    4. [gelöst] Backitup Problem mit Influxdb 1.x
      darkblu @Thomas Braun last edited by
      @thomas-braun , hat leider nix gebracht.
      im Log steht nach wie vor:
      backitup.0
      2024-11-01 15:55:05.790	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      backitup.0
      2024-11-01 15:55:02.659	error	[iobroker/ftp] File "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker.tar.gz" not found
      backitup.0
      2024-11-01 15:54:35.604	error	[iobroker] Error: Command failed: influxd backup -portable -database iobroker-db -host 192.168.178.39:8086 "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker"/bin/sh: 1: influxd: not found
      backitup.0
      2024-11-01 15:54:35.603	error	[iobroker/influxDB] /bin/sh: 1: influxd: not found
      backitup.0
      2024-11-01 15:54:35.603	error	[iobroker/influxDB] Error: Command failed: influxd backup -portable -database iobroker-db -host 192.168.178.39:8086 "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker"
      und im Fenster vom Backup erstellen:
      15:54:36.733DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker"
      15:54:36.761DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker" successfully deleted
      [DEBUG] [influxDB] -
      15:54:36.767ERRORinfluxDBError: Command failed: influxd backup -portable -database iobroker-db -host 192.168.178.39:8086 "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker"
      15:54:36.769DEBUGinfluxDBInfluxDB-Backup for is finish
      15:54:36.771DEBUGinfluxDBdone
      15:55:03.820ERRORftpFile "/opt/iobroker/backups/influxDB_2024_11_01-15_54_35_backupiobroker.tar.gz" not found
      15:55:06.907ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
        Thomas Braun Most Active @darkblu last edited by
        @darkblu sagte in Backitup Problem mit Influxdb 1.x:
        influxd: not found
        Welche Version ist denn jeweils auf den Kisten installiert?
          @thomas-braun said in Backitup Problem mit Influxdb 1.x:
          influxd: not found
          auf dem "alten" Raspi 4 ist Influxdb 1.8
          auf dem neuen Raspi 5 ist der ioBroker mit dem Influxdb Adapter 4.0.2
          oder was meinst du ?
            Da muss auch influx 1.8 installiert werden.
              auf beiden Raspis muss Influx installiert sein ?
              Das war ja meine Idee, Influx und ioBroker getrennt zu haben
                Ja.
                  @thomas-braun , kannst du mir erklären warum.
                  Es soll ja alles in Influx auf dem Raspi 4 reingeschrieben werden, und auch die soll gesichert werden.
                    Weil du auf dem Client die influxdb-clients brauchst. Und die sind halt in influxdb drin.
                    D Marc Berg 2 Replies Last reply Reply Quote 0
                      @thomas-braun , ok
                      dann mach ich das (später mal)
                      sitze heute schon wieder viel zu lang davor 😄
                        @darkblu
                        Siehe auch:
                        https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#influxdb-backup
                        • Marc Berg
                          Marc Berg Most Active @Thomas Braun last edited by
                          @thomas-braun sagte in Backitup Problem mit Influxdb 1.x:
                          Kleine Korrektur: Bei InfluxDb 1.x ist es eben nicht der Client, der zum Backup/Restore genutzt wird, sondern das Binary, welches auch den Server stellt (influxd).
                          Im Grunde reicht es, dieses Binary irgendwo hinzukopieren und dann in Backitup darauf zu referenzieren (korrekte Rechte/ACLs vorausgesetzt). Die saubere Variante ist natürlich, InfluxDB 1.x zu installieren und den Service einfach nicht zu starten, bzw. den Autostart zu deaktivieren. Damit werden nicht unnötig Ressourcen verbraten.
                            Thomas Braun Most Active @Marc Berg last edited by
                            @marc-berg
                            Ja, da war ich der Einfachheit wegen etwas unpräzise.
                              sorry, aber ich habe noch ein paar Fragen dazu.
                              wenn ich Influx auf dem neuen Raspi 5 installiere, muss ich dann auch die gleiche Datenbank (wie auf dem Raspi 4) anlegen und die Rechte zuweisen:
                              influx
                              create database iobroker-db
                              use iobroker-db
                              CREATE USER "admin" WITH PASSWORD 'influxadmin' WITH ALL PRIVILEGES
                              CREATE USER "user" WITH PASSWORD 'influxuser'
                              GRANT ALL ON "iobroker-db" TO "user"
                              und die influxdb. conf bearbeiten:
                              enabled = true
                              bind-address = ":8086"
                              log-enabled = true
                              write-tracing = false
                              pprof-enabled = false
                              https-enabled = false
                              Im ioBroker Adapter Influxdb beziehe ich mich ja auf die Datenbank auf dem Raspi 4 (mit IP Endung .39)
                              Im Backitup Adapter zeige ich ja auch auf die Datenbank auf dem Raspi 4 mit IP Endung .39
                              siehe oben screenshots.
                              Woher weiss denn nun der ioBroker (Backitup) das auch auf dem Raspi 5 (mit IP Endung .40) ebenfalls Influx installiert ist
                              und stellt die Verknüpfung zu dem Raspi 4 her ?
                              Danke für eure Geduld
                                @darkblu
                                Du musst da gar keine neue DB anlegen, nur das Paket 'influxdb' (in möglichst gleicher Version wie auf dem anderen System.
                                Mir wird z. B. auf meiner Kiste v1.11.7 als aktuellste Version von influxdb1 angeboten:
                                echad@chet:~ $ apt policy influxdb
                                influxdb:
                                  Installed: (none)
                                  Candidate: 1.11.7-1
                                  Version table:
                                     1.11.7-1 500
                                        500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                     1.8.10-1 500
                                        100 /var/lib/dpkg/status
                                     1.6.7~rc0-2+b7 500
                                        500 http://deb.debian.org/debian unstable/main arm64 Packages
                                  Weil das Programm 'influxdb' dann im $PATH liegt und vom Adapter auch dort gefunden wird.
                                  Und den Weg zur eigentlichen Datenbank weist du ja im Backitup-Adapter.
                                    ok, und laut Backitup Anleitung:
                                    Hierbei ist es egal, ob die Datenbank lokal verwaltet wird oder auf einen anderen Server läuft.
                                    Wenn die InfluxDB von einem entfernten Server gesichert werden soll, müssen in der influxdb.conf auf dem entfernten Server die Remote-Rechte für den RPC-Dienst angepasst werden.
                                    bind-address = "<InfluxDB-IP>:8088"
                                    oder
                                    bind-address = "0.0.0.0:8088"
                                    muss ich dann noch auf dem Raspi 4 in der influxdb.conf die IP .40:8086 eintragen (vorsichtige Frage 😧 )
                                    Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                                      @darkblu
                                      Ja.
                                        @thomas-braun ,
                                        DANKE
                                          @darkblu
                                          sudo systemctl disable influxdb.service
                                          nimmt influxdb dann auf dem RPi5 aus dem 'Autostart' raus. Muss ja nicht permanent mitlaufen.
                                          • Marc Berg
                                            Marc Berg Most Active @darkblu last edited by
                                            Nein. Nur die :8088, wie in der Doku angegeben.
                                            1173
