    4. Hargassner Anbindung ModBus läuft nicht
      FloK @Homoran last edited by
        Homoran Global Moderator Administrators @FloK last edited by
        @flok ....und im Register??
            @flok und was steht im log mit 287 und ohne Aias verwenden?
              @homoran Hier das LOG mit den gerade gezeigten Einstellungen:
              modbus.0
              2024-10-25 09:29:28.833	debug	[DevID_1] Poll start ---------------------
              modbus.0
              2024-10-25 09:29:23.761	debug	[DevID_1] Poll start ---------------------
              modbus.0
              2024-10-25 09:29:23.761	info	Connected to slave 192.168.178.41
              modbus.0
              2024-10-25 09:29:23.692	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
              modbus.0
              2024-10-25 09:29:23.684	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
              modbus.0
              2024-10-25 09:29:23.684	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
              modbus.0
              2024-10-25 09:29:23.684	error	Invalid data holdingRegisters/0: {"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
              modbus.0
              2024-10-25 09:29:23.684	debug	Initialize Objects for holdingRegs: [{"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
              modbus.0
              2024-10-25 09:29:23.684	debug	Initialize Objects for inputRegs: []
              modbus.0
              2024-10-25 09:29:23.684	debug	Initialize Objects for coils: []
              modbus.0
              2024-10-25 09:29:23.683	debug	Initialize Objects for disInputs: []
              modbus.0
              2024-10-25 09:29:23.682	error	Invalid holdingRegisters address: -39714
              modbus.0
              2024-10-25 09:29:23.615	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
              modbus.0
              2024-10-25 09:29:23.486	debug	Plugin sentry Initialize Plugin (enabled=true)
              Hier das LOG ohne Alias:
              modbus.0
              2024-10-25 09:42:29.140	debug	[DevID_1] Poll start ---------------------
              modbus.0
              2024-10-25 09:42:24.078	debug	[DevID_1] Poll start ---------------------
              modbus.0
              2024-10-25 09:42:24.078	info	Connected to slave 192.168.178.41
              modbus.0
              2024-10-25 09:42:23.969	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
              modbus.0
              2024-10-25 09:42:23.961	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
              modbus.0
              2024-10-25 09:42:23.961	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
              modbus.0
              2024-10-25 09:42:23.961	error	Invalid data holdingRegisters/0: {"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
              modbus.0
              2024-10-25 09:42:23.961	debug	Initialize Objects for holdingRegs: [{"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
              modbus.0
              2024-10-25 09:42:23.961	debug	Initialize Objects for inputRegs: []
              modbus.0
              2024-10-25 09:42:23.961	debug	Initialize Objects for coils: []
              modbus.0
              2024-10-25 09:42:23.960	debug	Initialize Objects for disInputs: []
              modbus.0
              2024-10-25 09:42:23.960	error	Invalid holdingRegisters address: -39714
              modbus.0
              2024-10-25 09:42:23.900	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
              modbus.0
              2024-10-25 09:42:23.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                @flok sagte in Hargassner Anbindung ModBus läuft nicht:
                ohne Alias:
                immer noch?
                _address":-39714
                da ist was faul
                  da haben wir den undefined!
                  und
                  da stimmt irgendwas gar nicht
                  F Homoran 2 Replies Last reply Reply Quote 0
                    @homoran Gerade gesehen, die Holding Adresse hatte sich geändert als ich Alias entfernt hatte. Hier das log mit ohne Alias aber wieder mit Adresse 287:
                    modbus.0
                    2024-10-25 09:49:10.759	info	Disconnected from slave 192.168.178.41
                    modbus.0
                    2024-10-25 09:49:10.759	debug	Closing client on purpose.
                    modbus.0
                    2024-10-25 09:49:09.757	debug	Cleaning up request fifo.
                    modbus.0
                    2024-10-25 09:49:09.757	debug	Clearing timeout of the current request.
