    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    • dogfight76
      dogfight76 last edited by
      Ok, bin dran !
      Moment bitte.......
      • dogfight76
        Langversion:
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.61-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         13:39:34 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-11-03 13:39:34 CET
                   Universal time: Sun 2024-11-03 12:39:34 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dogfight76
        HOME=/home/dogfight76
        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.8G        573M        962M         35M        2.3G        3.1G
        Swap:            99M          0B         99M
        Total:          3.9G        573M        1.1G
        Active iob-Instances:   1
                 3794 M total memory
                  573 M used memory
                  799 M active memory
                 1661 M inactive memory
                  961 M free memory
                  232 M buffer memory
                 2025 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 13:39:35 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
        Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3794.4 total,    961.7 free,    574.0 used,   2258.7 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3054.2 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       59G  6.4G   50G  12% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Sat Oct 14 21:37:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sat Oct 14 21:37:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sat Oct 14 21:37:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Oct 14 21:37:20 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.6G    /var/
        1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
        1.1G    /var/log
        259M    /var/cache
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        91M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        216M    /opt/iobroker/iobroker-data/
        169M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        40M     /opt/iobroker/iobroker-data/backup-objects
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        6.4M    /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        nodejs:                 N/A
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
             20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
         *** 16.20.2-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 197)
        Core adapters versions
        js-controller:  5.0.12
        admin:          7.1.5
        javascript:     7.1.4
        nodejs modules from github:     2
        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
          system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
          system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
          system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
          system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
        Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
        Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
        Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        989
        States:         790
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 319
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11229      559/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18069559   3929826/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11240      559/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18069558   3929826/cupsd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11154      399/avahi-daemon: r
        udp        0      0 0.0.0.0:53292           0.0.0.0:*                           108        11156      399/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      479/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18068882   3929827/cups-browse
        udp6       0      0 :::48058                :::*                                108        11157      399/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11155      399/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          17537999   479/dhcpcd
        2024-11-03 13:26:15.900  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
        2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 send kill signal
        2024-11-03 13:26:15.902  - info: host.iobroker stopInstance system.adapter.time-switch.0 send kill signal
        2024-11-03 13:26:15.904  - info: mqtt.0 (3937682) Terminated (NO_ERROR): Without reason
        2024-11-03 13:26:16.249  - info: cloud.0 (3937725) terminating
        2024-11-03 13:26:16.259  - info: vis-inventwo.0 (3937817) terminating
        2024-11-03 13:26:16.259  - info: backitup.0 (3937750) terminating
        2024-11-03 13:26:16.267  - info: web.0 (3937775) terminating
        2024-11-03 13:26:16.266  - info: admin.0 (3937625) terminating
        2024-11-03 13:26:16.270  - info: web.0 (3937775) Terminated (NO_ERROR): Without reason
        2024-11-03 13:26:16.273  - info: time-switch.0 (3937843) terminating
        2024-11-03 13:26:16.275  - info: mqtt.0 (3937682) terminating
        2024-11-03 13:26:16.276  - info: javascript.0 (3937647) terminating
        2024-11-03 13:26:16.601  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.603  - info: host.iobroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.604  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.644  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.727  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.753  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.831  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.831  - info: host.iobroker All instances are stopped.
        2024-11-03 13:26:17.064  - info: host.iobroker terminated
        iob diag has finished.
        Press any key for a summary
          Thomas Braun Most Active @dogfight76 last edited by
          @dogfight76
          Bring das ganze Ding beizeiten auf das aktuelle Release 'Bookworm'.
          Geht aber bei RaspberryOS nur per kompletter Neuinstallation.
          Die Zeit ist jedenfalls richtig konfiguriert.
          Warum nicht?
          sudo systemctl set-default multi-user.target
          Glückwunsch... Dein Betriebssystem möchte so dann und wann mal etwas Pflege erfahren...
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Wenn die Kiste wieder läuft:
          iob update
          iob upgrade all -y
          iob stop
          iob upgrade self
          iob start
          dogfight76 1 Reply Last reply Reply Quote 1
          • dogfight76
            dogfight76 @Thomas Braun last edited by
            @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
            Dann kam das hier:
            dogfight76@iobroker:~ $ sudo systemctl set-default multi-user.target
            Removed /etc/systemd/system/default.target.
            Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
              @dogfight76
              Ja, das ist richtig.
              • dogfight76
                Dann ist der PI jetzt beim full-upgrade !
                Werde den Rest dann so abarbeiten. Dann ist alles erledigt ?
                  @dogfight76
                  Wenn du damit durch bist nochmal die Langfassung posten.
                  • dogfight76
                    dogfight76 last edited by dogfight76
                    Es kam jetzt das hier:
                    Fetched 387 MB in 1min 21s (4,757 kB/s)
                    Reading changelogs... Done
                    apt-listchanges: News
                    cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
                      This release addresses a security issue (CVE-2023-32360) which allows
                      unauthorized users to fetch documents over local or remote networks.
