    4. EMS-ESP mit ipinside funktioniert nicht mehr?
      felixrhoese last edited by
      @mcm1957
      Danke für den Hinweis!
      Adapter: EMS-ESP 4.8.0
      Admin: 7.0.23
      Js-controller: 8.3.1
      Node: 18.17.1
      O/S: Linux auf Raspberry pi3
      Log des Adapters mit Level DEBUG:
      2024-09-14 09:31:51.979 - info: host.iobroker-pi "system.adapter.ems-esp.0" enabled
      2024-09-14 09:31:52.135 - info: host.iobroker-pi instance system.adapter.ems-esp.0 started with pid 19751
      2024-09-14 09:31:56.436 - info: ems-esp.0 (19751) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v18.17.1, js-controller: 5.0.19
      2024-09-14 09:31:56.939 - info: ems-esp.0 (19751) InfluxDB 1.x - Retention: 730 days --- Adapterversion: 4.0.2
      2024-09-14 09:32:00.037 - info: javascript.0 (13044) script.js.common.10_Heizung.Temperatur_Mean24h: 0
      2024-09-14 09:32:06.462 - info: host.iobroker-pi stopInstance system.adapter.ems-esp.0 (force=false, process=true)
      2024-09-14 09:32:06.473 - info: ems-esp.0 (19751) Got terminate signal TERMINATE_YOURSELF
      2024-09-14 09:32:06.478 - info: ems-esp.0 (19751) terminating
      2024-09-14 09:32:06.481 - info: ems-esp.0 (19751) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-09-14 09:32:06.517 - info: host.iobroker-pi stopInstance system.adapter.ems-esp.0 send kill signal
      2024-09-14 09:32:07.120 - info: host.iobroker-pi instance system.adapter.ems-esp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-09-14 09:32:10.138 - info: host.iobroker-pi instance system.adapter.ems-esp.0 started with pid 19766
      2024-09-14 09:32:13.802 - info: ems-esp.0 (19766) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v18.17.1, js-controller: 5.0.19
      2024-09-14 09:32:14.187 - info: ems-esp.0 (19766) InfluxDB 1.x - Retention: 730 days --- Adapterversion: 4.0.2
      2024-09-14 09:32:20.329 - info: javascript.0 (13044) script.js.common.10_Heizung.Temperature_Mean3h: NaN
      2024-09-14 09:32:34.908 - error: ems-esp.0 (19766) error reading KM200 gateway (wrong ip address) - stop KM200 read: http://TK-850-JH3E-NET
      Hinweis: Die IP Adresse bzw. der Hostname sind definitiv korrekt. In der MyBuderus App kann ich die Live Daten auch alle sehen.
      Output von iob diag IN DER LANGFASSUNG
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: iobroker-pi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7+
            Architecture: arm
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       09:43:31 up 1 day, 13:28,  1 user,  load average: 1.67, 0.84, 0.52
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-09-14 09:43:31 CEST
                 Universal time: Sat 2024-09-14 07:43:31 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:           972M        729M         52M         36M        190M        187M
      Swap:           99M         99M        0.0K
      Total:         1.1G        829M         52M
      Active iob-Instances:   11
                972 M total memory
                729 M used memory
                326 M active memory
                537 M inactive memory
                 52 M free memory
                 28 M buffer memory
                162 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 09:43:31 up 1 day, 13:28,  1 user,  load average: 1.67, 0.84, 0.52
      Tasks: 132 total,   1 running, 131 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    972.8 total,     51.9 free,    729.4 used,    191.4 buff/cache
      MiB Swap:    100.0 total,      0.2 free,     99.8 used.    187.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       57G  5.7G   49G  11% /
      devtmpfs       devtmpfs  454M     0  454M   0% /dev
      tmpfs          tmpfs     487M     0  487M   0% /dev/shm
      tmpfs          tmpfs     487M   50M  438M  11% /run
      tmpfs          tmpfs     487M     0  487M   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      247M   49M  198M  20% /boot
      tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
      [Thu Sep 12 20:14:39 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=d677b88f-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Sep 12 20:14:42 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Thu Sep 12 20:14:42 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Thu Sep 12 20:14:44 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Thu Sep 12 20:14:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Sep 12 20:14:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Sep 12 20:14:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [Fri Sep 13 20:17:02 2024] [<802b0ee8>] (filemap_fault) from [<8042d260>] (ext4_filemap_fault+0x38/0x4c)
      [Fri Sep 13 20:17:02 2024] [<8042d228>] (ext4_filemap_fault) from [<802e8900>] (__do_fault+0x48/0x14c)
      Show mounted filesystems:
      TARGET                                SOURCE         FSTYPE     OPTIONS
      /                                     /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=464768k,nr_inodes=116192,mode=755
      | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
      |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | `-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
      | `-/sys/kernel/config                configfs       configfs   rw,relatime
      |-/proc                               proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=99608k,mode=700,uid=1000,gid=1000
      `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.7G    /var/
      834M    /var/lib
      739M    /var/lib/influxdb
      703M    /var/lib/influxdb/data
      656M    /var/lib/influxdb/data/iobroker/autogen
      Archived and active journals take up 48.6M in the file system.
      /opt/iobroker/backups:
      31M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      272M    /opt/iobroker/iobroker-data/
      206M    /opt/iobroker/iobroker-data/files
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      nodejs:                 N/A
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin:          7.0.23
      javascript:     8.3.1
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled, compact disabled
      + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled, compact disabled
      + system.adapter.history.0                : history               : iobroker-pi                              -  enabled, compact disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, compact disabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled, compact disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker-pi                              -  enabled, compact disabled, port: 1885, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker-pi                              -  enabled, compact disabled
      + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iobroker-pi                              - disabled, compact disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Ich sehe selbst gerade, dass es wohl auch ein Problem mit dem NodeJS System gibt. Ich werde versuchen das zu fixen, auch wenn ich keine Ahnung habe.
