    4. iobroker.js-con 100% cpu
    • Marc Berg
      Marc Berg Most Active last edited by
      @thomas-braun sagte in iobroker.js-con 100% cpu:
      Da wird wohl irgendwas im Umfeld von mqtt / javaskript / history krumm sein.
      Sehe ich auch so. Mit einiger Wahrscheinlichkeit ist eine Schleife im MQTT Umfeld entstanden. Ohne Logs aber nicht final zu bewerten.
      • spicer
        spicer last edited by spicer
        @marc-berg
        Hier mal der log der letzten 2 Minuten:
        2024-10-29 17:39:36.406  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
        2024-10-29 17:39:36.406  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
        2024-10-29 17:39:54.140  - info: admin.0 (1274) ==> Connected system.user.admin from ::ffff:192.168.1.10
        2024-10-29 17:39:55.212  - info: admin.0 (1274) ==> Connected system.user.admin from ::ffff:192.168.1.10
        2024-10-29 17:40:00.033  - info: javascript.0 (2413) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
        2024-10-29 17:40:00.037  - info: javascript.0 (2413) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
        2024-10-29 17:40:10.047  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] connected with secret 1730220010046_3539
        2024-10-29 17:40:10.053  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
        2024-10-29 17:40:10.252  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] publishOnSubscribe
        2024-10-29 17:40:10.254  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:10.341  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] connected with secret 1730220010340_4058
        2024-10-29 17:40:10.345  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
        2024-10-29 17:40:10.544  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] publishOnSubscribe
        2024-10-29 17:40:10.546  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:10.688  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] connected with secret 1730220010671_5897
        2024-10-29 17:40:10.690  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
        2024-10-29 17:40:10.895  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] publishOnSubscribe
        2024-10-29 17:40:10.898  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:10.985  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] connected with secret 1730220010984_9685
        2024-10-29 17:40:10.994  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
        2024-10-29 17:40:11.198  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] publishOnSubscribe
        2024-10-29 17:40:11.201  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.287  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] connected with secret 1730220011286_3077
        2024-10-29 17:40:11.289  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
        2024-10-29 17:40:11.490  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] publishOnSubscribe
        2024-10-29 17:40:11.493  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.594  - info: mqtt.1 (2853) Client [mosqpub|32104-Dachrollo] connected with secret 1730220011591_1055
        2024-10-29 17:40:11.598  - info: mqtt.1 (2853) Client [mosqpub|32104-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.689  - info: mqtt.1 (2853) Client [mosqpub|32106-Dachrollo] connected with secret 1730220011689_2907
        2024-10-29 17:40:11.692  - info: mqtt.1 (2853) Client [mosqpub|32106-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.787  - info: mqtt.1 (2853) Client [mosqpub|32108-Dachrollo] connected with secret 1730220011786_3598
        2024-10-29 17:40:11.792  - info: mqtt.1 (2853) Client [mosqpub|32108-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.881  - info: mqtt.1 (2853) Client [mosqpub|32110-Dachrollo] connected with secret 1730220011880_7167
        2024-10-29 17:40:11.883  - info: mqtt.1 (2853) Client [mosqpub|32110-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:11.977  - info: mqtt.1 (2853) Client [mosqpub|32112-Dachrollo] connected with secret 1730220011977_2620
        2024-10-29 17:40:11.980  - info: mqtt.1 (2853) Client [mosqpub|32112-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:12.264  - info: mqtt.1 (2853) Client [mosqpub|32127-Dachrollo] connected with secret 1730220012263_3993
        2024-10-29 17:40:12.267  - info: mqtt.1 (2853) Client [mosqpub|32127-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:12.487  - info: mqtt.1 (2853) Client [mosqpub|32133-Dachrollo] connected with secret 1730220012483_2896
        2024-10-29 17:40:12.489  - info: mqtt.1 (2853) Client [mosqpub|32133-Dachrollo] connection closed: disconnected
        2024-10-29 17:40:15.215  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
        2024-10-29 17:40:15.216  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
        2024-10-29 17:40:26.015  - info: host.iobroker instance system.adapter.solarmanpv.0 in version "0.6.1" started with pid 3525
        2024-10-29 17:40:28.155  - info: solarmanpv.0 (3525) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.18.0, js-controller: 6.0.11
        2024-10-29 17:40:39.735  - info: solarmanpv.0 (3525) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2024-10-29 17:40:40.303  - info: host.iobroker instance system.adapter.solarmanpv.0 having pid 3525 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-10-29 17:41:09.838  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] connected with secret 1730220069837_6569
        2024-10-29 17:41:09.840  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
