    4. Bild versand
    Bild versand
    • totocotonio
      totocotonio @BananaJoe last edited by totocotonio
      @bananajoe
      ja durchgestartet habe ich natürlich schon mehrfach gemacht.
      Das sagt, das log
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobdebian
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:30:46 up 1 day, 14:51,  2 users,  load average: 1.81, 2.50, 2.33
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2024-10-21 16:30:46 CEST
                 Universal time: Mon 2024-10-21 14:30:46 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      torsten
      HOME=/home/torsten
      GROUPS=torsten sudo users
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.6G        4.6G        2.0G        135K        2.0G        4.0G
      Swap:           2.1G        4.1K        2.1G
      Total:           10G        4.6G        4.2G
      Active iob-Instances:   61
               8192 M total memory
               4395 M used memory
               4075 M active memory
               1727 M inactive memory
               1915 M free memory
                  0 M buffer memory
               1880 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 16:30:46 up 1 day, 14:51,  2 users,  load average: 1.83, 2.49, 2.33
      Tasks:  99 total,   1 running,  98 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   1913.9 free,   4397.3 used,   1880.9 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   3794.7 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--119--disk--1 ext4       32G   11G   20G  35% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   20G     0   20G   0% /dev/tty
      tmpfs                            tmpfs      20G     0   20G   0% /dev/shm
      tmpfs                            tmpfs     7.8G  132K  7.8G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /run/user/0
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--119--disk--1 ext4   rw,relatime,stripe=16
      /var:
      707M    /var/
      280M    /var/cache
      279M    /var/log/journal/bedee8e8251140b295fe88ba675d67ae
      279M    /var/log
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      375M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.1G    /opt/iobroker/iobroker-data/
      1.6G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      find: Failed to change directory: /root: Permission denied
      find: Failed to restore initial working directory: /root: Permission denied
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobdebian           iobdebian (version: 6.0.11, hostname: iobdebian     , alive, uptime: 513)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     9
      +-- iobroker.bmw@2.6.2 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#0099deef6a444cdec23fe43c09cdb0c74ef06cfd)
      +-- iobroker.fully-tablet-control@0.3.1-beta.2 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#b13e1a66ce3e9462dd3dc972af8f0ba6c4a06c16)
      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.slideshow@0.1.4 (git+ssh://git@github.com/gaudes/ioBroker.slideshow.git#07f045f491d76062044ba084c77ee24b414d7574)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
      +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#629f35c43f46f62ee5d9113c0df80c0f9a1c4b04)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobdebian                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : iobdebian                                - disabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : iobdebian                                - disabled
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobdebian                                -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobdebian                                -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobdebian                                - disabled
      + system.adapter.backitup.0               : backitup              : iobdebian                                -  enabled
        system.adapter.bmw.0                    : bmw                   : iobdebian                                - disabled
      + system.adapter.bring.0                  : bring                 : iobdebian                                -  enabled
        system.adapter.daswetter.0              : daswetter             : iobdebian                                -  enabled
        system.adapter.device-reminder.0        : device-reminder       : iobdebian                                - disabled
      + system.adapter.device-watcher.0         : device-watcher        : iobdebian                                -  enabled
        system.adapter.devices.0                : devices               : iobdebian                                - disabled
        system.adapter.discovery.0              : discovery             : iobdebian                                - disabled
        system.adapter.dwd.0                    : dwd                   : iobdebian                                -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobdebian                                -  enabled
        system.adapter.espresense.0             : espresense            : iobdebian                                - disabled
      + system.adapter.firetv.0                 : firetv                : iobdebian                                -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobdebian                                -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobdebian                                -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobdebian                                -  enabled
      + system.adapter.ham.0                    : ham                   : iobdebian                                -  enabled
        system.adapter.hass.0                   : hass                  : iobdebian                                - disabled, port: 8123
      + system.adapter.hm-rega.0                : hm-rega               : iobdebian                                -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobdebian                                -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobdebian                                -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobdebian                                -  enabled
        system.adapter.ical.1                   : ical                  : iobdebian                                -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobdebian                                - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobdebian                                - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobdebian                                - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobdebian                                - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobdebian                                - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobdebian                                - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobdebian                                - disabled
        system.adapter.influxdb.0               : influxdb              : iobdebian                                - disabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : iobdebian                                -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobdebian                                -  enabled
