    4. Hargassner Anbindung ModBus läuft nicht
      FloK @Samson71 last edited by
      @samson71 Hier nochmal das Log von gerade eben ```
      modbus.0
      2024-10-24 15:02:35.814	info	Disconnected from slave 192.168.178.41
      modbus.0
      2024-10-24 15:02:34.811	warn	[DevID_1] Poll error count: 3 code: {"err":"timeout","timeout":5000}
      modbus.0
      2024-10-24 15:02:34.811	error	Client in error state.
      modbus.0
      2024-10-24 15:02:34.811	error	Request timed out.
      modbus.0
      2024-10-24 15:02:34.810	warn	Error: undefined
      modbus.0
      2024-10-24 15:02:29.806	info	Connected to slave
      modbus.0
      2024-10-24 15:01:29.781	info	Disconnected from slave 192.168.178.41
      modbus.0
      2024-10-24 15:01:28.778	warn	[DevID_1] Poll error count: 2 code: {"err":"timeout","timeout":5000}
      modbus.0
      2024-10-24 15:01:28.777	error	Client in error state.
      modbus.0
      2024-10-24 15:01:28.777	error	Request timed out.
      modbus.0
      2024-10-24 15:01:28.776	warn	Error: undefined
      modbus.0
      2024-10-24 15:01:23.773	info	Connected to slave
      modbus.0
      2024-10-24 15:00:23.751	info	Disconnected from slave 192.168.178.41
      modbus.0
      2024-10-24 15:00:22.750	warn	[DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2024-10-24 15:00:22.749	error	Client in error state.
      modbus.0
      2024-10-24 15:00:22.748	error	Request timed out.
      modbus.0
      2024-10-24 15:00:22.748	warn	Error: undefined
      modbus.0
      2024-10-24 15:00:17.735	info	Connected to slave
      modbus.0
      2024-10-24 15:00:17.574	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
        Homoran Global Moderator Administrators @FloK last edited by Homoran
        @flok sagte in Hargassner Anbindung ModBus läuft nicht:
        Error: undefined
        schalt die Instanz mal auf debug.
        Vielleicht sieht man dann was undefined sein soll.
        Ansonsten wie immer bitte mehr Infos.
        Registerbeschreibung des Geräts und alle Konfigurationen der Instanz
          FloK @Homoran last edited by
          @homoran Bin kein Experte aber denke das sind die Debug Meldungen:
          modbus.0
          2024-10-24 15:15:13.727	info	Disconnected from slave 192.168.178.41
          modbus.0
          2024-10-24 15:15:13.727	debug	Closing client on purpose.
          modbus.0
          2024-10-24 15:15:12.725	debug	Cleaning up request fifo.
          modbus.0
          2024-10-24 15:15:12.725	debug	Clearing timeout of the current request.
          modbus.0
          2024-10-24 15:15:12.725	debug	Socket closed with error
          modbus.0
          2024-10-24 15:15:12.723	warn	[DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
          modbus.0
          2024-10-24 15:15:12.722	error	Client in error state.
          modbus.0
          2024-10-24 15:15:12.722	error	Request timed out.
          modbus.0
          2024-10-24 15:15:12.721	warn	Error: undefined
          modbus.0
          2024-10-24 15:15:07.708	debug	[DevID_1/holdingRegs] Poll address 40287 - 2 registers
          modbus.0
          2024-10-24 15:15:07.708	debug	Initialization of scale factors done!
