    4. Vis2 Adapter macht Probleme.
      TimoWald @Thomas Braun last edited by
      @thomas-braun iob diag sagt folgendes:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.8.12-1-pve
            Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2024-11-03 12:47:33 CET
                 Universal time: Sun 2024-11-03 11:47:33 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wald
      HOME=/home/wald
      GROUPS=wald sudo
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            7.8G        454M        3.6G        0.0K        3.8G        7.3G
      Swap:           7.0G        8.0M        7.0G
      Total:           14G        463M         10G
      Active iob-Instances:   1
               7778 M total memory
                454 M used memory
                 84 M active memory
               3687 M inactive memory
               3569 M free memory
                  0 M buffer memory
               3754 M swap cache
               7039 M total swap
                  8 M used swap
               7031 M free swap
      top - 12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
      Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.5 us,  3.1 sy,  0.0 ni, 95.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7778.1 total,   3568.8 free,    454.6 used,   3754.8 buff/cache
      MiB Swap:   7040.0 total,   7031.3 free,      8.7 used.   7323.5 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * iobroker.service              loaded failed failed ioBroker Server
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      4 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      /dev/loop3     ext4       32G   18G   13G  58% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      udev           devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs          tmpfs     1.6G  116K  1.6G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     778M     0  778M   0% /run/user/1005
      Show mounted filesystems:
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop3 ext4   rw,relatime
      /var:
      1.6G    /var/
      1.2G    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
      1.2G    /var/log
      348M    /var/cache
      Archived and active journals take up 24.0M in the file system.
      /opt/iobroker/backups:
      128M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.2G    /opt/iobroker/iobroker-data/
      1.6G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
           20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
       *** 20.17.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 http://security.debian.org bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1622837)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     13
      +-- iobroker.bydhvs@1.5.1 (git+ssh://git@github.com/christianh17/ioBroker.bydhvs.git#55d06a849a015b35995e8e3fdc3c35f57fdd9c0d)
      +-- iobroker.energiefluss-erweitert@0.5.1-alpha.10 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#3a8c53f95ee9a763bf454b74ea986d8eb5991a65)
      +-- iobroker.fronius@2.1.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fronius.git#392e182ba42b3255cdd84c657c00e7fd8a9c4814)
      +-- iobroker.icons-ultimate-png@1.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-ultimate-png.git#519f1a7d31416157f8297b6e5b33745a3989a122)
      +-- iobroker.luxtronik2@0.5.2 (git+ssh://git@github.com/boellner/ioBroker.luxtronik2.git#dc0b80246a75506d7419bc2f6e6fe1b0d34338ef)
      +-- iobroker.pvforecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.pvforecast.git#3ef9743f113e0c4a53a7f1841748131e5b1d66a3)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.vis-2@ (git+ssh://git@github.com/ioBroker/ioBroker.vis-2.git#cabeca3a63207dc71df3504865eccfcef2f22097)
      +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
      +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
      +-- iobroker.vis@1.5.6 (git+ssh://git@github.com/iobroker/ioBroker.vis.git#8518f7fbadf76519b3c6bceb5a34e298b9257c0a)
      +-- iobroker.wiobrowser@2.0.2 (git+ssh://git@github.com/Bettman66/ioBroker.wiobrowser.git#1ce25f0107ab18ad95b5851d4bd96efd4172469d)
      +-- iobroker.worx@3.1.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.worx.git#4511551fdae7eaa6084c884ad1c2aaa67cef80d2)
      Adapter State
        system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
        system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
        system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
        system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
        system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
        system.adapter.fronius-solarweb.1       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
        system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
        system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
        system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
        system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
        system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled, compact disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
        system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
        system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
        system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
        system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 -  enabled, compact disabled, port: 8214
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled, compact disabled
        system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
        system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1888, bind: 0.0.0.0
        system.adapter.mqtt.3                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1883, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
        system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
        system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
        system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
        system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
        system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
        system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled, compact disabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : iobroker                                 - disabled, compact disabled, port: 1887, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
