    3. Einsteigerfragen
    4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
      Thomas Braun Most Active @dogfight76 last edited by
      @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
      sudo apt autoremove
      Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
      iob update
      iob upgrade all
      iob stop
      iob upgrade self
      iob start
      iob update
      iob upgrade all
      • dogfight76
        Bin dabei........
        • dogfight76
          Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
          dogfight76@iobroker:~ $ iob update
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
          Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
          Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
          Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
          Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
          Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
          Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          dogfight76@iobroker:~ $ iob upgrade all
          Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
          This upgrade of "javascript" will at least introduce the following changes:
          -> 8.8.3:
          Fixed object selector in rules
          -> 8.8.2:
          updated dependencies
          -> 8.8.1:
          -> 8.8.0:
          Added option to register notifications via scripts
          Fixed sendTo block with empty name list
          -> 8.7.7:
          Fixed import scripts dialog
          Allow to remove all custom packages (empty list)
          -> 8.7.6:
          fix error with subpath imports in scripts
          -> 8.7.5:
          Fixed right aligned script names when using multiple instances
          added fallback for all require calls in scripts
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
          Update javascript from @7.1.4 to @8.8.3
          NPM version: 10.8.2
          Installing iobroker.javascript@8.8.3... (System call)
          added 2 packages, removed 25 packages, and changed 10 packages in 1m
          197 packages are looking for funding
            run `npm fund` for details
          Update "system.adapter.javascript.0"
          upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
          upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
          upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
          upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
          upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
          upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
          upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
          upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
          upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
          upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
          upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
          upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
          upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
          upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
          upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
          upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
          upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
          upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
          upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
          upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
          This upgrade of "hm-rega" will at least introduce the following changes:
          -> 5.1.0:
          added notification if devices are low on battery
          -> 5.0.0:
          required node 18
          -> 4.0.0:
          required node 16 due to adapter-core 3.x.x
          removed deprecated package - `request`
          -> 3.0.47:
          Updated packages
          -> 3.0.46:
          fix for controller v5 (closes #368)
          -> 3.0.44:
          compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
          also sync enums for maintenance channel of rfd devices (closes #320)
          -> 3.0.43:
          if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
          Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
          Update hm-rega from @3.0.40 to @5.1.0
          NPM version: 10.8.2
          Installing iobroker.hm-rega@5.1.0... (System call)
          added 1 package, removed 1 package, and changed 1 package in 10s
          Update "system.adapter.hm-rega.0"
          upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
          upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
          upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
          upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
          This upgrade of "fritzdect" will at least introduce the following changes:
          -> 2.5.11:
          update devDeps, linting error correction
          -> 2.5.10:
          more loggimg for issue #500 of restart loop
          -> 2.5.9:
          new message box, correction for statistics, password needs to be reentered in versions >2.5.4
          Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
          Update fritzdect from @2.2.6 to @2.5.11
          NPM version: 10.8.2
          Installing iobroker.fritzdect@2.5.11... (System call)
          added 181 packages, removed 8 packages, and changed 9 packages in 29s
          208 packages are looking for funding
          Adapter "system.adapter.vis.0" restarted.
          Update "system.adapter.fritzdect.0"
          upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
          upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
          upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
          upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
          upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
          upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
          This upgrade of "discovery" will at least introduce the following changes:
          -> 5.0.0:
          Packages updated
          Minimum node.js version is 18.x
          Updated licenses for knx and jarvis
          -> 4.5.0:
          Added Air-Q
          -> 4.4.0:
          Added WLED
          Added LaMetric
          Removed net-tools from proposals
          -> 4.3.0:
          Replaced vis with vis-2
          -> 4.2.0:
          Changed detection of myvbus and resol
          -> 4.1.0:
          Added detection of myvbus and resol
          -> 4.0.0:
          Added: frontier_silicon, sma-em, and speedwire
          Dropped node14 support, refactoring
          Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
          Update discovery from @3.1.0 to @5.0.0
          NPM version: 10.8.2
          Installing iobroker.discovery@5.0.0... (System call)
          added 2 packages, removed 1 package, and changed 19 packages in 13s
          210 packages are looking for funding
          Update "system.adapter.discovery.0"
          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
          This upgrade of "chromecast" will introduce the following changes:
          -> 3.4.1:
          migrated binary state to file
          -> 3.4.0:
          Support for devices located in different subnets has been added. [#154, #160]
          Dependencies have been updated
          -> 3.3.0:
          Adapter requires node.js 18 and js-controller >= 5 now
          -> 3.2.0:
          changed: Testing has been updated to use node.js 16/18/20
          changed: Dependencies have been updated
          YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
          AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
          Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
          -> 3.1.0:
          Refactoring done
          Removed dependency with nettools
          Added support of web port other than 8082
          -> 3.0.3:
          Breaking change: Object IDs are now mac addresses instead names
          set album name as song if provided in icy-name
          Make compatible with Node.js 16+
          Add Sentry for crash reporting
          Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
          Update chromecast from @2.3.1 to @3.4.1
          NPM version: 10.8.2
          Installing iobroker.chromecast@3.4.1... (System call)
          added 3 packages, removed 232 packages, and changed 1 package in 12s
          207 packages are looking for funding
          Update "system.adapter.chromecast.0"
          upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
          upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
          upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
          upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
          thopark created this issue in iobroker-community-adapters/ioBroker.chromecast
          closed Allow YouTube videos #75
          raintonr created this issue in iobroker-community-adapters/ioBroker.chromecast
          closed Add appId to status #151
          closed [Bug]: Webserver settings not properly saved/derived if chosen web instance bound to single interface #145
            Homoran Global Moderator Administrators @dogfight76 last edited by
            hast du den noch nicht aktualisiert?