          modbus.0
          2024-10-24 15:15:07.707	debug	[DevID_1] Poll start ---------------------
          modbus.0
          2024-10-24 15:15:07.706	info	Connected to slave 192.168.178.41
          modbus.0
          2024-10-24 15:15:07.594	debug	Add holdingRegisters.1.40287_Pufferfüllgrad: {"_id":"holdingRegisters.1.40287_Pufferfüllgrad","type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":40287,"deviceId":1,"type":"floatbe","len":2,"offset":0,"factor":1,"poll":true}}
          modbus.0
          2024-10-24 15:15:07.594	debug	Initialize Objects for holdingRegs: [{"_address":"40287","deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatbe","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":40287,"id":"holdingRegisters.1.40287_Pufferfüllgrad"}]
          modbus.0
          2024-10-24 15:15:07.594	debug	Initialize Objects for inputRegs: []
          modbus.0
          2024-10-24 15:15:07.594	debug	Initialize Objects for coils: []
          modbus.0
          2024-10-24 15:15:07.593	debug	Initialize Objects for disInputs: []
          modbus.0
          2024-10-24 15:15:07.533	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
          modbus.0
          2024-10-24 15:15:07.405	debug	Plugin sentry Initialize Plugin (enabled=true)
          modbus.0
          2024-10-24 15:15:03.526	info	terminating
          modbus.0
          2024-10-24 15:15:03.018	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          modbus.0
          2024-10-24 15:15:03.017	debug	Plugin sentry destroyed
          modbus.0
          2024-10-24 15:15:03.017	info	terminating
          modbus.0
          2024-10-24 15:15:03.010	debug	Closing client on purpose.
          modbus.0
          2024-10-24 15:15:03.009	info	Got terminate signal TERMINATE_YOURSELF
          Hier noch die Einstellung der Instanz und Register. Hab aktuell zum Test nur einen Datenpunkt.
          Hier das Datenblatt von Hargassner:
          https://forum.iobroker.net/assets/uploads/files/1615657901472-bedienungsanleitung_modbus_de_v06_11058240-002.pdf
            pdf nutzt mir mobil nichts
            so muss es auch sein.
            Warum Holdingregister?
            Pufferfüllgrad ist doch bestimmt nicht beschreibbar.
            da kommt leider keine weitere Info
            EDIT
            nimm mal nur die registeradresse 287
            • wendy2702
              Die Voraussetzungen sind erfüllt?
              Und Register mit 4xxxx sind eigentlich Input Register .
              F Homoran 2 Replies Last reply Reply Quote 0
                @homoran Sorry für die späte Rückmeldung. Holding war die Info vom Hersteller die ich per Mail erhalten hatte. Habe auch mit Hargassner telefoniert aber die konnten mir auch nicht groß helfen, da denen ioBroker nicht bekannt ist:
                Habs gerade mit 287 statt 40287 versucht aber ging auch nicht.
                Kann auch gerne eine andere versuchen wenn du magst. Die Beschreibung des Herstellers in PDF hatte ich ja im letztn Post drin.
                  FloK @wendy2702 last edited by
                  @wendy2702 Mein Kessel (Pellets) läuft gerad auf V14.0HAR.p1 und hatte im Sommer scheinbar ein automatisches Update bekommen. Daher denke ich, dass die Version passen sollte.
                  Im vorangegangenen Post hatte ich ja die Beschreibung mit allen Adressen geschickt. Dort steht überall 40000er drin. Laut Hersteller alles Holdings.
                    Homoran Global Moderator Administrators @wendy2702 last edited by
                    @wendy2702 sagte in Hargassner Anbindung ModBus läuft nicht:
                    nee, input ist 30000, holding ist 40000
                    @FloK
                    Es gibt einige Hersteller, die seltsamerweise auch die RO-Werte als Holdingregister verwenden.
                    Dann muss dort Abfrage aktiviert werden.
                      @homoran 40000 steht bei allem in der Herstellerliste. Und alles sind Holding laut EMail von denen.
                        mit welcher Meldung im log?
                        dann nimm mal 287 und hake "Alias verwenden" an.
                          @homoran Schaut schon besser aus. Instanz bleibt grün aber bekomme noch keine Werte. Auch der Datenpunkt erscheint bei Objekten nicht mehr.
