    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    • dogfight76
      dogfight76 last edited by
      Nach dem Full-Upgrade Befehl kommt am Schluss:
      apt-listchanges: News
      cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
        This release addresses a security issue (CVE-2023-32360) which allows
        unauthorized users to fetch documents over local or remote networks.
        Since this is a configuration fix, it might be that it does not reach you if you
        are updating 'cups-daemon' (rather than doing a fresh installation).
        Please double check your /etc/cups/cupsd.conf file, whether it limits the access
        to CUPS-Get-Document with something like the following
        >  <Limit CUPS-Get-Document>
        >    AuthType Default
        >    Require user @OWNER @SYSTEM
        >    Order deny,allow
        >   </Limit>
        (The important line is the 'AuthType Default' in this section)
       -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
      (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
      E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
      dogfight76@iobroker:~ $
      Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
      Thomas Braun dogfight76 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76
        sudo apt update
        sagt?
        • dogfight76
          Da kommt das:
          dogfight76@iobroker:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists... Done
          Building dependency tree... Done
          320 packages can be upgraded. Run 'apt list --upgradable' to see them.
          dogfight76@iobroker:~ $ iob stop
          dogfight76@iobroker:~ $ sudo apt full-upgrade
            @dogfight76
            Die 320 Updates müssen rein.
            Nach dem full-upgrade die Kiste sauber rebooten.
            • dogfight76
              dogfight76 @dogfight76 last edited by
              @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                >    AuthType Default
                >    Order deny,allow
                >   </Limit>
              Trotz der Meldung also den Reboot Befehl eingeben ?
                @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                Deinstallier das mal:
                sudo apt remove apt-listchanges
                sudo apt update
                sudo apt upgrade
                • dogfight76
                  Wollte ich jetzt eingeben, da steht das in Putty:
                  Calculating upgrade... Done
                  The following packages were automatically installed and are no longer required:
                    libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                  Use 'sudo apt autoremove' to remove them.
                  The following NEW packages will be installed:
                    kms++-utils raspi-utils
                  The following packages will be upgraded:
                    adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                    chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                    cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                    dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                    exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                    ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                    gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                    gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                    libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                    libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                    libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                    libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                    libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                    libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                    libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                    libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                    libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                    libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                    liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                    libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                    libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                    libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                    librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                    libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                    libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                    libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                    locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                    lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                    mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                    openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                    python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                    python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                    python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                    raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                    systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                    vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                    vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                    xwayland
                  320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B/488 MB of archives.
                  After this operation, 319 MB of additional disk space will be used.
                  Do you want to continue? [Y/n] y
                  Reading changelogs... Done
                    Thomas Braun Most Active @dogfight76 last edited by Thomas Braun
                    @dogfight76
                    Ja, so soll das.
                    Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
                    Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                    • dogfight76
                      Das Update/Upgrade nach der deinstallation läuft.
                      Die Installation, gibt es da ein How-To hier im Forum ?
                        @dogfight76
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        • dogfight76
                          Nach dem Update und dem Upgrade Befehl kam das:
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                          Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                          Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                          Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                          Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                          dogfight76@iobroker:~ $ sudo apt upgrade
                            libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            sudo apt autoremove
                            Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                            iob update
                            iob upgrade all
                            iob stop
                            iob upgrade self
                            iob start
                            iob update
                            iob upgrade all
                            • dogfight76
                              Bin dabei........
