    4. Änderungen iob CLI/Installer/Fixer mit Root Accounts
    • Chaot
      Chaot @Thomas Braun last edited by
      könnte klappen, wenn ich den iobroker stoppen kann
      haus@ioBroker:~$ iob stop
      Could not send "SIGTERM" to process 201: kill EPERM
      No "killall.sh" script found. Just stop.
      haus@ioBroker:~$ curl -fsL https://iobroker.net/fix.sh | bash -
      Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      201 iobroker.js-con
      408 io.admin.0
      419 io.javascript.0
      449 io.email.0
      478 io.influxdb.0
      513 io.whatsapp-cmb
      528 io.history.0
      539 io.tr-064.0
      558 io.sonoff.0
      637 io.proxmox.0
      666 io.backitup.0
      816 io.nut.0
      831 io.alexa2.0
      842 io.unifi.0
      873 io.ems-esp.0
      888 io.drag-indicat
      903 io.tuya.0
      918 io.web.0
      972 io.tankerkoenig
      1178 io.fritzdect.0
      1185 io.phantomjs.0
      1263 io.nina.0
      1309 io.trashschedul
      1401 io.sourceanalyt
      1438 io.wled.0
      1453 io.vis-inventwo
      1468 io.smartcontrol
      1479 io.linux-contro
      1498 io.time-switch.
      1564 io.upnp.0
      1575 io.mytime.0
      1586 io.ws.0
      1620 io.rssfeed.0
      1632 io.alexa-timer-
      1647 io.wiegand-tcpi
      1662 io.drops-weathe
      Please stop them first and try again!
      haus@ioBroker:~$
        Thomas Braun Most Active @Chaot last edited by
        @chaot
        sudo systemctl stop iobroker
        • Chaot
          Danke. Deine "Zauberfinger" haben mir das wieder gerade gebogen
          ```bash
                                 v.2024-10-19
            Static hostname: ioBroker
                  Icon name: computer-container
                    Chassis: container
             Virtualization: lxc
           Operating System: Ubuntu 20.04.6 LTS
                     Kernel: Linux 6.5.13-5-pve
               Architecture: x86-64
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1001
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:
          /usr/bin/nodejs         v20.18.0
          /usr/bin/node           v20.18.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          Recommended versions are nodejs  and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:           6.1G        3.7G        735M        1.0M        1.7G        2.4G
          Swap:          2.0G          0B        2.0G
          Total:         8.2G        3.7G        2.8G
          Active iob-Instances:   6
          Upgrade policy: none
          ioBroker Core:          js-controller           6.0.11
                                 admin                   7.2.6
          Objects type: jsonl
          States  type: redis
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
           system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 80, bind: 0.0.0.0, run as: admin
           system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                2
          States:                 29089
          Size of iob-Database:
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/objects.json.migrated
          21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          8.0K    /opt/iobroker/iobroker-data/states.json
          4.0K    /opt/iobroker/iobroker-data/states.json.bak
          Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
          === Mark text until here for copying ===
          [/s]
            @chaot
            Okay, iob stop / iob start sowie iob fix funktionieren jetzt wieder im direkten Aufruf?
            • Chaot
              @thomas-braun Ja, alles wieder wie gewohnt. Der neue Fixer hat auch gleich die GUI ausgeschaltet (die mir nicht bewusst war). Funktioniert also alles wieder wie gewohnt.
              Herzlichen Dank
                @chaot sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                Na ich hoffe aber, das du wenigstens gefragt wurdest und das aktiv per y-Taste bestätigt hast?
                • Chaot
                  @thomas-braun Ja, aber beim ersten Durchlauf lief der fixer nach der Frage weiter. Beim zweiten Start des fixers hat er dann angehalten und auf das "y" gewartet.
                    @chaot
                    Ja, so ist es richtig.
                    • Feuersturm
                      Feuersturm last edited by
                      @Thomas-Braun Ich hab gerade die aktuelle Version von iob fix ausgeführt und das Terminal im Hintergrund einige Zeit vergessen.
                      Anscheinend läuft ein Timer der irgendwann die Authentifizierung abbricht und als Fehlerhaft ausgibt.
                      Hat es einen Grund, das das Skript nicht einfach auf die Eingabe wartet oder aktiv abgebrochen werden muss mit Strg+C?
