    4. iobroker.js-con 100% cpu
      Homoran Global Moderator Administrators @spicer last edited by
      @spicer sagte in iobroker.js-con 100% cpu:
      DEBUG kommen so viele Posts (keine Warnungen oder Alarme)
      Natürlich, dafür ist debug ja da
      das willst Du gar nicht wissen!
      doch!
      daraus kann man dann ja sehen, was da so schnell triggert.
      (Natürlich nach mqtt gefiltert)
      spicer 1 Reply Last reply Reply Quote 0
      • spicer
        spicer @Homoran last edited by Homoran
        Mit debug bekomme ich Tausende:
        mqtt.1
        	2024-11-02 12:43:00.657	debug	stateChange mqtt.1.info.clients.mosqsub|19238-Dachrollo: {"val":false,"ack":true,"ts":1730547780656,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730083491295}
        mqtt.1
        	2024-11-02 12:43:00.656	debug	stateChange mqtt.1.info.clients.mosqsub|12126-Dachrollo: {"val":false,"ack":true,"ts":1730547780655,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730232875058}
        mqtt.1
        	2024-11-02 12:43:00.654	debug	stateChange mqtt.1.info.clients.mosqsub|12442-Dachrollo: {"val":false,"ack":true,"ts":1730547780653,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730233184883}
        mqtt.1
        	2024-11-02 12:43:00.652	debug	stateChange mqtt.1.info.clients.mosqsub|12072-Dachrollo: {"val":false,"ack":true,"ts":1730547780651,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730232844483}
        mqtt.1
        	2024-11-02 12:43:00.643	debug	stateChange mqtt.1.info.clients.mosqsub|19176-Dachrollo: {"val":false,"ack":true,"ts":1730547780642,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730083430513}
        mqtt.1
        	2024-11-02 12:43:00.641	debug	stateChange mqtt.1.info.clients.mosqsub|7642-Dachrollos: {"val":false,"ack":true,"ts":1730547780641,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730044408190}
        mqtt.1
        	2024-11-02 12:43:00.639	debug	stateChange mqtt.1.info.clients.mosqsub|19174-Dachrollo: {"val":false,"ack":true,"ts":1730547780638,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1730083430386}
        mqtt.1
        	2024-11-02 12:43:00.635	debug	stateChange mqtt.1.info.clients.mosqsub|12385-Dachrollo:
        ich verstehe nicht, weil ich nur alle 2 Minuten etwas publishe an den iob server.
        • spicer
          Willst mal per Teamviewer vorbei kommen?
          Ich öffne Dir vorher alles notwendige.
          • spicer
            spicer last edited by Homoran
            Ich finde in dieser Forensoftware nichtmal den PN Knopf 😞
            eine Ahnung woher die Dachrollo Meldungrn kommen.
            Kann es sein, dass die seit Monaten in einem Cache liegen?
            • mcm1957
              mcm1957 @spicer last edited by
              @spicer said in iobroker.js-con 100% cpu:
              Bitte lösch deine Teamviewer ID ASAP, die ist m.W. nach fix und das ist ne Einladung dich zu besuchen.
              @Homoran - ev. via MODEDIT löschen?
              mcm1957 Homoran 2 Replies Last reply Reply Quote 0
              • mcm1957
                mcm1957 @mcm1957 last edited by
                PN = CHATS = da
                  Homoran Global Moderator Administrators @spicer last edited by Homoran
                  und genau deshalb ist der debug log so wichtig.
                  Da sieht man was passiert.
                  was sagt denn die Mosquitto dazu.
                  den kenne ich nicht
                    Homoran Global Moderator Administrators @mcm1957 last edited by
                    @mcm1957 erledigt!
                    war leider bis jetzt afk
                      Edwin40 last edited by
                      also bei mir hat das Adapterupdate MQTT Broker/Client 6.1.1 auf 6.1.2 permanent bis zu 100% CPU Auslastung bewirkt. Zurück auf 6.1.1 und alles war gut....
                      mcm1957 D 2 Replies Last reply Reply Quote 0
                      • mcm1957
                        mcm1957 @Edwin40 last edited by mcm1957
                        @edwin40 said in iobroker.js-con 100% cpu:
                        Hast du das Problem mit den entsprechenden Infos in einem Issue erfasst? Bitte hier verlinken.
