    3. Einsteigerfragen
    4. Installation
    5. Passwort Iobroker über Mac-Terminal anders?
    • OliverIO
      OliverIO @Thomas Braun last edited by
      ok wenn man ,mag.
      Aber dieser Zustand ist blöd. Da weiß man ja gar nicht was sonst noch alles gemacht wurde.
      Dann lieber Grundzustand erstmal herstellen
      • U
        uliauer44 last edited by
        @thomas-braun said in Passwort Iobroker über Mac-Terminal anders?:
        iob diag
        Here it comes....
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.61-v8+
              Architecture: arm64
        OS is similar to:
        Model		: Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         14:55:01 up 1 day, 22:27,  3 users,  load average: 0.58, 0.62, 0.34
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2024-10-25 14:55:01 CEST
                   Universal time: Fri 2024-10-25 12:55:01 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
        iobroker
        HOME=/home/iobroker
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Run 'iobroker fix' or use the system tools to create a user.
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            1.8G        1.4G        236M         34M        216M        349M
        Swap:            99M         99M        0.0K
        Total:          1.9G        1.5G        236M
        Active iob-Instances: 	20
                 1849 M total memory
                 1396 M used memory
                  168 M active memory
                 1283 M inactive memory
                  236 M free memory
                   27 M buffer memory
                  189 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        top - 14:55:02 up 1 day, 22:27,  3 users,  load average: 0.58, 0.62, 0.34
        Tasks: 209 total,   1 running, 208 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 13.9 us,  6.9 sy,  0.0 ni, 79.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   1849.2 total,    235.6 free,   1395.8 used,    217.8 buff/cache
        MiB Swap:    100.0 total,      0.0 free,    100.0 used.    348.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        [sudo] password for iobroker:
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       15G  7.1G  6.5G  53% /
        devtmpfs       devtmpfs  763M     0  763M   0% /dev
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        tmpfs          tmpfs     370M  1.2M  369M   1% /run
        /dev/mmcblk0p1 vfat      255M   34M  222M  13% /boot
        tmpfs          tmpfs     185M   20K  185M   1% /run/user/1000
        [Wed Oct 23 16:27:32 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:26:FE:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bbc14122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Wed Oct 23 16:27:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Oct 23 16:27:35 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.9G	/var/
        1.5G	/var/log/journal/60dd197ce1dd470bacf92c92630f1c5a
        1.5G	/var/log
        184M	/var/lib
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        279M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        378M	/opt/iobroker/iobroker-data/
        298M	/opt/iobroker/iobroker-data/files
        99M	/opt/iobroker/iobroker-data/files/vis-2-beta
        52M	/opt/iobroker/iobroker-data/files/javascript.admin
        47M	/opt/iobroker/iobroker-data/backup-objects
        27M	/opt/iobroker/iobroker-data/objects.jsonl
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        9.7M	/opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
        8.5M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        8.0M	/opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        nodejs: 		N/A
        /usr/bin/node 		v16.17.0
        /usr/bin/npm 		8.15.0
        /usr/bin/npx 		8.15.0
        /usr/bin/corepack 	0.12.1
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 16.17.0-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
             16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         *** 16.17.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 165159)
        Core adapters versions
        js-controller: 	4.0.23
        admin: 		6.13.16
        javascript: 	7.1.4
        nodejs modules from github: 	2
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 - disabled, port: 0
          system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 - disabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 6.13.16 [Updatable]
        Adapter    "backitup"     : 3.0.25   , installed 2.11.0 [Updatable]
        Adapter    "denon"        : 1.15.12  , installed 1.15.5 [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.9  [Updatable]
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.17.0 [Updatable]
        Adapter    "hue"          : 3.12.0   , installed 3.10.1 [Updatable]
        Adapter    "ical"         : 1.15.0   , installed 1.13.3 [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
        Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
        Adapter    "openweathermap": 1.1.2   , installed 1.0.4  [Updatable]
        Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
        Adapter    "samsung"      : 0.6.1    , installed 0.5.11 [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.5.5  [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 0.3.11 [Updatable]
        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.0.3 [Updatable]
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.3.25 [Updatable]
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
        Objects and States
        Objects: 	6827
        States: 	5615
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists...
