    3. Einsteigerfragen
    4. Installation
    5. vw-connect Adapter nicht mehr verfügbar
      Thomas Braun Most Active @wibear last edited by
      @wibear
      Ist hier verfügbar. Sowohl über npm/beta wie auch github.
      Dein Setup sieht wie aus?
      iob diag
      mal anschauen.
      W 2 Replies Last reply Reply Quote 0
        wibear @Thomas Braun last edited by
        Soll ich diese Processe stoppen?
        *** iob diag is starting up, please wait ***
        iob diag needs to be updated. Please execute 'iobroker fix' first.
        wibear@iobroker-pi:~ $
        wibear@iobroker-pi:~ $ iobroker fix
        library: loaded
        Library version=2024-10-22
        ioBroker or some processes are still running:
        1634 iobroker.js-con
        1870 io.admin.0
        1909 io.history.0
        1939 io.influxdb.0
        2020 io.javascript.0
        2038 io.whatsapp-cmb
        2081 io.alexa2.0
        2132 io.backitup.0
        2405 io.hm-rega.0
        2422 io.hm-rpc.0
        2447 io.hm-rpc.1
        2471 io.hm-rpc.2
        2488 io.mqtt.0
        2505 io.rpi2.0
        2527 io.shelly.0
        2569 io.tr-064.0
        2610 io.discovery.0
        2644 io.fb-checkpres
        2722 io.fritzdect.0
        2876 io.simple-api.0
        3033 io.ems-esp.0
        3285 io.web.0
        9250 io.device-remin
        Please stop them first and try again!
          @wibear
          Ja, der kann nur ohne laufende iob-Prozesse funktionieren.
          iob stop
          iob fix
            Ausgeführt und IOB gestartet
            Welcome to the ioBroker installation fixer!
              Script version: 2024-10-22
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
            Hit:4 https://packages.grafana.com/oss/deb stable InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:6 https://repos.influxdata.com/debian bullseye InRelease
            Reading package lists... Done
            E: Unable to locate package polkitd
            Installed polkitd
              Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
            This system does not support setting default permissions.
            Do not use npm to manually install adapters unless you know what you are doing!
              Check and cleanup npm temporary directories (3/5)
            Done.
              Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
              Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
              @wibear
              Dann dürfte ja jetzt auch
              iob diag
              laufen.
                @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
                leider nicht:
                  @wibear
                  sudo apt update && sudo apt install distro-info
                  Wobei das eigentlich auch der Fixer hätte fixen sollen...
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
                    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                    Building dependency tree... Done
                    All packages are up to date.
                    distro-info is already the newest version (1.0+deb11u1).
                    distro-info set to manually installed.
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      @wibear
                      Sollte eigentlich dann aber funktionieren.
                      distro-info --stable
                      sagt? Und bitte immer die vollständige Ein- wie Ausgaben zeigen.
                        Unbekannt?
                        wibear@iobroker-pi:~ $ distro-info --stable
                        -bash: distro-info: command not found
                          @wibear
                          ??? Du hast es aber doch installiert???
                          ls -la /usr/bin/distro-info
                          echo $PATH
                          sagt?
                            Wie finde ich das?
                              sagt?
                              echo $PATH
                              lrwxrwxrwx 1 root root 20 Oct 29  2023 /usr/bin/distro-info -> raspbian-distro-info
                              /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                Thomas Braun Most Active @wibear last edited by Thomas Braun
                                @wibear sagte in vw-connect Adapter nicht mehr verfügbar:
                                Die Version ist mir unbekannt. Magst du mal die Raspbian-Version von iob-diag testen?
                                https://forum.iobroker.net/topic/59549/iob-diag-skript
                                Und mal die Ausgabe von
                                apt policy distro-info
                                noch?
                                  wibear@iobroker-pi:~ $ raspbian-distro-info
                                  -bash: raspbian-distro-info: command not found
                                  distro-info:
                                    Installed: 1.0+deb11u1
                                    Candidate: 1.0+deb11u1
                                    Version table:
                                   *** 1.0+deb11u1 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package   s
                                          100 /var/lib/dpkg/status
                                  Command not founf:
                                    @wibear
                                    Eigentlich ergibt das nicht viel Sinn...
                                    ls -l /usr/bin/raspbian-distro-info
                                    ls -l /usr/bin/debian-distro-info
                                    ls -l /usr/bin/ubuntu-distro-info
                                    sagt?
                                      ```bash
                                                              v.2024-10-26 Raspbian
                                         Static hostname: iobroker-pi
                                               Icon name: computer
                                        Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                  Kernel: Linux 6.1.21-v7l+
                                            Architecture: arm
                                      Installation:           native
                                      Kernel:                 armv7l
                                      Userland:               32 bit
                                      Timezone:               Europe/Berlin (CEST, +0200)
                                      User-ID:                1000
                                      Display-Server:         false
                                      Boot Target:            multi-user.target
                                      Pending OS-Updates:     0
                                      Pending iob updates:    0
                                      Nodejs-Installation:
                                      /usr/bin/nodejs         v20.18.0
                                      /usr/bin/node           v20.18.0
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.29.3
                                      Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                      nodeJS installation is correct
                                      MEMORY:
                                      Mem:            3.9G        1.3G        1.9G        1.0M        688M        2.5G
                                      Swap:            99M          0B         99M
                                      Total:          4.0G        1.3G        2.0G
                                      Active iob-Instances:   23
                                      Upgrade policy: patch
                                      ioBroker Core:          js-controller           6.0.11
                                                              admin                   7.1.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                6233
                                      States:                 5240
                                      Size of iob-Database:
                                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                                      9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        @wibear
                                        Die Langfassung? Da dürfte es ein paar Fehler hageln.