        system.adapter.iot.1                    : iot                   : iobdebian                                - disabled
      + system.adapter.javascript.0             : javascript            : iobdebian                                -  enabled
        system.adapter.kodi.0                   : kodi                  : iobdebian                                - disabled, port: 9090
      + system.adapter.logparser.0              : logparser             : iobdebian                                -  enabled
      + system.adapter.lorawan.0                : lorawan               : iobdebian                                -  enabled, port: 8883
      + system.adapter.luftdaten.0              : luftdaten             : iobdebian                                -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : iobdebian                                -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobdebian                                -  enabled, port: 54321
      + system.adapter.mihome.0                 : mihome                : iobdebian                                -  enabled, port: 9898, bind: 0.0.0.0
        system.adapter.milight.0                : milight               : iobdebian                                - disabled, port: 8899
        system.adapter.mobile.0                 : mobile                : iobdebian                                - disabled
        system.adapter.modbus.0                 : modbus                : iobdebian                                - disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : iobdebian                                -  enabled, port: 8883
      + system.adapter.mqtt.0                   : mqtt                  : iobdebian                                -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobdebian                                -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : iobdebian                                -  enabled
      + system.adapter.nina.0                   : nina                  : iobdebian                                -  enabled
      + system.adapter.node-red.0               : node-red              : iobdebian                                -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.node-red.1               : node-red              : iobdebian                                -  enabled, port: 1881, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobdebian                                -  enabled
      + system.adapter.octoprint.0              : octoprint             : iobdebian                                -  enabled
        system.adapter.parcel.1                 : parcel                : iobdebian                                - disabled
      + system.adapter.parser.0                 : parser                : iobdebian                                -  enabled
      + system.adapter.pi-hole.0                : pi-hole               : iobdebian                                -  enabled
      + system.adapter.ping.0                   : ping                  : iobdebian                                -  enabled
      + system.adapter.pixelit.0                : pixelit               : iobdebian                                -  enabled
      + system.adapter.pixelit.1                : pixelit               : iobdebian                                -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobdebian                                -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobdebian                                -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobdebian                                -  enabled
      + system.adapter.samsung.0                : samsung               : iobdebian                                -  enabled
        system.adapter.sayit.0                  : sayit                 : iobdebian                                - disabled
      + system.adapter.scenes.0                 : scenes                : iobdebian                                -  enabled
      + system.adapter.shelly.0                 : shelly                : iobdebian                                -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobdebian                                -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobdebian                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.slideshow.0              : slideshow             : iobdebian                                - disabled
      + system.adapter.sonoff.0                 : sonoff                : iobdebian                                -  enabled, port: 1883, bind: 192.168.178.122
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobdebian                                -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : iobdebian                                - disabled
        system.adapter.statistics.0             : statistics            : iobdebian                                - disabled
      + system.adapter.synology.0               : synology              : iobdebian                                -  enabled, port: 38000
        system.adapter.systeminfo.0             : systeminfo            : iobdebian                                - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobdebian                                -  enabled
      + system.adapter.telegram.0               : telegram              : iobdebian                                -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobdebian                                -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobdebian                                - disabled, port: 8088, bind: 192.168.178.122, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : iobdebian                                -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobdebian                                -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : iobdebian                                -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobdebian                                -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobdebian                                -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobdebian                                -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobdebian                                -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobdebian                                -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobdebian                                - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobdebian                                - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobdebian                                - disabled
        system.adapter.vis-history.0            : vis-history           : iobdebian                                - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobdebian                                - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobdebian                                - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobdebian                                -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobdebian                                - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobdebian                                - disabled
