    4. Node-Red
    5. [Gelöst] Alexa - Geräte reagieren nicht mehr
    • da_Woody
      da_Woody @Hant0r last edited by
      @hant0r was ist so schwer zu verstehen? Full iobdiag, nicht die summery.
      Hant0r 1 Reply Last reply Reply Quote 0
      • Samson71
        Samson71 Global Moderator @Hant0r last edited by
        @hant0r sagte in Alexa - Geräte reagieren nicht mehr:
        Danke dir, hier das Log:
        Ist "nur" der Summary, nicht das vollständige iob diag, aber
        ioBroker läuft in einem Docker auf einer Diskstation
        Da bin ich dann auch vermutlich raus.
        • Hant0r
          Hant0r @da_Woody last edited by
          @da_woody
          mia culpa
          ========== Start marking the full check here ===========
          Script v.2024-10-19
          *** BASE SYSTEM ***
          Hardware Vendor : Synology
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.1
          Virtualization  : Docker
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
          *** TIME AND TIMEZONES ***
          Mon Oct 21 09:02:48 UTC 2024
          Mon Oct 21 11:02:48 CEST 2024
          CEST +0200
          Etc/UTC
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:             12G        6.0G        278M        148M        6.6G        6.4G
          Swap:           9.6G         51M        9.5G
          Total:           21G        6.1G        9.8G
          Active iob-Instances:   42
                  11822 M total memory
                   5720 M used memory
                   5573 M active memory
                   4202 M inactive memory
                    265 M free memory
                     15 M buffer memory
                   6273 M swap cache
                   9143 M total swap
                     49 M used swap
                   9094 M free swap
          top - 11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
          Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  11822.1 total,    263.8 free,   5722.7 used,   6289.3 buff/cache
          MiB Swap:   9143.9 total,   9094.5 free,     49.4 used.   6099.5 avail Mem
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem             Type   Size  Used Avail Use% Mounted on
          /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /
          tmpfs                  tmpfs   64M     0   64M   0% /dev
          tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
          shm                    tmpfs   64M     0   64M   0% /dev/shm
          /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/iobroker
          /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /etc/hosts
          tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
          tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
          tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
          [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
          [Mon Oct 21 09:32:14 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
          Show mounted filesystems:
          TARGET             SOURCE        FSTYPE OPTIONS
          /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3717,subvol=/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250
          |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/ioBroker_data]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/ioBroker_data
          |-/opt/userscripts /dev/mapper/cachedev_0[/@syno/docker/userscripts]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/userscripts
          |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf
          |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname
          `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts
          /var:
          39M     /var/
          37M     /var/lib
          19M     /var/lib/apt/lists
          19M     /var/lib/apt
          18M     /var/lib/dpkg
          /opt/iobroker/backups:
          629M    /opt/iobroker/backups/
          339M    /opt/iobroker/backups/Doorbird
          323M    /opt/iobroker/backups/Doorbird/Motion
          17M     /opt/iobroker/backups/Doorbird/Doorbell
          1.5M    /opt/iobroker/backups/scripts
          /opt/iobroker/iobroker-data:
          1.6G    /opt/iobroker/iobroker-data/
          1.1G    /opt/iobroker/iobroker-data/files
          615M    /opt/iobroker/iobroker-data/files/javascript.admin
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          556M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/objects.json.bak2
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          29M     /opt/iobroker/iobroker-data/states.jsonl
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.4
          /usr/bin/node           v18.20.4
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 1001
                 1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 1001
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 1673)
          iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 1657)
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     8
          +-- iobroker.jablotron@0.1.3 (git+ssh://git@github.com/DEV2DEV-DE/ioBroker.jablotron.git#dc1b1e9d33abbd52148eb75e0a6d64f0cefbef19)
          +-- iobroker.javascript@8.8.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#840d03855636c4271971afc202532d008c22d264)
          +-- iobroker.mbus@2.7.0 (git+ssh://git@github.com/Apollon77/ioBroker.mbus.git#98a7dec9f646d76637fceca690092e6175665472)
          +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#9ae450bb73048774252ab422c33750af4f6f3904)
          +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
          +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
          +-- iobroker.tibberlink@3.5.1 (git+ssh://git@github.com/Hombach/ioBroker.tibberlink.git#6352b26d3016d46845aff2d6d5b81a7041794292)
          +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
            system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker-slave                           -  enabled
          + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
            system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
          + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
          + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
          + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
            system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
            system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.node-red.1               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
          + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
          + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
          + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
          + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : ioBroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          │ (index) │        name        │                           url                           │ auto upgrade │
          │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │     true     │
          │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          │    2    │       'List'       │        'http://download.iobroker.net/list.html'         │    false     │
          Active repo(s): Stable (default)
          Upgrade policy: patch
          Installed ioBroker-Instances
          Used repository: Stable (default)
          Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": aborted
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "cameras"      : 2.1.2    , installed 2.1.2
          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
          Adapter    "dysonairpurifier": 3.2.3 , installed 3.2.3
          Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
          Adapter    "followthesun" : 0.5.1    , installed 0.5.1
          Adapter    "hs100"        : 2.2.0    , installed 2.2.0
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "jablotron"    : 0.1.3    , installed 0.1.3
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "mbus"         : 2.7.0    , installed 2.7.0
          Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "openknx"      : 0.9.0    , installed 0.7.0  [Updatable]
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tibberlink"   : 3.4.10   , installed 3.5.1
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        26969
          States:         23347
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       845424     -
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       742643     -
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       739941     -
          tcp        0      0 127.0.0.11:44407        0.0.0.0:*               LISTEN      0          734875     -
          tcp6       0      0 :::3500                 :::*                    LISTEN      1000       749767     -
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       740119     -
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       760148     -
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       762097     -
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       750748     -
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       755103     -
          udp        0      0 127.0.0.11:45913        0.0.0.0:*                           0          734874     -
          udp        0      0 0.0.0.0:54315           0.0.0.0:*                           1000       751514     -
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       755873     -
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       760072     -
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       760073     -
          2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.wochentag
          2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.datum
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.uhrzeit
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxadresse
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxport
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxuser
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxpassword
          2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdbname
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdaylight
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdblokal
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxssl
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.demodaten
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.homeassistant.status
          2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.test
          2024-10-21 10:47:31.598  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.test.test
          2024-10-21 10:47:32.169  - info: mqtt.0 (1671) All states published
          2024-10-21 10:49:16.192  - info: javascript.0 (202) script.js.Doorbird.OpenDoor: Tür wurde geöffnet von: Kathi
          2024-10-21 11:00:00.037  - info: host.ioBroker instance system.adapter.ical.0 in version "1.15.0" started with pid 3312
          2024-10-21 11:00:00.162  - info: javascript.0 (202) script.js.common.Zentralfunktionen.Astrozeiten_in_Datenpunkte: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
          2024-10-21 11:00:10.900  - info: host.ioBroker instance system.adapter.ical.0 having pid 3312 terminated with code 0 (NO_ERROR)
          2024-10-21 11:00:23.035  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3355
          2024-10-21 11:00:35.974  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3355 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-21 11:01:38.078  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
          2024-10-21 11:01:38.550  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
          2024-10-21 11:01:48.542  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
          iob diag has finished.
          Samson71 da_Woody 2 Replies Last reply Reply Quote 0
          • Samson71
            @hant0r
            Das Einzige was ich Dir sagen kann ist, dass Du Dein Docker-Image von 9.1.1 auf 10.0.0 anheben musst für Nodejs 20 (latest v9 wäre auch 9.1.2). Ob das aber das Problem löst, kann ich nicht beurteilen.
            • Hant0r
              Hant0r @Samson71 last edited by
              @samson71 Danke dir, schaue ich mir mal an und hebe es auf die v10
              • Hant0r
                @samson71
                So bin nun auf Version 10 🙂
                NodeRed lässt sich innerhalb von ioBroker aber immer noch nicht öffnen.
