    3. Einsteigerfragen
    4. wieviel ist zu viel an Adapter?
      andibr @Thomas Braun last edited by andibr
      klar ist ja auch das temporäre Backup restore und alle Adapter sind deaktiviert. Ich habe soeben den echten LXC nochmals gestartet und lasse gerade auch das diag laufen. das sieht ganz anderst aus:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: Iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : 12th Gen Intel(R) Core(TM) i5-12400
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:54:17 up 15 min,  2 users,  load average: 1.76, 1.50, 1.56
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2024-10-29 18:54:17 CET
                 Universal time: Tue 2024-10-29 17:54:17 UTC
                       RTC time: n/a
                      Time zone: Europe/Zurich (CET, +0100)
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      andi
      HOME=/home/andi
      GROUPS=andi adm sudo users iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             12G         45M         11G        118K        908M         12G
      Swap:           8.6G          0B        8.6G
      Total:           21G         45M         20G
      Active iob-Instances:   0
              12000 M total memory
                 43 M used memory
                152 M active memory
                732 M inactive memory
              11090 M free memory
                  0 M buffer memory
                866 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      top - 18:54:17 up 15 min,  2 users,  load average: 1.76, 1.50, 1.56
      Tasks:  26 total,   1 running,  25 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  12000.0 total,  11088.6 free,     45.1 used,    866.4 buff/cache
      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  11954.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--105--disk--0 ext4       98G   23G   71G  25% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.2G  112K  6.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--105--disk--0 ext4   rw,relatime,stripe=16
      /var:
      507M    /var/
      248M    /var/cache
      244M    /var/cache/apt
      168M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 110.8M in the file system.
      /opt/iobroker/backups:
      6.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      7.9G    /opt/iobroker/iobroker-data/
      5.1G    /opt/iobroker/iobroker-data/history
      1.3G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      612M    /opt/iobroker/iobroker-data/esphome.0/.esphome
      483M    /opt/iobroker/iobroker-data/objects.jsonl
      183M    /opt/iobroker/iobroker-data/states.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      <--- Last few GCs --->
      [1413:0x752ffd0]    21777 ms: Scavenge 2034.9 (2081.3) -> 2034.8 (2086.3) MB, 3.70 / 0.00 ms  (average mu = 0.341, current mu = 0.186) allocation failure;
      [1413:0x752ffd0]    21792 ms: Scavenge 2037.7 (2086.3) -> 2037.6 (2087.3) MB, 5.01 / 0.00 ms  (average mu = 0.341, current mu = 0.186) allocation failure;
      [1413:0x752ffd0]    21981 ms: Scavenge 2038.6 (2087.3) -> 2038.2 (2097.3) MB, 184.96 / 0.00 ms  (average mu = 0.341, current mu = 0.186) allocation failure;
      <--- JS stacktrace --->
      FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      ----- Native stack trace -----
       1: 0xb8ced1 node::OOMErrorHandler(char const*, v8::OOMDetails const&) [node]
       2: 0xf06460 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [node]
       3: 0xf06747 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [node]
       4: 0x11182e5  [node]
       5: 0x1130168 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
       6: 0x1106281 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
       7: 0x1107415 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
       8: 0x10e3faa v8::internal::Factory::AllocateRawWithAllocationSite(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [node]
       9: 0x10f1448 v8::internal::Factory::NewJSObjectFromMap(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [node]
      10: 0x1248ca3 v8::internal::JsonParser<unsigned char>::BuildJsonObject(v8::internal::JsonParser<unsigned char>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [node]
      11: 0x124c6f7  [node]
      12: 0x124e9a9 v8::internal::JsonParser<unsigned char>::ParseJson(v8::internal::Handle<v8::internal::Object>) [node]
      13: 0xf98231 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [node]
      14: 0x7c8745ed9df6
      /usr/bin/iob: line 21:  1411 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      Hosts:
      [1453:0x7302250]    20704 ms: Scavenge 2036.9 (2083.3) -> 2036.8 (2088.5) MB, 3.73 / 0.00 ms  (average mu = 0.335, current mu = 0.201) allocation failure;
      [1453:0x7302250]    20718 ms: Scavenge 2039.8 (2088.5) -> 2039.7 (2089.5) MB, 4.73 / 0.00 ms  (average mu = 0.335, current mu = 0.201) allocation failure;
      [1453:0x7302250]    20895 ms: Scavenge 2040.6 (2089.5) -> 2040.2 (2099.3) MB, 174.24 / 0.00 ms  (average mu = 0.335, current mu = 0.201) allocation failure;
       4: 0x11182e5  [node]
       8: 0x10e3b36 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node]
