    4. Test Adapter Schedule-Switcher
    • Negalein
      Negalein Global Moderator @Lucky_ESA last edited by
      @lucky_esa
      gerade im Log gesehn
      schedule-switcher.0 2024-10-22 23:20:48.181	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:20:24.832	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:05:12.162	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:04:46.200	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:04:45.331	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:04:36.762	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:04:33.994	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:04:31.427	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:02:48.254	error	Message service change-view-dataId not initialized
      schedule-switcher.0 2024-10-22 23:01:02.050	error	Cannot find view "system"
      schedule-switcher.0 2024-10-22 23:01:02.050	error	Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:3513:19) at async Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:3554:37)
      schedule-switcher.0 2024-10-22 23:01:02.049	error	unhandled promise rejection: Cannot find view "system"
      schedule-switcher.0 2024-10-22 23:01:02.049	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      schedule-switcher.0 2024-10-22 23:01:02.048	error	Cannot find view "system" for search "state" : Connection is closed.
        Lucky_ESA Developer Most Active @Negalein last edited by
        @negalein Vielen Dank. change-view-dataId hatte ich vergessen. Habe es gerade auf GIT geladen.
        Welchen admin und js-contoller nutzt du und mit welchem System bist du unterwegs?
        Gruß//Lucky
          @negalein
          Bitte auch den Adapter aktiv lassen und nicht deaktivieren.
          sowieso
          Das darf so nicht aussehen. Wie sieht es jetzt aus?
          • warum ist hier alles in Englisch? ioB ist auf Deutsch.
          Kannst du in deinem Browser in die Console schauen?
          • bei + für condition tut sich nichts. Oder kommen die Bedingungen nicht bei jedem Trigger?
          Die Bedingunegn müssen in den Einstellung vom Widget erst angelegt werden (wenn man diese benötigt)
          • kann der Name vom State (hier hue.0.Wohnzimmer.level) ausgebledet werden?
          In den Einstellungen vom Widget unter Anzeigen des geschaltenen States
          Gruß//Lucky
          • Negalein
            @lucky_esa sagte in Test Adapter Schedule-Switcher:
            Fehler ist weg.
            Admin: 7.2.6
            JS-Controller: 6.0.11
            System Ubuntu 22.04
            • Negalein
              10.0.1.202-1729664198362.log
              Ah, ok.
              gefunden 🙂
              steht bei mir als showID
                sigi234 Forum Testing Most Active @Lucky_ESA last edited by
                @lucky_esa
                Hallo, soll ich den Adapter deinstallieren oder drüber?
                  Lucky_ESA Developer Most Active @sigi234 last edited by
                  @sigi234 sagte in Test Adapter Schedule-Switcher:
                  @lucky_esa
                  drüber. Du musst dann nur die Trigger editieren oder neu anlegen. Nicht das Widget...
                  In der Instanz Einstellung die Anzahl anlegen (+ Zeichen) wie viele Objekte du unter onoff hast.
                    Da kann ich nichts ändern steht schon da?
                      @sigi234 Es wäre besser beide zu löschen und dann neu anzulegen.
                      @Negalein Auf GIT funktioniert nun auch Translate bei VIS1.
                      Habe nun bei mir im Live System aktualisiert. Es waren dann alle 21 States weg. Musste die 21 neu anlegen und dann den Backup.json neu unter Objekte importiert.
                      History sollte nun funktionieren und bei Astro Trigger wird die Schaltzeit im Trigger angezeigt. Das funktioniert aber nicht zuverlässig.
                      Gruß//Lucky
                      • Negalein
                        Danke, nun ist alles in deutsch.
                        Musste ihn zuerst löschen und dann wieder neu.
                        PS:
                        das funktioniert bei mir nicht. Muss ihn immer über benutzerdefiniert laden.
                        Bei Git scheint er auch danach nicht auf.
                        Adapter zum ersten Mal von GIT laden:
                        Danach Updates von GIT laden:
                          @negalein Es ist eigentlich egal aber der Adapter sollte bei GIT zu sehen sein.