                      Bei einem zweiten Aufruf von iob fix war dann alles i.O.
                          Checking autostart (5/5)
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                      Authentication is required to stop 'iobroker.service'.
                      Authenticating as: ,,, (proxmox)
                      Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                      Enabling autostart...
                      Autostart enabled!
                        Thomas Braun Most Active @Feuersturm last edited by Thomas Braun
                        @feuersturm sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                        Kann ich nicht steuern, das kommt so vom polkit/pam.
                        Allerdings könnte man die falsche Erfolgsmeldung Autostart enabled! anpassen.
                        • David G.
                          Leider nur ein Screenshot, das c&p wollte irgendwie nicht...
                          Debian 12.
                            Thomas Braun Most Active @David G. last edited by
                            @david-g
                            Ja, ist bekannt. Fix ist 'in der Mache'.
                            David G. 1 Reply Last reply Reply Quote 1
                            • David G.
                              David G. @Thomas Braun last edited by
                              Wird das Script das auch irgendwann selber lösen können?
                              david@iobroker:~$ iob stop
                              david@iobroker:~$ iob fix
                              [sudo] Passwort für david:
                              bash: /home/iobroker/.fix.sh: Keine Berechtigung
                              david@iobroker:~$ sudo iob fix
                              ***For security reasons ioBroker should not be run or administrated as root.***
                              By default only a user that is member of iobroker group can execute ioBroker commands.
                              Please read the Documentation on how to set up such a user, if not done yet.
                              Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                              Please note that this option may be disabled in the future, so please change your setup accordingly now.
                              david@iobroker:~$
                                @david-g sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                                Was genau?
                                Schau dir die Rechte an
                                ls -l /home/iobroker/
                                ls -l /home/iobroker/.fix.sh
                                Vermutlich ist david nicht in der Gruppe 'iobroker' enthalten.
                                groups
                                zeigt die.
                                • David G.
                                  Dass ein User automatisch der erforderlichen Gruppe hinzugefügt werden kann.
                                  Ggf hat man ja schon einen User den man verwenden möchte anstatt einen neuen anzulegen.
                                  david@iobroker:~$ sudo ls -l /home/iobroker/
                                  insgesamt 24
                                  -rw-r--r-- 1 iobroker iobroker   122 21. Okt 22:17 iob_diag.log
                                  -rwxr--r-- 1 iobroker iobroker 15796 29. Sep 2023  iob_node_update
                                  drwxr-xr-x 5 iobroker iobroker  4096 31. Mär 2024  skripte
                                  david@iobroker:~$ sudo ls -l /home/iobroker/.fix.sh
                                  -rw-r--r-- 1 iobroker iobroker 45390 26. Okt 13:04 /home/iobroker/.fix.sh
                                  david@iobroker:~$ groups
                                  david sudo users
                                  david@iobroker:~$
                                    Thomas Braun Most Active @David G. last edited by Thomas Braun
                                    Nee, das muss der sys admin selber für bestehende user machen.
                                    Sonst könnte ja ein user, der es gar nicht in die Gruppe reingehört einfach das Skript aufrufen und sich dann so hinzufügen.
                                    sudo usermod -a -G iobroker david
                                    Den david dann einmal ausloggen und wieder einloggen.
                                    • David G.
                                      Kann aber gerne einen Thread auf machen.
                                      Ist ja eher sehr offtopic....
                                      Zumindest wenn der fixer es technisch nicht übernehmen kann.
                                      david@iobroker:~$ groups david
                                      david : david sudo users iobroker
                                      david@iobroker:~$
                                        @david-g
                                        david wurde ausgeloggt?
                                        ls -l /home
                                        sagt?
                                        • David G.
                                          David G. @Thomas Braun last edited by David G.
                                          Ja, auch einmal als anderen User angemeldet.
                                          david@iobroker:~$ ls -l /home
                                          insgesamt 8
                                          drwx------ 4 david    david    4096 26. Okt 13:36 david
                                          drwx------ 9 iobroker iobroker 4096 26. Okt 12:54 iobroker
                                          david@iobroker:~$
                                            Da fehlen die Gruppen-Rechte.
                                            sudo chmod 750 /home/iobroker
                                            Ist das heute frisch angelegt worden?
                                            81.1k
                                            202
                                            37651
