    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    • dogfight76
      dogfight76 last edited by
      Nach dem Update und dem Upgrade Befehl kam das:
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
      Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
      Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
      Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
      Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
      dogfight76@iobroker:~ $ sudo apt upgrade
      Reading package lists... Done
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
        sudo apt autoremove
        Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
        iob update
        iob upgrade all
        iob stop
        iob upgrade self
        iob start
        iob update
        iob upgrade all
        • dogfight76
          Bin dabei........
          • dogfight76
            Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
            dogfight76@iobroker:~ $ iob update
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
            Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
            Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
            Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
            Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
            Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            dogfight76@iobroker:~ $ iob upgrade all
            Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
            This upgrade of "javascript" will at least introduce the following changes:
            -> 8.8.3:
            Fixed object selector in rules
            -> 8.8.2:
            updated dependencies
            -> 8.8.1:
            -> 8.8.0:
            Added option to register notifications via scripts
            Fixed sendTo block with empty name list
            -> 8.7.7:
            Fixed import scripts dialog
            Allow to remove all custom packages (empty list)
            -> 8.7.6:
            fix error with subpath imports in scripts
            -> 8.7.5:
            Fixed right aligned script names when using multiple instances
            added fallback for all require calls in scripts
            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
            Update javascript from @7.1.4 to @8.8.3
            NPM version: 10.8.2
            Installing iobroker.javascript@8.8.3... (System call)
            added 2 packages, removed 25 packages, and changed 10 packages in 1m
            197 packages are looking for funding
              run `npm fund` for details
            Update "system.adapter.javascript.0"
            upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
            upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
            upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
            upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
            upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
            upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
            upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
            upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
            upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
            upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
            upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
            upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
            upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
            upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
            upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
            upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
            upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
            upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
            upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
            upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
            upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
            upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
            upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
            upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
            upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
            upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
            upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
            upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
            upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
            upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
            upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
            upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
            upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
            upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
            upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
            upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
            upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
            upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
            upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
            upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
            upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
            upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
            upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
            upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
            upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
            upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
            upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
            upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
            upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
            upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
            upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
            This upgrade of "hm-rega" will at least introduce the following changes:
            -> 5.1.0:
            added notification if devices are low on battery
            -> 5.0.0:
            required node 18
            -> 4.0.0:
            required node 16 due to adapter-core 3.x.x
            removed deprecated package - `request`
            -> 3.0.47:
            Updated packages
            -> 3.0.46:
            fix for controller v5 (closes #368)
            -> 3.0.44:
            compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
            also sync enums for maintenance channel of rfd devices (closes #320)
            -> 3.0.43:
            if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
            Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
            Update hm-rega from @3.0.40 to @5.1.0
            NPM version: 10.8.2
            Installing iobroker.hm-rega@5.1.0... (System call)
            added 1 package, removed 1 package, and changed 1 package in 10s
            Update "system.adapter.hm-rega.0"
            upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
            upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
            upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
            upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
            This upgrade of "fritzdect" will at least introduce the following changes:
            -> 2.5.11:
            update devDeps, linting error correction
            -> 2.5.10:
            more loggimg for issue #500 of restart loop
            -> 2.5.9:
            new message box, correction for statistics, password needs to be reentered in versions >2.5.4
            Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
            Update fritzdect from @2.2.6 to @2.5.11
            NPM version: 10.8.2
            Installing iobroker.fritzdect@2.5.11... (System call)
            added 181 packages, removed 8 packages, and changed 9 packages in 29s
            208 packages are looking for funding
            Adapter "system.adapter.vis.0" restarted.
            Update "system.adapter.fritzdect.0"
            upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
            upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
            upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
            upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
            upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
            upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
            This upgrade of "discovery" will at least introduce the following changes:
            -> 5.0.0:
            Packages updated
            Minimum node.js version is 18.x
            Updated licenses for knx and jarvis
            -> 4.5.0:
            Added Air-Q
            -> 4.4.0:
            Added WLED
            Added LaMetric
            Removed net-tools from proposals
            -> 4.3.0:
            Replaced vis with vis-2
            -> 4.2.0:
            Changed detection of myvbus and resol
            -> 4.1.0:
            Added detection of myvbus and resol
            -> 4.0.0:
            Added: frontier_silicon, sma-em, and speedwire
            Dropped node14 support, refactoring
            Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
            Update discovery from @3.1.0 to @5.0.0
            NPM version: 10.8.2
            Installing iobroker.discovery@5.0.0... (System call)
            added 2 packages, removed 1 package, and changed 19 packages in 13s
            210 packages are looking for funding
            Update "system.adapter.discovery.0"
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            This upgrade of "chromecast" will introduce the following changes:
            -> 3.4.1:
            migrated binary state to file
            -> 3.4.0:
            Support for devices located in different subnets has been added. [#154, #160]
            Dependencies have been updated
            -> 3.3.0:
            Adapter requires node.js 18 and js-controller >= 5 now
            -> 3.2.0:
            changed: Testing has been updated to use node.js 16/18/20
            changed: Dependencies have been updated
            YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
            AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
            Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
            -> 3.1.0:
            Refactoring done
            Removed dependency with nettools
            Added support of web port other than 8082
            -> 3.0.3:
            Breaking change: Object IDs are now mac addresses instead names
            set album name as song if provided in icy-name
            Make compatible with Node.js 16+
            Add Sentry for crash reporting
            Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
            Update chromecast from @2.3.1 to @3.4.1
            NPM version: 10.8.2
            Installing iobroker.chromecast@3.4.1... (System call)
            added 3 packages, removed 232 packages, and changed 1 package in 12s
            207 packages are looking for funding
            Update "system.adapter.chromecast.0"
            upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
            upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
            upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
            upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
            thopark created this issue in iobroker-community-adapters/ioBroker.chromecast
            closed Allow YouTube videos #75
            raintonr created this issue in iobroker-community-adapters/ioBroker.chromecast
            closed Add appId to status #151
            closed [Bug]: Webserver settings not properly saved/derived if chosen web instance bound to single interface #145
              Homoran Global Moderator Administrators @dogfight76 last edited by
              hast du den noch nicht aktualisiert?
