    4. ([gelöst]) Daten Sonnensystem Resol auslesen per VBUS
      alexw85 last edited by
      @dippi:
      Hallo
      ich bekomme folgende Fehlermeldung im Log bei dem Skript:
      host.ioBroker-Pi	2018-01-07 11:41:38.093	info	Restart adapter system.adapter.javascript.0 because enabled
      host.ioBroker-Pi	2018-01-07 11:41:38.093	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      Caught	2018-01-07 11:41:38.092	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught	2018-01-07 11:41:38.092	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
      Caught	2018-01-07 11:41:38.092	error	by controller[0]: at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
      Caught	2018-01-07 11:41:38.092	error	by controller[0]: at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
      Caught	2018-01-07 11:41:38.090	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
      Caught	2018-01-07 11:41:38.090	error	by controller[0]: at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
      Caught	2018-01-07 11:41:38.090	error	by controller[0]: at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
      Caught	2018-01-07 11:41:38.090	error	by controller[0]: at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
      Caught	2018-01-07 11:41:38.089	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
      Caught	2018-01-07 11:41:38.089	error	by controller[0]: at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
      Caught	2018-01-07 11:41:38.089	error	by controller[0]: at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
      Caught	2018-01-07 11:41:38.088	error	by controller[0]: TypeError: Cannot read property 'optimizeLoadConfiguration' of null
      javascript.0	2018-01-07 11:41:38.033	info	script.js.Dippi.Resol_2: Connection state changed to DISCONNECTED
      javascript.0	2018-01-07 11:41:38.022	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      javascript.0	2018-01-07 11:41:38.022	error	at _combinedTickCallback (internal/process/next_tick.js:73:7)
      javascript.0	2018-01-07 11:41:38.022	error	at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
      javascript.0	2018-01-07 11:41:38.022	error	at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
      javascript.0	2018-01-07 11:41:38.022	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
      javascript.0	2018-01-07 11:41:38.022	error	at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
      javascript.0	2018-01-07 11:41:38.022	error	at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
      javascript.0	2018-01-07 11:41:38.022	error	at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
      javascript.0	2018-01-07 11:41:38.022	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
      javascript.0	2018-01-07 11:41:38.022	error	at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
      javascript.0	2018-01-07 11:41:38.022	error	at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
      javascript.0	2018-01-07 11:41:38.022	error	TypeError: Cannot read property 'optimizeLoadConfiguration' of null
      javascript.0	2018-01-07 11:41:38.022	error	uncaught exception: Cannot read property 'optimizeLoadConfiguration' of null
      javascript.0	2018-01-07 11:41:38.005	info	script.js.Dippi.Resol_2: Connection state changed to DISCONNECTING
      javascript.0	2018-01-07 11:41:38.003	info	script.js.Dippi.Resol_2: Disconnecting...
      javascript.0	2018-01-07 11:41:37.999	info	script.js.Dippi.Resol_2: [1] Optimizing set of values for round 1
      javascript.0	2018-01-07 11:41:37.981	info	script.js.Dippi.Resol_2: WARNING: Unable to create optimizer for master with address 0x7210
      javascript.0	2018-01-07 11:41:37.971	info	script.js.Dippi.Resol_2: Found master with address 0x7210
      javascript.0	2018-01-07 11:41:36.347	info	script.js.Dippi.Resol_2: Waiting for free bus...
      javascript.0	2018-01-07 11:41:36.346	info	script.js.Dippi.Resol_2: Connection state changed to CONNECTED
      javascript.0	2018-01-07 11:41:36.222	info	script.js.Dippi.Resol_2: Connection state changed to CONNECTING
      muss ich noch was Updaten ?
      Gruß Dippi `
      Hmm… Also er erkennt den Controller, connected und dann meldet das Skript das er die Config nicht laden kann und deshalb die ganzen Fehlermeldungen.
      Welcher Resol Regler ist das? Hängt da vieleicht ein DL3 dran? Stimmt das Passwort?
      Gesendet von meinem SM-G955F mit Tapatalk
        dippi last edited by
        Guten Morgen
        ne es hängt ein SKSC3 Regler und ein HK Regler dran.
        Dippi
        • Dutchman
          @dippi:
          Guten Morgen
          Dippi `
          Die Geräte arbeiten aber auf resol-vbus?
          Laut docu des npm Moduls werden folgende Geräte unterstützt:
           Supported Devices & Services
          All current RESOL controllers with VBus
          RESOL DL2 Datalogger
          RESOL DL3 Datalogger
          RESOL VBus/LAN interface adapter
          RESOL VBus/USB interface adapter
          RESOL VBus.net
          Send from mobile device
            Hallo
            ja klar das andere Skript klappt ja. Hab nur das Problem das ich die Daten nicht in den Cloud Adapter rein bekomme als Temperatur sondern nur als An/Aus.
            Gruß Dippi
              Er erkennt aber mit dem Master 0x7210 einen SKSR 1/2/3
              Wenn ich das richtig verstehe sollte da aber ein 0x7211 erkannt werden müssen?!
              Wenn das andere Skript funktioniert, schonmal in den Objekten alles gelöscht was das Skript angelegt hat und neu gestartet? Nicht das durch die verschiedenen Skripte falsch formatierte States angelegt wurden und es deswegen nicht geht…
                Hallo
                die Daten bei den Obijekten hatte ich schon gelöscht, ich hab jetzt eine neue Karte mit dem image vom IObroker gemacht und wollte den Module installieren.