        system.adapter.vis-map.0                : vis-map               : iobdebian                                - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobdebian                                - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobdebian                                - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobdebian                                - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobdebian                                - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobdebian                                - disabled
        system.adapter.vis.0                    : vis                   : iobdebian                                -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobdebian                                -  enabled
        system.adapter.web-speedy.0             : web-speedy            : iobdebian                                - disabled
      + system.adapter.web.0                    : web                   : iobdebian                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wifilight.0              : wifilight             : iobdebian                                - disabled
        system.adapter.withings.0               : withings              : iobdebian                                - disabled
        system.adapter.wled.0                   : wled                  : iobdebian                                - disabled
      + system.adapter.yahka.0                  : yahka                 : iobdebian                                -  enabled
      + system.adapter.yamaha.0                 : yamaha                : iobdebian                                -  enabled
      + system.adapter.zendure-solarflow.0      : zendure-solarflow     : iobdebian                                -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobdebian                                -  enabled, port: tcp://192.168.178.183:20108
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alarm"        : 3.6.2    , installed 3.6.2
      Adapter    "alexa-timer-vis": 2.0.5  , installed 2.0.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "espresense"   : 0.4.4    , installed 0.4.4
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "lorawan"      : 1.4.2    , installed 1.4.2
      Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
      Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "milight"      : 0.4.0    , installed 0.4.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "shuttercontrol": 1.8.2   , installed 1.8.2
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "zendure-solarflow": 1.8.5, installed 1.8.5
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        58610
      States:         49696
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       82666361   480091/iobroker.js-
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       82667073   480091/iobroker.js-
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          58681303   322/master
      tcp        0      0 192.168.178.122:2010    0.0.0.0:*               LISTEN      1001       82677680   480600/io.hm-rpc.1
      tcp        0      0 192.168.178.122:2001    0.0.0.0:*               LISTEN      1001       82678626   480541/io.hm-rpc.0
      tcp        0      0 192.168.178.122:1883    0.0.0.0:*               LISTEN      1001       82696611   482033/io.sonoff.0
      tcp        0      0 0.0.0.0:44591           0.0.0.0:*               LISTEN      1001       82717586   482592/io.yahka.0
      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       82673740   480281/node-red
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       82671954   480229/node-red
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       82694043   481791/io.shelly.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       82685969   480956/io.mqtt.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          58681694   1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          58681304   322/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       82667403   480110/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       82719138   482576/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       82711439   482471/io.simple-ap
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       82671035   480229/node-red
      tcp6       0      0 :::22                   :::*                    LISTEN      0          58672919   1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          58681696   1/init
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          58681919   110/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          58681695   1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       82704040   482134/io.yamaha.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       82671958   480229/node-red
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       82717583   482592/io.yahka.0
      udp        0      0 192.168.178.122:5353    0.0.0.0:*                           1001       82697170   482077/io.tr-064.0
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       82683199   480718/io.mihome.0
      udp        0      0 192.168.178.122:50489   0.0.0.0:*                           1001       82704039   482134/io.yamaha.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       82681583   480703/io.mihome-va
      udp6       0      0 :::111                  :::*                                0          58681697   1/init
      2024-10-21 16:31:13.023  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.restart.1"
      2024-10-21 16:31:13.025  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.power.1"
      2024-10-21 16:31:13.026  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.limit.2"
      2024-10-21 16:31:13.028  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.restart.2"
      2024-10-21 16:31:13.029  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.power.2"
      2024-10-21 16:31:13.039  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.limit.3"
      2024-10-21 16:31:13.040  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.restart.3"
      2024-10-21 16:31:13.045  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.ctrl.power.3"
      2024-10-21 16:31:13.045  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] subscribes on "mqtt.0.BKW_Sued.setup.set_time"
      2024-10-21 16:31:13.217  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.219  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.223  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.225  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.226  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.227  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.229  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.239  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.240  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.245  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:13.246  - info: mqtt.0 (480956) Client [AHOY-DTU-47CEDF] publishOnSubscribe
      2024-10-21 16:31:17.606  - info: mqtt.1 (481002) send2Server mqtt.1.XUBFYhcp.R0k8d16D.state[XUBFYhcp/R0k8d16D/state]
      2024-10-21 16:31:18.920  - info: net-tools.0 (481047) Can not get mac for 192.168.178.122. Going to next IP.