                    modbus.0
                    2024-10-25 09:49:09.756	debug	Socket closed with error
                    modbus.0
                    2024-10-25 09:49:09.755	warn	[DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    2024-10-25 09:49:09.754	error	Client in error state.
                    modbus.0
                    2024-10-25 09:49:09.753	error	Request timed out.
                    modbus.0
                    2024-10-25 09:49:09.753	warn	Error: undefined
                    modbus.0
                    2024-10-25 09:49:04.749	debug	[DevID_1/holdingRegs] Poll address 287 - 2 registers
                    modbus.0
                    2024-10-25 09:49:04.749	debug	Initialization of scale factors done!
                    modbus.0
                    2024-10-25 09:49:04.749	debug	[DevID_1] Poll start ---------------------
                    modbus.0
                    2024-10-25 09:49:04.748	info	Connected to slave 192.168.178.41
                    modbus.0
                    2024-10-25 09:49:04.644	debug	Add holdingRegisters.1.287_Pufferfüllgrad: {"_id":"holdingRegisters.1.287_Pufferfüllgrad","type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":287,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                    modbus.0
                    2024-10-25 09:49:04.643	debug	Initialize Objects for holdingRegs: [{"_address":"287","deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":287,"id":"holdingRegisters.1.287_Pufferfüllgrad"}]
                    modbus.0
                    2024-10-25 09:49:04.643	debug	Initialize Objects for inputRegs: []
                    modbus.0
                    2024-10-25 09:49:04.643	debug	Initialize Objects for coils: []
                    modbus.0
                    2024-10-25 09:49:04.643	debug	Initialize Objects for disInputs: []
                    modbus.0
                    2024-10-25 09:49:04.583	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                    modbus.0
                    2024-10-25 09:49:04.450	debug	Plugin sentry Initialize Plugin (enabled=true)
                      Das ist ja Sinn der Sache!
                      ich wollte sehen mit welchem Offset das passiert (40000 oder 40001)
                        Homoran Global Moderator Administrators @Homoran last edited by
                        @homoran sagte in Hargassner Anbindung ModBus läuft nicht:
                        Was ist jetzt damit?
                        welche ID hast du?
                          @homoran Geräte ID habe ich 1 eingestellt. Slave ID steht auch auf 1
                            @flok Liest du auch die Meldungen?
                            Da steht
                                                    2024-10-25 09:22:52.331	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                            und welche ID hat das Gerät?
                            Lass dir doch nicht alles aus der Nase ziehen!
                              @homoran Sorry, bin kein Profi. Verstehe ich nicht. Was meins damit?
                                ich auch nicht!
                                Verstehe ich nicht.
                                was?
                                solche Halbsätze nutzen niemandem.
                                Was meins damit?
                                womit?
                                Dein Gerät hat eine ID
                                welche ist das?
                                  @homoran Welches Gerät meinst du denn? Den Heizkessel? Wo finde ich die ID? Kenne nur die IP Adresse davon.
                                    wenn es das ist was du abfragst, ja!
                                    keine Ahnung.
                                    müsste bei der Modbuskarte in der Anleitung stehen.
                                      @homoran Es geht um die Kommunikation mit einem Hargassner nano PK15 Heizkessel. Es gibt keine Modbus-Hardware dazu. Es wurde lediglich eine SD Karte gesteckt, was den Kessel dann Modbus-fähig macht. Daher wüsste ich nicht, wie oder wo man die ID nachschauen kann.
                                      Wie sieht so eine ID aus? Hast du ein Beispiel?
                                        Homoran Global Moderator Administrators @FloK last edited by Homoran
                                        1-255
                                        andererseits wird laut log ein String erwartet.
                                        Daher weiss ichbauch nicht was genau gemeint sein könnte
                                        und da steckt das LAN Kabel dran?
                                          @homoran Der Heizkessel ist über ein Web Interface mit dem LAN verbunden. Das ist auch ohne ModBus so.
                                            und gibt's da Einstellungen zum Modbus?
                                            hargassner modbus
                                            3919
