    4. Neuer Adapter für Roborock-Staubsauger
    • da_Woody
      da_Woody @myssv last edited by
      @myssv kann ich nicht sagen, Link auf dein issue wäre nicht schlecht...
        myssv @da_Woody last edited by
        @da_woody stimmt 😉
        https://github.com/copystring/ioBroker.roborock/issues/695
        myssv created this issue in copystring/ioBroker.roborock
        closed [BUG] Neues Modell: Roborock Qrevo Curv #695
        • da_Woody
          @myssv 👍 ist aber kein Bug, eher request.
          Die Jungs werden das schon einordnen. 😉
            Taddy81 last edited by
            Ich bekomme den Updater irgendwie nicht installiert, wo ist denn hier der Fehler?
             iobroker url https://github.com/copystring/ioBroker.roborock --host IOBroker --debug
            install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd
            Installing copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd... (System call)
            npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.git
            npm warn deprecated npmlog@7.0.1: This package is no longer supported.
            npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.
            npm warn deprecated gauge@5.0.2: This package is no longer supported.
            npm warn deprecated sinon@9.2.4: 16.1.1
            > node dist/install.js
            RequestError: getaddrinfo EAI_AGAIN github.com
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.log
            npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.gitnpm warn deprecated npmlog@7.0.1: This package is no longer supported.npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.npm warn deprecated gauge@5.0.2: This package is no longer supported.npm warn deprecated sinon@9.2.4: 16.1.1RequestError: getaddrinfo EAI_AGAIN github.comnpm error code 1npm error path /opt/iobroker/node_modules/go2rtc-staticnpm error command failednpm error command sh -c node dist/install.jsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.loghost.IOBroker Cannot install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd: 1
            ERROR: Process exited with code 25
              Thomas Braun Most Active @Taddy81 last edited by
              @taddy81
              Grundsätzlich funktioniert das.
              $ iobroker url copystring/ioBroker.roborock --host chet --debug
              Installing copystring/ioBroker.roborock... (System call)
              Support for loading ES Module in require() is an experimental feature and might change at any time(Use `node --trace-warnings ...` to show where the warning was created)
              > go2rtc-static@1.9.4 install> node dist/install.js
              > node install.js
              added 223 packages, and changed 1 package in 1m227 packages are looking for funding run `npm fund` for details
              upload [13] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
              upload [12] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [7] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/jsonConfig.json jsonConfig.json application/json
              upload [1] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
              Updating objects from io-package.json for adapter "roborock" with version "0.6.17"
              Process exited with code 0
              Ist immer ein Hinweis auf Netzwerk-Trouble. github.com kann nicht erreicht werden.
                @taddy81
                Verwende
                iobroker url copystring/ioBroker.roborock --host IOBroker --debug
                auf dem System...
                  Danke,
                  hat funktioniert.
                  Dein Code hat geklappt, warum hat denn der GitHub Repo nicht geklappt hat?
                  Ein Problem war bei mir noch, dass meine Firewall die URL von Roborock blockiert hat. Ist nun aber gefixt und ich kann auf die Instanz zugreifen.
                  Vielen Dank
                    @taddy81 sagte in Neuer Adapter für Roborock-Staubsauger:
                    Was genau hast du denn wo ausgewählt?
                      breaksrmine last edited by
                      Seit 2 Tagen gabs in iOS ein Update der Roborock App sieht auch optisch anders aus. Seitdem funktioniert in ioBroker die Steuerung nicht mehr. Ich bekomm werte soweit alles gut aber keine Reaktion beim z.b starten des Saugers.
                      Jemand das gleiche Problem ?
                      C H 2 Replies Last reply Reply Quote 0
                        chuck2941 @breaksrmine last edited by
                        @breaksrmine Also ich habe kein Update, die App sieht immer noch gleich aus und die Steuerung über ioBroker funktioniert.
                        Was aber immer im Log kommt wenn der Sauger läuft ist folgendes
                        roborock.0
                        2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapData" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:28.091	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.935	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.task_id" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.934	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_times" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.933	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dirty_replenish" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.manual_replenish" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.cleaned_area" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.931	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map_flag" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.wash_count" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.avoid_count" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dust_collection_status" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.finish_reason" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_type" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.start_type" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.927	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.complete" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.926	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.error" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.925	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.area" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.924	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.duration" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.end" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.begin" has no existing object, this might lead to an error in future versions
                        Ich kann die Einträge nicht finden in den Objekten
                          hansano @breaksrmine last edited by hansano
                          @breaksrmine
                          Das kann ich so bestätigen, ist bei mir auch so
                          Edit: nach Neustart des Adapters läuft es wieder
                            erickuttruff last edited by erickuttruff
                            Failed to execute get_map_v1 on robot 2BFDPXMouOnerH911HQrgP (roborock.vacuum.a51): TypeError: The "chunk" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Array at _write (node:internal/streams/writable:480:13) at Gzip.Writable.end (node:internal/streams/writable:821:17) at zlibBuffer (node:zlib:129:10) at Object.asyncBufferWrapper [as gzip] (node:zlib:776:12) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:70:11) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            Ich habe immer sehr viele Fehler wie im Screenshot zu sehen... An was liegt es?
                              Thomas Braun Most Active @erickuttruff last edited by
                              @erickuttruff sagte in Neuer Adapter für Roborock-Staubsauger:
                              Text bitte auch als TEXT in CodeTags eingebettet posten. Mit bunte Bildchens kann man nix anfangen.
                                erickuttruff @Thomas Braun last edited by
                                @thomas-braun: Ich habe den Beitrag korrigiert...
                                  breaksrmine @hansano last edited by
                                  @hansano bei mir auch so jetzt 🙂
                                    RISSN last edited by
                                    unhandled promise rejection: Login returned empty userdata.
                                    Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    Error in getUserData: Login returned empty userdata.
                                    Diese Fehler bekomme ich nach dem Updaten auf Version:
                                    v0.6.17. Auch ein rücksetzen auf die Vorgängerversion bliebt ohne Erfolg. Hat das vielleicht noch jemand?
                                    • Jey Cee
                                      @rissn Meld dich mal in der App neu an, die hatte ein Update.
                                      Danach gehts wieder.
                                      R B 2 Replies Last reply Reply Quote 1
                                        RISSN @Jey Cee last edited by
                                        @jey-cee vielen Dank, dass war es 👍
                                          breaksrmine @Jey Cee last edited by breaksrmine
                                          @jey-cee danke geht wieder !
                                            chuck2941 last edited by
                                            Hallo, jedesmal wenn der S8 in Aktion ist wird mir der Log mit Warnungen vollgeschrieben, weiß jemand was das ist?
                                            In den Objekten gibt es keine Einträge dazu.
                                            24-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapData" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.432 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.begin" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.433 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.end" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.duration" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.area" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.435 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.error" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.complete" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.start_type" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.437 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.clean_type" has no existing object, this might lead to an error in future versions
                                            2024-11-26 08:09:04.438 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.finish_reason" has no existing object, this might lead to an error in future versions
                                            T E 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            916
                                            303766