      2024-10-21 16:31:18.956  - info: net-tools.0 (481047) MAC address for 192.168.178.122: null
      • BananaJoe
        BananaJoe Most Active @totocotonio last edited by BananaJoe
        @totocotonio sieht ok aus,
        keine Ahnung, im Moment habe ich keine Idee.
        Aus das Log des entsprechenden Telegram Adapters auf Debug zu stellen und dann noch mal senden und schauen was das Log sagt.
        Die Bilder sind auch wirklich gültige Bilder? Wenn du dir diese mal ansiehst? Nicht das der Dateityp nicht - mehr - stimmt.
        Hattest du schon im ersten Post geschrieben das du die Bilder kontrolliert hast.
        Text senden geht nehme ich an.
        • haus-automatisierung
          haus-automatisierung Developer Most Active last edited by
          Warum überhaupt noch wget? Dafür habe ich doch die httpGet-Aktionen zur Verfügung gestellt 😞
          Geht mittlerweile alles ohne exec und wget...
          totocotonio 2 Replies Last reply Reply Quote 0
          • totocotonio
            totocotonio @haus-automatisierung last edited by
            kannst du mir mal ein Beispiel geben?
            • totocotonio
              Ich bin da etwas ratlos und würde auch gerne auf Ursachenforschung gehen.
                haus-automatisierung Developer Most Active @totocotonio last edited by
                @totocotonio sagte in Bild versand:
                Hier ein Screenshot aus dem Kurs:
                MartinP totocotonio 2 Replies Last reply Reply Quote 1
                  J_Paul @totocotonio last edited by
                  @totocotonio
                  Es liegt am Bild (danke fürs zu schicken) und damit ist es egal, auf welche Weise du es abholst.
                  Wenn man dein Bild in Paint ohne etwas zu ändern unter anderem Namen speicherst, dann lässt es sich über Telegram verschicken. Beide haben 640x480, 96dpi, beide unkomprimiert, das Original hat ca. 40 kB, die Kopie 70 kB. Versuch mal ob du bei den Einstellungen beim Octoprint was erreichen kannst.
                  BananaJoe totocotonio 2 Replies Last reply Reply Quote 0
                  • MartinP
                    MartinP @haus-automatisierung last edited by
                    @haus-automatisierung sagte in Bild versand:
                    Das wäre ja eine "Aufräum-Aktion" wert ... wie pingelig ist das get bzgl Zertifikaten... wget musste ein wenig "überredet" werden..
                    • BananaJoe
                      BananaJoe Most Active @J_Paul last edited by BananaJoe
                      @j_paul sagte in Bild versand:
                      @totocotonio
                      Als Workaround (Pfuschen):
                      • ImageMagick nachinstallieren auf der ioBroker Maschine (Befehle für Debian gemäß https://linuxcapable.com/how-to-install-imagemagick-on-debian-linux/)
                      sudo apt install libpng-dev libjpeg-dev libtiff-dev
                      sudo apt install imagemagick
                      und dann ein exec in das execwelches den Befehl convert aufruft und das Bild umwandelt, so etwas wie
                      Man könnte auch die Auflösung oder Qualität ändern (statt das Format)
                        haus-automatisierung Developer Most Active @MartinP last edited by
                        @martinp sagte in Bild versand:
                        Wird validiert. Die Validierung deaktivieren geht aktuell nur per JavaScript und ist in Blockly nicht umgesetzt.
