    4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
      leonundjulie @bolliy last edited by leonundjulie
      @bolliy Mit dem Thema LOG habe ich mich bis dato nicht wirklich befassen müssen.
      Wir reden über das was man unter PROTOKOLLE findet? Ich frage, weil ich dort noch kein JSON gesehen habe. Freue mich über eine kurze Info.
      Andreas
        bolliy Developer @leonundjulie last edited by
        @leonundjulie
        {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3695,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":3653,"getMultipleHoldingRegisters-address_32064-value_2-unidId_1":6028,"getMultipleHoldingRegisters-address_37113-value_2-unidId_1":6028,"getMultipleHoldingRegisters-address_38233-value_3-unidId_1":3653,"getMultipleHoldingRegisters-address_38275-value_3-unidId_1":3653,"getMultipleHoldingRegisters-address_38229-value_13-unidId_1":894,"getMultipleHoldingRegisters-address_38271-value_13-unidId_1":893,"getMultipleHoldingRegisters-address_37000-value_23-unidId_1":893,"getMultipleHoldingRegisters-address_37046-value_4-unidId_1":893,"getMultipleHoldingRegisters-address_47081-value_18-unidId_1":893,"getMultipleHoldingRegisters-address_32000-value_11-unidId_1":892,"getMultipleHoldingRegisters-address_32016-value_4-unidId_1":1774,"getMultipleHoldingRegisters-address_32089-value_1-unidId_1":893,"getMultipleHoldingRegisters-address_32066-value_50-unidId_1":892,"getMultipleHoldingRegisters-address_37100-value_38-unidId_1":1773,"getMultipleHoldingRegisters-address_37758-value_30-unidId_1":892,"getMultipleHoldingRegisters-address_47415-value_4-unidId_1":892,"getMultipleHoldingRegisters-address_37411-value_1-unidId_100":894,"getMultipleHoldingRegisters-address_37498-value_20-unidId_100":1773,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37001-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37107-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37109-value_2-unidId_1":2375,"#getMultipleHoldingRegisters-address_37068-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37004-value_1-unidId_1":2375,"getMultipleHoldingRegisters-address_37111-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37121-value_2-unidId_1":2375}}
        Im Protokoll den letzten Eintrag vom Modbus tcp server in die Zwischenablage kopieren und hier posten.
          leonundjulie @bolliy last edited by Homoran
          @bolliy hoffe, dass das richtig ist:
          2024-11-02 22:38:47.897 - info: sun2000.0 (57957) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":9069,"#getInputRegister-address_37760-value_1-unidId_1":9069,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":4512,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":4512,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4510,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4510}}
          2024-11-02 22:39:07.663 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 (force=false, process=true)
          2024-11-02 22:39:07.672 - info: sun2000.0 (57957) Got terminate signal TERMINATE_YOURSELF
          2024-11-02 22:39:07.675 - info: sun2000.0 (57957) cleaned everything up...
          2024-11-02 22:39:07.680 - info: sun2000.0 (57957) terminating
          2024-11-02 22:39:07.682 - info: sun2000.0 (57957) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-11-02 22:39:07.684 - info: sun2000.0 (57957) Modbus-proxy closed
          2024-11-02 22:39:07.875 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
          2024-11-02 22:39:08.184 - info: sun2000.0 (57957) terminating
          2024-11-02 22:39:08.331 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-11-02 22:39:12.159 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.15.1" started with pid 3698113
          2024-11-02 22:39:15.993 - info: sun2000.0 (3698113) starting. Version 0.15.1 in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
          2024-11-02 22:39:16.359 - info: sun2000.0 (3698113) Modbus-proxy listening on modbus://0.0.0.0:502
          2024-11-02 22:39:16.368 - info: sun2000.0 (3698113) Modbus-proxy initialized
          2024-11-02 22:39:16.517 - info: sun2000.0 (3698113) Open Connection...
          2024-11-02 22:39:21.523 - info: sun2000.0 (3698113) Connected Modbus TCP to 192.168.178.129:502
          2024-11-02 22:39:22.127 - info: sun2000.0 (3698113) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
          2024-11-02 22:39:22.289 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 (force=false, process=true)
          2024-11-02 22:39:22.294 - info: sun2000.0 (3698113) Got terminate signal TERMINATE_YOURSELF
          2024-11-02 22:39:22.296 - info: sun2000.0 (3698113) cleaned everything up...
          2024-11-02 22:39:22.300 - info: sun2000.0 (3698113) terminating
          2024-11-02 22:39:22.304 - info: sun2000.0 (3698113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-11-02 22:39:22.305 - info: sun2000.0 (3698113) Modbus-proxy closed
          2024-11-02 22:39:22.524 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
          2024-11-02 22:39:22.807 - info: sun2000.0 (3698113) terminating
          2024-11-02 22:39:22.962 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-11-02 22:39:26.687 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.15.1" started with pid 3698407
          2024-11-02 22:39:31.315 - info: sun2000.0 (3698407) starting. Version 0.15.1 in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
          2024-11-02 22:39:31.724 - info: sun2000.0 (3698407) Modbus-proxy listening on modbus://0.0.0.0:502
          2024-11-02 22:39:31.732 - info: sun2000.0 (3698407) Modbus-proxy initialized
          2024-11-02 22:39:31.873 - info: sun2000.0 (3698407) Open Connection...
