    3. Einsteigerfragen
    4. Installation
    5. vw-connect Adapter nicht mehr verfügbar
      wibear @Thomas Braun last edited by
      Soll ich diese Processe stoppen?
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      wibear@iobroker-pi:~ $
      wibear@iobroker-pi:~ $ iobroker fix
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      1634 iobroker.js-con
      1870 io.admin.0
      1909 io.history.0
      1939 io.influxdb.0
      2020 io.javascript.0
      2038 io.whatsapp-cmb
      2081 io.alexa2.0
      2132 io.backitup.0
      2405 io.hm-rega.0
      2422 io.hm-rpc.0
      2447 io.hm-rpc.1
      2471 io.hm-rpc.2
      2488 io.mqtt.0
      2505 io.rpi2.0
      2527 io.shelly.0
      2569 io.tr-064.0
      2610 io.discovery.0
      2644 io.fb-checkpres
      2722 io.fritzdect.0
      2876 io.simple-api.0
      3033 io.ems-esp.0
      3285 io.web.0
      9250 io.device-remin
      Please stop them first and try again!
        Thomas Braun Most Active @wibear last edited by
        @wibear
        Ja, der kann nur ohne laufende iob-Prozesse funktionieren.
        iob stop
        iob fix
          Ausgeführt und IOB gestartet
          Welcome to the ioBroker installation fixer!
            Script version: 2024-10-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:4 https://packages.grafana.com/oss/deb stable InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:6 https://repos.influxdata.com/debian bullseye InRelease
          Reading package lists... Done
          E: Unable to locate package polkitd
          Installed polkitd
            Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
          This system does not support setting default permissions.
          Do not use npm to manually install adapters unless you know what you are doing!
            Check and cleanup npm temporary directories (3/5)
          Done.
            Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
            Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
            @wibear
            Dann dürfte ja jetzt auch
            iob diag
            laufen.
              @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
              leider nicht:
                @wibear
                sudo apt update && sudo apt install distro-info
                Wobei das eigentlich auch der Fixer hätte fixen sollen...
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://repos.influxdata.com/debian bullseye InRelease
                  Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                  Building dependency tree... Done
                  All packages are up to date.
                  distro-info is already the newest version (1.0+deb11u1).
                  distro-info set to manually installed.
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    @wibear
                    Sollte eigentlich dann aber funktionieren.
                    distro-info --stable
                    sagt? Und bitte immer die vollständige Ein- wie Ausgaben zeigen.
                      Unbekannt?
                      wibear@iobroker-pi:~ $ distro-info --stable
                      -bash: distro-info: command not found
                        @wibear
                        ??? Du hast es aber doch installiert???
                        ls -la /usr/bin/distro-info
                        echo $PATH
                        sagt?
                          Ist hier verfügbar. Sowohl über npm/beta wie auch github.
                          Wie finde ich das?
                            sagt?
                            echo $PATH
                            lrwxrwxrwx 1 root root 20 Oct 29  2023 /usr/bin/distro-info -> raspbian-distro-info
                            /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                              Thomas Braun Most Active @wibear last edited by Thomas Braun
                              @wibear sagte in vw-connect Adapter nicht mehr verfügbar:
                              Die Version ist mir unbekannt. Magst du mal die Raspbian-Version von iob-diag testen?
                              https://forum.iobroker.net/topic/59549/iob-diag-skript
                              Und mal die Ausgabe von
                              apt policy distro-info
                              noch?
                              W 2 Replies Last reply Reply Quote 0
                                wibear@iobroker-pi:~ $ raspbian-distro-info
                                -bash: raspbian-distro-info: command not found
                                distro-info:
                                  Installed: 1.0+deb11u1
                                  Candidate: 1.0+deb11u1
                                  Version table:
                                 *** 1.0+deb11u1 500
                                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package   s
                                        100 /var/lib/dpkg/status
                                Command not founf:
                                  @wibear
                                  Eigentlich ergibt das nicht viel Sinn...
                                  ls -l /usr/bin/raspbian-distro-info
                                  ls -l /usr/bin/debian-distro-info
                                  ls -l /usr/bin/ubuntu-distro-info
                                  sagt?
                                    ```bash
                                                            v.2024-10-26 Raspbian
                                       Static hostname: iobroker-pi
                                             Icon name: computer
                                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v7l+
                                          Architecture: arm
                                    Installation:           native
                                    Kernel:                 armv7l
                                    Userland:               32 bit
                                    Timezone:               Europe/Berlin (CEST, +0200)
                                    User-ID:                1000
                                    Display-Server:         false
                                    Boot Target:            multi-user.target
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:
                                    /usr/bin/nodejs         v20.18.0
                                    /usr/bin/node           v20.18.0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.29.3
                                    Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                    nodeJS installation is correct
                                    MEMORY:
                                    Mem:            3.9G        1.3G        1.9G        1.0M        688M        2.5G
                                    Swap:            99M          0B         99M
                                    Total:          4.0G        1.3G        2.0G
                                    Active iob-Instances:   23
                                    Upgrade policy: patch
                                    ioBroker Core:          js-controller           6.0.11
                                                            admin                   7.1.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects:                6233
                                    States:                 5240
                                    Size of iob-Database:
                                    15M     /opt/iobroker/iobroker-data/objects.jsonl
                                    9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                      @wibear
                                      Die Langfassung? Da dürfte es ein paar Fehler hageln.