        Pending Updates: 325
        *** Listening Ports ***
        tcp        0      0 192.168.178.22:9292     0.0.0.0:*               LISTEN      1000       45177      6369/io.hm-rpc.1
        tcp        0      0 192.168.178.22:2010     0.0.0.0:*               LISTEN      1000       45202      6386/io.hm-rpc.2
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       43296      6175/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       42823      6175/iobroker.js-co
        tcp        0      0 192.168.178.22:2001     0.0.0.0:*               LISTEN      1000       41943      6322/io.hm-rpc.0
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          866244     82966/cupsd
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       46259      6524/io.jarvis.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11603      571/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       40887      6193/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46229      6479/io.web.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       45400      6535/io.terminal.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          866243     82966/cupsd
        tcp6       0      0 :::34957                :::*                    LISTEN      1000       43687      6494/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11605      571/sshd: /usr/sbin
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          868513     82968/cups-browsed
        udp        0      0 0.0.0.0:52180           0.0.0.0:*                           108        14204      340/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      468/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14202      340/avahi-daemon: r
        udp6       0      0 :::44790                :::*                                108        14205      340/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14203      340/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13290      468/dhcpcd
        2024-10-25 14:55:48.028  - error: hue.0 (6272) Could not poll all: unauthorized user
        2024-10-25 14:55:48.559  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:55:48.710  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:55:48.711  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:55:53.984  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:55:54.197  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:55:54.198  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:55:58.048  - error: hue.0 (6272) Could not poll all: unauthorized user
        2024-10-25 14:55:59.487  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:55:59.647  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:55:59.647  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:56:04.949  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:56:05.098  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:56:05.098  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:56:08.066  - error: hue.0 (6272) Could not poll all: unauthorized user
        2024-10-25 14:56:10.395  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:56:10.552  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:56:10.553  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:56:15.848  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:56:15.996  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:56:15.996  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        2024-10-25 14:56:18.081  - error: hue.0 (6272) Could not poll all: unauthorized user
        2024-10-25 14:56:21.282  - info: hue.0 (6272) Push connection error: Forbidden
        2024-10-25 14:56:21.441  - error: hue.0 (6272) unauthorized user
        2024-10-25 14:56:21.448  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
        iob diag has finished.
        Press any key for a summary
        Hier noch die anschließende Summary:
        Copy text starting here:
        			v.2024-10-19
                 Icon name: computer
              Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		64 bit
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1000
        Boot Target: 		graphical.target
        Pending OS-Updates: 	325
        Pending iob updates: 	22
        Nodejs-Installation:
        nodejs: 		N/A
        /usr/bin/npm 		8.15.0
        /usr/bin/npx 		8.15.0
        Recommended versions are nodejs 18.20.4 and npm 10.7.0
        Wrong installation path detected. This needs to be fixed.
        Please execute
        iob nodejs-update
        to fix these errors.
        MEMORY:
        Mem:            1.8G        1.4G        135M         35M        300M        332M
        Swap:            99M         99M          0B
        Total:          1.9G        1.5G        135M
        ioBroker Core: 		js-controller 		4.0.23
        			admin 			6.13.16
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		6827
        States: 		5615
        Size of iob-Database:
        8.1M	/opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        iobroker@iobroker:~ $
        @Meister-Mopper : Sehr hilfreicher Kommentar....weil ich auch andere Dinge im Leben zu tun habe....
          Thomas Braun Most Active last edited by
          @uliauer44
          Bring das Ding auf Stand...
          iob nodejs-update
          iob stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Und leg dir einen User an.
          • U
            uliauer44 @Thomas Braun last edited by
            Ja, den Hinweis mit dem NodeJS habe ich auch gesehen - Update läuft gerade...
            • U
              uliauer44 @uliauer44 last edited by uliauer44
              @uliauer44
              So. NodeJS Update hat geklappt - auch die anderen Update/Upgrade Befehle habe ich ausgeführt.
              Danke schonmal, Thomas, für Deine Hilfe!