        system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
        system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
        system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled, compact disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        system.adapter.windows-control.0        : windows-control       : iobroker                                 - disabled, compact disabled
        system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 2208
        system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
        system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled, compact disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.1
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.10
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "gira-iot"     : 0.5.0    , installed 0.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hmip"         : 1.24.3   , installed 1.24.3
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "knx"          : 2.0.28   , installed 2.0.28
      Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openknx"      : 0.9.0    , installed 0.9.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 3.0.0    , installed 4.0.0
      Adapter    "roborock"     : 0.6.16   , installed 0.6.16
      Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solax"        : 0.9.12   , installed 0.9.12
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.1.0    , installed 3.1.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        34385
      States:         27991
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 20
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        17344      110/systemd-resolve
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14077      1/init
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        17338      110/systemd-resolve
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18446      295/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14079      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14198      1/init
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        17341      110/systemd-resolve
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18447      295/master
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        17343      110/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14078      1/init
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        17337      110/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          14080      1/init
      udp6       0      0 :::5355                 :::*                                104        17340      110/systemd-resolve
      2024-11-03 12:38:03.521  - warn: host.iobroker instance system.adapter.backitup.0 terminated due to SIGKILL
      2024-11-03 12:38:03.521  - info: host.iobroker instance system.adapter.backitup.0 terminated with code null ()
      2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.modbus.1 terminated due to SIGKILL
      2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.modbus.1 terminated with code null ()
      2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.hass.0 terminated due to SIGKILL
      2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.hass.0 terminated with code null ()
      2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.pvforecast.0 terminated due to SIGKILL
      2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.pvforecast.0 terminated with code null ()
      2024-11-03 12:38:03.619  - warn: host.iobroker instance system.adapter.homeconnect.0 terminated due to SIGKILL
      2024-11-03 12:38:03.619  - info: host.iobroker instance system.adapter.homeconnect.0 terminated with code null ()
      2024-11-03 12:38:03.620  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
      2024-11-03 12:38:03.620  - info: host.iobroker instance system.adapter.iot.0 terminated with code null ()
      2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.iot.1 terminated due to SIGKILL
      2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.iot.1 terminated with code null ()
      2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.openknx.0 terminated due to SIGKILL
      2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.openknx.0 terminated with code null ()
      2024-11-03 12:38:03.709  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGKILL
      2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
      2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2024-11-03 12:38:03.749  - info: host.iobroker.compactgroup1 terminated
      2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
      2024-11-03 12:38:05.051  - info: host.iobroker compactgroup controller 1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-11-03 12:38:05.170  - info: host.iobroker All instances are stopped.
      2024-11-03 12:38:05.369  - info: host.iobroker terminated
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @TimoWald last edited by
        @timowald sagte in Vis2 Adapter macht Probleme.:
        Beizeiten den Container mit Bookkworm / Debian 12 betreiben. Bullseye ist tot.
        Setz den User 'wald' in die Gruppe 'adm' und 'iobroker' rein.
        sudo usermod -a -G adm,iobroker wald
        exit
        Warum nicht?
        Warum hantierst du da mit einer Alpha-Version von vis-2 herum?
        Gleiche gilt für vis1:
        Pending Updates: 20
        System auf Stand bringen.
        iob stop
        sudo apt update && sudo apt full-upgrade
        Dann Container neustarten und die stabilen Versionen von vis2 und vis1 installieren.
          TimoWald @Thomas Braun last edited by TimoWald
          @thomas-braun said in Vis2 Adapter macht Probleme.:
          Wie kann ich diesen Updaten? Und wie installiere ich die stabilen Versionen von Vis2?
          Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
            Muss dir einer der Container-Kapitäne sagen.
              iob update
              iob upgrade vis@1.5.6
              iob upgrade vis-2@2.9.64
                Mit diesen Befehlen ist der VIS2 schonmal grün und aktuell.
                Jetzt mus ich nur noch rausbekommen wie ich den Container Update.
                • OliverIO
                  OliverIO @TimoWald last edited by
                  Wie kann ich diesen updaten?