                        Zwischen 6.1.1 und 6.1.2 wurde eigentlich nur genau eine Zeile geändert die ein Problem beheben soll wenn Clients keine Id haben / senden...
                          darkiop Most Active @Edwin40 last edited by darkiop
                          @edwin40 sagte in iobroker.js-con 100% cpu:
                          Hier läuft der MQTT 6.1.2 ohne Auffälligkeiten.
                            Thomas Braun Most Active @darkiop last edited by
                            @darkiop sagte in iobroker.js-con 100% cpu:
                            Hier auch.
                            • ESP8266
                              ESP8266 @Thomas Braun last edited by ESP8266
                              @thomas-braun , mein Senf auch dazu, PI 5 hier ohne Auffälligkeiten.
                              Letzter Beta Stand.
                              Hats der Themenersteller nun gelöst ? ....keine Anwort mehr.
                              • spicer
                                spicer @ESP8266 last edited by spicer
                                @esp8266
                                Sorry für die späte Antwort (hatte auch nicht auf "beobachtet").
                                Status: Jein.
                                Ich habe alle MQTT-Pub's auf das altehrwürdige RPI1, welches für die Dachfenster und Sonnenstore zuständig ist, geleitet.
                                Dieses sendet nur alle 10min MQTT-Daten an das ioBroker RPI5. So hält die CPU-Auslastung die Füsse für 10min still.
                                Es fällt auf, dass das RPI5 bei nur einem einzigen MQTT-Sub für 30s auf 100% CPU geht.
                                Das auch, wenn ich den Javascript Adapter deaktiviert habe.
                                Es kann also kein Loop sein.
                                • Marc Berg
                                  Marc Berg Most Active @spicer last edited by
                                  Als ich von einer Schleife sprach, meinte ich eigentlich keine Javascript- sondern eine MQTT-Schleife, die entstehen kann, wenn es eine ungute Kombination aus Subscriptions, Publish und Einstellungen des Adapters gibt. Bitte mal die Einstellungen des Adapters zeigen.
                                  Seltsam finde ich auch das Topic
                                  , welches ja scheinbar die Last erzeugt. Soweit ich es kenne, legt der MQTT Adapter dieses Topic nicht automatisch an, obwohl der Zweig "info" dem Adapter gehört. Hast du eine Idee, wo es herkommt?
                                  Und macht die Instanz mqtt.0 noch irgend etwas?
                                  ESP8266 spicer 2 Replies Last reply Reply Quote 0
                                  • ESP8266
                                    ESP8266 @Marc Berg last edited by ESP8266
                                    @marc-berg , scheint vielleicht eine zusätzliche Mosquitto Installation zu sein.
                                    Ich habe wegen ebusd zwar auch eine, aber da kommt bei mir nichts ins Gehege.
                                    Davon wird mir nichts gemeldet.
                                    Doppelte Port Belegung !? Warum meldet das Rollo überhaupt stetig Nachrichten.
                                    Bei meinen wird nichts gemeldet. Die laufen über sonoff. Die melden nur zurück was gerade passiert, oder auch die Procent.
                                    • spicer
                                      spicer @Marc Berg last edited by
                                      @marc-berg
                                      Eine Instanz mqtt.0 gibt es nicht.
                                      • spicer
                                        @esp8266
                                        Das RPI5 ist ja neu installiert. Also keine weitere mosquitto Installation drauf.
                                        Das Dachrollo sendet aktuell nur noch alle 3min, seit ich die oben genannten veränderungen gemacht habe.
                                        • ESP8266
                                          ESP8266 @spicer last edited by ESP8266
                                          @spicer , keine Ahnung was bei dir zickt. Meiner läuft besser als der PI 4. (schneller)
                                          Die Installation wurde auch vom PI 4 übernommen.
                                          Die Kühlung hält sich in den Grenzen zwischen 45 - 50 °C
                                          • ESP8266
                                            @marc-berg
                                            Dann ist da was faul. Lösch mal den Adapter und installiere ihn neu und zwar mit Auto.
                                            Ich habe hier 2 Mqtt Instanzen laufen. Die erste ist 0 die zweite ist 1 für die Wetterstation.
                                            7366