              Leider immer noch kein aktualisierter JS-Controller im Host sichtbar.
              Wie meinst Du das genau mit dem neuen User? Und zum Verständnis: Was ist das Problem mit dem bisherigen?
              (Und ja, ich sollte ja nach Anleitung damals einen neuen User anlegen, der "pi" offensichtlich ersetzt hat...)
              Soll ich das mit dem gefixten NodeJS einfach nochmal probieren mit der JS-Controller Update-Routine?
              Oder ist die eh identisch mit den Upgrade-Zeilen, die Du mir geschrieben hast?
                Thomas Braun Most Active @uliauer44 last edited by
                @uliauer44
                Stand nun?
                Aktuellen Lauf von
                iob diag
                zeigen. Zusammenfassung reicht.
                • U
                  @thomas-braun ```
                  			v.2024-10-19
                           Icon name: computer
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		64 bit
                  User-ID: 		1000
                  Pending OS-Updates: 	0
                  /usr/bin/nodejs 	v20.18.0
                  /usr/bin/node 		v20.18.0
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  /usr/bin/corepack 	0.29.3
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            1.8G        1.1G        127M         37M        577M        600M
                  Swap:            99M        5.0M         94M
                  Total:          1.9G        1.1G        222M
                  			admin 			6.13.16
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		6827
                  States: 		5617
                  1.9M	/opt/iobroker/iobroker-data/states.jsonl
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                    @uliauer44
                    iob update
                    iob upgrade all -y
                    iob stop
                    iob upgrade self
                    iob start
                    • U
                      SUPER. Herzlichen Dank, Thomas - scheint soweit nun alles geklappt zu haben.
                      Bei der ersten Runde von "iob upgrade all -y" hatte er noch einige Fehlermeldungen bezüglich der zu alten Version von JS-controller,
                      nach "upgrade self" hat er diesen aber nun auch brav auf 6.0.11 aktualisiert....!
                      Sollte ich nun trotzdem noch eine neuen User anlegen? Oder ist das jetzt obsolet?
                      Hier nochmal die aktuellste Summary von "iob diag":
                      			v.2024-10-19
                               Icon name: computer
                            Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		64 bit
                      User-ID: 		1000
                      Pending iob updates: 	0
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      Recommended versions are nodejs 20.18.0 and npm 10.8.2
                      MEMORY:
                      Mem:            1.8G        1.2G         97M         38M        507M        498M
                      Swap:            99M         99M        0.0K
                      Total:          1.9G        1.3G         97M
                      Upgrade policy: none
                      ioBroker Core: 		js-controller 		6.0.11
                      			admin 			7.1.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		6881
                      States: 		5625
                      29M	/opt/iobroker/iobroker-data/objects.jsonl
                      4.5M	/opt/iobroker/iobroker-data/states.jsonl
                      Was ja immer noch geblieben ist, ist die bullseye/bookworm Meldung.....Was mach ich damit?
                        Homoran Global Moderator Administrators @uliauer44 last edited by Homoran
                        @uliauer44 sagte in Passwort Iobroker über Mac-Terminal anders?:
                        Was mach ich damit?
                        @meister-mopper sagte in Passwort Iobroker über Mac-Terminal anders?:
                        Mach den ganzen Bums neu
                        Das kann man nicht updaten.
                        Bookworm ist intern deutlich verändert worden
                        Da geht nur eine Neuinstallation mit anschließendem Einspielen des Backups
                          Nein, das ist nicht obsolet.
                          Denn im Zuge von
                          wirst du von dem jetzigen Stand ein Backup anlegen und dann damit in ein frisch, von Grund auf neuinstalliertes 'Bookworm' umziehen. Dann auch gleich mit individuellem username.
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          • U
                            uliauer44 @Thomas Braun last edited by uliauer44
                            Okay.
                            Hab jetzt beim Backup machen ein paar kleine Fehler bekommen...
                            16:13:10.980
                            WARN
                            jarvis
                            settings "theme" not found
                            16:13:13.822
                            WARN
                            nodered
                            no node-red database found!!