      Danke für jede Hilfe!
      VG
      Felix
      F Thomas Braun 2 Replies Last reply Reply Quote 0
        felixrhoese @felixrhoese last edited by
        @felixrhoese Ich habe das mit dem NodeJS nun auf V18 gefixt. leider ohne Erfolg.
        Jemand eine Idee?
          Thomas Braun Most Active @felixrhoese last edited by
          @felixrhoese sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
          (buster)
          Muss komplett von Grund auf NEUINSTALLIERT werden.
          Diesmal dann in der 64Bit-Lite-Version.
          Und
            felixrhoese @Thomas Braun last edited by
            Ich habe die Neuinstallation durchgeführt. Leider ohne Erfolg.
            Hier die Diag:
                                    v.2024-05-22
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.6.47+rpt-rpi-v8
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1000
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/nodejs         v20.17.0
            /usr/bin/node           v20.17.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.3
            Recommended versions are nodejs 20.17.0 and npm 10.8.2
            MEMORY:
            Mem:            951M        506M        101M         12K        411M        445M
            Swap:           209M        124M         85M
            Total:          1.2G        630M        186M
            Active iob-Instances:   3
            Upgrade policy: none
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.0.23
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            Objects:                203
            States:                 109
            Size of iob-Database:
            20M     /opt/iobroker/iobroker-data/objects.jsonl
            1.9M    /opt/iobroker/iobroker-data/states.jsonl
            Im Log sieht es so aus:
            2024-09-15 17:45:20.885 - info: host.raspberrypi instance system.adapter.ems-esp.0 in version "4.8.0" started with pid 13020
            2024-09-15 17:45:26.224 - info: ems-esp.0 (13020) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v20.17.0, js-controller: 6.0.11
            2024-09-15 17:45:26.498 - info: ems-esp.0 (13020) KM200 no database instance selected for recordings
            2024-09-15 17:45:26.843 - info: discovery.0 (13014) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
            2024-09-15 17:45:27.333 - info: javascript.0 (13007) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
            2024-09-15 17:45:27.866 - info: javascript.0 (13007) requesting all states
            2024-09-15 17:45:27.869 - info: javascript.0 (13007) requesting all objects
            2024-09-15 17:45:28.840 - warn: javascript.0 (13007) Configured latitude is not a number - check (instance/system) configuration
            2024-09-15 17:45:28.843 - warn: javascript.0 (13007) Configured longitude is not a number - check (instance/system) configuration
            2024-09-15 17:45:28.845 - info: javascript.0 (13007) received all objects
            2024-09-15 17:45:28.858 - info: javascript.0 (13007) received all states
            2024-09-15 17:45:47.131 - error: ems-esp.0 (13020) error reading KM200 gateway (wrong ip address) - stop KM200 read: http://192.168.178.84
            Hat jemand noch eine Idee?
            Vielen Dank und viele Grüße Felix
            DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @felixrhoese last edited by
              Langfassung von iobdiag zeigen und ein Tip: mit einem RPI3 mit 1GB Ram kommst Du nicht weit !
                (wrong ip address)
                Welche IP Addresse ist denn die richtige?
                  Die IP Adresse ist die 192.168.178.84.
                  Ich habe zwischenzeitlich auch Testweise eine Instanz vom Home Assistanz hochgezogen. Dort gibt des die Bosch Thermostat Integration, die nutzt direkt die Cloud. Da geht alles problemlos. Nur ist der Home Assistant nicht so komfortabel wie der IO Broker. Ich fürchte, die alte Integration über das KM200 Modul direkt, ohne die Nutzung der Cloud geht einfach nicht mehr, wegen FW Update seitens Buderus.
                  Probiere aber gerne weiter. Ansonsten werde ich mir eine Instanz vom Home Assistant auf dem kleinen Pi laufen lassen und mir für den IO Broker einen neuen holen. Danke für eure Mühen. VG Felix
                    Problem gelöst. Offenbar wurde das Format der Passworteingabe geändert. Es dürfen nun keine Bindestriche mehr genutzt werden. In der Adapter Ansicht ist auch noch das Ausrufezeichen zu sehen. Trotzdem ist in der Objektansicht alles aktuell. Sehr seltsam. Danke an alle, die mitgeholfen haben! VG Felix
                      luxusl last edited by
                      @felixrhoese
                      Welche Änderung musstest du im iobroker vornehmen, dass der Adapter wieder funktioniert?
                        Homoran Global Moderator Administrators @luxusl last edited by
                        @luxusl sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
                        @felixrhoese
                          @Homoran
                          Das habe ich gelesen, nur welche Konsequenz hat dies schlussendlich? einfach die Bindestriche löschen geht nicht...
                            Natürlich nicht!
                            Du musst das Passwort ändern
                              luxusl @Homoran last edited by
                              @homoran ich habe eine Buderus, da wüsste ich nicht wie ich das Gateway-Passwort im Gerät ändern kann. Das Passwort ist mit einem Aufkleber sogar außen aufgebracht? Mit der App Buderus MyDevice finde ich keine Änderungsmöglichkeit.
                                @luxusl dann kann ich dir nicht mehr helfen.
                                Vielleicht weiss @felixrhoese wie
                                932
