    3. Einsteigerfragen
    4. Installation
    5. vw-connect Adapter nicht mehr verfügbar
      wibear @Thomas Braun last edited by
      Ausgeführt und IOB gestartet
      Welcome to the ioBroker installation fixer!
        Script version: 2024-10-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Reading package lists... Done
      E: Unable to locate package polkitd
      Installed polkitd
        Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
        Check and cleanup npm temporary directories (3/5)
      Done.
        Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
        Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
        Thomas Braun Most Active @wibear last edited by
        @wibear
        Dann dürfte ja jetzt auch
        iob diag
        laufen.
          @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
          leider nicht:
          *** iob diag is starting up, please wait ***
          iob diag needs to be updated. Please execute 'iobroker fix' first.
            @wibear
            sudo apt update && sudo apt install distro-info
            Wobei das eigentlich auch der Fixer hätte fixen sollen...
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:5 https://repos.influxdata.com/debian bullseye InRelease
              Hit:6 https://packages.grafana.com/oss/deb stable InRelease
              Building dependency tree... Done
              All packages are up to date.
              distro-info is already the newest version (1.0+deb11u1).
              distro-info set to manually installed.
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                @wibear
                Sollte eigentlich dann aber funktionieren.
                distro-info --stable
                sagt? Und bitte immer die vollständige Ein- wie Ausgaben zeigen.
                  Unbekannt?
                  wibear@iobroker-pi:~ $ distro-info --stable
                  -bash: distro-info: command not found
                    @wibear
                    ??? Du hast es aber doch installiert???
                    ls -la /usr/bin/distro-info
                    echo $PATH
                    sagt?
                      Ist hier verfügbar. Sowohl über npm/beta wie auch github.
                      Wie finde ich das?
                        sagt?
                        echo $PATH
                        lrwxrwxrwx 1 root root 20 Oct 29  2023 /usr/bin/distro-info -> raspbian-distro-info
                        /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                          Thomas Braun Most Active @wibear last edited by Thomas Braun
                          @wibear sagte in vw-connect Adapter nicht mehr verfügbar:
                          Die Version ist mir unbekannt. Magst du mal die Raspbian-Version von iob-diag testen?
                          https://forum.iobroker.net/topic/59549/iob-diag-skript
                          Und mal die Ausgabe von
                          apt policy distro-info
                          noch?
                          W 2 Replies Last reply Reply Quote 0
                            wibear@iobroker-pi:~ $ raspbian-distro-info
                            -bash: raspbian-distro-info: command not found
                            distro-info:
                              Installed: 1.0+deb11u1
                              Candidate: 1.0+deb11u1
                              Version table:
                             *** 1.0+deb11u1 500
                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package   s
                                    100 /var/lib/dpkg/status
                            Command not founf:
                              @wibear
                              Eigentlich ergibt das nicht viel Sinn...
                              ls -l /usr/bin/raspbian-distro-info
                              ls -l /usr/bin/debian-distro-info
                              ls -l /usr/bin/ubuntu-distro-info
                              sagt?
                                ```bash
                                                        v.2024-10-26 Raspbian
                                   Static hostname: iobroker-pi
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v7l+
                                      Architecture: arm
                                Installation:           native
                                Kernel:                 armv7l
                                Userland:               32 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                Display-Server:         false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/nodejs         v20.18.0
                                /usr/bin/node           v20.18.0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.3
                                Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                nodeJS installation is correct
                                MEMORY:
                                Mem:            3.9G        1.3G        1.9G        1.0M        688M        2.5G
                                Swap:            99M          0B         99M
                                Total:          4.0G        1.3G        2.0G
                                Active iob-Instances:   23
                                Upgrade policy: patch
                                ioBroker Core:          js-controller           6.0.11
                                                        admin                   7.1.5
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                6233
                                States:                 5240
                                Size of iob-Database:
                                15M     /opt/iobroker/iobroker-data/objects.jsonl
                                9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                  @wibear
                                  Die Langfassung? Da dürfte es ein paar Fehler hageln.
                                    Die Langfassung
                                    Wie bekomme ich diese?
                                      ========== Start marking the full check here ===========
                                      ```bash
                                      Script v.2024-10-26 Raspbian
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                      OS is similar to: debian
                                      Model           : Raspberry Pi 4 Model B Rev 1.5
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : armv7l
                                      Userland        : 32 bit
                                      Systemuptime and Load:
                                       19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Sat 2024-10-26 19:54:22 CEST
                                                 Universal time: Sat 2024-10-26 17:54:22 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      wibear
                                      HOME=/home/wibear
                                      GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                      *** DISPLAY-SERVER SETUP ***
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
                                      Swap:            99M          0B         99M
                                               3887 M total memory
                                               1291 M used memory
                                                238 M active memory
                                               1638 M inactive memory
                                               1894 M free memory
                                                 79 M buffer memory
                                                622 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                      Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
                                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       29G   12G   17G  41% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                      /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
                                      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                      [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET  SOURCE         FSTYPE OPTIONS
                                      /       /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                      4.6G    /var/
                                      2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                      2.9G    /var/log
                                      856M    /var/cache
                                      Archived and active journals take up 2.8G in the file system.