                            Ist da was Wichtiges dabei, das ich vor dem Wechsel auf bookworm noch fixen sollte?
                              Kann ich dir nicht sagen, verwende weder node-red noch jarvis.
                              • U
                                Okay, dann ist es ja jedenfalls nix existenziell erforderliches 😉
                                Sorry für die Noob-Frage: Wie lege ich jetzt den neuen User an?
                                Den Pi-Imager habe ich schon auf dem Mac am Start...
                                Ah....sehe jetzt gerade erst in Deiner Anleitung, dass dort der user eingerichtet wird....also geh ich das mal komplett durch....
                                  Direkt im Imager macht man das. Nenn den uli oder sonst wie, aber NICHT iobroker.
                                  • U
                                    Okay. Soweit in der Spur (Das "aktualisieren" nach dem Install läuft jetzt schon sehr lange, aber das ist vermutlich in Ordnung, nur langsam)
                                    Ich habe aber noch ein anderes Problem:
                                    Ich kann mich aktuell (das habe ich VOR dem gerade laufenden Aktualisieren festgestellt) nur über die WLAN IP-Adresse anmelden.
                                    Über die LAN-Verbindung bekomme ich folgende Meldung:
                                    ssh uli@192.168.178.22
                                    @    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
                                    IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
                                    Someone could be eavesdropping on you right now (man-in-the-middle attack)!
                                    It is also possible that a host key has just been changed.
                                    The fingerprint for the ED25519 key sent by the remote host is
                                    SHA256:/5CJrlsdDnAGxI3m86IinQQWAnl8aPr/ZuQYdpGCx7k.
                                    Please contact your system administrator.
                                    Add correct host key in /Users/ulimaxbook/.ssh/known_hosts to get rid of this message.
                                    Offending ED25519 key in /Users/ulimaxbook/.ssh/known_hosts:5
                                    Host key for 192.168.178.22 has changed and you have requested strict checking.
                                    Host key verification failed.
                                    Hinweis: Beide IP-Adressen sind bei mir in der Fritzbox fest zugewiesen (22 für LAN, 180 für WLAN)
                                      Die genannte Datei muss angepasst werden. Wenn du nur den Eintrag löschst wird bei erneuter Verbingsaufnahme der Schlüssel neugeschrieben.
                                      U 2 Replies Last reply Reply Quote 0
                                      • U
                                        Wie mache ich das?
                                          Wie mache ich das?
                                          Mit einem Editor?
                                          • U
                                            Ja, aber was? Die Datei besteht hieraus....
                                            iobroker.local ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIB6C+A2ymodV55rvTFDxK3JjffFTd3EDdpu8NN6VakAo
                                            iobroker.local ssh-rsa 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
                                            iobroker.local ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBDTtZUIPIaqODccZayvOy0e4KmigwO9OTDZgyZhNlywVbT9SZI8Gt7rHgbvwk6mJkcb6Ipw2Wy98G4G6vEawUV0=
                                            sftp.hidrive.strato.com ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIKj++KINkipb3Uh30rB+BpR0TArchTWDoetSEKpymo9o
                                            192.168.178.22 ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIB6C+A2ymodV55rvTFDxK3JjffFTd3EDdpu8NN6VakAo
                                            192.168.178.222 ssh-rsa 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
                                            192.168.178.180 ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIHqO6j6Mlm1GWCwtVXM4BcpetfY/i0JK0d3Ot9fkVI+8
                                            192.168.178.180 ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABgQCjBGIWZayXiB6ow4INofNriYhxMIoso8ap5Xq+8vW4eF0flR7HdcoKD/1kLZV2o3/TAejemcMiCwR1gHrN8aHBeBA3OWHqzc6H/nZMolAlUjJuSk6ql+XtUQ7+1d5IkFym9/aWUPLOugkD2zNj98Ld8I5s7MzgbdY5idMUp3Mi6askoBkhgvtIv7ziruSnvVx1h/AQE2t/uCeQ/7tGehA+KQChhbuAeEEYKmyIb8svehPgdxapYXMWGrUXkUJ3hOBKHqp9ybFomLOCu/
                                            133
                                            10066