                Schon beim ersten Modul bekomme ich folgende Fehlermeldung:
                pi@All-in-One-Pi:/opt/iobroker/node_modules/iobroker.javascript $ sudo npm install resol-vbus
                > serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                > node-pre-gyp install --fallback-to-build
                node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.4 (node-v48 ABI) (falling back to source compile with node-gyp)
                gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.11.4"
                gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/.node-gyp"
                make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build“ wird betreten
                make: *** Keine Regel vorhanden, um das Ziel „../.node-gyp/6.11.4/include/node/common.gypi“,
                  benötigt von „Makefile“, zu erstellen.  Schluss.
                make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build“ wird verlassen
                gyp ERR! build error
                gyp ERR! stack Error: `make` failed with exit code: 2
                gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
                gyp ERR! stack     at emitTwo (events.js:106:13)
                gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                gyp ERR! System Linux 4.9.41-v7+
                gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.javascript/no        de_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/Release"
                gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                gyp ERR! node -v v6.11.4
                gyp ERR! node-gyp -v v3.6.0
                gyp ERR! not ok
                node-pre-gyp ERR! build error
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_module        s/iobroker.javascript/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/R        elease' (1)
                node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
                node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                node-pre-gyp ERR! System Linux 4.9.41-v7+
                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                node-pre-gyp ERR! node -v v6.11.4
                node-pre-gyp ERR! node-pre-gyp -v v0.6.32
                node-pre-gyp ERR! not ok
                Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.javascript/node_modu        les/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/Release' (1)
                pi@All-in-One-Pi:/opt/iobroker/node_modules/iobroker.javascript $</anonymous>
                Auch bei dem Github Link kommt der Fehler 404
                Dippi
                  @dippi:
                  Hallo
                  gyp ERR! not ok
                  Dippi ` Root hat kein Zugriff? Ist die SD Karte kaputt oder das Filesystem ReadOnly gemountet? 🙂 Das npm install ist schlecht, hatte ich am Anfang auch gemacht, beim nächsten Update des Javascript Adapter ist alles wieder weg, daher besser im WebIf unter Instanzen bei den Einstellungen zum Javascript bei "zusätzliche NPM Module installieren" oder so ähnlich kommagetrennt die Module reinschreiben die du brauchst, dann kommen sie nach dem Update wieder!
                  Gesendet von meinem SM-T819 mit Tapatalk
                    Hi
                    ja das kann schon sein das das System noch Read only ist, hast du mir bitte den Befehl um die Rechte zu vergeben.
                    und welche Module muss ich im Adapter reinschreiben.
                    Dippi
                      @dippi:
                      Hi
                      Dippi ` So anbei die Bilder, normal sollte das Filesystem nicht Schreibgeschützt sein, aber ich hatte bei einem Raspberry der mir zwei Kamerabilder angezeigt und selbst eine Raspicam zum aufzeichnen hatte das Problem das mir 2-3x die SD Karte kaputtgegangen ist mit selben Erscheinungen weil das Netzteil zu schwach war! ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 6253e3.jpg">https://uploads.tapatalk-cdn.com/20180109/322b747749eec58115b43765416253e3.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 424748.jpg">https://uploads.tapatalk-cdn.com/20180109/2541e38fa1ee7affce9690e037424748.jpg</link_text>" />
                      Gesendet von meinem SM-T819 mit Tapatalk~~~~
                        Hallo
                        ich hab die Eintragungen im Javascript Adapter eingtragen, beim Installieren kommen folgende Fehlermeldungen.
                        javascript.0 2018-01-09 19:46:35.839 info Stop script script.js.Dippi.Skript1
                        javascript.0 2018-01-09 19:45:52.467 info received all objects
                        javascript.0 2018-01-09 19:45:51.606 info received all states
                        javascript.0 2018-01-09 19:45:50.538 info requesting all objects
                        javascript.0 2018-01-09 19:45:50.534 info requesting all states
                        javascript.0 2018-01-09 19:45:50.492 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modul
                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent
                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                        javascript.0 2018-01-09 19:45:50.490 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modul
                        javascript.0 2018-01-09 19:45:50.489 error npm
                        javascript.0 2018-01-09 19:45:50.489 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:50.487 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                        javascript.0 2018-01-09 19:45:50.485 error npm
                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                        javascript.0 2018-01-09 19:45:50.485 error enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/nod
                        javascript.0 2018-01-09 19:45:50.476 error npm WARN
                        javascript.0 2018-01-09 19:45:50.476 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_mo
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validato
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/no
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-str
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_mo
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once/packag
                        javascript.0 2018-01-09 19:45:50.474 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignor
                        javascript.0 2018-01-09 19:45:50.466 error npm
                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/pac
                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug/packa
                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/package.
                        javascript.0 2018-01-09 19:45:50.466 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/package.js
                        javascript.0 2018-01-09 19:45:50.464 error npm
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/package
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs/package.j
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringi
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/package
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validato
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/pa
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-str
                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist/package.