       9: 0x10d5764 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node]
      10: 0x10d7f46 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [node]
      11: 0x1247508 v8::internal::JsonParser<unsigned char>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [node]
      12: 0x124c96d  [node]
      13: 0x124e9a9 v8::internal::JsonParser<unsigned char>::ParseJson(v8::internal::Handle<v8::internal::Object>) [node]
      14: 0xf98231 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [node]
      15: 0x73f23bcd9df6
      /usr/bin/iob: line 21:  1451 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     4
      +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#d60377cc7c7d3092a8bcb1cf945ed256cba6e96f)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
      +-- iobroker.timer-switch@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.timer-switch.git#f38b114f0ed2d399b3f2665ea92a8f841727e0e5)
      Adapter State
      ioBroker-Repositories
       Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "bestway"      : 0.0.4    , installed 0.0.4
       Objects database error: read ECONNRESET
      Adapter    "device-reminder": 3.1.2  , installed 3.0.0  [Updatable]
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "pid"          : 1.1.3    , installed 1.1.3
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "roborock"     : 0.6.16   , installed 0.6.16
      Adapter    "rssfeed"      : 3.1.0    , installed 3.1.0
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
       Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.Iobroker"]
      Objects and States
      andi@Iobroker:~$ systemctl status iobroker.service
      * iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
           Active: active (running) since Tue 2024-10-29 19:00:59 CET; 6s ago
             Docs: http://iobroker.net
         Main PID: 1853 (iobroker.js-con)
            Tasks: 11 (limit: 38006)
           Memory: 1.9G
              CPU: 8.338s
           CGroup: /system.slice/iobroker.service
                   `-1853 iobroker.js-controller
      Oct 29 19:00:59 Iobroker systemd[1]: Started iobroker.service - ioBroker Server.
      andi@Iobroker:~$
        Thomas Braun Most Active @David G. last edited by
        @david-g
        Der dort aufgeführte admin ist aber nicht 'alive'. Wenn er es wäre, dann würde er auf port 8081 SSL-verschlüsselt lauschen.
          andi@Iobroker:~$ netstat -tulpen
          (No info could be read for "-p": geteuid()=1000 but you should be root.)
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          4574757    -
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       4631345    -
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4578329    -
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          4574758    -
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4564985    -
          tcp6       0      0 :::111                  :::*                    LISTEN      0          4578331    -
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4573038    -
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4578330    -
          udp        0      0 192.168.130.10:123      0.0.0.0:*                           0          4579372    -
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          4579370    -
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          4579366    -
          udp6       0      0 :::111                  :::*                                0          4578332    -
          udp6       0      0 fe80::be24:11ff:fe6:123 :::*                                105        4579447    -
          udp6       0      0 ::1:123                 :::*                                0          4579374    -
          udp6       0      0 :::123
          • David G.
            David G. @andibr last edited by David G.
            @andibr
            Die Frage ist eher was das alles ist
             1: 0xb8ced1 node::OOMErrorHandler(char const*, v8::black_right_pointing_double_triangle_with_vertical_bar: OMDetails const&) [node]
            Oder
              andibr @David G. last edited by
              das ist genau mein Problem. Ich habe jetzt zwei Installationen, eine alte die völlig zerschossen ist und eine neue von heute die als nackte curl Installation lief und nach dem Backup Restore auch nicht mehr erreichbar ist.
              Ich gehe davon aus, dass mein Backup schon irgendwie ein Fehler hat und darum den Restore zwar macht, aber die ganze Installation gleich zersetzt. Klar ich könnte es jetzt auch noch mit einem Backup von vor einer Woche testen, aber irgendwie möchte ich gerne wissen wo dass das Problem ist, damit ich es beseitigen kann. Genau darum habe ich auch diesenetwas merkwürdigen Titel gewählt.
              Kann ich beim Restore irgendwie selektiv auswählen was er machen soll?
                andibr @andibr last edited by
                ich habe jetzt nochmals ein neuer LXC-Container mit einer älteren Debian 12 gemacht, jetzt hat auch der Restore irgendwie besser funktioniert.
                Ich habe jetzt nur die allernötigsten Adapter eingeschaltet und schaue mal wie lange es jetzt stabil läuft.
