    4. Leckagesensor SYR Safe-T Connect - how to get it smart
      dmq @KNXbroker last edited by
      @knxbroker bist Du ggf. schon weitergekommen? Danke vorab.
      K 2 Replies Last reply Reply Quote 0
        KNXbroker @dmq last edited by
        @dmq nicht wirklich, das Thema hat im Sommer leider keine Prio...
        Falls von Interesse, hier schon mal Node Red Code zum Auslesen der Webserver Requests.
        Die Einzelabfrage (komplett lokal) gestaltet sich als schwierig, da das interne LAN Modul immer dazwischen quatscht. Ich kann damit vorerst so leben, sollte es eines Tages die Cloud nicht mehr geben, dann werde ich das LAN Modul intern abklemmen.
        PS: Den Home Assistant spezifischen Teil habe ich in diesem Forum mal weggelassen.
        [{"id":"c346de70e5a46098","type":"serial in","z":"7d9d3cbb2597cd82","name":"","serial":"07c6650d2ff49b41","x":190,"y":2340,"wires":[["9d3388838e7f0cb7","94a5d32d473eb13d","d2190ca65994c11d","c499ae1e1b0a14b5","b09321ac134f816a","4ce39c90acf1d1d5"]]},{"id":"7c813e64bee7583b","type":"function","z":"7d9d3cbb2597cd82","name":"getBAR Match","func":"// Get water pressure [bar]\nconst pattern = new RegExp(\"(?<=getbar\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = Math.round(found[0].replace(',', '.') / 100) / 10;\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2640,"wires":[[]]},{"id":"0e3a4af116c977f1","type":"function","z":"7d9d3cbb2597cd82","name":"getVOL Match","func":"// Get total water volume [L]\nconst pattern = new RegExp(\"(?<=Vol\\\[L\\\])(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = found[0].replace(',', '.');\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2700,"wires":[[]]},{"id":"9d3388838e7f0cb7","type":"delay","z":"7d9d3cbb2597cd82","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":340,"y":2640,"wires":[["7c813e64bee7583b","0e3a4af116c977f1","1115f0f138466e0c","f424d047f8af2bea"]]},{"id":"1115f0f138466e0c","type":"function","z":"7d9d3cbb2597cd82","name":"getBAR Match","func":"// Get water pressure [Bar]\nconst pattern = new RegExp(\"(?<=getBat\\\\r)(\\\\d*,\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = Math.round(found[0].replace(',', '.') * 10) / 10;\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2760,"wires":[[]]},{"id":"f424d047f8af2bea","type":"function","z":"7d9d3cbb2597cd82","name":"getCEL Match","func":"// Get water temperature [°C]\nconst pattern = new RegExp(\"(?<=getCel\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = found[0].replace(',', '.') / 10;\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2820,"wires":[[]]},{"id":"94a5d32d473eb13d","type":"function","z":"7d9d3cbb2597cd82","name":"getAB Match","func":"// Get valve status [1= Open / 2 = Closed]\nconst pattern = new RegExp(\"(?<=getAB\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = Math.abs(found[0] - 2); // HA specific adaption\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":2460,"wires":[[]]},{"id":"d2190ca65994c11d","type":"function","z":"7d9d3cbb2597cd82","name":"getALA Match","func":"// Get alarms\nconst pattern = new RegExp(\"(?<=getALA\\\\r)(.*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    var failure;\n    var issue = true;\n    switch (found[0]) {\n        case \"A1\":\n            failure = \"Absperrung defekt\"\n            break;\n        case \"A2\":\n            failure = \"Kein Turbinen-Signal\"\n            break;\n        case \"A3\":\n            failure = \"Anwesenheits-Leckage\"\n            break;\n        case \"A4\":\n            failure = \"Durchfluss-Leckage\"\n            break;\n        case \"A5\":\n            failure = \"Abwesenheits-Leckage\"\n            break;\n        case \"A6\":\n            failure = \"Bodensensor-Leckage\"\n            break;\n        case \"A7\":\n            failure = \"Leckage an Eingang IN2\"\n            break;\n        case \"FF\":\n            failure = \"Keine\";\n            issue = false;\n            break;\n        default:\n            failure = \"Unbekannte Störung \" + found;\n    }\n    msg.payload = failure;\n    msg.issue = issue;\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2520,"wires":[[]]},{"id":"c499ae1e1b0a14b5","type":"function","z":"7d9d3cbb2597cd82","name":"getTMP Match","func":"// Get temporary inactivity time [s]\nconst pattern = new RegExp(\"(?