                  Indem du ein aktuelleres Image auswählst:
                  https://hub.docker.com/layers/buanet/iobroker/v10.0.0/images/sha256-8261681190598bcaf5483779b1093e8d8a1a64be0d9e73c5df51287cea66b364?context=explore
                    TimoWald @OliverIO last edited by
                    @oliverio Sorry hier bin ich überfragt. Wo wähle ich das aus. Mein IOB läuft auf Proxmox.
                    • OliverIO
                      OliverIO @TimoWald last edited by OliverIO
                      @timowald
                      Als Docker Container oder als LXC Container oder als vm ?
                        @oliverio LXC
                        • OliverIO
                          @timowald
                          Bei lxc weiß ich es leider nicht. Da diese Art von Container etwas anders funktionieren wie Docker. Nach meinem Verständnis eher wie leicht Gewicht VMs
                          im Zweifel, komplett neuen Container erstellen, mit einem der aktuelleren Betriebssysteme installieren, dann iobroker installieren, dann Back-up aus dem alten iobroker einspielen
                            @oliverio Vis2 ist zwar jetzt grün aber viele Fehler im LOG.
                            2024-11-03 13:34:24.290 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:34:24.308 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472710
                            2024-11-03 13:34:25.187 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:34:25.667 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:34:25.685 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:34:26.209 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:34:27.848 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:34:28.828 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:34:28.831 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:34:29.023 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:34:29.024 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:34:29.031 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:34:29.040 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:34:29.041 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:34:29.041 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:34:29.042 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:34:29.042 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:34:29.055 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:34:29.056 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:34:29.058 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:34:29.058 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:34:29.557 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:34:29.681 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:34:29.682 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:34:29.849 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:34:30.078 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:34:30.185 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:34:30.185 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:34:30.185 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:34:30.185 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[4]: Error: Login returned empty userdata.
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[4]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:34:30.186 - error: host.iobroker Caught by controller[4]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:34:30.186 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:35:00.896 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:35:00.913 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472741
                            2024-11-03 13:35:02.000 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:35:02.354 - info: javascript.0 (471118) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
                            2024-11-03 13:35:02.596 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:35:02.615 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:35:02.929 - info: web.0 (471869) ==> Connected system.user.admin from ::ffff:192.168.9.50
                            2024-11-03 13:35:03.182 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:35:05.671 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:35:06.138 - info: javascript.0 (471118) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
                            2024-11-03 13:35:07.456 - info: solax.0 (471456) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                            2024-11-03 13:35:07.719 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:35:07.722 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:35:07.940 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:35:07.940 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:35:07.948 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:35:07.957 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:35:07.959 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:35:07.959 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:35:07.960 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:35:07.960 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:35:07.975 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:35:07.976 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:35:07.977 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:35:07.980 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:35:08.477 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:35:08.617 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:35:08.617 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:35:08.937 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:35:08.990 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:35:09.092 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[4]: Error: Login returned empty userdata.
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[4]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:09.093 - error: host.iobroker Caught by controller[4]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:09.093 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:35:16.296 - info: web.0 (471869) ==> Connected system.user.admin from ::ffff:192.168.9.50
                            2024-11-03 13:35:39.650 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:35:39.673 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472759
                            2024-11-03 13:35:40.637 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:35:41.065 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:35:41.082 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:35:41.644 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:35:43.850 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:35:44.642 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:35:44.645 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:35:44.835 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:35:44.835 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:35:44.845 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:35:44.855 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:35:44.857 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:35:44.857 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:35:44.857 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:35:44.858 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:35:44.873 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:35:44.874 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:35:44.876 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:35:44.940 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:35:45.375 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:35:45.504 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:35:45.505 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:35:45.669 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:35:45.894 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:35:46.064 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:35:46.064 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[1]: Error: Login returned empty userdata.