        2024-10-29 17:41:10.040  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] publishOnSubscribe
        2024-10-29 17:41:10.044  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:10.137  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] connected with secret 1730220070134_4114
        2024-10-29 17:41:10.141  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
        2024-10-29 17:41:10.342  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] publishOnSubscribe
        2024-10-29 17:41:10.345  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:10.430  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] connected with secret 1730220070430_9522
        2024-10-29 17:41:10.432  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
        2024-10-29 17:41:10.632  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] publishOnSubscribe
        2024-10-29 17:41:10.634  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:10.754  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] connected with secret 1730220070754_549
        2024-10-29 17:41:10.758  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
        2024-10-29 17:41:10.958  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] publishOnSubscribe
        2024-10-29 17:41:11.034  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.064  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] connected with secret 1730220071062_4274
        2024-10-29 17:41:11.066  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
        2024-10-29 17:41:11.266  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] publishOnSubscribe
        2024-10-29 17:41:11.268  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.370  - info: mqtt.1 (2853) Client [mosqpub|32169-Dachrollo] connected with secret 1730220071368_6906
        2024-10-29 17:41:11.373  - info: mqtt.1 (2853) Client [mosqpub|32169-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.466  - info: mqtt.1 (2853) Client [mosqpub|32171-Dachrollo] connected with secret 1730220071465_7954
        2024-10-29 17:41:11.468  - info: mqtt.1 (2853) Client [mosqpub|32171-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.574  - info: mqtt.1 (2853) Client [mosqpub|32173-Dachrollo] connected with secret 1730220071573_7598
        2024-10-29 17:41:11.577  - info: mqtt.1 (2853) Client [mosqpub|32173-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.689  - info: mqtt.1 (2853) Client [mosqpub|32175-Dachrollo] connected with secret 1730220071686_3418
        2024-10-29 17:41:11.692  - info: mqtt.1 (2853) Client [mosqpub|32175-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:11.785  - info: mqtt.1 (2853) Client [mosqpub|32177-Dachrollo] connected with secret 1730220071785_4540
        2024-10-29 17:41:11.787  - info: mqtt.1 (2853) Client [mosqpub|32177-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:12.102  - info: mqtt.1 (2853) Client [mosqpub|32192-Dachrollo] connected with secret 1730220072083_5782
        2024-10-29 17:41:12.104  - info: mqtt.1 (2853) Client [mosqpub|32192-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:12.272  - info: mqtt.1 (2853) Client [mosqpub|32198-Dachrollo] connected with secret 1730220072272_4085
        2024-10-29 17:41:12.274  - info: mqtt.1 (2853) Client [mosqpub|32198-Dachrollo] connection closed: disconnected
        2024-10-29 17:41:50.877  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] connected with secret 1730220110871_4120
        2024-10-29 17:41:51.030  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
        2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
        2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
        2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
        2024-10-29 17:41:51.047  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] connection closed: disconnected
        2024-10-29 17:41:51.230  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] publishOnSubscribe
        2024-10-29 17:41:51.247  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] publishOnSubscribe
        2024-10-29 17:41:51.526  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] connected with secret 1730220111511_8377
        2024-10-29 17:41:51.671  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
        2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
        2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
        2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
        2024-10-29 17:41:51.871  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
        2024-10-29 17:41:51.891  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
        2024-10-29 17:41:51.892  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
        2024-10-29 17:41:52.292  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1730220112290_6243
        2024-10-29 17:41:52.307  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
        2024-10-29 17:41:52.307  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
        2024-10-29 17:41:52.521  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
        2024-10-29 17:42:00.035  - info: javascript.0 (2413) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
        2024-10-29 17:42:00.053  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 57.6 °C
        2024-10-29 17:42:00.054  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 56.2 °C
        2024-10-29 17:42:00.054  - info: javascript.0 (2413) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