<=getTMP\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = found[0];\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":2400,"wires":[[]]},{"id":"b09321ac134f816a","type":"function","z":"7d9d3cbb2597cd82","name":"getUL Match","func":"// Get presense\nconst pattern = new RegExp(\"(?<=getUL\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    if (found[0] == 0) {\n        msg.payload = true;\n        return msg;\n    }\n    else {\n        msg.payload = false;\n        return msg;\n    }\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":2340,"wires":[[]]},{"id":"4ce39c90acf1d1d5","type":"function","z":"7d9d3cbb2597cd82","name":"getLE Match","func":"// Get current water limit [L]\nconst pattern = new RegExp(\"(?<=getLE\\\\r)(\\\\d*)\", \"i\");\nvar found = msg.payload.match(pattern);\nif (Array.isArray(found)) {\n    msg.payload = found[0]*50;\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":2580,"wires":[[]]},{"id":"d9ef234728f55896","type":"comment","z":"7d9d3cbb2597cd82","name":"Anwesendheit","info":"","x":850,"y":2340,"wires":[]},{"id":"8c0b98a0743a69a4","type":"comment","z":"7d9d3cbb2597cd82","name":"Temporäre Inaktivität","info":"","x":870,"y":2400,"wires":[]},{"id":"f8dd9b2a4b0d85fb","type":"comment","z":"7d9d3cbb2597cd82","name":"Auslesen von WebServer Requests","info":"","x":260,"y":2260,"wires":[]},{"id":"edce790ca722ef59","type":"comment","z":"7d9d3cbb2597cd82","name":"Ventilstatus","info":"","x":850,"y":2460,"wires":[]},{"id":"7e4e1d3dbd0ef890","type":"comment","z":"7d9d3cbb2597cd82","name":"Alarm","info":"","x":830,"y":2520,"wires":[]},{"id":"ef3777ab8741ac8f","type":"comment","z":"7d9d3cbb2597cd82","name":"Wasserlimit","info":"","x":850,"y":2580,"wires":[]},{"id":"8369c6d71aa2f63a","type":"comment","z":"7d9d3cbb2597cd82","name":"Wasserdruck","info":"","x":850,"y":2640,"wires":[]},{"id":"242b89811638941f","type":"comment","z":"7d9d3cbb2597cd82","name":"Volumen Gesamt","info":"","x":860,"y":2700,"wires":[]},{"id":"6cedcffe51a141e9","type":"comment","z":"7d9d3cbb2597cd82","name":"Wasserdruck","info":"","x":850,"y":2760,"wires":[]},{"id":"836ac7537e1cce37","type":"comment","z":"7d9d3cbb2597cd82","name":"Wassertemperatur","info":"","x":870,"y":2820,"wires":[]},{"id":"07c6650d2ff49b41","type":"serial-port","serialport":"/dev/ttyUSB1","serialbaud":"19200","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"2000","bin":"false","out":"interbyte","addchar":"","responsetimeout":"300"}]
          @dmq Und hier Node Red Code zur Steuerung, wieder ohne Home Assistant Knoten.
          ToDo: Bestätigung von Alarm Meldungen!
          Steuerung ist ebenfalls vom WebServer abhängig und somit nicht lokal. Der Code wartet auf die WebServer Abfrage und schickt danacht Befehle los, um eine Kollision zu vermeiden.
          [{"id":"d2dddf837a5f48b7","type":"function","z":"7d9d3cbb2597cd82","name":"Wait for msg.release","func":"const messages = context.get('messages') || [];\n\nif(msg.release) {\n    context.set('messages', null);\n    node.status({text: `Sent: ${messages.length}`});\n    return [messages];\n}\n\nmessages.push(msg);\ncontext.set('messages', messages);\nnode.status({text: `Holding: ${messages.length}`});","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":2580,"wires":[["9f5e2b7a9f1ee9da"]]},{"id":"850c0728ec1a735c","type":"change","z":"7d9d3cbb2597cd82","name":"","rules":[{"t":"set","p":"release","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":2440,"wires":[["d2dddf837a5f48b7"]]},{"id":"2841702637ee5a33","type":"function","z":"7d9d3cbb2597cd82","name":"setAB2","func":"// Close the vavle\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setAB2\");\nvar cmdend = Buffer.from(\"0d0a\", \"hex\"); // cR + LF\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":2520,"wires":[["d2dddf837a5f48b7"]]},{"id":"7ec7b7f3b2be5f8b","type":"function","z":"7d9d3cbb2597cd82","name":"setAB1","func":"// Open the vavle\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setAB1\");\nvar cmdend = Buffer.from(\"0d0a\", \"hex\"); // CR + LF\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":2580,"wires":[["d2dddf837a5f48b7"]]},{"id":"3bc209160cce93a1","type":"serial