    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. [gelöst] Weatherman 2.1 mit wiffi-wz Adapter
      best57 @Homoran last edited by Homoran
      hier ein Log-Auszug beim Start von wiffi-wz:
      2024-10-23 16:31:09.837 - info: wiffi-wz.0 (221359) Got terminate signal TERMINATE_YOURSELF
      2024-10-23 16:31:09.845 - info: wiffi-wz.0 (221359) Stopping adapter ...
      2024-10-23 16:31:09.848 - debug: wiffi-wz.0 (221359) Server closed
      2024-10-23 16:31:09.850 - info: wiffi-wz.0 (221359) Adapter stopped.
      2024-10-23 16:31:09.853 - info: wiffi-wz.0 (221359) terminating
      2024-10-23 16:31:09.855 - info: wiffi-wz.0 (221359) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-23 16:31:09.955 - warn: wiffi-wz.0 (221359) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "false"
      2024-10-23 16:31:10.002 - warn: wiffi-wz.0 (221359) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "false"
      2024-10-23 16:31:18.290 - debug: wiffi-wz.0 (221510) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-10-23 16:31:18.328 - debug: wiffi-wz.0 (221510) Objects client ready ... initialize now
      2024-10-23 16:31:18.331 - debug: wiffi-wz.0 (221510) Objects create System PubSub Client
      2024-10-23 16:31:18.332 - debug: wiffi-wz.0 (221510) Objects create User PubSub Client
      2024-10-23 16:31:18.378 - debug: wiffi-wz.0 (221510) Objects client initialize lua scripts
      2024-10-23 16:31:18.387 - debug: wiffi-wz.0 (221510) Objects connected to redis: 127.0.0.1:9001
      2024-10-23 16:31:18.390 - silly: wiffi-wz.0 (221510) redis psubscribe cfg.o.system.user.*
      2024-10-23 16:31:18.418 - silly: wiffi-wz.0 (221510) redis psubscribe cfg.o.enum.*
      2024-10-23 16:31:18.422 - silly: wiffi-wz.0 (221510) objectDB connected
      2024-10-23 16:31:18.426 - debug: wiffi-wz.0 (221510) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-10-23 16:31:18.442 - debug: wiffi-wz.0 (221510) States create System PubSub Client
      2024-10-23 16:31:18.443 - debug: wiffi-wz.0 (221510) States create User PubSub Client
      2024-10-23 16:31:18.533 - debug: wiffi-wz.0 (221510) States connected to redis: 127.0.0.1:9000
      2024-10-23 16:31:18.536 - silly: wiffi-wz.0 (221510) statesDB connected
      2024-10-23 16:31:18.749 - info: wiffi-wz.0 (221510) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.wiffi-wz, node: v18.20.4, js-controller: 6.0.11
      2024-10-23 16:31:18.794 - silly: wiffi-wz.0 (221510) States system redis pmessage system.adapter.wiffi-wz.0.logLevel/system.adapter.wiffi-wz.0.logLevel:{"val":"silly","ack":true,"ts":1729693878772,"q":0,"from":"system.adapter.wiffi-wz.0","lc":1729693394545}
      2024-10-23 16:31:18.854 - info: wiffi-wz.0 (221510) Opening local server on 0.0.0.0:8181
      2024-10-23 16:31:18.859 - info: wiffi-wz.0 (221510) Server listening on 0.0.0.0:8181
      2024-10-23 16:31:18.883 - warn: wiffi-wz.0 (221510) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "true"
      2024-10-23 16:31:18.956 - debug: wiffi-wz.0 (221510) Create basic states for Wiffi with ip 192.168.72.25
      2024-10-23 16:31:18.958 - info: wiffi-wz.0 (221510) Method "createChannel" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
      der WM2.1 wurde gleich konfiguriert wie der WM2.
      Wenn ich so nicht weiter komme, werde ich wohl den Weg über den HomeMatic-Adpater wählen müssen.
      Homoran crunchip 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @best57 last edited by
        @best57 sagte in Weatherman 2.1 mit wiffi-wz Adapter:
        oder per Skript die Daten holen.
        Das log verstehe ich leider nicht, sehe aber keinen ERROR, warum etwas nicht geht.
        ich sehe auch nicht dass Daten abgerufen werden.
        Was hängt denn an port 8181?