        2024-10-29 17:42:00.060  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 199
         MB von 2048MB (10%)
        2024-10-29 17:42:00.064  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 4300
         MB von 922MB (466%)
        2024-10-29 17:42:09.489  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] connected with secret 1730220129488_7150
        2024-10-29 17:42:09.496  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
        2024-10-29 17:42:09.696  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] publishOnSubscribe
        2024-10-29 17:42:09.698  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:09.784  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] connected with secret 1730220129783_376
        2024-10-29 17:42:09.792  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
        2024-10-29 17:42:09.991  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] publishOnSubscribe
        2024-10-29 17:42:09.995  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:10.083  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] connected with secret 1730220130082_8766
        2024-10-29 17:42:10.085  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
        2024-10-29 17:42:10.290  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] publishOnSubscribe
        2024-10-29 17:42:10.295  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:10.385  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] connected with secret 1730220130381_2598
        2024-10-29 17:42:10.391  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
        2024-10-29 17:42:10.606  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] publishOnSubscribe
        2024-10-29 17:42:10.613  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:10.709  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] connected with secret 1730220130702_1490
        2024-10-29 17:42:10.713  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
        2024-10-29 17:42:10.926  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] publishOnSubscribe
        2024-10-29 17:42:10.931  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.029  - info: mqtt.1 (2853) Client [mosqpub|32234-Dachrollo] connected with secret 1730220131025_2941
        2024-10-29 17:42:11.033  - info: mqtt.1 (2853) Client [mosqpub|32234-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.126  - info: mqtt.1 (2853) Client [mosqpub|32236-Dachrollo] connected with secret 1730220131125_3706
        2024-10-29 17:42:11.128  - info: mqtt.1 (2853) Client [mosqpub|32236-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.223  - info: mqtt.1 (2853) Client [mosqpub|32238-Dachrollo] connected with secret 1730220131223_4616
        2024-10-29 17:42:11.226  - info: mqtt.1 (2853) Client [mosqpub|32238-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.318  - info: mqtt.1 (2853) Client [mosqpub|32240-Dachrollo] connected with secret 1730220131318_7545
        2024-10-29 17:42:11.320  - info: mqtt.1 (2853) Client [mosqpub|32240-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.464  - info: mqtt.1 (2853) Client [mosqpub|32242-Dachrollo] connected with secret 1730220131450_8743
        2024-10-29 17:42:11.468  - info: mqtt.1 (2853) Client [mosqpub|32242-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.765  - info: mqtt.1 (2853) Client [mosqpub|32257-Dachrollo] connected with secret 1730220131764_8864
        2024-10-29 17:42:11.767  - info: mqtt.1 (2853) Client [mosqpub|32257-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:11.990  - info: mqtt.1 (2853) Client [mosqpub|32263-Dachrollo] connected with secret 1730220131973_9098
        2024-10-29 17:42:11.992  - info: mqtt.1 (2853) Client [mosqpub|32263-Dachrollo] connection closed: disconnected
        2024-10-29 17:42:25.976  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
        Alle Minuten kommen MQTT Daten von der Wetterstation rein. Sieht für mich sorichtig aus.
        Bleibt zu sagen, dass unter der alten Installation auf dem RPI3 keine 100% CPU gebraucht wurden.
        Habe ja beim RPI5 nur alles restored mittels Backitup.
        Wenn ich den MQTT Adapter pausiere, ist die CPU auf 2% !
          Homoran Global Moderator Administrators @spicer last edited by
          @spicer und was rattert da im Millisekundentakt durch?
          spicer 1 Reply Last reply Reply Quote 0
          • spicer
            spicer @Homoran last edited by
            Alle 1 Minute kommen da die verschiedenen Daten von der Wetterstation.
            wendy2702 Marc Berg 2 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @spicer last edited by
              @spicer ist die Wetterstation der “Aussenfühler” ?
              • spicer
                spicer @wendy2702 last edited by
                @wendy2702 Jep
                • Marc Berg
                  Marc Berg Most Active @spicer last edited by
                  @spicer
                  Hast du das Loglevel der MQTT.1 Instanz mal auf "debug" gestellt? Dann sieht man vielleicht mehr. So sieht das erstmal unspektakulär aus.
                  • wendy2702
                    @spicer der verliert scheinbar im Millisekunden Takt die Verbindung
                    • Marc Berg
                      Marc Berg Most Active @wendy2702 last edited by Marc Berg
                      @wendy2702 sagte in iobroker.js-con 100% cpu:
                      Oder ein ungünstig progammiertes Script, welches sich anmeldet, Wert subscribed, sich abmeldet, sich wieder anmeldet, nächsten Wert subscribed, ...