                Script v.2024-10-19
                *** BASE SYSTEM ***
                Kernel          : x86_64
                Userland        : 64 bit
                Docker          : v10.0.0
                Kernel          : x86_64
                Userland        : 64 bit
                 12:28:51 up  2:58,  0 user,  load average: 2.51, 2.39, 2.18
                CPU threads: 4
                Mon Oct 21 10:28:51 UTC 2024
                Mon Oct 21 12:28:51 CEST 2024
                CEST +0200
                Etc/UTC
                root
                HOME=/root
                GROUPS=root
                iobroker
                HOME=/opt/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:             12G        5.3G        319M        147M        7.3G        7.1G
                Swap:           9.6G         95M        9.5G
                Total:           21G        5.3G        9.8G
                         5008 M used memory
                         5857 M active memory
                         4104 M inactive memory
                          303 M free memory
                           20 M buffer memory
                         6942 M swap cache
                         9143 M total swap
                           90 M used swap
                         9053 M free swap
                top - 12:28:52 up  2:58,  0 user,  load average: 2.47, 2.38, 2.18
                Tasks:  46 total,   2 running,  44 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  11822.1 total,    302.4 free,   5009.0 used,   6963.5 buff/cache
                MiB Swap:   9143.9 total,   9053.1 free,     90.8 used.   6813.1 avail Mem
                *** FILESYSTEM ***
                /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/userscripts
                /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3981,subvol=/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0
                |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf
                |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname
                `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts
                /var:
                34M     /var/
                32M     /var/lib
                19M     /var/lib/apt
                13M     /var/lib/dpkg
                29M     /opt/iobroker/iobroker-data/objects.jsonl
                24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                /usr/bin/nodejs         v20.18.0
                /usr/bin/node           v20.18.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Candidate: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 726)
                iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 3136)
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        26969
                States:         23419
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       1671508    -
                tcp        0      0 127.0.0.11:35365        0.0.0.0:*               LISTEN      0          1650777    -
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1651429    -
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1657631    -
                tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1653573    -
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1659405    -
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1671493    -
                tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1677436    -
                udp        0      0 127.0.0.11:34303        0.0.0.0:*                           0          1650776    -
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1664540    -
                udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       1665311    -
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1665591    -
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1671412    -
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1671413    -
                udp        0      0 0.0.0.0:56567           0.0.0.0:*                           1000       1664947    -
                2024-10-21 12:19:41.529  - info: energiefluss.0 (971) starting. Version 3.6.1 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.18.0, js-controller: 6.0.11
                2024-10-21 12:19:41.563  - info: energiefluss.0 (971) Starting Energiefluss Adapter
                2024-10-21 12:19:42.114  - info: energiefluss.0 (971) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                2024-10-21 12:19:42.126  - info: energiefluss.0 (971) Adapter started and listening to 18 States
                2024-10-21 12:19:42.801  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#208C4F#1.Relay0.gesamt successfully
                2024-10-21 12:19:42.804  - info: sourceanalytix.0 (807) Initialising (5 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt"
                2024-10-21 12:19:45.653  - info: tapo.0 (911) Start first Update
                2024-10-21 12:19:46.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt successfully
                2024-10-21 12:19:46.351  - info: sourceanalytix.0 (807) Initialising (6 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt"
                2024-10-21 12:19:48.792  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt successfully
                2024-10-21 12:19:48.793  - info: sourceanalytix.0 (807) Initialising (7 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt"
                2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt successfully
                2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialising (8 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt"
                2024-10-21 12:19:52.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt successfully
                2024-10-21 12:19:52.351  - info: sourceanalytix.0 (807) Initialising (9 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt"
                2024-10-21 12:19:53.535  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt successfully
                2024-10-21 12:19:53.544  - info: sourceanalytix.0 (807) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me!
                2024-10-21 12:19:58.405  - info: alexa2.0 (436) Subscribing to states...
                2024-10-21 12:20:00.139  - info: alexa2.0 (436) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2024-10-21 12:20:11.758  - info: pvforecast.0 (949) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                2024-10-21 12:20:23.112  - info: alexa2.0 (436) Initialization Done ...
                2024-10-21 12:23:31.035  - info: host.ioBroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1212
                2024-10-21 12:23:34.216  - info: openweathermap.0 (1212) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
                2024-10-21 12:23:49.101  - info: openweathermap.0 (1212) Terminated (NO_ERROR): Without reason
                2024-10-21 12:23:49.627  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 1212 terminated with code 0 (NO_ERROR)
                • da_Woody
                  @hant0r schon ok, mit nodered kann ich dir nicht helfen.
                  systemupdate sollte aber immer vorrangig sein.
                  allerdings verstehe ich auch nicht, warum du nodered für alexa brauchst. meine shelly dingens werden über den skill automatisch erkannt.
                  • Dr. Bakterius
                    Dr. Bakterius Most Active @da_Woody last edited by
                    @da_woody sagte in Alexa - Geräte reagieren nicht mehr:
                    Weil man damit ganz leicht eigene Geräte für Alexa anlegen kann. So kann ich meine Rollläden und die Markise mit Alexa steuern (und noch einiges anderes). Das ginge sonst nicht (ohne ioBroker-Cloud).
                    Hant0r 1 Reply Last reply Reply Quote 1
                      peterfido last edited by
                      @dr-bakterius
                      iob fix
                      hast Du schon ausgeführt? Alexa krams braucht den Port 80, den 'schaltet' der fix wieder nutzbar.
