    4. Zigbee Adapter Einstellung nicht möglich
      losossos @arteck last edited by
      @arteck said in Zigbee Adapter Einstellung nicht möglich:
      also was versuchst du uns mitzuteilen ??
      Naja, der Zigbee-Adapter wird mir nicht aktueller als 1.10.3 angeboten. Wenn ich den Expertenmodus aktiviere kann ich Versionen höher 1.10.3 anwählen. Versuche ich diese aber zu installieren, bekomme ich folgendes log:
      $ iobroker upgrade zigbee@1.10.4 --debug
      Update zigbee from @1.10.3 to @1.10.4
      NPM version: 10.8.2
      Installing iobroker.zigbee@1.10.4... (System call)
      npm error code ETARGET
      npm error notarget No matching version found for iobroker.zigbee@1.10.4.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.
      npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-10-29T12_19_45_737Z-debug-0.log
      Updating objects from io-package.json for adapter "zigbee" with version "1.10.3"
      Update "system.adapter.zigbee.0"
      upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
      Process exited with code 0
      ob es dann was mit der npm-version zu tun hat - keine Ahnung, aber zumindest kommt ja diesbezüglich ne Fehlermeldung und der Adapter wird ja auch nicht in der entsprechenden Version installiert.
      Ich bin gerade dabei meine Hausautomation auf nen mini-PC und alles in Containern umzuziehen. Ggw. läuft aber noch alles über nen RPI 4 mit diesem Stand:
      PlatformBetriebssystem:linux
      Architektur:arm
      CPUs:4
      Geschwindigkeit:1800 MHz
      Modell:unknown
      RAM:7.6 GB
      System-Betriebszeit:20 T. 00:03:55
      Node.js:v20.18.0
      time:1730204860907
      timeOffset:-60
      NPM:10.8.2
      Adapter-Anzahl:634
      Datenträgergröße:58.2 GB
      Freier Festplattenspeicher:43.4 GB
      Aktive Instanzen:14
      Pfad:/opt/iobroker/
      Betriebszeit:5 T. 17:01:42
      aktiv:true
      _nodeCurrent:20.18.0
      _nodeNewest:20.18.0
      _nodeNewestNext:20.18.0
      _npmCurrent:10.8.2
      _npmNewest:10.8.2
      _npmNewestNext:10.8.2
      auch hier kann ich den Zigbee-adapter nicht höher als 1.10.3 installieren.
      (kommt die gleiche Fehlermeldung)
      • haselchen
        haselchen Most Active @losossos last edited by haselchen
        @losossos
        Liegt vielleicht daran, dass es diese Version nicht (mehr gibt)
        Er schreibt ja auch im Log no matching version found.
        Entweder nochmal manuell eine von den obigen Versionen installieren oder Expertenmodus und per GUI installieren (Kachel)
          losossos @haselchen last edited by
          @haselchen said in Zigbee Adapter Einstellung nicht möglich:
          ok, wenn ich versuche 1.10.10 zu installieren sieht das log so aus:
          $ iobroker upgrade zigbee@1.10.10 --debug
          Update zigbee from @1.10.3 to @1.10.10
          NPM version: 10.8.2
          Installing iobroker.zigbee@1.10.10... (System call)
          npm error notarget No matching version found for iobroker.zigbee@1.10.10.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.
          npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-10-29T12_36_21_600Z-debug-0.log
          upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
          upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
          upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
          upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
          upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
          🤷‍♂️ hmm wahrscheinlich liegts an meiner Aura 😕
          Homoran Thomas Braun haselchen 3 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @losossos last edited by
            @losossos sagte in Zigbee Adapter Einstellung nicht möglich:
            nöö, die 1.10.10 liegt noch nicht auf npm
              Thomas Braun Most Active @losossos last edited by
              @losossos
              Im Beta/Latest-Repo liegt nur die
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Das hat auch nix mit deiner npm-Version zu tun, das Regal mit dem Fach 1.10.10 ist einfach leer.
              • haselchen
                @losossos
                auf NPM liegt bis 1.10.3
                Höhere Versionen auf eigene Gefahr!
                Auf den Strich wo das rote Kreuz ist klicken und dann den zigbee Adapter aussuchen.
                Sollte was nicht passen oder völlig durcheinander geraten, dann wieder auf die 1.10.3!!!
                  losossos @Homoran last edited by
                  wie gesagt, habe den admin temporär auf 7.1.5 installiert. Danach konte ich im Zigbee-Adapter den entsprechenden Zugangsweg zum Coordinator einstellen. Anschließend habe ich den Admin wieder auf "aktuell" installiert und mein Zigbee-NW werkelt (noch). Also alles gut.
                  Ich gehe davon aus, das das Problem in Zunkuft schon irgendwann behoben wird.
                  Ggw. wurde mir ja geholfen, also will da jetzt kein Drama draus machen.
                  Danke an alle.
                    wieder auf Beta gesetzt...
                      losossos @Thomas Braun last edited by
                      @thomas-braun said in Zigbee Adapter Einstellung nicht möglich:
                      stimmt...
                      sorry für diesen Fauxpas : 😉
                        der Vollständigkeit halber; ja, wenn ich Github als Quelle angebe funzt es.
                        (auch das Einstellen des Com-Anschlusses geht nun)
                        sorry, das ich das nicht gleich 🙄 so gemacht habe.. Besten Dank!
                        zigbee adapter
                        877