                      Darauf deutet der Name hin.
                      spicer 2 Replies Last reply Reply Quote 0
                      • spicer
                        spicer @Marc Berg last edited by
                        @marc-berg
                        Das könnte gut sein. Ich werd mal meine Scripts (Python und BASH) überprüfen.
                        • spicer
                          @marc-berg
                          Du hast mich auf die richtige Fährte gebracht. Wenn ich die MQTT Server IP ändere (ins Leere), sieht top so aus:
                          • Marc Berg
                            @spicer sagte in iobroker.js-con 100% cpu:
                            @marc-berg sagte in iobroker.js-con 100% cpu:
                            • spicer
                              @marc-berg
                              Ja, aber da kann so viel Output, dass top 300% CPU anzeigte ^^
                              • Marc Berg
                                @marc-berg
                                Das sagt aber schon alles. Ich bleibe dabei: eine Schleife.
                                spicer 1 Reply Last reply Reply Quote 1
                                • spicer
                                  @marc-berg
                                  Jo, das glaube ich Dir.
                                  Muss nun suchen 😞
                                  Ist ziemlich viel.
                                  • Marc Berg
                                    Muss nun suchen
                                    Aber wenn du das Debug-Log kurz anmachst, dann wirst du sicher Hinweise sehen.
                                      Thomas Braun Most Active @Marc Berg last edited by
                                      Ist zwar jetzt etwas OT hier, aber hier einer der wirklichen Gründe, warum man keine GUI auf einem Server laufen hat:
                                      https://www.phoronix.com/news/X.Org-CVE-2024-9632
                                      Was nicht läuft und am besten auch erst gar nicht installiert ist kann auch nicht anfällig für eine 'Privilege Escalation' sein.
                                      • spicer
                                        Hab das Problem gefunden.
                                        Alle 30 Sekunden oder teilweise sogar 10 Sekunden wurde der MQTT Server mit sub/pub's gelöchert.
                                        Wenn das geschieht, geht die CPU für ca 30 Sekunden auf 100%.
                                        Das war natürlich zuviel.
                                        Habe jetzt das Intervall (ausser Regen und Wind Warnung) auf mind 2 Minuten gesetzt.
                                        So beruhigt sich das Ganze immer für ca 90 Sekunden.
                                        • spicer
                                          Konnte die Situation weiter entschärfen, in dem ich alles MQTT auf dem RPI1, welches für die Dachfenster und Rollo Steuerung zuständig ist, sammle.
                                          Sende dann nur alle paar Minuten MQTT Daten an das RPI5.
                                          Einzig die Windgeschwindigkeit sende ich jede minute (das ist ein String von 3-4 Zeichen).
                                          Es fällt auf, dass der ioBroker Adapter MQTT auch nur bei diesem empfangenen MQTT Datensatz die CPU für fast 30 Sekunden auf 100-106% (laut top) treibt.
                                          Es sieht so aus, dass da der Adapter auch "etwas komisches" macht. Wenn ihr mich fragt, mit dem Adapter stimmt was nicht.
                                          So viel Rechenleistung wegen einem einzigen Subscribe (Datenempfang) von zBsp "0.1".
                                          Ein Loop kann es nicht sein, weil das Gleiche geschieht, wenn ich die Instanz Javascript stoppe.
                                          Befriedigend ist die jetzige Lösung bzw Verhalten nicht.
                                          PS:
                                          Beim RPI1 zeigt top unter 1% Auslastung, obschon da jede Sekunde Mosquitto Daten reinschneien.
                                          Dieses hat einen Bruchteil der Rechenleistung des RPI5!
                                          Wenn ich auf dem RPI1 top ausführe, ist meistens top der belastendste Task ^^
                                          • spicer
                                            spicer @spicer last edited by spicer
                                            @spicer
                                            Bitte testet doch mal selber und meldet es gegebenenfalls dem Dev.
                                            Es könnte ja auch sein, dass das nur bei Raspberry OS so ist und nicht bei Raspbian.
                                            deCONZ zBsp hatte genau dieses Problem!
                                            Eine if Abfrage ging auf "raspbian" und nicht auf "debian", was Raspberry OS heute ausgibt.
                                            1.0k
                                            8743