                        javascript.0 2018-01-09 19:45:50.464 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/deep-extend/package.json'
                        javascript.0 2018-01-09 19:45:50.454 error enoent
                        javascript.0 2018-01-09 19:45:50.450 error npm WARN
                        javascript.0 2018-01-09 19:45:50.450 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/package
                        javascript.0 2018-01-09 19:45:50.450 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                        javascript.0 2018-01-09 19:45:50.450 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist/package.json'
                        javascript.0 2018-01-09 19:45:50.444 error enoent
                        javascript.0 2018-01-09 19:45:50.443 error npm WARN
                        javascript.0 2018-01-09 19:45:50.443 error enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/package.json'
                        javascript.0 2018-01-09 19:45:50.433 error npm WARN
                        javascript.0 2018-01-09 19:45:50.433 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/package.json'
                        javascript.0 2018-01-09 19:45:50.433 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/semver/package.json'
                        javascript.0 2018-01-09 19:45:50.433 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/package.json'
                        javascript.0 2018-01-09 19:45:50.431 error npm
                        javascript.0 2018-01-09 19:45:50.431 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/package.json'
                        javascript.0 2018-01-09 19:45:50.431 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/package.json'
                        javascript.0 2018-01-09 19:45:50.430 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/package.json'
                        javascript.0 2018-01-09 19:45:50.428 error enoent
                        javascript.0 2018-01-09 19:45:50.416 error npm WARN
                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/package.json'
                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/package.json'
                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/package.json'
                        javascript.0 2018-01-09 19:45:50.416 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/package.json'
                        javascript.0 2018-01-09 19:45:50.415 error enoent
                        javascript.0 2018-01-09 19:45:50.414 error npm WARN
                        javascript.0 2018-01-09 19:45:50.414 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign/package.json'
                        javascript.0 2018-01-09 19:45:50.414 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys/package.json'
                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent
                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/package.json'
                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie/package.json'
                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/package.json'
                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/package.json'
                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/package.json'
                        javascript.0 2018-01-09 19:45:50.411 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/package.json'
                        javascript.0 2018-01-09 19:45:50.411 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/package.json'
                        javascript.0 2018-01-09 19:45:50.409 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander/package.json'
                        javascript.0 2018-01-09 19:45:50.406 error enoent
                        javascript.0 2018-01-09 19:45:50.404 error
                        javascript.0 2018-01-09 19:45:50.401 error WARN
                        javascript.0 2018-01-09 19:45:50.399 error
                        javascript.0 2018-01-09 19:45:50.397 error npm
                        javascript.0 2018-01-09 19:45:50.383 info └── optimist@0.6.1
                        javascript.0 2018-01-09 19:45:50.383 info iobroker.javascript@3.4.0 /opt/iobroker/node_modules/iobroker.javascript
                        javascript.0 2018-01-09 19:45:33.372 info npm install optimist --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                        javascript.0 2018-01-09 19:45:33.283 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                        javascript.0 2018-01-09 19:45:33.283 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                        javascript.0 2018-01-09 19:45:33.282 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:33.281 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:33.281 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                        javascript.0 2018-01-09 19:45:33.280 error npm
                        javascript.0 2018-01-09 19:45:33.278 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/
                        javascript.0 2018-01-09 19:45:33.276 error
                        javascript.0 2018-01-09 19:45:33.273 error npm
                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                        javascript.0 2018-01-09 19:45:33.240 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_module
                        javascript.0 2018-01-09 19:45:33.237 error enoent
                        javascript.0 2018-01-09 19:45:33.235 error
                        debug pm WARN
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatur
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_mod
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/nod
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stre
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_mod
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-y
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-str
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once/package
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-igno
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/pack
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug/packag
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/package.j
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/package.j
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/package.
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie/
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs/package.js
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringif
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/package.
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/pac
                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist/package.j
                        Ich hab das Skript vom 05.01.2018 genommen und die IP Adresse geändert.
                        Dippi
                        • Dutchman
                          Hi @alexw85,
                          Ich habe jetzt auch mal das neue script eingesetzt und damit sollte es ja auch moeglich sein daten zu aendern richtig ?
                          Schick varible zurueck aber nach 30 sekunden wird sie wieder die halten ist da noch ein bestimmter trick ?
                          Greetz,
                          Dutch
                            @dippi:
                            Hallo
                            debug pm WARN
                            Dippi `  Lade dir mal bitte das Programm Etcher zum flashen der SD-Karte runter und nimm vieleicht gleich ne andere, da ist irgendwas grundlegend schief gelaufen!? Sieht aus das neben root auch iobroker nix schreiben kann!
                              @Dutchman:
                              Hi @alexw85,
                              Greetz,
                              Dutch ` Hi Dutchman,
                              der einzigste Trick ist eigentlich zu warten bis das Skript sich initialisiert hat und alle Werte vom Controller gelesen hat. Kann je nach Verbindung und Anzahl der Datenpunkte schon mal 1-2min dauern! Erst dann werden um die Config des Controllers nicht zu beschädigen oder zu verstellen Änderungen angenommen. Im Log kann man das mitverfolgen, es steht dann "ready for processing…" im Log wenn es fertig ist. Ansonsten darf natürlich das Skript nicht doppelt laufen, oder zwei Skripte auf den Vbus zugreifen und der Javascript Adapter darf sich nicht ständig resetten, sonst startet das Skript ja immer wieder neu. Ich hatte das Problem mal beim testen mit anderen Sachen das der Javascript Adapter abstürzte und dann wurde ständig die Config gelesen! 🙂
                              Kannst du mal das Log posten wenns nicht daran liegen sollte?
                              Ich lasse damit ständig einen Heizkreis ein und ausschalten. Immer wenn die Sonne rauskommt meldet im Wohnzimmer das Homematic Wandthermostat der u.a. die Wandheizkörper regelt eine Temperatur von >23 Grad, dann schaltet der Heizkreis für die Fußbodenheizung aus, bei 22,5 geht sie wieder an, bei unter 21,5 wird Heizkurve angehoben um 1 Grad wenn nach 30min es nicht wärmer wird erneut um 1 Grad (bis max 5 Grad), ab 22,5 wird umgekehrt abgesenkt. Brauch deshalb keine Thermostatventile in den Räumen um auf meine 22Grad zu kommen 🙂 Funktioniert auch sehr gut, momentan heizt der Fußboden meist nur zwischen 20-12Uhr und die Temperatur wird gut gehalten. Ob das woanders Sinn macht außer bei mir ist fraglich, mein Vorgänger hat nämlich die FBH falsch verlegt und viel zu klein ausgelegt, (ein Wasserkocher war wohl sein Vorbild) daher muss ich Temperaturen in den Boden pumpen die fast auf Heizkörperniveau liegen. Bis ich alle Fliesen rausgerissen habe und alles neu gemacht habe muss ich jetzt mit der Sch... leben 🙂
                                Tipe1965 last edited by
                                Hallo, ich bin auch noch recht neu hier.