                          Hier das LOG:
                          modbus.0
                          2024-10-25 09:23:02.545	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2024-10-25 09:22:57.473	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2024-10-25 09:22:52.410	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2024-10-25 09:22:52.409	info	Connected to slave 192.168.178.41
                          modbus.0
                          2024-10-25 09:22:52.331	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                          modbus.0
                          2024-10-25 09:22:52.322	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatle","len":2,"offset":0,"factor":1,"poll":true}}
                          modbus.0
                          2024-10-25 09:22:52.322	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatle","len":2,"offset":0,"factor":1,"poll":true}}
                          modbus.0
                          2024-10-25 09:22:52.322	error	Invalid data holdingRegisters/0: {"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatle","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
                          modbus.0
                          2024-10-25 09:22:52.322	debug	Initialize Objects for holdingRegs: [{"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatle","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
                          modbus.0
                          2024-10-25 09:22:52.322	debug	Initialize Objects for inputRegs: []
                          modbus.0
                          2024-10-25 09:22:52.322	debug	Initialize Objects for coils: []
                          modbus.0
                          2024-10-25 09:22:52.322	debug	Initialize Objects for disInputs: []
                          modbus.0
                          2024-10-25 09:22:52.321	error	Invalid holdingRegisters address: -39714
                          modbus.0
                          2024-10-25 09:22:52.261	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                          modbus.0
                          2024-10-25 09:22:52.126	debug	Plugin sentry Initialize Plugin (enabled=true)
                          Homoran W 2 Replies Last reply Reply Quote 0
                            mit welcher Einstellung?
                              warp735 @FloK last edited by
                              @flok
                              Sieht nach falschem Daten Typ aus
                                FloK @warp735 last edited by
                                @warp735 Beschreibung sagt Float. So ist es auch hinterlegt
                                    @flok ....und im Register??
                                        @flok und was steht im log mit 287 und ohne Aias verwenden?
                                          @homoran Hier das LOG mit den gerade gezeigten Einstellungen:
                                          modbus.0
                                          2024-10-25 09:29:28.833	debug	[DevID_1] Poll start ---------------------
                                          modbus.0
                                          2024-10-25 09:29:23.761	debug	[DevID_1] Poll start ---------------------
                                          modbus.0
                                          2024-10-25 09:29:23.761	info	Connected to slave 192.168.178.41
                                          modbus.0
                                          2024-10-25 09:29:23.692	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                                          modbus.0
                                          2024-10-25 09:29:23.684	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                                          modbus.0
                                          2024-10-25 09:29:23.684	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                                          modbus.0
                                          2024-10-25 09:29:23.684	error	Invalid data holdingRegisters/0: {"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
                                          modbus.0
                                          2024-10-25 09:29:23.684	debug	Initialize Objects for holdingRegs: [{"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
                                          modbus.0
                                          2024-10-25 09:29:23.684	debug	Initialize Objects for inputRegs: []
                                          modbus.0
                                          2024-10-25 09:29:23.684	debug	Initialize Objects for coils: []
                                          modbus.0
                                          2024-10-25 09:29:23.683	debug	Initialize Objects for disInputs: []
                                          modbus.0
                                          2024-10-25 09:29:23.682	error	Invalid holdingRegisters address: -39714
                                          modbus.0
                                          2024-10-25 09:29:23.615	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                                          modbus.0
                                          2024-10-25 09:29:23.486	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          Hier das LOG ohne Alias:
                                          modbus.0
                                          2024-10-25 09:42:29.140	debug	[DevID_1] Poll start ---------------------
                                          modbus.0
                                          2024-10-25 09:42:24.078	debug	[DevID_1] Poll start ---------------------
                                          modbus.0
                                          2024-10-25 09:42:24.078	info	Connected to slave 192.168.178.41
                                          modbus.0
                                          2024-10-25 09:42:23.969	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                                          modbus.0
                                          2024-10-25 09:42:23.961	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                                          modbus.0
                                          2024-10-25 09:42:23.961	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                                          modbus.0
                                          2024-10-25 09:42:23.961	error	Invalid data holdingRegisters/0: {"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
                                          modbus.0
                                          2024-10-25 09:42:23.961	debug	Initialize Objects for holdingRegs: [{"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
                                          modbus.0
                                          2024-10-25 09:42:23.961	debug	Initialize Objects for inputRegs: []
                                          modbus.0
                                          2024-10-25 09:42:23.961	debug	Initialize Objects for coils: []
                                          modbus.0
                                          2024-10-25 09:42:23.960	debug	Initialize Objects for disInputs: []
                                          modbus.0
                                          2024-10-25 09:42:23.960	error	Invalid holdingRegisters address: -39714
                                          modbus.0
                                          2024-10-25 09:42:23.900	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                                          modbus.0
                                          2024-10-25 09:42:23.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                                            ohne Alias:
                                            immer noch?
                                            _address":-39714
                                            da ist was faul
                                            hargassner modbus
                                            3919
