    4. Änderungen iob CLI/Installer/Fixer mit Root Accounts
    • Chaot
      Chaot last edited by
      Bei mir immer noch das gleiche Problem:
      haus@ioBroker:~$ iob stop
      Could not send "SIGTERM" to process 203: kill EPERM
      No "killall.sh" script found. Just stop.
      haus@ioBroker:~$ iob fix
      iobroker fix
      Execute the installation fixer script, this updates your ioBroker installation
      Options:
        --help  Show help  [boolean]
      haus@ioBroker:~$ iob start
      Gerade gemerkt. Scheinbar bin ich auf JS Version 7.0.1
        Thomas Braun Most Active @Chaot last edited by
        @chaot
        Kannst du denn iob diag ausführen?
        • Chaot
          Chaot @Thomas Braun last edited by
          Nein. Kommt in rot die Liste der Befehle
            @chaot
            ls -l /home
            sagt? Kannst du
            iob status
            ausführen?
            • Chaot
              @thomas-braun sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
              iob status
              haus@ioBroker:~$ ls -l /home
              total 8
              drwxr-xr-x 11 haus     haus     4096 Oct 21 21:38 haus
              drwxr-xr-x 11 iobroker iobroker 4096 May 22 19:18 iobroker
              haus@ioBroker:~$ iob status
              Objects type: jsonl
              States  type: redis
                Thomas Braun Most Active @Chaot last edited by Thomas Braun
                @chaot
                ls -la /home/iobroker/
                id
                • Chaot
                  id
                  haus@ioBroker:~$ ls -la /home/iobroker/
                  total 180
                  drwxr-xr-x 11 iobroker iobroker  4096 May 22 19:18 .
                  drwxr-xr-x  4 root     root      4096 Mar  6  2019 ..
                  drwxr-xr-x  3 iobroker iobroker  4096 Mar  7  2019 .anyproxy
                  -rw-r--r--  1 iobroker iobroker   220 Apr  4  2018 .bash_logout
                  -rw-r--r--  1 iobroker iobroker  3771 Apr  4  2018 .bashrc
                  drwxr-xr-x  7 iobroker iobroker  4096 Apr  6  2024 .cache
                  drwx------  4 iobroker iobroker  4096 Jan 17  2021 .config
                  -rw-rw-r--  1 iobroker iobroker 23305 May 22 19:23 .diag.sh
                  drwxr-xr-x  2 iobroker iobroker  4096 Feb  4  2022 .electron
                  drwxr-xr-x  2 iobroker iobroker  4096 Mar 27  2020 .lgtv2
                  drwx------  3 iobroker iobroker  4096 Jan 17  2021 .local
                  drwxr-xr-x  6 iobroker iobroker  4096 Aug 19  2019 .node-gyp
                  -rw-rw-r--  1 iobroker iobroker 16123 May 22 19:30 .nodejs-update.sh
                  drwxr-xr-x  9 iobroker iobroker  4096 Apr 19  2024 .npm
                  drwx------  3 iobroker iobroker  4096 Feb  7  2022 .pki
                  -rw-r--r--  1 iobroker iobroker   807 Apr  4  2018 .profile
                  -rw-rw-r--  1 iobroker iobroker 83818 May 22 19:27 iob_diag.log
                  haus@ioBroker:~$ id
                  uid=1001(haus) gid=1001(haus) groups=1001(haus),1000(iobroker)
                  haus@ioBroker:~$
                    @chaot
                    Da funktioniert irgendwie der Abruf von fix und diag nicht. Kannst du denn
                    iob nodejs-update
                    ausführen?
                    Eigentlich sollten da nämlich immer aktuelle Downloads liegen:
                    Bei mir:
                    -rwxr-x---  1 iobroker iobroker 39757 Oct 23 13:28 .diag.sh
                    -rwxr-x---  1 iobroker iobroker 45390 Oct 23 13:27 .fix.sh
                    -rw-r--r--  1 iobroker iobroker 32474 Oct 23 13:29 iob_diag.log
                    -rwxr-x---  1 iobroker iobroker 18018 Oct 20 20:41 .nodejs-update.sh
                    • Chaot
                      iob nodejs-update
                      haus@ioBroker:~$ iob nodejs-update
                      iobroker nodejs-update [<major-version>]
                      Upgrade the Node.JS installation to the current LTS
                      Options:
                      Ich bin wieder runter auf die 6.0.11.