                                Nachdem ich ein wenig gegoogelt habe bezüglich Datalogger und iobroker bin ich auf den Thread gestoßen.
                                Erstmal vielen Dank für dieses Skript, das ist schonmal super Arbeit.
                                Nach ein bisschen hin und her fummeln hab ich es dann auch zum laufen bekommen und er zieht sich auch die Daten.
                                Jetzt hab ich mal eine Frage,
                                ich nutze den DL2. Ich würde gerne je nach Außentemperatur meine Anlage auf ein anderes Schema umstellen da ich die Heizung im Sommer eh aus habe möchte ich die komplette Leistung ins warm Wasser liefern und nicht auch in die Heizungsunterstützung.
                                Jetzt zu meiner frage, kann ich Einmach mit einem Blogly Skript besp sagen wenn Außentemperatur Fühler über 15 grad dann setzte Schema auf 6 statt 9? müsste dann ggf auch noch ein paar min und max werte anpassen. Will da nur nicht einfach in der Config rum ändern.
                                Wäre super wenn ihr mir da helfen könntet.
                                Danke schonmal im Voraus.
                                  Hallo zusammen
                                  ich hab mich nun nach etwas Pause nochmal an das Skipt gewagt. Die installation der Module hat wie es ausgesehen hat geklappt, im gegensatz zum letzten mal.
                                  nun bekomm ich ber folgende Fehlermeldungen
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.421	info	Restart adapter system.adapter.javascript.0 because enabled
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.421	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.420	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.420	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.420	error	Caught by controller[0]: at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.420	error	Caught by controller[0]: at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.420	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.419	error	Caught by controller[0]: at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.419	error	Caught by controller[0]: at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.419	error	Caught by controller[0]: at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.419	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.418	error	Caught by controller[0]: at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.418	error	Caught by controller[0]: at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
                                  host.Dippi-Iobroker	2018-03-04 20:25:36.417	error	Caught by controller[0]: TypeError: Cannot read property 'optimizeLoadConfiguration' of null
                                  javascript.0	2018-03-04 20:25:34.491	info	script.js.Dippi_Skript.Resol: Waiting for free bus...
                                  javascript.0	2018-03-04 20:25:34.490	info	script.js.Dippi_Skript.Resol: Connection state changed to CONNECTED
                                  javascript.0	2018-03-04 20:25:34.387	info	script.js.Dippi_Skript.Resol: Connection state changed to CONNECTING
                                  javascript.0	2018-03-04 20:25:34.384	info	script.js.Dippi_Skript.Resol: Connecting...
                                  javascript.0	2018-03-04 20:25:34.384	info	script.js.Dippi_Skript.Resol: registered 0 subscriptions and 0 schedules
                                  leider kann ich damit nichts anfangen.
                                  woran könnte das jetzt liegen ?
                                  Viele Grüße
                                  Dippi
                                  • Dutchman
                                    Hi @alexw85,
                                    So nach langer Zeit mal wieder platz gefunden um alles zu testen und es funktioniert einwandfrei !
                                    Ich habe die letzte version deine Änderungen auf Github hochgeladen damit es nicht nur im forum steht, auch das layout ist ein bisschen durcheinander geraten hier im Forum auf git steht es jetzt richtig.
                                    Das script kan man als version 1.3 in volgende github repository finden : https://github.com/DutchmanNL/ioBroker.Resol-VBUS
                                    ToDo : installations Beschreibung auf Github in der realem festlegen Edit : Done
                                      @Dutchman:
                                      Hi @alexw85,
                                      ToDo : installations Beschreibung auf Github in der realem festlegen Edit : Done ` Sehr schön! [emoji4]
                                      Ich hoffe ich komme auch bald mal dazu einen Adapter zu basteln… [emoji849]
                                        AThobaben last edited by
                                        Hallo Zusammen
                                        Ich komme leider nicht weiter mit dem Script…
                                        Als Hardware verwende ich eine Windhager OEM Version der Resol Steuerung mit einem RS485 nach LAN Konverter. Mit der Resol Software funktioniert die ganze Sache.
                                        Mit Hilfe der Seite
                                        http://danielwippermann.github.io/resol ... c1__anchor
                                        habe ich meine Verbindungsdaten wie folgt angepasst:
                                        var config = {
                                        "connection": {
                                        "class": "TcpConnection",
                                        "options": {
                                        "host": "192.168.10.254", 	// IP-Adresse oder VBus.net Adresse hier eintragen
                                        // "viaTag": "", 		// Bei Verbindung über VBus.net ist hier das viaTag einzutragen
                                        // "password": "vbus", 	// Passwort, Standard ist: vbus
                                        // "channel" : "1" 		// Channel, wird nur für die Verbindung über einen DL3 benötigt und ist standardmäßig auskommentiert!
                                        "port": "7053",
                                        "rawVBusDataOnly" : "true"
                                        Damit komme ich schon mal viel weiter als ohne der "rawVBusDataOnly" Parameter.