                          Komisch...aber egal.. Bei VIS1 muss ich nach dem Update unter Adapter bei VIS neu downloaden, sonst werden Änderungen nicht übernommen (bei dev-server).
                          Gruß//Lucky
                          • Negalein
                            Ahh, da kann ich lange nach Schedule suchen. 😂
                            Ok, ich hab nur beim Schedule-Switcher den Upload gemacht.
                              @negalein
                              So sollte es auch eigentlich sein. Warum das nicht ohne download auf meinen dev-server funktioniert entzieht sich meine Kenntnis. Man muss auch nicht alles wissen.
                              Gruß//Lucky
                              • BananaJoe
                                BananaJoe Most Active last edited by
                                Zwischenfrage:
                                Kann ich den Schedule-Switcher parallel zum time-Switcher installieren?
                                Mir geht es darum ob die beiden sich gegenseitig stören,
                                übernommen werden muss nichts / wird idealerweise nichts.
                                Ich würde dann parallel arbeiten und alles Stück für Stück umstellen
                                  Lucky_ESA Developer Most Active @BananaJoe last edited by
                                  @bananajoe sagte in Test Adapter Schedule-Switcher:
                                  Zwischenfrage:
                                  Wenn du parallel aufbaust verwendest du ja die selben Zeiten. Bedeutet du Triggerst dann States doppelt womit kein Adapter umgehen kann. Wenn du andere States verwendest, ist das kein Problem.
                                  Gruß//Lucky
                                  • BananaJoe
                                    BananaJoe Most Active @Lucky_ESA last edited by
                                    Zwischenfrage:
                                    Gruß//Lucky
                                    naja, ich wollte das schon bei deinen Adapter neu einrichten und dann auf dem bisherigen deaktivieren ...
                                      @bananajoe
                                      Das wäre kein Problem
                                        mane444 last edited by mane444
                                        Bin gerade am testen und auch froh das ich auf VIS2 umsteigen kann.
                                        Mir ist aber folgendes aufgefallen.
                                        Ich habe in den Instanz Einstellungen für 8 Schaltpläne erzeugt, danach in der Vis2 das erste Widget hineingezogen und parametriert. Soweit klappt das alles super.
                                        Da ich nun etwas faul bin, wollte ich in der Vis2 Seite das Widget kopieren und dann die Schaltplandaten händisch ändern.
                                        Beim Ändern der ID kommen im log folgende Fehlermeldungen:
                                        schedule-switcher.0
                                        2024-10-29 19:33:34.515	error	Could not handle message:
                                        schedule-switcher.0
                                        2024-10-29 19:33:34.515	error	TypeError: Cannot set properties of undefined (setting 'vis-2.0') at MessageService.updateViews (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/services/MessageService.js:199:35) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async MessageService.handleMessage (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/services/MessageService.js:54:7) at async ScheduleSwitcher.setSendTo (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/main.js:735:9)
                                        schedule-switcher.0
                                        2024-10-29 19:33:34.514	error	Requested getState schedule-switcher.0.onoff..views returned null/undefined!
                                        Die Instanz vom schedule-switcher bleibt grün, aber man kann in der VIS2 keine Änderungen mehr pflegen. Erst nach einem Neustart von der Instanz vom schedule-switcher läuft wieder alles wie es soll.
                                        Vielleicht lässt sich das ja irgendwie abfangen.
                                          darkaragon last edited by
                                          Moin,
                                          ich wollte nur kurz Danke sagen, dass es mit dem Adapter in Zukunft weiter geht. Ich benutze ihn für etliche Schaltvorgänge und die Rolladen.
                                          Hätte einen riesen Stress wenn er weg wäre.
                                            Lucky_ESA Developer Most Active @mane444 last edited by Lucky_ESA
                                            @mane444 Danke für diese Info. Werde es mir anschauen.
                                            Ist mit 0.0.3 gefixt
                                            89
                                            9469
