum du nodered für alexa brauchst. meine shelly dingens werden über den skill automatisch erkannt.
                      • Dr. Bakterius
                        Dr. Bakterius Most Active @da_Woody last edited by
                        @da_woody sagte in Alexa - Geräte reagieren nicht mehr:
                        Weil man damit ganz leicht eigene Geräte für Alexa anlegen kann. So kann ich meine Rollläden und die Markise mit Alexa steuern (und noch einiges anderes). Das ginge sonst nicht (ohne ioBroker-Cloud).
                        Hant0r 1 Reply Last reply Reply Quote 1
                          peterfido last edited by
                          @dr-bakterius
                          iob fix
                          hast Du schon ausgeführt? Alexa krams braucht den Port 80, den 'schaltet' der fix wieder nutzbar.
                          Ansonsten in den Node-Red-Adapter Einstellungen den Sicherheismodus aktivieren und gucken, ob Du dann drau kommst. Der Sicherheitmodus deaktiviert die Nodes alle, um hängende 'Programme' bearbeiten zu können.
                          • Hant0r
                            Hant0r @Dr. Bakterius last edited by
                            @dr-bakterius sagte in Alexa - Geräte reagieren nicht mehr:
                            Genau so ist es. Ich nutze es, um Geräte zu simulieren, um Digne wie Rolladen, KNX Komponenten und Co zu steuern.
                            @peterfido sagte in Alexa - Geräte reagieren nicht mehr:
                            Habe ich ausgeführt, da sonst der "diag" Befehl nicht funktionierte. Mal sehen ob es geholfen hat.
                            Seltsam ist ja aber, dass es mal klappt und dann wieder nicht.
                            Ich werde es mal die Tage beobachten
                            • Hant0r
                              Habes es nun paar Tage beobachtet. Gefühlt ist es etwas besser geworden, aber es kommt dennoch vor, dass die Alexa sagt "Das Gerät antwortet nicht" ... im ioBroker steht nichts im Log.
                              Öffne ich Node-Red, um es dort ggf. zu debuggen, geht es natürlich wieder als wäre nichts gewesen 😞
                              • Hant0r
                                Hant0r last edited by Hant0r
                                Ich habe es nun oft bemerkt, Alexa sagt erst "Gerät reagiert leider nicht", man wartet paar Sekunden und versuche es erneut und es funktioniert.
                                Im Node-Red kommt im Debug auch nichts an, wenn Alexa das Gerät nicht findet. Würde daher Node-Red ausschließen (oder?)
                                Ro75 1 Reply Last reply Reply Quote 0
                                • Ro75
                                  Ro75 @Hant0r last edited by
                                  @hant0r sschon mal das komplette Netzwerk neu gestartet? Alle Echos, und LAN, WLAN, Zigbee-Geräte?
                                  Ro75.
                                  • Hant0r
                                    Hant0r @Ro75 last edited by
                                    @ro75
                                    ne bisher noch nicht. Mache ich mal.
                                    Gar nicht so einfach alles im Haus neu zu starten... Aber auch die Batterie betriebenen Zigbee Geräte?
                                    • Ro75
                                      Ro75 last edited by
                                      Nein. Aber Router (FB?), Echos...
                                      Ro75.
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active last edited by Dr. Bakterius
                                        Und den Rechner auf dem der ioBroker läuft nicht vergessen!
                                        Nachdem heute ja die Zeitumstellung war, könnte man den FI testen und so automatisch alle Geräte die am Strom hängen auch neu starten.
                                        • da_Woody
                                          da_Woody @Dr. Bakterius last edited by
                                          nuja, das könnte bei raspis mit sd eventuell ungesund sein... mir hats bei stromausfall schon meinen synology router gekillt.
                                          Thomas Braun Dr. Bakterius 2 Replies Last reply Reply Quote 1
                                            Thomas Braun Most Active @da_Woody last edited by
                                            Nicht nur für die. Das findet kein Gerät wirklich prickelnd.
                                            da_Woody 1 Reply Last reply Reply Quote 1
                                            81.1k
                                            13080