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[1]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:35:46.065 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:35:46.065 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:36:16.986 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:36:17.008 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472790
                            2024-11-03 13:36:17.899 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:36:18.281 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:36:18.299 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:36:18.864 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:36:21.187 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:36:22.021 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:36:22.024 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:36:22.210 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:36:22.210 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:36:22.217 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:36:22.226 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:36:22.227 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:36:22.227 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:36:22.228 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:36:22.228 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:36:22.243 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:36:22.244 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:36:22.246 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:36:22.249 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:36:22.745 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:36:22.879 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:36:22.879 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:36:23.035 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:36:23.264 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[1]: Error: Login returned empty userdata.
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[1]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:36:23.401 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:36:23.402 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:36:23.402 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:36:23.402 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:36:23.402 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:36:53.978 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:36:54.001 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472807
                            2024-11-03 13:36:54.947 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:36:55.384 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:36:55.415 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:36:55.943 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:36:58.109 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:36:58.906 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:36:58.909 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:36:59.102 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:36:59.103 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:36:59.111 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:36:59.120 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:36:59.122 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:36:59.122 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:36:59.122 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:36:59.123 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:36:59.137 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:36:59.138 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:36:59.140 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:36:59.143 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:36:59.640 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:36:59.775 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:36:59.775 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:36:59.945 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:37:00.159 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:37:00.267 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:00.268 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:00.268 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:37:30.778 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:37:30.795 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472838
                            2024-11-03 13:37:31.747 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:37:32.127 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:37:32.151 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:37:32.708 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:37:35.251 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:37:36.121 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:37:36.124 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:37:36.311 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:37:36.311 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:37:36.318 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:37:36.326 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:37:36.328 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:37:36.328 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:37:36.328 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:37:36.329 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:37:36.344 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:37:36.344 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:37:36.346 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:37:36.349 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:37:36.846 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:37:36.984 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:37:36.985 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:37:37.135 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:37:37.370 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:37:37.480 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:37:37.480 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:37.480 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:37:37.481 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:37:37.481 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:38:08.127 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:38:08.148 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472869
                            2024-11-03 13:38:09.043 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:38:09.641 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:38:09.659 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:38:10.203 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:38:12.253 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:38:13.094 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:38:13.097 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:38:13.272 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:38:13.273 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:38:13.280 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:38:13.288 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:38:13.289 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:38:13.289 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:38:13.290 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:38:13.290 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:38:13.303 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:38:13.304 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:38:13.306 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:38:13.307 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:38:13.805 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:38:13.935 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:38:13.935 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:38:14.097 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:38:14.319 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:38:14.427 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[1]: Error: Login returned empty userdata.
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[1]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:14.428 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:14.428 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:38:44.902 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:38:44.943 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472886
                            2024-11-03 13:38:46.006 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:38:46.478 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:38:46.497 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:38:47.033 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:38:50.324 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:38:51.085 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:38:51.087 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:38:51.297 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:38:51.297 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:38:51.305 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:38:51.314 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:38:51.316 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:38:51.317 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:38:51.317 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:38:51.317 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:38:51.333 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:38:51.334 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:38:51.336 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:38:51.339 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:38:51.835 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:38:51.966 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:38:51.967 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:38:52.124 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:38:52.350 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:38:52.454 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:52.455 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:52.456 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:38:52.456 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:38:52.456 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:38:52.456 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:38:52.456 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:38:52.456 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:39:23.053 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:39:23.070 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472917
                            2024-11-03 13:39:24.068 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:39:24.653 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:39:24.668 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:39:25.226 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:39:27.421 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:39:28.199 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:39:28.202 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:39:28.391 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:39:28.391 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:39:28.399 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:39:28.408 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:39:28.409 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:39:28.409 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:39:28.410 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:39:28.410 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:39:28.426 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:39:28.427 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:39:28.430 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:39:28.431 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:39:28.929 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:39:29.055 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:39:29.055 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:39:29.217 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:39:29.442 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[4]: Error: Login returned empty userdata.