                • Codierknecht
                  Codierknecht Developer Most Active last edited by
                  @andibr
                  "Wenn aber der js-controller-Prozess ständig über 50-70% CPU in Anspruch nimmt oder seine IO-Last im Dateisystem spürbar wird, kann es Zeit werden sich über den Einsatz von Redis Gedanken zu machen"
                  https://forum.iobroker.net/topic/26327/redis-in-iobroker-überblick
                  • David G.
                    @andibr sagte in wieviel ist zu viel an Adapter?:
                    Wartest aber nach dem restore einige Zeit oder?
                    Da müssen alle Adapter neu geladen und gebaut werden. Das kann schonmal was dauern....
                      Ja, das dauert bei mir mit dem aktuell Backup gut 1h. Solange kann man in der Linux Shell sehr gut die Auslastung sehen. Immerhin ist das ganze jetzt über Nacht durchgelaufen und macht wieder was es soll.
                      Ich werde mich wohl mal mit Redis beschäftigen.
                        andibr @andibr last edited by andibr
                        Leider funktioniert das ganze immer noch nicht zuverläsig, und ich stehe da etwas im abseits weil ich nicht mehr weiss wo suchen.
                        Nach dem es gestern nach ca 23h. wieder komplett abgestürzt ist und der "iob fix" die Meldung "no connect Databases" gebracht hat, habe ich nun den kompletten Proxmox platt gemacht und alles neu aufgesetzt.
                        Logischerweise zusätzlich gleich redis nach der Basis-Installation gemacht. Jetzt läuft es seit ca 12h mit diesem "iob diag":
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                         Static hostname: iobroker
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         08:10:13 up 10:42,  2 users,  load average: 0.11, 0.17, 0.11
                        CPU threads: 8
                                       Local time: Fri 2024-11-01 08:10:14 CET
                                   Universal time: Fri 2024-11-01 07:10:14 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        andi
                        HOME=/home/andi
                        GROUPS=andi sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev redis
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:             12G        2.9G        2.1G        131K        7.5G        9.6G
                        Swap:           8.6G          0B        8.6G
                        Total:           21G        2.9G         10G
                        Active iob-Instances:   21
                                 2806 M used memory
                                 2764 M active memory
                                 7016 M inactive memory
                                 2018 M free memory
                                    0 M buffer memory
                                 7175 M swap cache
                                 8191 M total swap
                                    0 M used swap
                                 8191 M free swap
                        top - 08:10:14 up 10:42,  2 users,  load average: 0.11, 0.17, 0.11
                        Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  12000.0 total,   2016.7 free,   2808.1 used,   7175.4 buff/cache
                        MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   9191.9 avail Mem
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--110--disk--0 ext4      196G   15G  172G   8% /
                        tmpfs                            tmpfs     6.2G  120K  6.2G   1% /run
                        /      /dev/mapper/pve-vm--110--disk--0 ext4   rw,relatime,stripe=16
                        /var:
                        417M    /var/
                        245M    /var/cache
                        242M    /var/cache/apt
                        166M    /var/cache/apt/archives
                        146M    /var/lib
                        Archived and active journals take up 8.0M in the file system.
                        2.1G    /opt/iobroker/backups/
                        7.2G    /opt/iobroker/iobroker-data/
                        134M    /opt/iobroker/iobroker-data/states.jsonl
                        130M    /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 38570)
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     5
                        +-- iobroker.enocean@0.9.4 (git+ssh://git@github.com/jey-cee/ioBroker.enocean.git#7a623c622a67ec6f723822940570dc0b36883ab2)
                        +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#8ca51cd0460c21c1a817acc18c774da1fcf4f5ff)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.bestway.0                : bestway               : iobroker                                 - disabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                          system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                          system.adapter.devices.0                : devices               : iobroker                                 - disabled
                          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                          system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
                        + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                          system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                          system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
                        + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
                          system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                          system.adapter.pid.0                    : pid                   : iobroker                                 - disabled
                          system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                          system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
                          system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                        + system.adapter.timer-switch.0           : timer-switch          : iobroker                                 -  enabled
                          system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.wireless-mbus.1          : wireless-mbus         : iobroker                                 - disabled
                        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                        + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                        + instance is alive
                        Adapter    "wled"         : 0.7.2    , installed 0.7.3-beta.0
                        Objects and States
                        Objects:        178881
                        States:         144886
                        Hit:2 http://security.debian.org bookworm-security InRelease
                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       10723      163/iobroker.js-con
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       10718      163/iobroker.js-con
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15136      321/master
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10932      571/io.shelly.1
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11882      556/io.mqtt.1
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       16944      541/io.mqtt.0
                        tcp        0      0 0.0.0.0:502             0.0.0.0:*               LISTEN      1001       11854      499/io.modbus.1
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9892       1/init
                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        7651       151/redis-server 12
                        tcp6       0      0 ::1:6379                :::*                    LISTEN      105        7652       151/redis-server 12
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          7620       1/init
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          9894       1/init
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9057       692/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4574       332/io.admin.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       11078      722/io.ws.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15137      321/master
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5885       707/io.wled.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11655      92/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9893       1/init
                        udp6       0      0 :::111                  :::*                                0          9895       1/init
                        2024-11-01 08:04:05.703  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:04:38.704  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:04:38.704  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:05:11.707  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:05:11.707  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:05:44.708  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:05:44.708  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:06:17.708  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:06:17.708  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:06:50.710  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:06:50.710  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:07:23.713  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:07:23.713  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:07:56.842  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:07:56.842  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:08:29.843  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:08:29.843  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:09:02.843  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:09:02.843  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:09:35.843  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:09:35.843  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:10:08.843  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:10:08.843  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        2024-11-01 08:10:41.845  - error: wled.0 (707) [requestDeviceDataByAPI] AxiosError: timeout of 3000ms exceeded
                        2024-11-01 08:10:41.845  - warn: wled.0 (707) Unable to initialise 192.168.130.162 will retry in scheduled interval !