                      Ansonsten in den Node-Red-Adapter Einstellungen den Sicherheismodus aktivieren und gucken, ob Du dann drau kommst. Der Sicherheitmodus deaktiviert die Nodes alle, um hängende 'Programme' bearbeiten zu können.
                      • Hant0r
                        Hant0r @Dr. Bakterius last edited by
                        @dr-bakterius sagte in Alexa - Geräte reagieren nicht mehr:
                        Genau so ist es. Ich nutze es, um Geräte zu simulieren, um Digne wie Rolladen, KNX Komponenten und Co zu steuern.
                        @peterfido sagte in Alexa - Geräte reagieren nicht mehr:
                        Habe ich ausgeführt, da sonst der "diag" Befehl nicht funktionierte. Mal sehen ob es geholfen hat.
                        Seltsam ist ja aber, dass es mal klappt und dann wieder nicht.
                        Ich werde es mal die Tage beobachten
                        • Hant0r
                          Habes es nun paar Tage beobachtet. Gefühlt ist es etwas besser geworden, aber es kommt dennoch vor, dass die Alexa sagt "Das Gerät antwortet nicht" ... im ioBroker steht nichts im Log.
                          Öffne ich Node-Red, um es dort ggf. zu debuggen, geht es natürlich wieder als wäre nichts gewesen 😞
                          • Hant0r
                            Hant0r last edited by Hant0r
                            Ich habe es nun oft bemerkt, Alexa sagt erst "Gerät reagiert leider nicht", man wartet paar Sekunden und versuche es erneut und es funktioniert.
                            Im Node-Red kommt im Debug auch nichts an, wenn Alexa das Gerät nicht findet. Würde daher Node-Red ausschließen (oder?)
                            Ro75 1 Reply Last reply Reply Quote 0
                            • Ro75
                              Ro75 @Hant0r last edited by
                              @hant0r sschon mal das komplette Netzwerk neu gestartet? Alle Echos, und LAN, WLAN, Zigbee-Geräte?
                              Ro75.
                              • Hant0r
                                Hant0r @Ro75 last edited by
                                @ro75
                                ne bisher noch nicht. Mache ich mal.
                                Gar nicht so einfach alles im Haus neu zu starten... Aber auch die Batterie betriebenen Zigbee Geräte?
                                • Ro75
                                  Ro75 last edited by
                                  Nein. Aber Router (FB?), Echos...
                                  Ro75.
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active last edited by Dr. Bakterius
                                    Und den Rechner auf dem der ioBroker läuft nicht vergessen!
                                    Nachdem heute ja die Zeitumstellung war, könnte man den FI testen und so automatisch alle Geräte die am Strom hängen auch neu starten.
                                    • da_Woody
                                      da_Woody @Dr. Bakterius last edited by
                                      nuja, das könnte bei raspis mit sd eventuell ungesund sein... mir hats bei stromausfall schon meinen synology router gekillt.
                                      Thomas Braun Dr. Bakterius 2 Replies Last reply Reply Quote 1
                                        Thomas Braun Most Active @da_Woody last edited by
                                        Nicht nur für die. Das findet kein Gerät wirklich prickelnd.
                                        da_Woody 1 Reply Last reply Reply Quote 1
                                        • da_Woody
                                          da_Woody @Thomas Braun last edited by
                                          @thomas-braun klar, mein server hats bis jetzt aber überlebt... 😉
                                          wollte damit nur sagen, alles runterfahren, dann kann man FI testen und alles in der richtigen reihenfolge wieder starten.
                                          mein kabelrouter ist als reines modem in betrieb. nach so einem blödsinn kam es schon vor, daß sich der router, oder ein pc beim provider angemeldet hat, weil der kabelrouter zu spät dran war mit einloggen. ergo, kein inet zugriff. anruf bei kabel+, reset vom kabeldingens, klappt wieder. geht schneller, als alles wieder selbst neu starten.
                                          • Hant0r
                                            @ro75 sagte in Alexa - Geräte reagieren nicht mehr:
                                            Ro75.
                                            Habe ich alle mal neu gestartet.
                                            Als Netzwerk setze ich auch das Unifi-System ohne FritzBox etc. - da geht das zum Glück recht easy 🙂
                                            Würde bei mir nicht viel passieren, es hängt alles hinter einer USV, genau damit es mir meine Synology und Rest nicht killt 😉
                                            Ich beobachte das Verhalten mal weiter
                                            81.1k
                                            13080
