    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    • dogfight76
      dogfight76 last edited by
      Das Update/Upgrade nach der deinstallation läuft.
      Die Installation, gibt es da ein How-To hier im Forum ?
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        • dogfight76
          Nach dem Update und dem Upgrade Befehl kam das:
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
          Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
          Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
          Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
          Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
          dogfight76@iobroker:~ $ sudo apt upgrade
          Reading package lists... Done
          Building dependency tree... Done
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
          Use 'sudo apt autoremove' to remove them.
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
            sudo apt autoremove
            Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
            iob update
            iob upgrade all
            iob stop
            iob upgrade self
            iob start
            iob update
            iob upgrade all
            • dogfight76
              Bin dabei........
              • dogfight76
                Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                dogfight76@iobroker:~ $ iob update
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                dogfight76@iobroker:~ $ iob upgrade all
                Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                This upgrade of "javascript" will at least introduce the following changes:
                -> 8.8.3:
                Fixed object selector in rules
                -> 8.8.2:
                updated dependencies
                -> 8.8.1:
                -> 8.8.0:
                Added option to register notifications via scripts
                Fixed sendTo block with empty name list
                -> 8.7.7:
                Fixed import scripts dialog
                Allow to remove all custom packages (empty list)
                -> 8.7.6:
                fix error with subpath imports in scripts
                -> 8.7.5:
                Fixed right aligned script names when using multiple instances
                added fallback for all require calls in scripts
                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                Update javascript from @7.1.4 to @8.8.3
                NPM version: 10.8.2
                Installing iobroker.javascript@8.8.3... (System call)
                added 2 packages, removed 25 packages, and changed 10 packages in 1m
                197 packages are looking for funding
                  run `npm fund` for details
                Update "system.adapter.javascript.0"
                upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                This upgrade of "hm-rega" will at least introduce the following changes:
                -> 5.1.0:
                added notification if devices are low on battery
                -> 5.0.0:
                required node 18
                -> 4.0.0:
                required node 16 due to adapter-core 3.x.x
                removed deprecated package - `request`
                -> 3.0.47:
                Updated packages
                -> 3.0.46:
                fix for controller v5 (closes #368)
                -> 3.0.44:
                compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                also sync enums for maintenance channel of rfd devices (closes #320)
                -> 3.0.43:
                if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                Update hm-rega from @3.0.40 to @5.1.0
                NPM version: 10.8.2
                Installing iobroker.hm-rega@5.1.0... (System call)
                added 1 package, removed 1 package, and changed 1 package in 10s
                Update "system.adapter.hm-rega.0"
                upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                This upgrade of "fritzdect" will at least introduce the following changes:
                -> 2.5.11:
                update devDeps, linting error correction
                -> 2.5.10:
                more loggimg for issue #500 of restart loop
                -> 2.5.9:
                new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                Update fritzdect from @2.2.6 to @2.5.11
                NPM version: 10.8.2
                Installing iobroker.fritzdect@2.5.11... (System call)
                added 181 packages, removed 8 packages, and changed 9 packages in 29s
                208 packages are looking for funding
                Adapter "system.adapter.vis.0" restarted.
                Update "system.adapter.fritzdect.0"
                upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                This upgrade of "discovery" will at least introduce the following changes:
                -> 5.0.0:
                Packages updated
                Minimum node.js version is 18.x
                Updated licenses for knx and jarvis
                -> 4.5.0:
                Added Air-Q
                -> 4.4.0:
                Added WLED
                Added LaMetric
                Removed net-tools from proposals
                -> 4.3.0:
                Replaced vis with vis-2
                -> 4.2.0:
                Changed detection of myvbus and resol
                -> 4.1.0:
                Added detection of myvbus and resol
                -> 4.0.0:
                Added: frontier_silicon, sma-em, and speedwire
                Dropped node14 support, refactoring
                Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                Update discovery from @3.1.0 to @5.0.0
                NPM version: 10.8.2
                Installing iobroker.discovery@5.0.0... (System call)
                added 2 packages, removed 1 package, and changed 19 packages in 13s
                210 packages are looking for funding
                Update "system.adapter.discovery.0"
                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                This upgrade of "chromecast" will introduce the following changes:
                -> 3.4.1:
                migrated binary state to file
                -> 3.4.0:
                Support for devices located in different subnets has been added. [#154, #160]
                Dependencies have been updated
                -> 3.3.0:
                Adapter requires node.js 18 and js-controller >= 5 now
                -> 3.2.0:
                changed: Testing has been updated to use node.js 16/18/20
                changed: Dependencies have been updated
                YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                -> 3.1.0:
                Refactoring done
                Removed dependency with nettools
                Added support of web port other than 8082
                -> 3.0.3:
                Breaking change: Object IDs are now mac addresses instead names
                set album name as song if provided in icy-name
                Make compatible with Node.js 16+
                Add Sentry for crash reporting
                Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                Update chromecast from @2.3.1 to @3.4.1
                NPM version: 10.8.2
                Installing iobroker.chromecast@3.4.1... (System call)
                added 3 packages, removed 232 packages, and changed 1 package in 12s
                207 packages are looking for funding
                Update "system.adapter.chromecast.0"
                upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                thopark created this issue in iobroker-community-adapters/ioBroker.chromecast
                closed Allow YouTube videos #75
                raintonr created this issue in iobroker-community-adapters/ioBroker.chromecast
                closed Add appId to status #151
                closed [Bug]: Webserver settings not properly saved/derived if chosen web instance bound to single interface #145
                  Homoran Global Moderator Administrators @dogfight76 last edited by
                  hast du den noch nicht aktualisiert?