                                      /opt/iobroker/backups:
                                      82M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      886M    /opt/iobroker/iobroker-data/
                                      744M    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                      10M     /opt/iobroker/iobroker-data/states.jsonl
                                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Installed: 20.18.0-1nodesource1
                                        Candidate: 20.18.0-1nodesource1
                                        Version table:
                                       *** 20.18.0-1nodesource1 600
                                              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                           20.17.0-1nodesource1 600
                                           20.16.0-1nodesource1 600
                                           20.15.1-1nodesource1 600
                                           20.15.0-1nodesource1 600
                                           20.14.0-1nodesource1 600
                                           20.13.1-1nodesource1 600
                                           20.13.0-1nodesource1 600
                                           20.12.2-1nodesource1 600
                                           20.12.1-1nodesource1 600
                                           20.12.0-1nodesource1 600
                                           20.11.1-1nodesource1 600
                                           20.11.0-1nodesource1 600
                                           20.10.0-1nodesource1 600
                                           20.9.0-1nodesource1 600
                                           20.8.1-1nodesource1 600
                                           20.8.0-1nodesource1 600
                                           20.7.0-1nodesource1 600
                                           20.6.1-1nodesource1 600
                                           20.6.0-1nodesource1 600
                                           20.5.1-1nodesource1 600
                                           20.5.0-1nodesource1 600
                                           20.4.0-1nodesource1 600
                                           20.3.1-1nodesource1 600
                                           20.3.0-1nodesource1 600
                                           20.2.0-1nodesource1 600
                                           20.1.0-1nodesource1 600
                                           20.0.0-1nodesource1 600
                                           12.22.12~dfsg-1~deb11u5 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
                                      Core adapters versions
                                      js-controller:  6.0.11
                                      admin:          7.1.5
                                      javascript:     8.8.3
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                      + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                      + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                      + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                        system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                      + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                      + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                      Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                      Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 6.0.11   , installed 6.0.11
                                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Objects and States
                                      Objects:        6233
                                      States:         5240
                                      Hit:2 https://repos.influxdata.com/debian bullseye InRelease
                                      Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                                      Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
                                      tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
                                      tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
                                      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
                                      tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
                                      tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
                                      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
                                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
                                      udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
                                      udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
                                      2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                      2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
                                      2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
                                      2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
                                      2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                      2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
                                      2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                      2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                      2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
                                      2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
                                      2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                      2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
                                      2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                      2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
                                      2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                      2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
                                      2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                      2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
                                      2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
                                      2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
                                      2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                        @wibear
                                        Die läuft vor der Zusammenfassung über deinen Bildschirm.
                                        • mcm1957
                                          mcm1957 @wibear last edited by
                                          @wibear said in vw-connect Adapter nicht mehr verfügbar:
                                          Hallo zusammen, der vw-connect Adapter sowie seine Instanz waren bis zuletzt noch installiert und haben funktioniert.. Nach einem Backup-Recovery verschwand der Adapter aus der Liste und ich kann ihn nicht finden, auch bei GitHub nicht.
                                          Ist was dazu bekannt?
                                          Danke und Grüße
                                          Der Adapter vw-connect ist nur mehr im LATEST / BETA repository verfügbar:
                                          Der Maintainer hat keine aktuelle Version für das Stable Repository bereitgestellt und auch auf mehrfache Nachfrage nicht bestätigt, dass die (eher veraltete) Version im Stable Repository noch funktionstüchtig ist. Siehe https://github.com/TA2k/ioBroker.vw-connect/issues/316
                                          Es gibt daher von diesem Adapter derzeit nur eine BETA Version im LATEST Repository. Wenn du diese BETA Version installieren willst, kannst du das durch Auswahl des Beta Repositories oder über "von NPM installieren" im Expertenmodus machen. Bite beachte, dass BETA Versionen generell zum Testen gedacht sind und für produktive Systeme nicht empfohlen werden. Es steht dir frei, den Maintainer zu ersuchen eine geeignete Version für STABLE bereitzustellen.
                                          Bezüglich INSTALLATION von Github noch die nachfolgende Information:
                                          Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                          Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                          Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                          Und falls es irgendwie unklar ist:
                                          ioBroker unterstützt folgende Arten von Installation:
                                          • aus dem STABLE Repository
                                            Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                          • aus dem LATEST Repository
                                            Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                          • direkt von GITHUB
                                            Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                          • direkt von npm
                                            Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                          Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                                          mcm1957 created this issue in TA2k/ioBroker.vw-connect
                                          open Please confirm functionality of release 0.0.67 #316
                                          W 2 Replies Last reply Reply Quote 1
                                            wibear @mcm1957 last edited by
                                            @mcm1957
                                            Guten Morgen und danke für den Hinweis. Ich habe mich einfach gewundert, warum dieser Adapter plötzlich verschwunden ist. Schade, dass er nicht weiter entwickelt wird.
                                            1099