                        • totocotonio
                          totocotonio @J_Paul last edited by
                          @j_paul
                          Danke Jörg.
                          • totocotonio
                            totocotonio @haus-automatisierung last edited by totocotonio
                            Danke Mathias für den Hinweis.
                            Geht leider auch nicht.
                            • totocotonio
                              @bananajoe
                              Das wäre eine Möglichkeit.
                              Ich fange jetzt erst einmal damit an, was bei Octoprint passiert ist.
                              Es hat ja immer funktioniert. Da muss also was mit dem Bild passiert sein.
                              Ich gebe auf jeden Fall Rückmeldung
                              • MartinP
                                MartinP @haus-automatisierung last edited by MartinP
                                @haus-automatisierung Danke - eine Ausrede, da vorerst nicht aufzuräumen 😉
                                Der Snapshot kommt direkt von einer Reolink-Kamera... vielleicht kann man sich da ja einen Workaround mit eigenem DNS (oder schlichtweg einer hosts-Datei) und einer URL passend zum Zertifikat basteln ...
                                Sind aber aktuell schon zwei Reolink-Kameras ...
                                Habe mal das Zertifikat der beiden Kameras unter die Lupe genommen
                                C:\> certutil -dump certificate.pem
                                X.509-Zertifikat:
                                Version: 1
                                Seriennummer: 01
                                Signaturalgorithmus:
                                    Algorithmus Objekt-ID: 1.2.840.113549.1.1.11 sha256RSA
                                    Algorithmusparameter:
                                    05 00
                                Aussteller:
                                    E=CERTIFICATE@CERTIFICATE.com
                                    CN=CERTIFICATE
                                    OU=CERTIFICATE
                                    O=CERTIFICATE
                                    L=SZ
                                    S=GD
                                    C=CN
                                  Namenshash (sha1): 8c30e4da4a81d52b835743fc261edeb26b0ac4da
                                  Namenshash (md5): 606efb5bd531bd73d791f6522a1d22f9
                                 Nicht vor: 12.05.2023 11:36
                                 Nicht nach: 07.05.2043 11:36
                                Antragsteller:
                                    CN=CERTIFICATE
                                    OU=CERTIFICATE
                                    O=CERTIFICATE
                                    L=SZ
                                    S=GD
                                    C=CN
                                Öffentlicher Schlüssel-Algorithmus:
                                    Algorithmus Objekt-ID: 1.2.840.113549.1.1.1 RSA (RSA_SIGN)
                                    05 00
                                Länge des öffentlichen Schlüssels: 2048 Bits
                                Öffentlicher Schlüssel: Nicht verwendete Bits = 0
                                    0000  30 82 01 0a 02 82 01 01  00 bb 7a 3c d7 3c 95 40
                                    0010  70 80 a0 44 98 fb 77 03  1c ef 02 5c 0f af 99 b0
                                    0020  61 08 0d b0 a9 d0 14 38  e7 2b 95 08 04 74 85 61
                                    0030  f7 28 ee 37 00 79 c7 cf  81 a9 b8 0d ec 46 e7 be
                                    0040  a6 ba 15 2c 2b a9 0e fa  38 23 f4 51 ca 3a f6 4b
                                    0050  c5 eb 3e 43 ff 11 04 e9  bc a9 f2 1f 2a 22 1e 08
                                    0060  c8 d6 5b 90 e8 23 62 bc  a3 ab bd bc 8c 29 f0 21
                                    0070  4c 03 bd 17 94 56 ca db  b2 34 af 45 19 54 89 18