                    @dogfight76
                    Gib die Befehle in der Abfolge wie oben gepostet ein.
                    Fehlermeldungen sind jetzt irrelevant und erwartet.
                    dogfight76 2 Replies Last reply Reply Quote 0
                    • dogfight76
                      Damit fing das Problem doch an........
                      Ich wollte im ioBroker das Update des js-controller anstoßen
                      • dogfight76
                        dogfight76 @Thomas Braun last edited by
                        @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                        @dogfight76
                        Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                        Arbeite die Befehlsliste gerade ab
                        • dogfight76
                          @thomas-braun Fertig. Ohne Fehlermeldung
                            da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                              @dogfight76
                              Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                              iob diag
                              anschauen.
                              • dogfight76
                                Hier das Ergebnis:
                                ========== Start marking the full check here ===========
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                   Static hostname: iobroker
                                         Icon name: computer
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 5.15.61-v8+
                                      Architecture: arm64
                                OS is similar to:
                                Model           : Raspberry Pi 4 Model B Rev 1.2
                                Docker          : false
                                Virtualization  : none
                                Kernel          : aarch64
                                Userland        : 64 bit
                                Systemuptime and Load:
                                 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                CPU threads: 4
                                *** LIFE CYCLE STATUS ***
                                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                This system needs to be REBOOTED!
                                *** TIME AND TIMEZONES ***
                                               Local time: Sun 2024-11-03 15:20:43 CET
                                           Universal time: Sun 2024-11-03 14:20:43 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                dogfight76
                                HOME=/home/dogfight76
                                GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                *** DISPLAY-SERVER SETUP ***
                                Display-Server: false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                                Swap:            99M        2.0M         97M
                                Total:          3.9G        804M        215M
                                Active iob-Instances:   11
                                         3794 M total memory
                                          802 M used memory
                                          934 M active memory
                                         2452 M inactive memory
                                          117 M free memory
                                          178 M buffer memory
                                         2696 M swap cache
                                           99 M total swap
                                            2 M used swap
                                           97 M free swap
                                top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                                MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  8.6G   48G  16% /
                                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                Show mounted filesystems:
                                TARGET  SOURCE         FSTYPE OPTIONS
                                /       /dev/mmcblk0p2 ext4   rw,noatime
                                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                2.0G    /var/
                                1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                                1.1G    /var/log
                                634M    /var/cache
                                Archived and active journals take up 1.0G in the file system.
                                /opt/iobroker/backups:
                                91M     /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                815M    /opt/iobroker/iobroker-data/
                                761M    /opt/iobroker/iobroker-data/files
                                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                13M     /opt/iobroker/iobroker-data/objects.jsonl
                                12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                USB-Devices by-id:
                                No Devices found 'by-id'
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v20.18.0
                                /usr/bin/node           v20.18.0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.3
                                nodejs:
                                  Installed: 20.18.0-1nodesource1
                                  Candidate: 20.18.0-1nodesource1
                                  Version table:
                                 *** 20.18.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                        100 /var/lib/dpkg/status
                                     20.17.0-1nodesource1 1001
                                     20.16.0-1nodesource1 1001
                                     20.15.1-1nodesource1 1001
                                     20.15.0-1nodesource1 1001
                                     20.14.0-1nodesource1 1001
                                     20.13.1-1nodesource1 1001
                                     20.13.0-1nodesource1 1001
                                     20.12.2-1nodesource1 1001
                                     20.12.1-1nodesource1 1001
                                     20.12.0-1nodesource1 1001
                                     20.11.1-1nodesource1 1001
                                     20.11.0-1nodesource1 1001
                                     20.10.0-1nodesource1 1001
                                     20.9.0-1nodesource1 1001
                                     20.8.1-1nodesource1 1001
                                     20.8.0-1nodesource1 1001
                                     20.7.0-1nodesource1 1001
                                     20.6.1-1nodesource1 1001
                                     20.6.0-1nodesource1 1001
                                     20.5.1-1nodesource1 1001
                                     20.5.0-1nodesource1 1001
                                     20.4.0-1nodesource1 1001
                                     20.3.1-1nodesource1 1001
                                     20.3.0-1nodesource1 1001
                                     20.2.0-1nodesource1 1001
                                     20.1.0-1nodesource1 1001
                                     20.0.0-1nodesource1 1001
                                     12.22.12~dfsg-1~deb11u5 500
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                     12.22.12~dfsg-1~deb11u4 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                No problems detected
                                Errors in npm tree: 0
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                                Core adapters versions
                                js-controller:  6.0.11
                                admin:          7.1.5
                                javascript:     8.8.3
                                nodejs modules from github:     2
                                +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                                +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                  system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                  system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                  system.adapter.history.0                : history               : iobroker                                 - disabled
                                  system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                                  system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                                  system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                                  system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                  system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                  system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                                + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                  system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Upgrade policy: none
                                Installed ioBroker-Instances
                                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 6.0.11   , installed 6.0.11
                                Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                Objects and States
                                Objects:        1050
                                States:         801
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                                tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                                udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                                udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                                udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                                2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                                iob diag has finished.
                                Press any key for a summary
                                  • dogfight76
                                    Reboot isr durch
                                      @dogfight76
                                      Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                                      Mit
                                      muss dir aber wer anders weiterhelfen.
                                      Ich würde vorschlagen, in einem separaten Thread.
                                        @dogfight76
                                        influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                                        • dogfight76
                                          InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                                          Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                                          Und dann weiter ?
                                            Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                                            Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                                            Ob du das brauchst musst du selber entscheiden.
                                            4965