                      Aber irgendwas ist da verbogen
                      Could not send "SIGTERM" to process 201: kill EPERM
                      ^[[Ahaus@ioBroker:~$
                      iobroker fix
                      Options:
                      Controller is already running with pid 201
                        @chaot
                        Versuch mal den Fixer direkt zu laden:
                        curl -fsL https://iobroker.net/fix.sh | bash -
                        • Chaot
                          könnte klappen, wenn ich den iobroker stoppen kann
                          haus@ioBroker:~$ curl -fsL https://iobroker.net/fix.sh | bash -
                          Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                          library: loaded
                          Library version=2024-10-22
                          ioBroker or some processes are still running:
                          201 iobroker.js-con
                          408 io.admin.0
                          419 io.javascript.0
                          449 io.email.0
                          478 io.influxdb.0
                          513 io.whatsapp-cmb
                          528 io.history.0
                          539 io.tr-064.0
                          558 io.sonoff.0
                          637 io.proxmox.0
                          666 io.backitup.0
                          816 io.nut.0
                          831 io.alexa2.0
                          842 io.unifi.0
                          873 io.ems-esp.0
                          888 io.drag-indicat
                          903 io.tuya.0
                          918 io.web.0
                          972 io.tankerkoenig
                          1178 io.fritzdect.0
                          1185 io.phantomjs.0
                          1263 io.nina.0
                          1309 io.trashschedul
                          1401 io.sourceanalyt
                          1438 io.wled.0
                          1453 io.vis-inventwo
                          1468 io.smartcontrol
                          1479 io.linux-contro
                          1498 io.time-switch.
                          1564 io.upnp.0
                          1575 io.mytime.0
                          1586 io.ws.0
                          1620 io.rssfeed.0
                          1632 io.alexa-timer-
                          1647 io.wiegand-tcpi
                          1662 io.drops-weathe
                          Please stop them first and try again!
                          haus@ioBroker:~$
                            @chaot
                            sudo systemctl stop iobroker
                            • Chaot
                              Danke. Deine "Zauberfinger" haben mir das wieder gerade gebogen
                              ```bash
                                                     v.2024-10-19
                                Static hostname: ioBroker
                                      Icon name: computer-container
                                        Chassis: container
                                 Virtualization: lxc
                               Operating System: Ubuntu 20.04.6 LTS
                                         Kernel: Linux 6.5.13-5-pve
                                   Architecture: x86-64
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              Timezone:               Europe/Berlin (CEST, +0200)
                              User-ID:                1001
                              Display-Server:         false
                              Boot Target:            multi-user.target
                              Pending OS-Updates:     0
                              Pending iob updates:    1
                              Nodejs-Installation:
                              /usr/bin/nodejs         v20.18.0
                              /usr/bin/node           v20.18.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.3
                              Recommended versions are nodejs  and npm 10.8.2
                              nodeJS installation is correct
                              MEMORY:
                              Mem:           6.1G        3.7G        735M        1.0M        1.7G        2.4G
                              Swap:          2.0G          0B        2.0G
                              Total:         8.2G        3.7G        2.8G
                              Active iob-Instances:   6
                              Upgrade policy: none
                              ioBroker Core:          js-controller           6.0.11
                                                     admin                   7.2.6
                              Objects type: jsonl
                              States  type: redis
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                               system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 80, bind: 0.0.0.0, run as: admin
                               system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                2
                              States:                 29089
                              Size of iob-Database:
                              29M     /opt/iobroker/iobroker-data/objects.jsonl
                              21M     /opt/iobroker/iobroker-data/objects.json.migrated
                              21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              8.0K    /opt/iobroker/iobroker-data/states.json
                              4.0K    /opt/iobroker/iobroker-data/states.json.bak
                              Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                              === Mark text until here for copying ===
                              [/s]
                                @chaot
                                Okay, iob stop / iob start sowie iob fix funktionieren jetzt wieder im direkten Aufruf?
                                • Chaot
                                  @thomas-braun Ja, alles wieder wie gewohnt. Der neue Fixer hat auch gleich die GUI ausgeschaltet (die mir nicht bewusst war). Funktioniert also alles wieder wie gewohnt.
                                  Herzlichen Dank
                                    @chaot sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                                    Na ich hoffe aber, das du wenigstens gefragt wurdest und das aktiv per y-Taste bestätigt hast?
                                    • Chaot
                                      @thomas-braun Ja, aber beim ersten Durchlauf lief der fixer nach der Frage weiter. Beim zweiten Start des fixers hat er dann angehalten und auf das "y" gewartet.
                                        @chaot
                                        Ja, so ist es richtig.
                                        • Feuersturm
                                          Feuersturm last edited by
                                          @Thomas-Braun Ich hab gerade die aktuelle Version von iob fix ausgeführt und das Terminal im Hintergrund einige Zeit vergessen.
                                          Anscheinend läuft ein Timer der irgendwann die Authentifizierung abbricht und als Fehlerhaft ausgibt.
                                          Hat es einen Grund, das das Skript nicht einfach auf die Eingabe wartet oder aktiv abgebrochen werden muss mit Strg+C?
                                          Bei einem zweiten Aufruf von iob fix war dann alles i.O.
                                              Checking autostart (5/5)
                                          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                                          Authentication is required to stop 'iobroker.service'.
                                          Authenticating as: ,,, (proxmox)
                                          Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                                          Enabling autostart...
                                          Autostart enabled!
                                            Thomas Braun Most Active @Feuersturm last edited by Thomas Braun
                                            @feuersturm sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                                            Kann ich nicht steuern, das kommt so vom polkit/pam.
                                            Allerdings könnte man die falsche Erfolgsmeldung Autostart enabled! anpassen.
                                            81.1k
                                            202
                                            37632