                                    0080  14 27 4e 13 a0 f4 03 2a  9a 74 0a 99 d3 c2 3e 14
                                    0090  ca 23 66 1e 43 1c 4a ce  e7 e8 31 75 2c 96 6a df
                                    00a0  97 fb 09 b5 63 25 fa 3e  02 27 0d 4b 0e 41 d3 e6
                                    00b0  86 47 1c 57 00 74 00 45  3e 8e c7 74 a2 8e e3 dd
                                    00c0  fa 13 5b e3 f2 29 d0 d2  fc da 4d 74 70 aa 28 82
                                    00d0  d0 32 a0 b6 9e c1 83 58  f8 63 37 e7 eb 49 2f 00
                                    00e0  31 cd 30 a8 33 4b 5b 61  3d b6 4c af 91 31 97 7b
                                    00f0  a6 d4 1e e5 7a d5 6e 3f  f0 80 7e f2 e8 7e 68 bd
                                    0100  95 16 54 7d c8 68 50 1d  65 02 03 01 00 01
                                Zertifikaterweiterungen: 0
                                    05 00
                                Signatur: Nicht verwendete Bits=0
                                    0000  bb 27 8d c1 d2 1f 21 56  0d 61 1e 36 be 9f 70 cc
                                    0010  49 de 94 37 1a 47 7f 2f  0f 3d ce fa 80 73 ce 94
                                    0020  4b e3 4c d7 4d 02 e6 7e  74 22 1e cb 07 af 94 ae
                                    0030  5d 49 a2 de 91 c6 17 f6  7a cb ee 8d 30 32 0c 5d
                                    0040  f9 5a 64 8d 79 1b 2b a4  28 99 f9 3c 1b 1c 7e 16
                                    0050  25 88 5e 7b fc dd b5 d6  c3 16 cd 20 a3 65 f3 0f
                                    0060  a2 36 a3 6a eb 74 29 dc  4f fa d7 a4 6e 6d c9 9d
                                    0070  9f f2 0f 1d c5 2e 5e 2e  37 b3 f0 e0 37 ca f0 f7
                                    0080  99 d8 47 7d 65 d9 9a 8c  c4 3a e6 df 97 81 3a 80
                                    0090  ad 10 23 2c 76 94 d3 7f  36 6b f2 09 68 3a bb a7
                                    00a0  04 a1 fd 4d 51 e2 c6 d8  13 86 ae 9a ad 13 47 9d
                                    00b0  4f 1f 9f 4e 52 05 b0 72  7a e8 de 29 6d 05 9f 9d
                                    00c0  c8 bc 0a 90 37 d8 fd 62  9e 79 b0 14 b8 95 ff 0e
                                    00d0  15 c6 d7 5c 42 58 9b 7b  43 20 c3 9d b0 63 d4 3d
                                    00e0  7b 54 aa 6f ef 2c dd 92  65 52 65 84 9b b6 62 03
                                    00f0  6f f8 e2 7b 5e 5c be 21  d3 f2 9a e3 86 31 05 5e
                                Mögliches Stammzertifikat: Antragsteller stimmt mit dem Aussteller überein, die Signaturüberprüfung ist jedoch fehlgeschlagen: c000a000
                                Schlüssel-ID-Hash(rfc-sha1): 03adbc8bcb86603f51966ab575bdfbe5162cb2a0
                                Schlüssel-ID-Hash(sha1): 34685c10923c3cb37b0016727a0f4bfae4cbb2db
                                Schlüssel-ID-Hash(bcrypt-sha1): dc23c04a86d3756a28aa64f336b64015f70c58fd
                                Schlüssel-ID-Hash(bcrypt-sha256): bacb41f8b26978c5f38972d5afb1466eef577d27e854e8e620c81a2d8a53986f
                                Schlüssel-ID-Hash(md5): e5ed45bb65c078a13444b98762ed3a21
                                Schlüssel-ID-Hash(sha256): b8354843a3f64e5bc705b9df0c7b0d8bc645d4bbdcb48d340be4f176cda11ae7
                                Schlüssel-ID-Hash(pin-sha256): pnwMqh30qaq4iVkysVTZ2xU0g1YrOA5vTUVL9Tbf3MU=
                                Schlüssel-ID-Hash(pin-sha256-hex): a67c0caa1df4a9aab8895932b154d9db153483562b380e6f4d454bf536dfdcc5
                                Zertifikathash(md5): 759c6764d15b1eac3d2e97a564c540c9
                                Zertifikathash(sha1): c3611265dde2ff12aec1494b16882aa10624038e
                                Zertifikathash(sha256): d0f5937fdf67bb73f342b5abd108bc33843ee55af3641a48a83c453a7b884d40
                                Signaturhash: c4e34e8e50e2547b235d99146660b2d60429ac351e7ae7533b98de8069f47d44
                                CertUtil: -dump-Befehl wurde erfolgreich ausgeführt.