                              • dogfight76
                                Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                                dogfight76@iobroker:~ $ iob update
                                Used repository: stable
                                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                                Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                                Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                                Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                                Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                                Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                                Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                dogfight76@iobroker:~ $ iob upgrade all
                                Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                                This upgrade of "javascript" will at least introduce the following changes:
                                -> 8.8.3:
                                Fixed object selector in rules
                                -> 8.8.2:
                                updated dependencies
                                -> 8.8.1:
                                -> 8.8.0:
                                Added option to register notifications via scripts
                                Fixed sendTo block with empty name list
                                -> 8.7.7:
                                Fixed import scripts dialog
                                Allow to remove all custom packages (empty list)
                                -> 8.7.6:
                                fix error with subpath imports in scripts
                                -> 8.7.5:
                                Fixed right aligned script names when using multiple instances
                                added fallback for all require calls in scripts
                                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                                Update javascript from @7.1.4 to @8.8.3
                                NPM version: 10.8.2
                                Installing iobroker.javascript@8.8.3... (System call)
                                added 2 packages, removed 25 packages, and changed 10 packages in 1m
                                197 packages are looking for funding
                                  run `npm fund` for details
                                Update "system.adapter.javascript.0"
                                upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                                upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                                upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                                upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                                upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                                upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                                upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                                upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                                upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                                upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                                upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                                upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                                upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                                upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                                upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                                upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                                upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                                upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                This upgrade of "hm-rega" will at least introduce the following changes:
                                -> 5.1.0:
                                added notification if devices are low on battery
                                -> 5.0.0:
                                required node 18
                                -> 4.0.0:
                                required node 16 due to adapter-core 3.x.x
                                removed deprecated package - `request`
                                -> 3.0.47:
                                Updated packages
                                -> 3.0.46:
                                fix for controller v5 (closes #368)
                                -> 3.0.44:
                                compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                                also sync enums for maintenance channel of rfd devices (closes #320)
                                -> 3.0.43:
                                if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                                Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                                Update hm-rega from @3.0.40 to @5.1.0
                                NPM version: 10.8.2
                                Installing iobroker.hm-rega@5.1.0... (System call)
                                added 1 package, removed 1 package, and changed 1 package in 10s
                                Update "system.adapter.hm-rega.0"
                                upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                                upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                                upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                                upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                                This upgrade of "fritzdect" will at least introduce the following changes:
                                -> 2.5.11:
                                update devDeps, linting error correction
                                -> 2.5.10:
                                more loggimg for issue #500 of restart loop
                                -> 2.5.9:
                                new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                                Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                                Update fritzdect from @2.2.6 to @2.5.11
                                NPM version: 10.8.2
                                Installing iobroker.fritzdect@2.5.11... (System call)
                                added 181 packages, removed 8 packages, and changed 9 packages in 29s
                                208 packages are looking for funding
                                Adapter "system.adapter.vis.0" restarted.
                                Update "system.adapter.fritzdect.0"
                                upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                                upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                                upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                                This upgrade of "discovery" will at least introduce the following changes:
                                -> 5.0.0:
                                Packages updated
                                Minimum node.js version is 18.x
                                Updated licenses for knx and jarvis
                                -> 4.5.0:
                                Added Air-Q
                                -> 4.4.0:
                                Added WLED
                                Added LaMetric
                                Removed net-tools from proposals
                                -> 4.3.0:
                                Replaced vis with vis-2
                                -> 4.2.0:
                                Changed detection of myvbus and resol
                                -> 4.1.0:
                                Added detection of myvbus and resol
                                -> 4.0.0:
                                Added: frontier_silicon, sma-em, and speedwire
                                Dropped node14 support, refactoring
                                Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                                Update discovery from @3.1.0 to @5.0.0
                                NPM version: 10.8.2
                                Installing iobroker.discovery@5.0.0... (System call)
                                added 2 packages, removed 1 package, and changed 19 packages in 13s
                                210 packages are looking for funding
                                Update "system.adapter.discovery.0"
                                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                This upgrade of "chromecast" will introduce the following changes:
                                -> 3.4.1:
                                migrated binary state to file
                                -> 3.4.0:
                                Support for devices located in different subnets has been added. [#154, #160]
                                Dependencies have been updated
                                -> 3.3.0:
                                Adapter requires node.js 18 and js-controller >= 5 now
                                -> 3.2.0:
                                changed: Testing has been updated to use node.js 16/18/20
                                changed: Dependencies have been updated
                                YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                                AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                                Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                                -> 3.1.0:
                                Refactoring done
                                Removed dependency with nettools
                                Added support of web port other than 8082
                                -> 3.0.3:
                                Breaking change: Object IDs are now mac addresses instead names
                                set album name as song if provided in icy-name
                                Make compatible with Node.js 16+
                                Add Sentry for crash reporting
                                Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                                Update chromecast from @2.3.1 to @3.4.1
                                NPM version: 10.8.2
                                Installing iobroker.chromecast@3.4.1... (System call)
                                added 3 packages, removed 232 packages, and changed 1 package in 12s
                                207 packages are looking for funding
                                Update "system.adapter.chromecast.0"
                                upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                thopark created this issue in iobroker-community-adapters/ioBroker.chromecast
                                closed Allow YouTube videos #75
                                raintonr created this issue in iobroker-community-adapters/ioBroker.chromecast
                                closed Add appId to status #151
                                closed [Bug]: Webserver settings not properly saved/derived if chosen web instance bound to single interface #145
                                  Homoran Global Moderator Administrators @dogfight76 last edited by
                                  hast du den noch nicht aktualisiert?
                                    @dogfight76
                                    Gib die Befehle in der Abfolge wie oben gepostet ein.
                                    Fehlermeldungen sind jetzt irrelevant und erwartet.
                                    • dogfight76
                                      Damit fing das Problem doch an........
                                      Ich wollte im ioBroker das Update des js-controller anstoßen
                                      • dogfight76
                                        dogfight76 @Thomas Braun last edited by
                                        @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                        @dogfight76
                                        Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                        Arbeite die Befehlsliste gerade ab
                                        • dogfight76
                                          @thomas-braun Fertig. Ohne Fehlermeldung
                                            da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                            2625
