    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
      Thomas Braun Most Active @dogfight76 last edited by
      @dogfight76
      sudo apt update
      sagt?
      • dogfight76
        Da kommt das:
        dogfight76@iobroker:~ $ sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Building dependency tree... Done
        320 packages can be upgraded. Run 'apt list --upgradable' to see them.
        dogfight76@iobroker:~ $ iob stop
        dogfight76@iobroker:~ $ sudo apt full-upgrade
          @dogfight76
          Die 320 Updates müssen rein.
          Nach dem full-upgrade die Kiste sauber rebooten.
          • dogfight76
            dogfight76 @dogfight76 last edited by
            @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
            Nach dem Full-Upgrade Befehl kommt am Schluss:
            apt-listchanges: News
            cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
              This release addresses a security issue (CVE-2023-32360) which allows
              unauthorized users to fetch documents over local or remote networks.
              Since this is a configuration fix, it might be that it does not reach you if you
              are updating 'cups-daemon' (rather than doing a fresh installation).
              Please double check your /etc/cups/cupsd.conf file, whether it limits the access
              to CUPS-Get-Document with something like the following
              >  <Limit CUPS-Get-Document>
              >    AuthType Default
              >    Require user @OWNER @SYSTEM
              >    Order deny,allow
              >   </Limit>
              (The important line is the 'AuthType Default' in this section)
             -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
            (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
            E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
            Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
            Trotz der Meldung also den Reboot Befehl eingeben ?
              @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
              Keine Ahnung warum apt-listchanges da bei dir rumzickt.
              Deinstallier das mal:
              sudo apt remove apt-listchanges
              sudo apt update
              sudo apt upgrade
              • dogfight76
                Wollte ich jetzt eingeben, da steht das in Putty:
                Calculating upgrade... Done
                The following packages were automatically installed and are no longer required:
                  libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                Use 'sudo apt autoremove' to remove them.
                The following NEW packages will be installed:
                  kms++-utils raspi-utils
                The following packages will be upgraded:
                  adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                  chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                  cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                  dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                  exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                  ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                  gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                  gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                  libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                  libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                  libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                  libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                  libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                  libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                  libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                  libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                  libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                  libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                  liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                  libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                  libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                  libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                  librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                  libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                  libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                  libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                  locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                  lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                  mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                  openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                  python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                  python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                  python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                  raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                  systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                  vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                  vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                  xwayland
                320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                Need to get 0 B/488 MB of archives.
                After this operation, 319 MB of additional disk space will be used.
                Do you want to continue? [Y/n] y
                Reading changelogs... Done
                  Thomas Braun Most Active @dogfight76 last edited by Thomas Braun
                  @dogfight76
                  Ja, so soll das.
                  Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
                  Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                  • dogfight76
                    Das Update/Upgrade nach der deinstallation läuft.
                    Die Installation, gibt es da ein How-To hier im Forum ?
                      @dogfight76
                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      • dogfight76
                        Nach dem Update und dem Upgrade Befehl kam das:
                        Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                        Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                        Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                        Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                        Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                        dogfight76@iobroker:~ $ sudo apt upgrade
                          libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          sudo apt autoremove
                          Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                          iob update
                          iob upgrade all
                          iob stop
                          iob upgrade self
                          iob start
                          iob update
                          iob upgrade all
                          • dogfight76
                            Bin dabei........
                            • dogfight76
                              Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                              dogfight76@iobroker:~ $ iob update
                              Used repository: stable
                              Adapter    "admin"        : 7.1.5    , installed 7.1.5
                              Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                              Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                              Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                              Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                              Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                              Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                              Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                              Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                              Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                              Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              dogfight76@iobroker:~ $ iob upgrade all
                              Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                              This upgrade of "javascript" will at least introduce the following changes:
                              -> 8.8.3:
                              Fixed object selector in rules
                              -> 8.8.2:
                              updated dependencies
                              -> 8.8.1:
                              -> 8.8.0:
                              Added option to register notifications via scripts
                              Fixed sendTo block with empty name list
                              -> 8.7.7:
                              Fixed import scripts dialog
                              Allow to remove all custom packages (empty list)
                              -> 8.7.6:
                              fix error with subpath imports in scripts
                              -> 8.7.5:
                              Fixed right aligned script names when using multiple instances
                              added fallback for all require calls in scripts
                              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                              Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                              Update javascript from @7.1.4 to @8.8.3
                              NPM version: 10.8.2
                              Installing iobroker.javascript@8.8.3... (System call)
                              added 2 packages, removed 25 packages, and changed 10 packages in 1m
                              197 packages are looking for funding
                                run `npm fund` for details
                              Update "system.adapter.javascript.0"
                              upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                              upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                              upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                              upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                              upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                              upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                              upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                              upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                              upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                              upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                              upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                              upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                              upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                              upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                              upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                              upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                              upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                              upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                              upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                              upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                              upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                              upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                              upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                              upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                              upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                              This upgrade of "hm-rega" will at least introduce the following changes:
                              -> 5.1.0:
                              added notification if devices are low on battery
                              -> 5.0.0:
                              required node 18
                              -> 4.0.0:
                              required node 16 due to adapter-core 3.x.x
                              removed deprecated package - `request`
                              -> 3.0.47:
                              Updated packages
                              -> 3.0.46:
                              fix for controller v5 (closes #368)
                              -> 3.0.44:
                              compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                              also sync enums for maintenance channel of rfd devices (closes #320)
                              -> 3.0.43:
                              if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                              Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                              Update hm-rega from @3.0.40 to @5.1.0
                              NPM version: 10.8.2
                              Installing iobroker.hm-rega@5.1.0... (System call)
                              added 1 package, removed 1 package, and changed 1 package in 10s
                              Update "system.adapter.hm-rega.0"
                              upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                              upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                              upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                              upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                              This upgrade of "fritzdect" will at least introduce the following changes:
                              -> 2.5.11:
                              update devDeps, linting error correction
                              -> 2.5.10:
                              more loggimg for issue #500 of restart loop
                              -> 2.5.9:
                              new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                              Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                              Update fritzdect from @2.2.6 to @2.5.11
                              NPM version: 10.8.2
                              Installing iobroker.fritzdect@2.5.11... (System call)
                              added 181 packages, removed 8 packages, and changed 9 packages in 29s
                              208 packages are looking for funding
                              Adapter "system.adapter.vis.0" restarted.