                                        Leider scheint irgendwo immer noch der Wurm drin zu sein, den ich bekomme folgende Fehler:
                                        g
                                        18:04:24.375	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:04:24.377	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:04:24.380	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:04:24.383	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:04:24.393	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTED
                                        18:04:24.395	[info]	javascript.0 script.js.VBUS: Waiting for free bus...
                                        18:04:44.521	[info]	javascript.0 script.js.VBUS: Disconnecting...
                                        18:04:44.533	[info]	javascript.0 script.js.VBUS: Connection state changed to DISCONNECTING
                                        18:04:44.538	[error]	javascript.0 TypeError: Cannot read property 'sourceAddress' of null at script.js.VBUS:361:33 at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54) at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13) at _combinedTickCallback (internal/process/next_tick.js:73:7) at process._tickCallback (internal/process/next_tick.js:104:9)
                                        18:04:44.883	[error]	Caught by controller[0]: at script.js.VBUS:361:33
                                        18:06:42.173	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:06:42.175	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:06:42.177	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:06:42.183	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:06:42.185	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTED
                                        18:06:42.193	[info]	javascript.0 script.js.VBUS: Waiting for free bus...
                                        18:07:02.280	[info]	javascript.0 script.js.VBUS: Disconnecting...
                                        18:07:02.293	[info]	javascript.0 script.js.VBUS: Connection state changed to DISCONNECTING
                                        18:07:02.297	[error]	javascript.0 TypeError: Cannot read property 'sourceAddress' of null at script.js.VBUS:361:33 at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54) at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13) at _combinedTickCallback (internal/process/next_tick.js:73:7) at process._tickCallback (internal/process/next_tick.js:104:9)
                                        18:07:02.528	[error]	Caught by controller[0]: at script.js.VBUS:361:33
                                        18:08:58.743	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:08:58.745	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:08:58.747	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:08:58.750	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:08:58.752	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTED
                                        18:08:58.763	[info]	javascript.0 script.js.VBUS: Waiting for free bus...
                                        18:09:18.810	[info]	javascript.0 script.js.VBUS: Disconnecting...
                                        18:09:18.813	[info]	javascript.0 script.js.VBUS: Connection state changed to DISCONNECTING
                                        18:09:18.826	[error]	javascript.0 TypeError: Cannot read property 'sourceAddress' of null at script.js.VBUS:361:33 at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54) at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13) at _combinedTickCallback (internal/process/next_tick.js:73:7) at process._tickCallback (internal/process/next_tick.js:104:9)
                                        18:09:19.047	[error]	Caught by controller[0]: at script.js.VBUS:361:33
                                        18:11:16.603	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:11:16.613	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:11:16.615	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:11:16.618	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:11:16.620	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTED
                                        18:11:16.622	[info]	javascript.0 script.js.VBUS: Waiting for free bus...
                                        18:11:16.755	[info]	javascript.0 Stop script script.js.VBUS
                                        18:11:16.943	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:11:16.945	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:11:16.953	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:11:16.955	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:11:36.700	[info]	javascript.0 script.js.VBUS: Disconnecting...
                                        18:11:36.711	[info]	javascript.0 script.js.VBUS: Connection state changed to DISCONNECTING
                                        18:11:36.716	[error]	javascript.0 TypeError: Cannot read property 'sourceAddress' of null at script.js.VBUS:361:33 at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54) at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13) at _combinedTickCallback (internal/process/next_tick.js:73:7) at process._tickCallback (internal/process/next_tick.js:104:9)
                                        18:11:36.943	[error]	Caught by controller[0]: at script.js.VBUS:361:33
                                        18:13:33.845	[info]	javascript.0 Start javascript script.js.VBUS
                                        18:13:33.848	[info]	javascript.0 script.js.VBUS: registered 0 subscriptions and 0 schedules
                                        18:13:33.852	[info]	javascript.0 script.js.VBUS: Connecting...
                                        18:13:33.863	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTING
                                        18:13:33.865	[info]	javascript.0 script.js.VBUS: Connection state changed to CONNECTED
                                        18:13:33.868	[info]	javascript.0 script.js.VBUS: Waiting for free bus...
                                        18:13:33.989	[info]	javascript.0 Stop script script.js.VBUS
                                        18:13:53.970	[info]	javascript.0 script.js.VBUS: Disconnecting...
                                        18:13:53.981	[info]	javascript.0 script.js.VBUS: Connection state changed to DISCONNECTING
                                        18:13:53.985	[error]	javascript.0 TypeError: Cannot read property 'sourceAddress' of null at script.js.VBUS:361:33 at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54) at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13) at _combinedTickCallback (internal/process/next_tick.js:73:7) at process._tickCallback (internal/process/next_tick.js:104:9)
                                        18:13:54.219	[error]	Caught by controller[0]: at script.js.VBUS:361:33
                                        Das Property "sourceAdress" ist nicht lesbar…
                                        Kann mir jemand mit Sachdienlichen Hinweisen weiterhelfen wo ich suchen könnte?
                                        LG,
                                        Axel
                                        • Dutchman
                                          Source Adresse benutze ich nicht in unserem Script das muss dann aus dem resol npm Modul kommen.
                                          Sicher das die die Konfiguration laut Vorgabe eingegeben hast ?