              @dogfight76
              Gib die Befehle in der Abfolge wie oben gepostet ein.
              Fehlermeldungen sind jetzt irrelevant und erwartet.
              dogfight76 2 Replies Last reply Reply Quote 0
              • dogfight76
                Damit fing das Problem doch an........
                Ich wollte im ioBroker das Update des js-controller anstoßen
                • dogfight76
                  dogfight76 @Thomas Braun last edited by
                  @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                  @dogfight76
                  Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                  Arbeite die Befehlsliste gerade ab
                  • dogfight76
                    @thomas-braun Fertig. Ohne Fehlermeldung
                      da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                        @dogfight76
                        Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                        iob diag
                        anschauen.
                        • dogfight76
                          Hier das Ergebnis:
                          ========== Start marking the full check here ===========
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 5.15.61-v8+
                                Architecture: arm64
                          OS is similar to:
                          Model           : Raspberry Pi 4 Model B Rev 1.2
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                          CPU threads: 4
                          *** LIFE CYCLE STATUS ***
                          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          This system needs to be REBOOTED!
                          *** TIME AND TIMEZONES ***
                                         Local time: Sun 2024-11-03 15:20:43 CET
                                     Universal time: Sun 2024-11-03 14:20:43 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          dogfight76
                          HOME=/home/dogfight76
                          GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                          *** DISPLAY-SERVER SETUP ***
                          Display-Server: false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                          Swap:            99M        2.0M         97M
                          Total:          3.9G        804M        215M
                          Active iob-Instances:   11
                                   3794 M total memory
                                    802 M used memory
                                    934 M active memory
                                   2452 M inactive memory
                                    117 M free memory
                                    178 M buffer memory
                                   2696 M swap cache
                                     99 M total swap
                                      2 M used swap
                                     97 M free swap
                          top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                          Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                          MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          No critical errors detected
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G  8.6G   48G  16% /
                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                          tmpfs          tmpfs     759M  1.2M  758M   1% /run
                          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                          tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                          [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                          [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                          Show mounted filesystems:
                          TARGET  SOURCE         FSTYPE OPTIONS
                          /       /dev/mmcblk0p2 ext4   rw,noatime
                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          2.0G    /var/
                          1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                          1.1G    /var/log
                          634M    /var/cache
                          Archived and active journals take up 1.0G in the file system.
                          /opt/iobroker/backups:
                          91M     /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          815M    /opt/iobroker/iobroker-data/
                          761M    /opt/iobroker/iobroker-data/files
                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                          13M     /opt/iobroker/iobroker-data/objects.jsonl
                          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v20.18.0
                          /usr/bin/node           v20.18.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.29.3
                          nodejs:
                            Installed: 20.18.0-1nodesource1
                            Candidate: 20.18.0-1nodesource1
                            Version table:
                           *** 20.18.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                  100 /var/lib/dpkg/status
                               20.17.0-1nodesource1 1001
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u5 500
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                          Core adapters versions
                          js-controller:  6.0.11
                          admin:          7.1.5
                          javascript:     8.8.3
                          nodejs modules from github:     2
                          +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                          +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                            system.adapter.history.0                : history               : iobroker                                 - disabled
                            system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                            system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                            system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                            system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                            system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                            system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                          + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Upgrade policy: none
                          Installed ioBroker-Instances
                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                          Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                          Controller "js-controller": 6.0.11   , installed 6.0.11
                          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                          Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                          Objects and States
                          Objects:        1050
                          States:         801
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                          tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                          udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                          udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                          udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                          2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                          2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                          2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                          2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                          iob diag has finished.
                          Press any key for a summary
                            • dogfight76
                              Reboot isr durch
                                @dogfight76
                                Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                                Mit
                                muss dir aber wer anders weiterhelfen.
                                Ich würde vorschlagen, in einem separaten Thread.
                                  @dogfight76
                                  influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                                  • dogfight76
                                    InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                                    Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                                    Und dann weiter ?
                                      Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                                      Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                                      Ob du das brauchst musst du selber entscheiden.
                                      • dogfight76
                                        Ok, jetzt noch das Update beovr das aktuelle OS-Lite (64bit) auf die microSD-Karte kommt ?
                                          Welches Update? Das Betriebssystem ist aktuell, ebenso wie der ioBroker.
                                          Mit der Basis kannst du jetzt umziehen.
                                          • dogfight76
                                            Sorry, natürlich war das Backup gemeint.
                                            Das muss ich dann ja noch von der SD-Karte auf meinen PC ziehen, um das dann wieder einzuspielen. Oder ?
                                            4963