                              Update "system.adapter.fritzdect.0"
                              upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                              upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                              upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                              upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                              This upgrade of "discovery" will at least introduce the following changes:
                              -> 5.0.0:
                              Packages updated
                              Minimum node.js version is 18.x
                              Updated licenses for knx and jarvis
                              -> 4.5.0:
                              Added Air-Q
                              -> 4.4.0:
                              Added WLED
                              Added LaMetric
                              Removed net-tools from proposals
                              -> 4.3.0:
                              Replaced vis with vis-2
                              -> 4.2.0:
                              Changed detection of myvbus and resol
                              -> 4.1.0:
                              Added detection of myvbus and resol
                              -> 4.0.0:
                              Added: frontier_silicon, sma-em, and speedwire
                              Dropped node14 support, refactoring
                              Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                              Update discovery from @3.1.0 to @5.0.0
                              NPM version: 10.8.2
                              Installing iobroker.discovery@5.0.0... (System call)
                              added 2 packages, removed 1 package, and changed 19 packages in 13s
                              210 packages are looking for funding
                              Update "system.adapter.discovery.0"
                              upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                              This upgrade of "chromecast" will introduce the following changes:
                              -> 3.4.1:
                              migrated binary state to file
                              -> 3.4.0:
                              Support for devices located in different subnets has been added. [#154, #160]
                              Dependencies have been updated
                              -> 3.3.0:
                              Adapter requires node.js 18 and js-controller >= 5 now
                              -> 3.2.0:
                              changed: Testing has been updated to use node.js 16/18/20
                              changed: Dependencies have been updated
                              YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                              AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                              Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                              -> 3.1.0:
                              Refactoring done
                              Removed dependency with nettools
                              Added support of web port other than 8082
                              -> 3.0.3:
                              Breaking change: Object IDs are now mac addresses instead names
                              set album name as song if provided in icy-name
                              Make compatible with Node.js 16+
                              Add Sentry for crash reporting
                              Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                              Update chromecast from @2.3.1 to @3.4.1
                              NPM version: 10.8.2
                              Installing iobroker.chromecast@3.4.1... (System call)
                              added 3 packages, removed 232 packages, and changed 1 package in 12s
                              207 packages are looking for funding
                              Update "system.adapter.chromecast.0"
                              upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                              upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                              upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                              upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                              thopark created this issue in iobroker-community-adapters/ioBroker.chromecast
                              closed Allow YouTube videos #75
                              raintonr created this issue in iobroker-community-adapters/ioBroker.chromecast
                              closed Add appId to status #151
                              closed [Bug]: Webserver settings not properly saved/derived if chosen web instance bound to single interface #145
                                Homoran Global Moderator Administrators @dogfight76 last edited by
                                hast du den noch nicht aktualisiert?
                                  @dogfight76
                                  Gib die Befehle in der Abfolge wie oben gepostet ein.
                                  Fehlermeldungen sind jetzt irrelevant und erwartet.
                                  dogfight76 2 Replies Last reply Reply Quote 0
                                  • dogfight76
                                    Damit fing das Problem doch an........
                                    Ich wollte im ioBroker das Update des js-controller anstoßen
                                    • dogfight76
                                      dogfight76 @Thomas Braun last edited by
                                      @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                      @dogfight76
                                      Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                      Arbeite die Befehlsliste gerade ab
                                      • dogfight76
                                        @thomas-braun Fertig. Ohne Fehlermeldung
                                          da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                            @dogfight76
                                            Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                                            iob diag
                                            anschauen.
                                            4963