                                          Copy Paste doch Mal drin komplettes Script (Password selbstverständlich vertuschen)
                                            Hallo Dutchman
                                            Yep - es kommt aus dem npm Modul. Ich bin einen Schritt weiter gekommen, in dem ich die Konfiguration angepasst habe und einen Parameter ergänzt habe. Leider eben nur einen Schritt… Hier die "neue" Fehlermeldung:
                                            host.ioBroker-RPi1	2018-06-28 20:53:19.790	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            Caught	2018-06-28 20:53:19.788	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                                            Caught	2018-06-28 20:53:19.785	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                            Caught	2018-06-28 20:53:19.783	error	by controller[0]: at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
                                            Caught	2018-06-28 20:53:19.780	error	by controller[0]: at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
                                            Caught	2018-06-28 20:53:19.778	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
                                            Caught	2018-06-28 20:53:19.776	error	by controller[0]: at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
                                            Caught	2018-06-28 20:53:19.773	error	by controller[0]: at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
                                            Caught	2018-06-28 20:53:19.771	error	by controller[0]: at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
                                            Caught	2018-06-28 20:53:19.768	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
                                            Caught	2018-06-28 20:53:19.766	error	by controller[0]: at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
                                            Caught	2018-06-28 20:53:19.762	error	by controller[0]: at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
                                            Caught	2018-06-28 20:53:19.756	error	by controller[0]: TypeError: Cannot read property 'optimizeLoadConfiguration' of null
                                            javascript.0	2018-06-28 20:53:19.545	info	terminating
                                            javascript.0	2018-06-28 20:53:19.417	error	at process._tickCallback (internal/process/next_tick.js:104:9)
                                            javascript.0	2018-06-28 20:53:19.417	error	at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                            javascript.0	2018-06-28 20:53:19.417	error	at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
                                            javascript.0	2018-06-28 20:53:19.417	error	at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
                                            javascript.0	2018-06-28 20:53:19.417	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
                                            javascript.0	2018-06-28 20:53:19.417	error	at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
                                            javascript.0	2018-06-28 20:53:19.417	error	at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
                                            javascript.0	2018-06-28 20:53:19.417	error	at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
                                            javascript.0	2018-06-28 20:53:19.417	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
                                            javascript.0	2018-06-28 20:53:19.417	error	at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
                                            javascript.0	2018-06-28 20:53:19.417	error	at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
                                            javascript.0	2018-06-28 20:53:19.417	error	TypeError: Cannot read property 'optimizeLoadConfiguration' of null
                                            javascript.0	2018-06-28 20:53:19.413	error	uncaught exception: Cannot read property 'optimizeLoadConfiguration' of null
                                            javascript.0	2018-06-28 20:53:19.313	info	script.js.VBUS: Connection state changed to DISCONNECTING
                                            javascript.0	2018-06-28 20:53:19.307	info	script.js.VBUS: Disconnecting...
                                            javascript.0	2018-06-28 20:53:19.281	info	script.js.VBUS: [1] Optimizing set of values for round 1
                                            javascript.0	2018-06-28 20:53:19.160	info	script.js.VBUS: WARNING: Unable to create optimizer for master with address 0x7731
                                            javascript.0	2018-06-28 20:53:19.089	info	script.js.VBUS: Found master with address 0x7731
                                            javascript.0	2018-06-28 20:53:18.915	info	script.js.VBUS: Waiting for free bus...
                                            javascript.0	2018-06-28 20:53:18.907	info	script.js.VBUS: Connection state changed to CONNECTED
                                            javascript.0	2018-06-28 20:53:17.937	info	script.js.VBUS: Connection state changed to CONNECTING
                                            javascript.0	2018-06-28 20:53:17.925	info	script.js.VBUS: Connecting...
                                            javascript.0	2018-06-28 20:53:17.838	info	script.js.VBUS: registered 0 subscriptions and 0 schedules
                                            javascript.0	2018-06-28 20:52:15.788	info	Start javascript script.js.VBUS
                                            javascript.0	2018-06-28 20:52:15.778	info	script.js.Zaehler: registered 0 subscriptions and 1 schedule
                                            javascript.0	2018-06-28 20:52:15.463	info	Start javascript script.js.Zaehler
                                            javascript.0	2018-06-28 20:52:15.126	info	received all objects
                                            javascript.0	2018-06-28 20:52:11.669	info	received all states
                                            javascript.0	2018-06-28 20:52:07.916	info	requesting all objects
                                            javascript.0	2018-06-28 20:52:07.891	info	requesting all states
                                            javascript.0	2018-06-28 20:52:07.799	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.0
                                            javascript.0	2018-06-28 20:52:07.330	info	States connected to redis: 127.0.0.1:6379
                                            host.ioBroker-RPi1	2018-06-28 20:51:52.032	info	instance system.adapter.javascript.0 started with pid 7987
                                            host.ioBroker-RPi1	2018-06-28 20:51:21.975	info	Restart adapter system.adapter.javascript.0 because enabled
                                            Du hast in Zeile 17 folgendes stehen:
                                            /opt/iobroker/ResolVBusConfigTest.json
                                            Wenn ich da schauen gehe, gibt es die Datei nicht. Auch wenn ich die Anlege, gibt es weiter Probleme.
                                            Und ja - ich habe die Module in JS-Modul angegeben.
                                            Hier mal mein Script…
                                            /*! ### ioBroker Script zum auslesen und konfigurieren von Resol und anderen auf VBus basierenden Steuerungen ### */
                                            /*! ####### Das Script basiert auf auf dem Node JS Modul "resol-vbus" von Daniel Wippermann und wurde von ####### */
                                            /*! ################### Dutchman, meifi2017 & AlexW für die Verwendung in ioBroker angepasst! ################### */
                                            /*! ############################################ V 1.3 ########################################################## */
                                            var fs = require('fs');
                                            var express = require('express');
                                            var kue = require('kue');
                                            var _ = require('lodash');
                                            var optimist = require('optimist');
                                            var Q = require('q');
                                            var vbus = require('resol-vbus/src/index');
                                            var action = {
                                                "loadAll": true, // Bedeutet das beim Start des Scripts der Controller ausgelesen werden soll!