in","z":"7d9d3cbb2597cd82","name":"","serial":"07c6650d2ff49b41","x":170,"y":2440,"wires":[["850c0728ec1a735c"]]},{"id":"41ad879c02123e89","type":"function","z":"7d9d3cbb2597cd82","name":"setTmp0","func":"// Set temporary inactivity time to 0s\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setTMP0\");\nvar cmdend = Buffer.from(\"0d\", \"hex\");\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":2740,"wires":[["d2dddf837a5f48b7"]]},{"id":"fce9cff1374cce55","type":"function","z":"7d9d3cbb2597cd82","name":"setTmp14400","func":"// Set temporary inactivity time to 4h\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setTMP14400\");\nvar cmdend = Buffer.from(\"0d\", \"hex\");\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":2680,"wires":[["d2dddf837a5f48b7"]]},{"id":"46a371ee6322b0b8","type":"comment","z":"7d9d3cbb2597cd82","name":"SYR Connect - Control ","info":"","x":200,"y":2380,"wires":[]},{"id":"55aa5d6d321d51ec","type":"function","z":"7d9d3cbb2597cd82","name":"setUL0","func":"// Close the vavle\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setUL0\");\nvar cmdend = Buffer.from(\"0d0a\", \"hex\"); // cR + LF\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":2820,"wires":[["d2dddf837a5f48b7"]]},{"id":"abef738776e765eb","type":"function","z":"7d9d3cbb2597cd82","name":"setUL3","func":"// Open the vavle\nvar cmdstart = Buffer.from(\"0d0a1b313a\", \"hex\");\nvar cmdmiddle = Buffer.from(\"setUL3\");\nvar cmdend = Buffer.from(\"0d0a\", \"hex\"); // CR + LF\nmsg.payload = Buffer.concat([cmdstart, cmdmiddle, cmdend]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":2880,"wires":[["d2dddf837a5f48b7"]]},{"id":"e3b1591eaec5c765","type":"comment","z":"7d9d3cbb2597cd82","name":"Ventil Zu","info":"","x":160,"y":2520,"wires":[]},{"id":"9a432a6df02f8f39","type":"comment","z":"7d9d3cbb2597cd82","name":"Ventil Auf","info":"","x":160,"y":2580,"wires":[]},{"id":"996ebd2f1e184a87","type":"comment","z":"7d9d3cbb2597cd82","name":"Anwesend","info":"","x":160,"y":2820,"wires":[]},{"id":"95ab097536ee9cf2","type":"comment","z":"7d9d3cbb2597cd82","name":"Abwesend (30L)","info":"","x":180,"y":2880,"wires":[]},{"id":"b25ef65f1a65fc12","type":"comment","z":"7d9d3cbb2597cd82","name":"Inaktiv Timer 4h","info":"","x":180,"y":2680,"wires":[]},{"id":"bc165e6cd206e810","type":"comment","z":"7d9d3cbb2597cd82","name":"Inaktiv Timer Aus","info":"","x":180,"y":2740,"wires":[]},{"id":"344b580893fb384e","type":"serial out","z":"7d9d3cbb2597cd82","name":"","serial":"07c6650d2ff49b41","x":730,"y":2720,"wires":[]},{"id":"9f5e2b7a9f1ee9da","type":"delay","z":"7d9d3cbb2597cd82","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":720,"y":2660,"wires":[["f4043b8aa0ba6a4e","344b580893fb384e"]]},{"id":"07c6650d2ff49b41","type":"serial-port","serialport":"/dev/ttyUSB1","serialbaud":"19200","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"2000","bin":"false","out":"interbyte","addchar":"","responsetimeout":"300"}]
            @knxbroker besten Dank dafür. Schaue ich mir mal in Ruhe an.
              Hi @dmq, und alle anderen die daran Interesse haben:
              Habe nun auch die Bestätigung von Alarmmeldungen in Node Red Implementiert, ich verweise hier einfach mal auf meinen Post im Home Assistant Forum:
              https://community.home-assistant.io/t/add-support-for-leakage-detection-device-safe-t-connect-from-hans-sasserath-gmbh-co-kg/172728/12?u=knxbroker
              Eine komplette Offline Lösung sollte eigentlich auch nicht so schwer sein zu implementieren, aber für mich erstmal so okay.
                dmq @KNXbroker last edited by dmq
                @knxbroker danke fürs informieren und freigeben. Ich habe die Komponenten hier, aber noch nicht physisch eingebaut (überlege auch noch ob ich es selbst einbaue oder (versuche) einbauen zu lassen. Daran hängt leider mein Fortschritt mich da tiefer einzuarbeiten und hoffentlich auch mal was sinnvolles zurückzugeben 😉
                  @dmq Kein Ding, vielleicht hilft es ja auch anderen. Ohne die Hilfe von @Kachel wäre das nicht möglich gewesen, großes Dankeschön meinerseits. 👍
                    A Former User @Kachel last edited by
                    @kachel @KNXbroker
                    Die hier gezeigte Loesung waere mein Plan B gewesen, vielen Dank euch allen, die sich hier soviel Arbeit machen und alles und jeden Schritt dokumentieren!
