    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    • dogfight76
      dogfight76 last edited by
      An den Inhalt komme ich ja nicht mehr. Ist nur das übrig geblieben......wie kopiere ich die Langfassung dann ?
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76
        Dann lass es nochmal laufen.
        Und es kommt eine Tastaturabfrage, bevor die Zusammenfassung eingeblendet wird.
        Da halt nix drücken und die Langfassung kopieren.
        • dogfight76
          Ok, bin dran !
          Moment bitte.......
          • dogfight76
            Langversion:
            ========== Start marking the full check here ===========
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 5.15.61-v8+
                  Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             13:39:34 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Sun 2024-11-03 13:39:34 CET
                       Universal time: Sun 2024-11-03 12:39:34 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            dogfight76
            HOME=/home/dogfight76
            GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            3.8G        573M        962M         35M        2.3G        3.1G
            Swap:            99M          0B         99M
            Total:          3.9G        573M        1.1G
            Active iob-Instances:   1
                     3794 M total memory
                      573 M used memory
                      799 M active memory
                     1661 M inactive memory
                      961 M free memory
                      232 M buffer memory
                     2025 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 13:39:35 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
            Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3794.4 total,    961.7 free,    574.0 used,   2258.7 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3054.2 avail Mem
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * iobroker.service loaded failed failed ioBroker Server
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4       59G  6.4G   50G  12% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
            tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
            [Sat Oct 14 21:37:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Sat Oct 14 21:37:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Sat Oct 14 21:37:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sat Oct 14 21:37:20 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.6G    /var/
            1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
            1.1G    /var/log
            259M    /var/cache
            Archived and active journals take up 1.0G in the file system.
            /opt/iobroker/backups:
            91M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            216M    /opt/iobroker/iobroker-data/
            169M    /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            40M     /opt/iobroker/iobroker-data/backup-objects
            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
            7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
            6.4M    /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            nodejs:                 N/A
            /usr/bin/node           v16.20.2
            /usr/bin/npm            8.19.4
            /usr/bin/npx            8.19.4
            /usr/bin/corepack       0.17.0
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 16.20.2-deb-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
                 20.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
             *** 16.20.2-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u5 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 197)
            Core adapters versions
            js-controller:  5.0.12
            admin:          7.1.5
            javascript:     7.1.4
            nodejs modules from github:     2
            +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
            Adapter State
              system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
              system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
              system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
              system.adapter.history.0                : history               : iobroker                                 - disabled
              system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
              system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
              system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
              system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
              system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
              system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
              system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
              system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
              system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
              system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
              system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
            Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
            Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
            Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
            Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
            Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        989
            States:         790
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 319
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11229      559/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18069559   3929826/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          11240      559/sshd: /usr/sbin
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18069558   3929826/cupsd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11154      399/avahi-daemon: r
            udp        0      0 0.0.0.0:53292           0.0.0.0:*                           108        11156      399/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      479/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18068882   3929827/cups-browse
            udp6       0      0 :::48058                :::*                                108        11157      399/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        11155      399/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          17537999   479/dhcpcd
            2024-11-03 13:26:15.900  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
            2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
            2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 send kill signal
            2024-11-03 13:26:15.902  - info: host.iobroker stopInstance system.adapter.time-switch.0 send kill signal
            2024-11-03 13:26:15.904  - info: mqtt.0 (3937682) Terminated (NO_ERROR): Without reason
            2024-11-03 13:26:16.249  - info: cloud.0 (3937725) terminating
            2024-11-03 13:26:16.259  - info: vis-inventwo.0 (3937817) terminating
            2024-11-03 13:26:16.259  - info: backitup.0 (3937750) terminating
            2024-11-03 13:26:16.267  - info: web.0 (3937775) terminating
            2024-11-03 13:26:16.266  - info: admin.0 (3937625) terminating
            2024-11-03 13:26:16.270  - info: web.0 (3937775) Terminated (NO_ERROR): Without reason
            2024-11-03 13:26:16.273  - info: time-switch.0 (3937843) terminating
            2024-11-03 13:26:16.275  - info: mqtt.0 (3937682) terminating
            2024-11-03 13:26:16.276  - info: javascript.0 (3937647) terminating
            2024-11-03 13:26:16.601  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.603  - info: host.iobroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.604  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.644  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.727  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.753  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.831  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
            2024-11-03 13:26:16.831  - info: host.iobroker All instances are stopped.
            2024-11-03 13:26:17.064  - info: host.iobroker terminated
            iob diag has finished.
            Press any key for a summary
              @dogfight76
              Bring das ganze Ding beizeiten auf das aktuelle Release 'Bookworm'.
              Geht aber bei RaspberryOS nur per kompletter Neuinstallation.
              Die Zeit ist jedenfalls richtig konfiguriert.
              Warum nicht?
              sudo systemctl set-default multi-user.target
              Glückwunsch... Dein Betriebssystem möchte so dann und wann mal etwas Pflege erfahren...