                                          Die Langfassung
                                          Wie bekomme ich diese?
                                            ========== Start marking the full check here ===========
                                            ```bash
                                            Script v.2024-10-26 Raspbian
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm
                                            OS is similar to: debian
                                            Model           : Raspberry Pi 4 Model B Rev 1.5
                                            Docker          : false
                                            Virtualization  : none
                                            Kernel          : armv7l
                                            Userland        : 32 bit
                                            Systemuptime and Load:
                                             19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                            CPU threads: 4
                                            *** LIFE CYCLE STATUS ***
                                            *** RASPBERRY THROTTLING ***
                                            Current issues:
                                            Previously detected issues:
                                            *** TIME AND TIMEZONES ***
                                                           Local time: Sat 2024-10-26 19:54:22 CEST
                                                       Universal time: Sat 2024-10-26 17:54:22 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** Users and Groups ***
                                            User that called 'iob diag':
                                            wibear
                                            HOME=/home/wibear
                                            GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                            iobroker
                                            HOME=/home/iobroker
                                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                            *** DISPLAY-SERVER SETUP ***
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
                                            Swap:            99M          0B         99M
                                                     3887 M total memory
                                                     1291 M used memory
                                                      238 M active memory
                                                     1638 M inactive memory
                                                     1894 M free memory
                                                       79 M buffer memory
                                                      622 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                            Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
                                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
                                            *** FAILED SERVICES ***
                                            0 loaded units listed.
                                            *** DMESG CRITICAL ERRORS ***
                                            No critical errors detected
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       29G   12G   17G  41% /
                                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                            tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                            /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
                                            tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                            [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                            [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                            Show mounted filesystems:
                                            TARGET  SOURCE         FSTYPE OPTIONS
                                            /       /dev/mmcblk0p2 ext4   rw,noatime
                                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                            /var:
                                            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                            4.6G    /var/
                                            2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                            2.9G    /var/log
                                            856M    /var/cache
                                            Archived and active journals take up 2.8G in the file system.
                                            /opt/iobroker/backups:
                                            82M     /opt/iobroker/backups/
                                            /opt/iobroker/iobroker-data:
                                            886M    /opt/iobroker/iobroker-data/
                                            744M    /opt/iobroker/iobroker-data/files
                                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                            10M     /opt/iobroker/iobroker-data/states.jsonl
                                            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                            USB-Devices by-id:
                                            No Devices found 'by-id'
                                            *** NodeJS-Installation ***
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                              Installed: 20.18.0-1nodesource1
                                              Candidate: 20.18.0-1nodesource1
                                              Version table:
                                             *** 20.18.0-1nodesource1 600
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                                 20.17.0-1nodesource1 600
                                                 20.16.0-1nodesource1 600
                                                 20.15.1-1nodesource1 600
                                                 20.15.0-1nodesource1 600
                                                 20.14.0-1nodesource1 600
                                                 20.13.1-1nodesource1 600
                                                 20.13.0-1nodesource1 600
                                                 20.12.2-1nodesource1 600
                                                 20.12.1-1nodesource1 600
                                                 20.12.0-1nodesource1 600
                                                 20.11.1-1nodesource1 600
                                                 20.11.0-1nodesource1 600
                                                 20.10.0-1nodesource1 600
                                                 20.9.0-1nodesource1 600
                                                 20.8.1-1nodesource1 600
                                                 20.8.0-1nodesource1 600
                                                 20.7.0-1nodesource1 600
                                                 20.6.1-1nodesource1 600
                                                 20.6.0-1nodesource1 600
                                                 20.5.1-1nodesource1 600
                                                 20.5.0-1nodesource1 600
                                                 20.4.0-1nodesource1 600
                                                 20.3.1-1nodesource1 600
                                                 20.3.0-1nodesource1 600
                                                 20.2.0-1nodesource1 600
                                                 20.1.0-1nodesource1 600
                                                 20.0.0-1nodesource1 600
                                                 12.22.12~dfsg-1~deb11u5 500
                                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                            No problems detected
                                            Errors in npm tree: 0
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Hosts:
                                            iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
                                            Core adapters versions
                                            js-controller:  6.0.11
                                            admin:          7.1.5
                                            javascript:     8.8.3
                                            nodejs modules from github:     0
                                            Adapter State
                                            + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                            + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                            + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                            + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                            + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                            + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                              system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                            + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                            + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                            + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                            + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                            + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                            + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                              system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                            + instance is alive
                                            ioBroker-Repositories
                                            │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                            Active repo(s): stable
                                            Installed ioBroker-Instances
                                            Used repository: stable
                                            Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                            Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                            Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                            Controller "js-controller": 6.0.11   , installed 6.0.11
                                            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                            Objects and States
                                            Objects:        6233
                                            States:         5240
                                            Hit:2 https://repos.influxdata.com/debian bullseye InRelease
                                            Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                                            Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
                                            tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
                                            tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
                                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
                                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
                                            tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
                                            tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
                                            tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
                                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
                                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
                                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
                                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
                                            udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
                                            udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
                                            2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
                                            2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
                                            2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
                                            2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                            2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
                                            2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
                                            2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
                                            2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
                                            2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
                                            2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
                                            2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                            1099