                                                "out": "/opt/iobroker/ResolVBusConfigTest.json" // Pfad wo die gesamten Konfigurationswerte des Controllers beim Start des Scripts gespeichert werden sollen
                                            /*! Hier bitte die spezifischen Verbindungsdaten eintragen! */
                                            var config = {
                                            "connection": {
                                            "options": {
                                            "port": "7053",
                                            /*! Ab hier reiner Code */
                                            var timestamp;
                                            var Live = function() {
                                                var vbuslive = require('resol-vbus');
                                                var headerSetlive = new vbuslive.HeaderSet();
                                                var connlive;
                                                // Schedule every 30 seconds
                                                schedule("*/30 * * * * *", function() {
                                                    // Define connection values
                                                    var connectionConfigLive = config.connection;
                                                    var ConnectionLive = vbuslive[connectionConfigLive.class];
                                                    connlive = new ConnectionLive(connectionConfigLive.options);
                                                    // Log connection status
                                                    var onConnectionStateChange = function(state) {
                                                        console.debug(state);
                                                    var onPacket = function(packet) {
                                                        headerSetlive.addHeader(packet);
                                                    connlive.on('connectionState', onConnectionStateChange);
                                                    connlive.on('packet', onPacket);
                                                    connlive.connect().done(function() {
                                                        setTimeout(function() {
                                                            connlive.disconnect();
                                                            //create header packages
                                                            var packets = headerSetlive.getSortedHeaders();
                                                            var spec = vbuslive.Specification.getDefaultSpecification();
                                                            var packetFields = spec.getPacketFieldsForHeaders(packets);
                                                            var packet = null;
                                                            var counter = 0;
                                                            packetFields.forEach(function(packetField) {
        counter = counter + 1;
        if (packet !== packetField.packet) {
        packet = packetField.packet;
        console.debug(packetField.packetSpec.fullName);
        // write values in memory
        packetField.name = packetField.name.replace(/ /g, "");
        console.debug("Value received : " + packetField.name + " = " + packetField.formatTextValue());
        try {
        if (getIdByName(packetField.name) != null) {
        setState("vbus.values." + packetField.name, packetField.formatTextValue(), true);
        } else {
        createState("vbus.values." + packetField.name, {
        type: 'string',
        role: 'value',
        def: packetField.formatTextValue(),
        } catch (e) {}
                                                            // 10 second timer, collection all information takes some seconds Bild
                                                        }, 10000);
                                            var createStates = function() {
                                                var file = action.out;
                                                fs.readFile(file, 'utf8', function(err, body) {
                                                    if (err) {}
                                                    JSON.parse(body, (key, value) => {
                                                        var jsonkey = key;
                                                        var jsonvalue = value;
                                                        try {
                                                            if (jsonkey !== "" && getIdByName(jsonkey) != null)
        setState("vbus.config." + jsonkey, parseFloat(jsonvalue), true);
                                                        } catch (e) {}
                                                        try {
                                                            if (jsonkey !== "")
        createState("vbus.config." + jsonkey, {
        type: 'number',
        role: 'value',
        def: parseFloat(jsonvalue),
                                                        } catch (e) {}
                                                action.loadAll = false;
                                                timestamp = Date.now();
                                                var ready = "Ready for processing...";
                                                setTimeout(console.log, 10000, ready);
                                                return;
                                            var writeStates = function() {
                                                on({
                                                    change: "ne"
                                                }, function(obj) {
                                                    var statename = obj.name;
                                                    var value = obj.state.val;
                                                    var lastChanged = getState(obj.id).lc;
                                                    if (typeof oldValue !== "undefined" && lastChanged > (timestamp + 10000)) {
                                                        console.log(statename + " hat sich von " + oldValue + " auf " + value + " geändert!");
                                                        jsonWrite = JSON.stringify({
                                                            [statename]: value
                                                        action.save = true;
                                                        action.data = jsonWrite;
                                                        setState("vbus.config." + statename, parseFloat(value), true);
                                                        return runSingleShot(action);
                                            var promise = vbus.utils.promise;
                                            var i18n = new vbus.I18N('en');
                                            var reportProgress = function(message) {
                                                var line;
                                                if (_.isString(message)) {
                                                    line = message;
                                                } else if (message.message === 'OPTIMIZING_VALUES') {
                                                    line = i18n.sprintf('Optimizing set of values for round %d', message.round);
                                                } else if (message.message === 'GETTING_VALUE') {
                                                    line = i18n.sprintf('Getting value %d/%d, try %d: %s', message.valueNr, message.valueCount, message.tries, message.valueId);
                                                } else if (message.message === 'SETTING_VALUE') {
                                                    line = i18n.sprintf('Setting value %d/%d, try %d: %s', message.valueNr, message.valueCount, message.tries, message.valueId);
                                                } else if (message.message === 'CONNECTION_STATE') {
                                                    line = i18n.sprintf('Connection state changed to %s', message.connectionState);
                                                } else if (message.message === 'WAITING_FOR_FREE_BUS') {
                                                    line = i18n.sprintf('Waiting for free bus');
                                                } else if (message.message === 'RELEASING_BUS') {
                                                    line = i18n.sprintf('Releasing bus');
                                                } else {
                                                    line = i18n.sprintf('%s: %s', message.message, JSON.stringify(message));
                                                if (_.isNumber(message.round)) {
                                                    line = i18n.sprintf('[%d] %s', message.round, line);
                                                console.log(line);
                                            var loadJsonFile = function(filename) {
                                                return promise(function(resolve, reject) {
                                                    fs.readFile(filename, function(err, data) {
                                                        if (err) {
                                                            reject(err);
                                                        } else {
                                                            resolve(data);
                                                }).then(function(data) {
                                                    return JSON.parse(data);
                                            var createConnection = function() {
                                                var connectionConfig = config.connection;
                                                var Connection = vbus[connectionConfig.class];
                                                var conn = new Connection(connectionConfig.options);