          über Port 8181 sollte der WM mit dem wiffi-wz Adapter kommunizieren. Ich habe da schon mit anderen Ports getestet, ohne Erfolg.
            Homoran Global Moderator Administrators @best57 last edited by Homoran
            port 8181 vom wiffi??
            EDIT:
            hab gerade bei meinem WIFFI nachgesehen.
            ich fürchte die IP 0.0.0.0 taugt nicht, wenn diese dem WM mitgeteilt wird um dorthin zu verbinden.
            ich habe da die IP des ioBroker Servers drin
              crunchip Forum Testing Most Active @best57 last edited by
              192.168.72.25
              Und das ist dein neuer wiffi? Oder der alte?
              Vllt Schreibfehler in den Einstellungen beim Neuen
              @homoran sagte in Weatherman 2.1 mit wiffi-wz Adapter:
              0.0.0.0
              Ist doch der instanzeintrag
              @Homoran das war der gemeigte Fehler, nicht wie oben geschrieben... Number/string
                Homoran Global Moderator Administrators @crunchip last edited by Homoran
                @crunchip sagte in Weatherman 2.1 mit wiffi-wz Adapter:
                ja, aber auch die IP in Form 192.168.xxx.yyy kann da ausgewählt werden.
                Mein Gedanke mangels Wissen war:
                Bei hm-rpc wird diese IP der CCU mitgeteilt damit die CCU dorthin antwortet.
                Sollte das beim wiffi Adapter identisch sein hilft 0.0.0.0 nichts
                  crunchip Forum Testing Most Active @Homoran last edited by
                  @homoran ich habe keine ccu, daher hört meine Instanz auf alle und funktioniert. Im wiffi Gerät(pulscounter) hab ich die IP des iobroker hinterlegt.
                    es werden unterhalb vom Verzeichnis 192_168_xx_xx keine Objekte angelegt.
                    bin mir nicht genau sicher, ist schon Jahre her, aber ich meine, ich hatte setvar damals abgesetzt, damit die Datenpunkte erschienen
                    ansonsten steht bei ccu-ip die des iobrokers und my ip habe ich fest vergeben
                      @crunchip Ich weiss wirklich nicht mehr was ich eingestellt habe.
                      ich meine aber dass sowohl die CCU als auch iobroker die Daten bekommen, auch wenn sich die IP des iob mittlerweile geändert hat ohne dass ich am Wiffi was verändert habe
                      Diese Einstellung zeigt die verschiedenen Möglichkeiten
                      Allerdings kann man auch mit <IP>?:json: die Werte pullen
                      ich weiss jetzt gar nicht was der Adapter macht.
                      EDIT:
                      in dem json ist die neue IP des ioBrokers als CCU-IP angegeben.
                      Da ich mir ziemlich sicher bin diese nicht über kryptische Befehle via Adresse des Wiffis eingegeben, sondern nur in der Konfiguration desr Instanz geändert zu haben. vermute ich, dass der Adapter diese Konfiguration durchführt.
                      Dazu braucht der Adapter aber eine IP mit der der Wiffi dann ioBroker erreichn kann.
                      Also nicht 0.0.0.0, sondern 192.168.xxx.yyy
                        weils bei dir über die ccu läuft, ist ja der parameter darüber, so wie ich das verstehe
                        ich sende direkt an den iobroker
                          nein tut es nicht, hab gerade im debug log nachgesehen (siehe edit)
                          die beiden Zeilen der Beschreibung gilt für Parameter 27. Der Wert kann 0,1, oder in meinem Fall die 8181 als port sein.
                          wie kommst du auf die Seite mit der IP?
                          expert 0 bis 3 ist es nicht.
                            ist die startseite, wenn ich die ip aufrufe
                            wenn ich hin und her blättere, steht
                            http://10.1.30.10/?xpert:0:
                              @crunchip Danke!
                              ich bin blind gewesen.
                              Hab nur den unteren Block gesehen 🤦
                              Da steht die aktuelle IP des ioBrokers
                              wäre jetzt interessant was dort bei @best57 im neuen Weatherman steht
                                sorry, konnte mich erst jetzt wieder damit beschäftigen. Es war tatsächlich die falsche IP beim Parameter "CCU IP-Adresse". Mit der IP des iobroker funktioniert es nun. Wegen der Bezeichnung hatte ich das wohl übersehen.
                                Danke für eure Unterstützung.
                                1103