                                Da wird man wohl wenig Glück haben, sich eine Fake-URL in seine hosts - datei zu basteln ...
                                Habe es mal versucht
                                die certificate.pem Datei mit dem Broweser heruntergeladen, und auf den iobroker Linux LXC geschoben:
                                martin@iobroker-test-sicher:/usr/local/share/ca-certificates$ mv reolink.pem reolink.crt
                                martin@iobroker-test-sicher:/usr/local/share/ca-certificates$ sudo mv reolink.pem reolink.crt
                                martin@iobroker-test-sicher:/usr/local/share/ca-certificates$ ls
                                reolink.crt
                                martin@iobroker-test-sicher:/usr/local/share/ca-certificates$ cd ..
                                martin@iobroker-test-sicher:/usr/local/share$ bash update-ca-certificates
                                bash: update-ca-certificates: No such file or directory
                                martin@iobroker-test-sicher:/usr/local/share$ sudo update-ca-certificates
                                Updating certificates in /etc/ssl/certs...
                                rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
                                1 added, 0 removed; done.
                                Running hooks in /etc/ca-certificates/update.d...
                                done.
                                Hilft aber erstmal nicht ...
                                martin@iobroker-test-sicher:/usr/local/share$ wget 'https://192.168.2.190/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=Martin&passwordxxxxxxxxxxxxxxx&width=640&height=480'
                                --2024-10-22 13:38:38--  https://192.168.2.190/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=Martin&password=xxxxxxxxxxxxxx&width=640&height=480
                                Connecting to 192.168.2.190:443... connected.
                                The certificate's owner does not match hostname '192.168.2.190'
                                jetzt mit hosts Einträgen
                                192.168.2.190 garage.CERTIFICATE garage.CERTIFICATE.cn garage.CERTIFICATE.com garage.CERTIFICATE.CERTIFICATE
                                nichts funktioniert
                                martin@iobroker-test-sicher:~$ wget --verbose 'https://garage.CERTIFICATE#/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&userq=Martin&password=xxxxxxxxxxxxxxxx!&width=640&height=480'
                                --2024-10-22 14:01:37--  https://garage.certificate/
                                Resolving garage.certificate (garage.certificate)... 192.168.2.190
                                Connecting to garage.certificate (garage.certificate)|192.168.2.190|:443... connected.
                                The certificate's owner does not match hostname 'garage.certificate'
                                martin@iobroker-test-sicher:~$ wget --verbose 'https://garage.CERTIFICATE.com#/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&userq=Martin&passwordxxxxxxxxxxxxxxxx!&width=640&height=480'
                                --2024-10-22 14:01:49--  https://garage.certificate.com/
                                Resolving garage.certificate.com (garage.certificate.com)... 192.168.2.190
                                Connecting to garage.certificate.com (garage.certificate.com)|192.168.2.190|:443... connected.
                                The certificate's owner does not match hostname 'garage.certificate.com'
                                martin@iobroker-test-sicher:~$ wget --verbose 'https://garage.CERTIFICATE.cn#/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&userq=Martin&password=xxxxxxxxxxxxx!&width=640&height=480'
                                --2024-10-22 14:01:58--  https://garage.certificate.cn/
                                Resolving garage.certificate.cn (garage.certificate.cn)... 192.168.2.190
                                Connecting to garage.certificate.cn (garage.certificate.cn)|192.168.2.190|:443... connected.