                                        Die Langfassung
                                        Wie bekomme ich diese?
                                          ========== Start marking the full check here ===========
                                          ```bash
                                          Script v.2024-10-26 Raspbian
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm
                                          OS is similar to: debian
                                          Model           : Raspberry Pi 4 Model B Rev 1.5
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : armv7l
                                          Userland        : 32 bit
                                          Systemuptime and Load:
                                           19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                          CPU threads: 4
                                          *** LIFE CYCLE STATUS ***
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** TIME AND TIMEZONES ***
                                                         Local time: Sat 2024-10-26 19:54:22 CEST
                                                     Universal time: Sat 2024-10-26 17:54:22 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          wibear
                                          HOME=/home/wibear
                                          GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                          *** DISPLAY-SERVER SETUP ***
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
                                          Swap:            99M          0B         99M
                                                   3887 M total memory
                                                   1291 M used memory
                                                    238 M active memory
                                                   1638 M inactive memory
                                                   1894 M free memory
                                                     79 M buffer memory
                                                    622 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                          Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
                                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** DMESG CRITICAL ERRORS ***
                                          No critical errors detected
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       29G   12G   17G  41% /
                                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                          tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                          /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
                                          tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                          [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                          4.6G    /var/
                                          2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                          2.9G    /var/log
                                          856M    /var/cache
                                          Archived and active journals take up 2.8G in the file system.
                                          /opt/iobroker/backups:
                                          82M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          886M    /opt/iobroker/iobroker-data/
                                          744M    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                          10M     /opt/iobroker/iobroker-data/states.jsonl
                                          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Installed: 20.18.0-1nodesource1
                                            Candidate: 20.18.0-1nodesource1
                                            Version table:
                                           *** 20.18.0-1nodesource1 600
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                               20.17.0-1nodesource1 600
                                               20.16.0-1nodesource1 600
                                               20.15.1-1nodesource1 600
                                               20.15.0-1nodesource1 600
                                               20.14.0-1nodesource1 600
                                               20.13.1-1nodesource1 600
                                               20.13.0-1nodesource1 600
                                               20.12.2-1nodesource1 600
                                               20.12.1-1nodesource1 600
                                               20.12.0-1nodesource1 600
                                               20.11.1-1nodesource1 600
                                               20.11.0-1nodesource1 600
                                               20.10.0-1nodesource1 600
                                               20.9.0-1nodesource1 600
                                               20.8.1-1nodesource1 600
                                               20.8.0-1nodesource1 600
                                               20.7.0-1nodesource1 600
                                               20.6.1-1nodesource1 600
                                               20.6.0-1nodesource1 600
                                               20.5.1-1nodesource1 600
                                               20.5.0-1nodesource1 600
                                               20.4.0-1nodesource1 600
                                               20.3.1-1nodesource1 600
                                               20.3.0-1nodesource1 600
                                               20.2.0-1nodesource1 600
                                               20.1.0-1nodesource1 600
                                               20.0.0-1nodesource1 600
                                               12.22.12~dfsg-1~deb11u5 500
                                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                          No problems detected
                                          Errors in npm tree: 0
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
                                          Core adapters versions
                                          js-controller:  6.0.11
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          nodejs modules from github:     0
                                          Adapter State
                                          + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                          + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                          + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                          + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                          + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                          + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                            system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                          + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                          + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                          + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                          + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                          Active repo(s): stable
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                          Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                          Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Controller "js-controller": 6.0.11   , installed 6.0.11
                                          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                          Objects and States
                                          Objects:        6233
                                          States:         5240
                                          Hit:2 https://repos.influxdata.com/debian bullseye InRelease
                                          Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                                          Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
                                          tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
                                          tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
                                          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
                                          tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
                                          tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
                                          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
                                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
                                          udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
                                          udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
                                          2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                          2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
                                          2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
                                          2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
                                          2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                          2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
                                          2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                          2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                          2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
                                          2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
                                          2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                          2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
                                          2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                          2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
                                          2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                          2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
                                          2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                          2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
                                          2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
                                          2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
                                          2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                            @wibear
                                            Die läuft vor der Zusammenfassung über deinen Bildschirm.
                                            1099