                      Since this is a configuration fix, it might be that it does not reach you if you
                      are updating 'cups-daemon' (rather than doing a fresh installation).
                      Please double check your /etc/cups/cupsd.conf file, whether it limits the access
                      to CUPS-Get-Document with something like the following
                      >  <Limit CUPS-Get-Document>
                      >    AuthType Default
                      >    Require user @OWNER @SYSTEM
                      >    Order deny,allow
                      >   </Limit>
                      (The important line is the 'AuthType Default' in this section)
                     -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
                    (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
                    E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
                    Trotzdem deine Liste weiter abarebiten ?
                      @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                      Ja, das ist eines der von dir vernachlässigten Sicherheitsupdates...
                      Und ganz eigentlich sollte CUPS auch gar nicht auf dem System laufen, außer du betreibst da einen Drucker dran.
                      • dogfight76
                        Nein, kein Drucker angeschlossen.
                        Nach Abschluss aller Befehle:
                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        Update chromecast from @2.3.1 to @3.4.1
                        NPM version: 8.19.4
                        Installing iobroker.chromecast@3.4.1... (System call)
                        Adapter "system.adapter.vis.0" restarted.
                        upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                        upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                        upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                        upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                        Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                        dogfight76@iobroker:~ $ iob stop
                        dogfight76@iobroker:~ $ iob upgrade self
                        Update js-controller from @5.0.12 to @6.0.11
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 8.19.4
                        Installing iobroker.js-controller@6.0.11... (System call)
                        dogfight76@iobroker:~ $ iob start
                          ...möchte ich einen frischen Lauf von iob diag sehen.
                          • dogfight76
                            Da ist er:
                            ```bash
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-11-03 14:13:55 CET
                                       Universal time: Sun 2024-11-03 13:13:55 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            dogfight76
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
                            Swap:            99M          0B         99M
                            Total:          3.9G        748M        2.6G
                            Active iob-Instances:   9
                                     3794 M total memory
                                      748 M used memory
                                      197 M active memory
                                      938 M inactive memory
                                     2546 M free memory
                                       49 M buffer memory
                                      449 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                            Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  6.8G   50G  13% /
                            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                            [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                            /var:
                            2.0G    /var/
                            1.1G    /var/log
                            628M    /var/cache
                            217M    /opt/iobroker/iobroker-data/
                            6.7M    /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            nodejs:                 N/A
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
                            admin:          7.1.5
                            javascript:     7.1.4
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Objects and States
                            Objects:        989
                            States:         798
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
                            tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
                            udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
                            udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                            2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
                            2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
                            2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                              und
                              sudo apt update
                              iob stop
                              sudo reboot
                              • dogfight76
                                Nach dem Full-Upgrade Befehl kommt am Schluss:
                                  >    AuthType Default
                                  >    Order deny,allow
                                  >   </Limit>
                                Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
                                Thomas Braun dogfight76 2 Replies Last reply Reply Quote 0
                                  @dogfight76
                                  sudo apt update
                                  sagt?
                                  • dogfight76
                                    Da kommt das:
                                    dogfight76@iobroker:~ $ sudo apt update
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Reading package lists... Done
                                    Building dependency tree... Done
                                    320 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    dogfight76@iobroker:~ $ sudo apt full-upgrade
                                      @dogfight76
                                      Die 320 Updates müssen rein.
                                      Nach dem full-upgrade die Kiste sauber rebooten.
                                      • dogfight76
                                        dogfight76 @dogfight76 last edited by
                                        @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                          >    AuthType Default
                                          >    Order deny,allow
                                          >   </Limit>
                                        Trotz der Meldung also den Reboot Befehl eingeben ?
                                          Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                                          Deinstallier das mal:
                                          sudo apt remove apt-listchanges
                                          sudo apt update
                                          sudo apt upgrade
                                          • dogfight76
                                            Wollte ich jetzt eingeben, da steht das in Putty:
                                            Calculating upgrade... Done
                                            The following packages were automatically installed and are no longer required:
                                              libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                                            Use 'sudo apt autoremove' to remove them.
                                            The following NEW packages will be installed:
                                              kms++-utils raspi-utils
                                            The following packages will be upgraded:
                                              adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                                              chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                                              cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                                              dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                                              exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                                              ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                                              gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                                              gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                                              libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                                              libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                                              libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                                              libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                                              libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                                              libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                                              libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                                              libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                                              libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                                              libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                                              liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                                              libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                                              libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                                              libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                                              librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                                              libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                                              libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                                              libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                                              locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                                              lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                                              mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                                              openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                                              python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                                              python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                                              python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                                              raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                                              systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                                              vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                                              vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                                              xwayland
                                            320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                            Need to get 0 B/488 MB of archives.
                                            After this operation, 319 MB of additional disk space will be used.
                                            Do you want to continue? [Y/n] y
                                            4965
