    4. Hargassner Anbindung ModBus läuft nicht
      FloK @Homoran last edited by
      @homoran Gerade gesehen, die Holding Adresse hatte sich geändert als ich Alias entfernt hatte. Hier das log mit ohne Alias aber wieder mit Adresse 287:
      modbus.0
      2024-10-25 09:49:10.759	info	Disconnected from slave 192.168.178.41
      modbus.0
      2024-10-25 09:49:10.759	debug	Closing client on purpose.
      modbus.0
      2024-10-25 09:49:09.757	debug	Cleaning up request fifo.
      modbus.0
      2024-10-25 09:49:09.757	debug	Clearing timeout of the current request.
      modbus.0
      2024-10-25 09:49:09.756	debug	Socket closed with error
      modbus.0
      2024-10-25 09:49:09.755	warn	[DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2024-10-25 09:49:09.754	error	Client in error state.
      modbus.0
      2024-10-25 09:49:09.753	error	Request timed out.
      modbus.0
      2024-10-25 09:49:09.753	warn	Error: undefined
      modbus.0
      2024-10-25 09:49:04.749	debug	[DevID_1/holdingRegs] Poll address 287 - 2 registers
      modbus.0
      2024-10-25 09:49:04.749	debug	Initialization of scale factors done!
      modbus.0
      2024-10-25 09:49:04.749	debug	[DevID_1] Poll start ---------------------
      modbus.0
      2024-10-25 09:49:04.748	info	Connected to slave 192.168.178.41
      modbus.0
      2024-10-25 09:49:04.644	debug	Add holdingRegisters.1.287_Pufferfüllgrad: {"_id":"holdingRegisters.1.287_Pufferfüllgrad","type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":287,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
      modbus.0
      2024-10-25 09:49:04.643	debug	Initialize Objects for holdingRegs: [{"_address":"287","deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":287,"id":"holdingRegisters.1.287_Pufferfüllgrad"}]
      modbus.0
      2024-10-25 09:49:04.643	debug	Initialize Objects for inputRegs: []
      modbus.0
      2024-10-25 09:49:04.643	debug	Initialize Objects for coils: []
      modbus.0
      2024-10-25 09:49:04.643	debug	Initialize Objects for disInputs: []
      modbus.0
      2024-10-25 09:49:04.583	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
      modbus.0
      2024-10-25 09:49:04.450	debug	Plugin sentry Initialize Plugin (enabled=true)
        Homoran Global Moderator Administrators @FloK last edited by
        @flok sagte in Hargassner Anbindung ModBus läuft nicht:
        Das ist ja Sinn der Sache!
        ich wollte sehen mit welchem Offset das passiert (40000 oder 40001)
          Homoran Global Moderator Administrators @Homoran last edited by
          @homoran sagte in Hargassner Anbindung ModBus läuft nicht:
          Was ist jetzt damit?
          welche ID hast du?
            @homoran Geräte ID habe ich 1 eingestellt. Slave ID steht auch auf 1
              @flok Liest du auch die Meldungen?
              Da steht
                                      2024-10-25 09:22:52.331	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
              und welche ID hat das Gerät?
              Lass dir doch nicht alles aus der Nase ziehen!
                @homoran Sorry, bin kein Profi. Verstehe ich nicht. Was meins damit?
                  ich auch nicht!
                  Verstehe ich nicht.
                  was?
                  solche Halbsätze nutzen niemandem.
                  Was meins damit?
                  womit?
                  Dein Gerät hat eine ID
                  welche ist das?
                    @homoran Welches Gerät meinst du denn? Den Heizkessel? Wo finde ich die ID? Kenne nur die IP Adresse davon.
                      wenn es das ist was du abfragst, ja!
                      keine Ahnung.
                      müsste bei der Modbuskarte in der Anleitung stehen.
                        @homoran Es geht um die Kommunikation mit einem Hargassner nano PK15 Heizkessel. Es gibt keine Modbus-Hardware dazu. Es wurde lediglich eine SD Karte gesteckt, was den Kessel dann Modbus-fähig macht. Daher wüsste ich nicht, wie oder wo man die ID nachschauen kann.
                        Wie sieht so eine ID aus? Hast du ein Beispiel?
                          Homoran Global Moderator Administrators @FloK last edited by Homoran
                          1-255
                          andererseits wird laut log ein String erwartet.
                          Daher weiss ichbauch nicht was genau gemeint sein könnte
                          und da steckt das LAN Kabel dran?
                            @homoran Der Heizkessel ist über ein Web Interface mit dem LAN verbunden. Das ist auch ohne ModBus so.
                              und gibt's da Einstellungen zum Modbus?
                                @homoran Da kannst du den Modbus nur ein- und ausschalten sobald die SD Karte gesteckt ist. Mehr gibt es nicht
                                  Mehr gibt es nicht
                                  auch keine INFORMATIONEN?
                                  Gibt es da auch kein erweitertes Menü?
                                  ggf. für den Installateur?
                                  Aber nichts verstellen wenn du dich da nicht auskennst!
                                    warp735 last edited by warp735
                                    Das Informations PDF ist doch in Beitrag 5 verlinkt.
                                      @homoran Nur das PDF vom Hersteller (Link weiter oben)
                                        Homoran Global Moderator Administrators @warp735 last edited by
                                        @warp735 sagte in Hargassner Anbindung ModBus läuft nicht:
                                        isch 'abe kein pdf reader auf dem Handy
                                          @homoran Habs auch über den Browser geöffnet. Geht das am Handy nicht auf? Liegt auch in nem Forum.
                                          https://forum.iobroker.net/assets/uploads/files/1615657901472-bedienungsanleitung_modbus_de_v06_11058240-002.pdf
                                            Seit wann geht das denn?
                                            Hat früher immer nur unter Downloads gespeichert, da nutzte es mir nichts.
                                            @FloK
                                            die Adresse für die ersten Register finde ich nicht, bei späteren Tabellen scheint die notwendige Adresse drüber zu stehen
                                            In den Grundeinstellungen hast du ja auch bereits "mehrere IDs verwenden" angehakt
                                            hargassner modbus
                                            3919