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[4]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:39:29.545 - error: host.iobroker Caught by controller[4]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:39:29.545 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:40:00.124 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:40:00.141 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472948
                            2024-11-03 13:40:01.074 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:40:01.526 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:40:01.548 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:40:02.076 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:40:03.963 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:40:04.770 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:40:04.772 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:40:04.949 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:40:04.950 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:40:04.957 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:40:04.968 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:40:04.969 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:40:04.970 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:40:04.970 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:40:04.971 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:40:04.985 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:40:04.985 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:40:04.987 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:40:04.990 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:40:05.486 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:40:05.610 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:40:05.610 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:40:05.777 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:40:06.004 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:40:06.167 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:40:06.167 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:06.167 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[2]: Error: Login returned empty userdata.
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[2]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[2]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:06.168 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:06.169 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:06.169 - info: host.iobroker Restart compact group controller 1
                            2024-11-03 13:40:06.753 - info: solax.0 (471456) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                            2024-11-03 13:40:36.641 - info: host.iobroker start controller for compactgroup 1
                            2024-11-03 13:40:36.664 - info: host.iobroker instance system.adapter.roborock.0 is handled by compact group controller pid 472965
                            2024-11-03 13:40:37.868 - info: host.iobroker.compactgroup1 iobroker.js-controller version 6.0.11 js-controller starting
                            2024-11-03 13:40:38.314 - info: host.iobroker.compactgroup1 connected to Objects and States
                            2024-11-03 13:40:38.334 - info: host.iobroker.compactgroup1 added notifications configuration of host
                            2024-11-03 13:40:38.886 - info: host.iobroker.compactgroup1 starting 1 instance
                            2024-11-03 13:40:41.216 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 started in COMPACT mode
                            2024-11-03 13:40:42.087 - info: roborock.0 (COMPACT) starting. Version 0.6.16 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 6.0.11
                            2024-11-03 13:40:42.090 - info: roborock.0 (COMPACT) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            2024-11-03 13:40:42.274 - error: roborock.0 (COMPACT) Error in getUserData: Login returned empty userdata.
                            2024-11-03 13:40:42.275 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:40:42.282 - info: roborock.0 (COMPACT) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-11-03 13:40:42.291 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 (force=false, process=true)
                            2024-11-03 13:40:42.292 - error: roborock.0 (COMPACT) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-11-03 13:40:42.293 - error: roborock.0 (COMPACT) unhandled promise rejection: Login returned empty userdata.
                            2024-11-03 13:40:42.293 - error: roborock.0 (COMPACT) Error: Login returned empty userdata.
                            2024-11-03 13:40:42.293 - error: roborock.0 (COMPACT) Login returned empty userdata.
                            2024-11-03 13:40:42.308 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:40:42.309 - warn: roborock.0 (COMPACT) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-11-03 13:40:42.311 - info: roborock.0 (COMPACT) Got terminate signal TERMINATE_YOURSELF
                            2024-11-03 13:40:42.315 - info: host.iobroker.compactgroup1 stopInstance system.adapter.roborock.0 send kill signal
                            2024-11-03 13:40:42.810 - info: roborock.0 (COMPACT) terminating
                            2024-11-03 13:40:42.935 - info: host.iobroker.compactgroup1 instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:40:42.936 - info: host.iobroker.compactgroup1 All instances are stopped.
                            2024-11-03 13:40:43.104 - info: host.iobroker.compactgroup1 terminated
                            2024-11-03 13:40:43.324 - info: host.iobroker compactgroup controller 1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-11-03 13:40:43.453 - error: host.iobroker Caught by controller[0]: Uncaught Rejection: Error: Login returned empty userdata.
                            2024-11-03 13:40:43.453 - error: host.iobroker Caught by controller[0]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[0]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[1]: Login returned empty userdata.
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[1]: Error: Login returned empty userdata.
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[1]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[3]: Error: Login returned empty userdata.
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[3]: at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:253:11)
                            2024-11-03 13:40:43.454 - error: host.iobroker Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-11-03 13:40:43.455 - error: host.iobroker Caught by controller[3]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:102:20)
                            2024-11-03 13:40:43.455 - info: host.iobroker Restart compact group controller 1
                            598