                @dogfight76
                Gib die Befehle in der Abfolge wie oben gepostet ein.
                Fehlermeldungen sind jetzt irrelevant und erwartet.
                dogfight76 2 Replies Last reply Reply Quote 0
                • dogfight76
                  Damit fing das Problem doch an........
                  Ich wollte im ioBroker das Update des js-controller anstoßen
                  • dogfight76
                    dogfight76 @Thomas Braun last edited by
                    @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                    @dogfight76
                    Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                    Arbeite die Befehlsliste gerade ab
                    • dogfight76
                      @thomas-braun Fertig. Ohne Fehlermeldung
                        da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                          @dogfight76
                          Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                          iob diag
                          anschauen.
                          • dogfight76
                            Hier das Ergebnis:
                            ========== Start marking the full check here ===========
                            ```bash
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer
                              Operating System: Debian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 5.15.61-v8+
                                  Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 4 Model B Rev 1.2
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            This system needs to be REBOOTED!
                            *** TIME AND TIMEZONES ***
                                           Local time: Sun 2024-11-03 15:20:43 CET
                                       Universal time: Sun 2024-11-03 14:20:43 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            dogfight76
                            HOME=/home/dogfight76
                            GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                            Swap:            99M        2.0M         97M
                            Total:          3.9G        804M        215M
                            Active iob-Instances:   11
                                     3794 M total memory
                                      802 M used memory
                                      934 M active memory
                                     2452 M inactive memory
                                      117 M free memory
                                      178 M buffer memory
                                     2696 M swap cache
                                       99 M total swap
                                        2 M used swap
                                       97 M free swap
                            top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                            Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                            MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  8.6G   48G  16% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                            tmpfs          tmpfs     759M  1.2M  758M   1% /run
                            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                            [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                            Show mounted filesystems:
                            TARGET  SOURCE         FSTYPE OPTIONS
                            /       /dev/mmcblk0p2 ext4   rw,noatime
                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            2.0G    /var/
                            1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                            1.1G    /var/log
                            634M    /var/cache
                            Archived and active journals take up 1.0G in the file system.
                            /opt/iobroker/backups:
                            91M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            815M    /opt/iobroker/iobroker-data/
                            761M    /opt/iobroker/iobroker-data/files
                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            13M     /opt/iobroker/iobroker-data/objects.jsonl
                            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                            8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.18.0
                            /usr/bin/node           v20.18.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.3
                            nodejs:
                              Installed: 20.18.0-1nodesource1
                              Candidate: 20.18.0-1nodesource1
                              Version table:
                             *** 20.18.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                 20.17.0-1nodesource1 1001
                                 20.16.0-1nodesource1 1001
                                 20.15.1-1nodesource1 1001
                                 20.15.0-1nodesource1 1001
                                 20.14.0-1nodesource1 1001
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                                 12.22.12~dfsg-1~deb11u5 500
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                 12.22.12~dfsg-1~deb11u4 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                            Core adapters versions
                            js-controller:  6.0.11
                            admin:          7.1.5
                            javascript:     8.8.3
                            nodejs modules from github:     2
                            +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                              system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                              system.adapter.history.0                : history               : iobroker                                 - disabled
                              system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                              system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                              system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                              system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                              system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                            + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                              system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                              system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                            + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                              system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Upgrade policy: none
                            Installed ioBroker-Instances
                            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                            Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 6.0.11   , installed 6.0.11
                            Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                            Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                            Objects and States
                            Objects:        1050
                            States:         801
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                            tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                            udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                            udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                            udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                            2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                            2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                            2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                            2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                            iob diag has finished.
                            Press any key for a summary
                              • dogfight76
                                Reboot isr durch
                                  @dogfight76
                                  Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                                  Mit
                                  muss dir aber wer anders weiterhelfen.
                                  Ich würde vorschlagen, in einem separaten Thread.
                                    @dogfight76
                                    influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                                    • dogfight76
                                      InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                                      Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                                      Und dann weiter ?
                                        Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                                        Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                                        Ob du das brauchst musst du selber entscheiden.
                                        • dogfight76
                                          Ok, jetzt noch das Update beovr das aktuelle OS-Lite (64bit) auf die microSD-Karte kommt ?
                                            Welches Update? Das Betriebssystem ist aktuell, ebenso wie der ioBroker.
                                            Mit der Basis kannst du jetzt umziehen.
                                            4963