                    Wer das hier findet, und vielleicht lieber ein Adapter installiert (leider wird zur Zeit noch ein dns-routing und webserver(alternativ iptables) gebraucht. Ist aber kein Hexenwerk zum installieren.
                    Der Adapter unterstuetzt seit heute auch die SyrLexPlus10SL.
                    https://github.com/eifel-tech/ioBroker.syrconnect
                      Habe mittlerweile auch eine Node Red Offline Lösung mittels seriellen Adapter am Laufen falls jemand Interesse hat. Läuft seit über einem Jahr ohne Probleme und ich bin nicht mehr auf die SYR Cloud angewiesen.
                      ? D 2 Replies Last reply Reply Quote 0
                        A Former User @KNXbroker last edited by
                        @knxbroker
                        kannst du auch schalten, Ventil, Abwesend etc.. ?
                        Meine ist ja Enthaertungsanlage und Safeconnect in einem...
                          KNXbroker @Guest last edited by
                          @ilovegym kann alles schalten, aber habe den SYR safe-t connect; habe das Netzwerkkabel rausgezogen und bediene nun alles mittels der seriellen Service Schnittstelle
                            @knxbroker ich hätte Interesse an der Node Red Offline Lösung. Hast Du hierzu einen Link? Würde mich sehr freuen - danke vorab.
                              @dmq Kein Problem, unten findest du den Node Red Code im Anhang zur lokalen Ansteuerung eines SYR safe-t connect über RS485. Wie gesagt, ich nutze IOBroker nicht mehr, du musst die ganzen Home Assistant I/O Nodes entsprechend konvertieren, aber die Logik sollte die gleiche sein.
                              Achtung: Netzwerkkabel abstecken, sonst funktioniert es nicht. Parallelbetrieb von Cloud und dieser Offline Lösung ist nicht möglich, aber die Offline Lösung arbeitet bei mir seit langem zuverlässiger als die Cloud.
                              Was macht das Script?
                              • Alle drei Minuten gibt es auf dem RS485 Bus eine Art ALIVE Abfrage. Das Skript wartet auf diese Abfrage und beginnt dann zu arbeiten.
                              • Alle 20s werden Steuerungsbefehle abgeschickt, sofern vorhanden. Alle 25s werden die Statusdaten vom Gerät gelesen.
                              • Kurz bevor die ALIVE Abfrage wieder kommt, macht das Skript Pause und synchronisiert sich dann wieder auf die nächste ALIVE Abfrage auf.
                              Viel Spass
                              SYR Connect RS485 Offline Control V2.txt
                                @knxbroker super, vielen Dank. Schöne Tage wünsche ich.
                                  @knxbroker melde mich noch mal zurück, ich hoffe kleinere Rückfragen sind für dich in Ordnung. Als Eingang hätte ich ein serielles Gerät (ttyX) erwartet. Hier ist aber eine TCP/IP-Quelle (modbus-tcp, tcp/500). Hast Du da ggf. einen RS485 / MODBUS-TCP -Konverter dazwischen? Lieben Dank vorab.
                                    KNXbroker @dmq last edited by KNXbroker
                                    @dmq ich hatte zu Beginn einen seriellen USB Stick am Raspberry, der hatte aber immer wieder Startprobleme (glaube das war aber ein Problem vom Stick / Rasperry Setup). Theoretisch sollte es genauso funktionieren, du musst nur die TCP Knoten tauschen, die seriellen Knoten sollten ähnlich heißen. Ich bin dann auf einen Waveshare RS485 auf Ethernet Konverter gewechselt, seit dem läuft es bei mir ohne Probleme.
                                      @knxbroker ok, sehr schön. Einen Waveshare RS485 Konverter habe ich tatsächlich auch noch hier liegen 😉 Danke Dir und komm gut ins neue Jahr.
                                        tschortsch @KNXbroker last edited by
                                        @knxbroker
                                        kannst du mir sagen, wie du den Syr-Safe+ in den iobroker eingebunden hast bzw. wie du den steuerst?
                                        Viele Grüße
                                          tombox last edited by
                                          @tschortsch
                                          Dieser Adapter kann dafür genutzt werden
                                          https://forum.iobroker.net/topic/79653/test-syrconnect-app-adapter
                                          5317