                                                conn.on('connectionState', function(state) {
                                                    reportProgress({
                                                        message: 'CONNECTION_STATE',
                                                        connectionState: state,
                                                return conn;
                                            var processCustomizationJob = function(context, job) {
                                                'use strict';
                                                return Q.fcall(function() {
                                                    reportProgress('Waiting for free bus...');
                                                    return context.connection.waitForFreeBus();
                                                }).then(function(datagram) {
                                                    context.masterAddress = datagram.sourceAddress;
                                                    reportProgress('Found master with address 0x' + context.masterAddress.toString(16));
                                                    context.deviceAddress = context.masterAddress;
                                                    return vbus.ConfigurationOptimizerFactory.createOptimizerByDeviceAddress(context.deviceAddress);
                                                }).then(function(optimizer) {
                                                    context.optimizer = optimizer;
                                                    context.customizer = new vbus.ConnectionCustomizer({
                                                        deviceAddress: context.deviceAddress,
                                                        connection: context.connection,
                                                        optimizer: context.optimizer,
                                                }).then(function() {
                                                    var onProgress = function(progress) {
                                                        reportProgress(progress);
                                                    var command = job.data.command;
                                                    var config = job.data.config;
                                                    var currentConfig = context.currentConfig;
                                                    var options = {
                                                        optimize: false,
                                                    if (command === 'load') {
                                                        options.optimize = !config;
                                                            return context.customizer.loadConfiguration(config, options).progress(onProgress);
                                                        }).then(function(config) {
                                                            return context.optimizer.completeConfiguration(config, currentConfig);
                                                            context.currentConfig = config;
                                                    } else if (command === 'save') {
                                                            return context.customizer.saveConfiguration(config, currentConfig, options).progress(onProgress);
                                                    } else {
                                                        throw new Error('Unknown command ' + JSON.stringify(command));
                                            var serve = function() {
                                                'use strict';
                                                var context = {};
                                                    return createConnection();
                                                }).then(function(conn) {
                                                    context.connection = conn;
                                                    reportProgress('Connecting...');
                                                    return context.connection.connect();
                                                    var jobs = kue.createQueue();
                                                    jobs.process('customization', function(job, done) {
                                                            return processCustomizationJob(context, job);
                                                        }).done(function() {
                                                            console.log('Job done!');
                                                            done();
                                                        }, function(err) {
                                                            console.log('Job failed!');
                                                            done(err);
                                                    var app = express();
                                                    app.get('/config', function(req, res) {
                                                        var jsonConfig = _.reduce(context.currentConfig, function(memo, value) {
                                                            if (!value.ignored) {
        memo[value.valueId] = value.value;
                                                            return memo;
                                                        res.json(jsonConfig);
                                                    app.use(kue.app);
                                                    app.listen(3000);
                                            var runSingleShot = function(action) {
                                                var context = {};
                                                if (action.q) {
                                                    reportProgress = function() {};
                                                }).then(function(oldConfig) {
                                                    context.oldConfig = oldConfig;
                                                    if (action.loadAll) {
                                                        return null;
                                                    } else if (action.load) {
                                                        return loadJsonFile(action.load);
                                                }).then(function(loadConfig) {
                                                    context.loadConfig = loadConfig;
                                                    if (action.save) {
                                                        return JSON.parse(jsonWrite);
                                                }).then(function(saveConfig) {
                                                    context.saveConfig = saveConfig;
                                                    if (!optimizer) {
                                                        reportProgress(i18n.sprintf('WARNING: Unable to create optimizer for master with address 0x%04X', context.masterAddress));
                                                    if (context.loadConfig !== undefined) {
                                                        var config = context.loadConfig;
                                                        var options = {
                                                            optimize: !config,
                                                    context.loadedConfig = config;
                                                    if (context.saveConfig !== undefined) {
                                                        var saveConfig = context.saveConfig;
                                                        var oldConfig = context.oldConfig;
                                                        var options = {
                                                            optimize: false,
                                                        return context.customizer.saveConfiguration(saveConfig, oldConfig, options).progress(onProgress);
                                                    } else {
                                                        return config;
                                                    var jsonConfig = _.reduce(config, function(memo, value) {
                                                        return memo;
                                                    jsonConfig = JSON.stringify(jsonConfig);
                                                    if (action.out) {
                                                        return vbus.utils.promise(function(resolve, reject) {
                                                            fs.writeFile(action.out, jsonConfig, function(err) {
        if (err) {
        reject(err);
        } else {
        resolve();
                                                    } else {
                                                        console.log(jsonConfig);
                                                }).finally(function() {
                                                    reportProgress('Disconnecting...');
                                                    if (context.connection !== null) {
                                                        context.connection.disconnect();
                                            var main = function() {
                                                var argv = optimist.argv;
                                                if (argv.serve) {
                                                    return serve();
                                                } else {
                                            Q.fcall(main)
                                                .then(createStates)
                                                .then(writeStates)
                                                .then(Live)
                                            .done();
                                            LG,
                                            Axel
                                            118
                                            24225