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Wenn die Kiste wieder läuft:
              iob update
              iob upgrade all -y
              iob stop
              iob upgrade self
              iob start
              dogfight76 1 Reply Last reply Reply Quote 1
              • dogfight76
                dogfight76 @Thomas Braun last edited by
                @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                Dann kam das hier:
                dogfight76@iobroker:~ $ sudo systemctl set-default multi-user.target
                Removed /etc/systemd/system/default.target.
                Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                  @dogfight76
                  Ja, das ist richtig.
                  • dogfight76
                    Dann ist der PI jetzt beim full-upgrade !
                    Werde den Rest dann so abarbeiten. Dann ist alles erledigt ?
                      @dogfight76
                      Wenn du damit durch bist nochmal die Langfassung posten.
                      • dogfight76
                        dogfight76 last edited by dogfight76
                        Es kam jetzt das hier:
                        Fetched 387 MB in 1min 21s (4,757 kB/s)
                        Reading changelogs... Done
                        apt-listchanges: News
                        cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
                          This release addresses a security issue (CVE-2023-32360) which allows
                          unauthorized users to fetch documents over local or remote networks.
                          Since this is a configuration fix, it might be that it does not reach you if you
                          are updating 'cups-daemon' (rather than doing a fresh installation).
                          Please double check your /etc/cups/cupsd.conf file, whether it limits the access
                          to CUPS-Get-Document with something like the following
                          >  <Limit CUPS-Get-Document>
                          >    AuthType Default
                          >    Require user @OWNER @SYSTEM
                          >    Order deny,allow
                          >   </Limit>
                          (The important line is the 'AuthType Default' in this section)
                         -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
                        (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
                        E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
                        Trotzdem deine Liste weiter abarebiten ?
                          @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                          Ja, das ist eines der von dir vernachlässigten Sicherheitsupdates...
                          Und ganz eigentlich sollte CUPS auch gar nicht auf dem System laufen, außer du betreibst da einen Drucker dran.
                          • dogfight76
                            Nein, kein Drucker angeschlossen.
                            Nach Abschluss aller Befehle:
                            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                            Update chromecast from @2.3.1 to @3.4.1
                            NPM version: 8.19.4
                            Installing iobroker.chromecast@3.4.1... (System call)
                            Adapter "system.adapter.vis.0" restarted.
                            upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                            upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                            upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                            upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                            Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                            dogfight76@iobroker:~ $ iob stop
                            dogfight76@iobroker:~ $ iob upgrade self
                            Update js-controller from @5.0.12 to @6.0.11
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 8.19.4
                            Installing iobroker.js-controller@6.0.11... (System call)
                            dogfight76@iobroker:~ $ iob start
                              ...möchte ich einen frischen Lauf von iob diag sehen.
                              • dogfight76
                                Da ist er:
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                                CPU threads: 4
                                Current issues:
                                               Local time: Sun 2024-11-03 14:13:55 CET
                                           Universal time: Sun 2024-11-03 13:13:55 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                dogfight76
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
                                Swap:            99M          0B         99M
                                Total:          3.9G        748M        2.6G
                                Active iob-Instances:   9
                                         3794 M total memory
                                          748 M used memory
                                          197 M active memory
                                          938 M inactive memory
                                         2546 M free memory
                                           49 M buffer memory
                                          449 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                                Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  6.8G   50G  13% /
                                tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                /var:
                                2.0G    /var/
                                1.1G    /var/log
                                628M    /var/cache
                                217M    /opt/iobroker/iobroker-data/
                                6.7M    /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                nodejs:                 N/A
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
                                admin:          7.1.5
                                javascript:     7.1.4
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Objects and States
                                Objects:        989
                                States:         798
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
                                tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
                                udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
                                udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
                                2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
                                2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                                2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                                2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                                  und
                                  sudo apt update
                                  iob stop
                                  sudo reboot
                                  • dogfight76
                                    Nach dem Full-Upgrade Befehl kommt am Schluss:
                                      >    AuthType Default
                                      >    Order deny,allow
                                      >   </Limit>
                                    Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
                                    Thomas Braun dogfight76 2 Replies Last reply Reply Quote 0
                                      @dogfight76
                                      sudo apt update
                                      sagt?
                                      • dogfight76
                                        Da kommt das:
                                        dogfight76@iobroker:~ $ sudo apt update
                                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                        Reading package lists... Done
                                        Building dependency tree... Done
                                        320 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        dogfight76@iobroker:~ $ sudo apt full-upgrade
                                          @dogfight76
                                          Die 320 Updates müssen rein.
                                          Nach dem full-upgrade die Kiste sauber rebooten.
                                          • dogfight76
                                            dogfight76 @dogfight76 last edited by
                                            @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                              >    AuthType Default
                                              >    Order deny,allow
                                              >   </Limit>
                                            Trotz der Meldung also den Reboot Befehl eingeben ?
                                            1.0k
                                            4963