                        und ja, es läuft bei weitem nicht alles was ich drauf habe, sondern nur dass was ich zum Betrieb meines Hauses wirklich brauche. Irgendwie traue ich der ganze Sache schlicht noch nicht, denn ich würde zu gerne wissen woran es scheitert um eine weitere solche Aktion verhindern zu können.
                        Ich sehe hier gerade das bei den States wieder "json" steht, da stimmt doch was schon wieder nicht mehr. Stellt sich das mit einem Restore wieder auf json zurück
                        andi@iobroker:~$ iob setup custom
                        Current configuration:
                        - Objects database:
                          - Type: jsonl
                          - Host/Unix Socket: 0.0.0.0
                          - Port: 9001
                        - States database:
                          - Type: jsonl
                          - Port: 9000
                        - Data Directory: ../../iobroker-data/
                        Nur damit keiner fragen muss: ich habe das mit dem User "andi" der root rechte hat installiert. Ich habe jetzt die "States wieder auf redis gestellt und er hat mir die Daten konvertiert.
                        Gibt es irgend eine ersichtlichen Grund wieso sich mein System so merkwürdig verhält, oder anderst gefragt was ist bei mir anderst und läuft darum nicht stabil? (ich weiss ist die berühmte "suche nach der Nadel im Heuhaufen" , aber vieleicht hat einer einen Magneten dafür).
                        Danke für Tips
                        Edit:
                        und schon gehen die Probleme wieder los:
                        andi@iobroker:~$ iob start
                        andi@iobroker:~$ iob status
                         Cannot read system.config: null (OK when migrating or restoring)
                        Objects type: file
                        States  type: redis
                        andi@iobroker:~$
                        ich verstehe es nicht mehr
                        • Marc Berg
                          Marc Berg Most Active last edited by Marc Berg
                          Ist das eine Frage? Wenn das Backup aus Zeiten stammt, in denen der ioBroker noch auf "jsonl" lief, ist das Verhalten normal.
                          Objects type: file
                          States  type: redis
                          Keine Ahnung, ob das mit deinen Problemen zusammenhängt, aber "file" ist schon länger nicht mehr der empfohlene Type. Wenn du sowieso Redis hast, warum nicht auch die Objects-DB umstellen?
                            andibr @Marc Berg last edited by andibr
                            @marc-berg
                            Ich habe erst seit dem jetzt vorletzen installieren aus redis umgestellt. Aber gut zu wissen, das er beim restore die "state" auch überschreibt. Ich habe jetzt auf der Konsole das Backup von heute morgen 03.00 zurück geholt und jetzt scheint es wieder zu laufen.
                            Objects type: jsonl
                            States  type: redis
                            andi@iobroker:~$
                            Ich frage mich langsam ob es an meinen Fähigkeiten liegt, oder ob ich irgendwo rundum ein Problem habe. Die Hardware möchte ich ja nicht ganz ausschliessen, aber die ist noch kein halbes Jahr alt und zeugt auch bei der SSD bisher keine Auffälligkeiten.
                            Edit:
                            Was ich sicher schon bezeugen kann: die vis ist mit redis sehr viel schneller in der Anzeige
                            2072
