    3. Einsteigerfragen
    4. Installation
    5. vw-connect Adapter nicht mehr verfügbar
      wibear @Thomas Braun last edited by
      ```bash
                              v.2024-10-26 Raspbian
         Static hostname: iobroker-pi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.18.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            3.9G        1.3G        1.9G        1.0M        688M        2.5G
      Swap:            99M          0B         99M
      Total:          4.0G        1.3G        2.0G
      Active iob-Instances:   23
      Upgrade policy: patch
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                6233
      States:                 5240
      Size of iob-Database:
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      9.4M    /opt/iobroker/iobroker-data/states.jsonl
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        Thomas Braun Most Active @wibear last edited by
        @wibear
        Die Langfassung? Da dürfte es ein paar Fehler hageln.
        W 2 Replies Last reply Reply Quote 0
          @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
          Die Langfassung
          Wie bekomme ich diese?
            ========== Start marking the full check here ===========
            ```bash
            Script v.2024-10-26 Raspbian
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            OS is similar to: debian
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2024-10-26 19:54:22 CEST
                       Universal time: Sat 2024-10-26 17:54:22 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            wibear
            HOME=/home/wibear
            GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
            Swap:            99M          0B         99M
                     3887 M total memory
                     1291 M used memory
                      238 M active memory
                     1638 M inactive memory
                     1894 M free memory
                       79 M buffer memory
                      622 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
            Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4       29G   12G   17G  41% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     778M  1.1M  777M   1% /run
            /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
            tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
            [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
            4.6G    /var/
            2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
            2.9G    /var/log
            856M    /var/cache
            Archived and active journals take up 2.8G in the file system.
            /opt/iobroker/backups:
            82M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            886M    /opt/iobroker/iobroker-data/
            744M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
            10M     /opt/iobroker/iobroker-data/states.jsonl
            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
             *** 20.18.0-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 600
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 12.22.12~dfsg-1~deb11u5 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
            Core adapters versions
            js-controller:  6.0.11
            admin:          7.1.5
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
            + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
              system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
            + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
            + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
            + instance is alive
            ioBroker-Repositories
            │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
            Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        6233
            States:         5240
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 https://repos.influxdata.com/debian bullseye InRelease
            Hit:3 https://packages.grafana.com/oss/deb stable InRelease
            Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists... Done
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
            tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
            tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
            tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
            tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
            udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
            udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
            2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
            2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
            2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
            2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
            2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
            2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
            2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
            2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
            2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
            2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
            2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
            2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
            2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
            2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
            2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
            2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
            2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
              @wibear
              Die läuft vor der Zusammenfassung über deinen Bildschirm.
              • mcm1957
                mcm1957 @wibear last edited by
                @wibear said in vw-connect Adapter nicht mehr verfügbar:
                Hallo zusammen, der vw-connect Adapter sowie seine Instanz waren bis zuletzt noch installiert und haben funktioniert.. Nach einem Backup-Recovery verschwand der Adapter aus der Liste und ich kann ihn nicht finden, auch bei GitHub nicht.
                Ist was dazu bekannt?
                Danke und Grüße
                Der Adapter vw-connect ist nur mehr im LATEST / BETA repository verfügbar:
                Der Maintainer hat keine aktuelle Version für das Stable Repository bereitgestellt und auch auf mehrfache Nachfrage nicht bestätigt, dass die (eher veraltete) Version im Stable Repository noch funktionstüchtig ist. Siehe https://github.com/TA2k/ioBroker.vw-connect/issues/316
                Es gibt daher von diesem Adapter derzeit nur eine BETA Version im LATEST Repository. Wenn du diese BETA Version installieren willst, kannst du das durch Auswahl des Beta Repositories oder über "von NPM installieren" im Expertenmodus machen. Bite beachte, dass BETA Versionen generell zum Testen gedacht sind und für produktive Systeme nicht empfohlen werden. Es steht dir frei, den Maintainer zu ersuchen eine geeignete Version für STABLE bereitzustellen.
                Bezüglich INSTALLATION von Github noch die nachfolgende Information:
                Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                Und falls es irgendwie unklar ist:
                ioBroker unterstützt folgende Arten von Installation:
                • aus dem STABLE Repository
                  Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                • aus dem LATEST Repository
                  Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                • direkt von GITHUB
                  Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                • direkt von npm
                  Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                mcm1957 created this issue in TA2k/ioBroker.vw-connect
                open Please confirm functionality of release 0.0.67 #316
                W 2 Replies Last reply Reply Quote 1
                  wibear @mcm1957 last edited by
                  @mcm1957
                  Guten Morgen und danke für den Hinweis. Ich habe mich einfach gewundert, warum dieser Adapter plötzlich verschwunden ist. Schade, dass er nicht weiter entwickelt wird.
                  • mcm1957
                    @mcm1957
                    Das möchte ich nicht so im Raum stehen lassen. Meiner Info nach wird der Adapter durchaus weiter entwickelt - nur eher im "Quick and Dirty" Stil. Das soll jetzt nicht abwertend klingen sondern nur beschreiben, dass das Drumherum (Changelog, Readme, Stable Requests, ...) eingespart werden und der Grundgedanke "Hauptsache es läuft mal" überwiegt.
                    Jeder Dev hat nur maximal 24h am Tage Zeit. Und je nach User ist auch eine Software die wenig gestestet ist und mal eben so angepasst wird ausreichend. Das muss jeder User selbst entscheiden. Derzeit ist nicht geplant den Adapter aus LATEST zu entfernen.
                      @mcm1957 sagte in vw-connect Adapter nicht mehr verfügbar:
                      Wie kann ich es bitte finden? vw-connect ist weder von npm noch von github auffindbar.
                        @wibear
                        iobroker url iobroker.vw-connect@latest --debug
                        Damit mal probiert?
                          Damit mal probiert?
                          Danke, es funktioniert jetzt.
                          1099