                                The certificate's owner does not match hostname 'garage.certificate.cn'
                                martin@iobroker-test-sicher:~$ wget --verbose 'https://garage.CERTIFICATE.certificate#/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&userq=Martin&passworxxxxxxxxxxx!&width=640&height=480'
                                --2024-10-22 14:02:10--  https://garage.certificate.certificate/
                                Resolving garage.certificate.certificate (garage.certificate.certificate)... 192.168.2.190
                                Connecting to garage.certificate.certificate (garage.certificate.certificate)|192.168.2.190|:443... connected.
                                The certificate's owner does not match hostname 'garage.certificate.certificate'
                                  Logisch. Kannst Dir ja keine Domain ausdenken und darauf ein beliebiges Zertifikat ausliefern:
                                  • MartinP
                                    Bei EINER Kamera würde es so funktionieren ...
                                    hosts Eintrag
                                    192.168.2.190 certificate
                                    Wget-Aufruf
                                    martin@iobroker-test-sicher:~$ wget --verbose 'https://certificate#/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&userq=Martin&password=xxxxxxxxxxxx&width=640&height=480'
                                    --2024-10-22 14:17:25--  https://certificate/
                                    Resolving certificate (certificate)... 192.168.2.190
                                    Connecting to certificate (certificate)|192.168.2.190|:443... connected.
                                    HTTP request sent, awaiting response... 200 OK
                                    Length: 23193 (23K) [text/html]
                                    Saving to: 'index.html.1'
                                    Leider ist das Zertifikat der zweiten Kamera auch auf die Dummy-Domain "certificate" ausgestellt ...
                                    Wenn die die Zertifikate jeder einzelnen Kamera auf "<seriennummer>.certificate" ausstellen würden, wäre das ja eine Lösung ....
                                    oder es in den Zertifikaten eine Liste von Domains gäbe, z. B. "0.certifikate" bis "255.certificate"
                                    Muss mich wohl noch weiter mit dem Zertifikationsgedöns auseinandersetzen ...
                                    dachte, wenn man ein Zertifikat für" blablubb.de" hat, gilt das auch für "dies.blablubb.de" und "das.blablubb.de".
                                    Gilt aber leider nur für "blablubb.de/dies" und "blablubb.de/das"
                                    Dafür gibt es dann keine "hosts" Tricks 😉
                                      Dazu wäre ein Wildcard-Zertifikat notwendig. Wir kapern aber gerade den Thread mit OT. Daher bin ich raus 🙂
                                      • totocotonio
                                        @bananajoe
                                        wie Jörg bereits gesagt hat, liegt es definitiv am Bild.
                                        Ich weiß nur noch nicht, warum!
                                        Es ging ja immer.
                                        Ich habe jetzt mit verschiedenen Auflösungen getestet, immer das gleiche, das Bild wird nicht versendet, obwohl es auf dem Server gelandet ist.
                                          Was sagt denn file /opt/iobroker/Bild_Kamera/1.jpg
                                          PS: Man arbeitet nicht als root. Nie. Das ist aber ein anderes Thema und hat nichts mit dem Problem zu tun. Leg Dir zur zeitnah einen neuen Benutzer an und arbeite mit sudo (falls nötig).
                                          totocotonio 1 Reply Last reply Reply Quote 0
                                          • totocotonio
                                            arbeite normal nicht als root. Hatte nur getestet.
                                            Hier das Ergebnis.
                                            torsten@iobdebian:~$ file /opt/iobroker/Bild_Kamera/8.jpg
                                            /opt/iobroker/Bild_Kamera/8.jpg: JPEG image data, baseline, precision 8, 640x480, components 3
                                            2615