          2024-11-02 22:39:36.880 - info: sun2000.0 (3698407) Connected Modbus TCP to 192.168.178.129:502
          2024-11-02 22:39:37.520 - info: sun2000.0 (3698407) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
          2024-11-02 22:39:38.219 - info: sun2000.0 (3698407) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 2
          2024-11-02 22:41:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":6,"#getInputRegister-address_37760-value_1-unidId_1":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":1,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":1}}
          2024-11-02 22:42:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":9,"#getInputRegister-address_37760-value_1-unidId_1":9,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":3}}
          2024-11-02 22:42:55.169 - warn: ebus.0 (2954287) no update since 2.11.2024, 12:35:27 broadcast.messages.error.lastup
          2024-11-02 22:42:55.225 - warn: ebus.0 (2954287) no update since 24.10.2024, 14:24:52 broadcast.messages.signoflife.lastup
          2024-11-02 22:42:55.529 - info: ebus.0 (2954287) installed ebusd version is 23.3
          2024-11-02 22:42:55.647 - info: ebus.0 (2954287) all http done
          2024-11-02 22:43:31.723 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":12,"#getInputRegister-address_37760-value_1-unidId_1":12,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4}}
          2024-11-02 22:44:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":15,"#getInputRegister-address_37760-value_1-unidId_1":15,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":6,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":6,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":6}}
          2024-11-02 22:45:15.306 - info: admin.0 (2952665) <== Disconnect system.user.admin from ::ffff:192.168.178.88 admin
          2024-11-02 22:45:23.163 - info: admin.0 (2952665) ==> Connected system.user.admin from ::ffff:192.168.178.88
          2024-11-02 22:45:31.719 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":18,"#getInputRegister-address_37760-value_1-unidId_1":18,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":8,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":8,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":7,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":7}}
          2024-11-02 22:45:40.053 - info: host.raspberrypi instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3705914
          2024-11-02 22:45:44.183 - info: daswetter.0 (3705914) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.4, js-controller: 6.0.11
            @leonundjulie ich sehe nun was das Problem ist. smartfox liest die Registerdaten auch über die inputRegister-Abfrage. Das Verhalten ist zwar ok, aber ungewöhnlich.
            Ich werde den Adapter anpassen und mich wieder melden. Dann kannst du testen 😉
            LG Stephan
              @leonundjulie ich hoffe, dass es nun mit dem smartfox und dem modbus-proxy funktioniert - bitte testen und Rückmeldung geben.
              Die Installation erfolgt über den Expertenmodus. Danach auf die „Krakenkatze“ klicken, dann "von github" den Adapter "sun2000" auswählen und die Installation starten.
              Danach muss der Adapter ggf. einmal neu gestartet werden!
              Falls weiter Probleme auftauchen - nur das JSON hinter Modbus tcp server: posten. Sonst platzt hier das Forum noch. 😉
              LG Stephan
                @bolliy danke Stephan.
                In welcher Version hast Du es angepasst?
                Weil ich an der Stelle noch keine Erfahrungen gemacht habe: wie kann ich Deine Bitte zum JSON umsetzen?
                Gruß Andreas
                  @leonundjulie in der letzten. (V0.16.0)
                  Das Projekt wird auf github (Versionsverwaltung) gehostet. https://github.com/bolliy/ioBroker.sun2000
                  Dort kannst du meine Änderungen verfolgen.
                  Bitte so installieren wie ich es beschrieben habe. Es ist noch keine eigene Version. Eine neue Version erfolgt erst wenn es keine Fehler mehr von dir festgestellt werden...
                  Das JSON ist ein Format um Daten und deren Struktur abzubilden. Kannst du bei Wikipedia nachlesen.
                  Im Protokoll die Stelle mit dem JSON in die Zwischenablage kopieren und hier posten.
                  Stephan
                    @bolliy Guten Morgen Stephan.
                    Die Sonne ist aufgegangen und ich habe die neue Version eingepflanzt.
                    Das Ergebnis:
                    2024-11-04 07:48:36.012 - info: sun2000.0 (1896556) terminating
                    2024-11-04 07:48:36.014 - info: sun2000.0 (1896556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-11-04 07:48:36.016 - info: sun2000.0 (1896556) Modbus-proxy closed
                    2024-11-04 07:48:36.220 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
                    2024-11-04 07:48:36.517 - info: sun2000.0 (1896556) terminating
                    2024-11-04 07:48:36.661 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2024-11-04 07:48:40.544 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.16.0" (non-npm: bolliy/ioBroker.sun2000) started with pid 1897241
                    2024-11-04 07:48:45.602 - info: sun2000.0 (1897241) starting. Version 0.16.0 (non-npm: bolliy/ioBroker.sun2000) in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
                    2024-11-04 07:48:46.047 - info: sun2000.0 (1897241) Modbus-proxy listening on modbus://0.0.0.0:502
                    2024-11-04 07:48:46.059 - info: sun2000.0 (1897241) Modbus-proxy initialized
                    2024-11-04 07:48:46.189 - info: sun2000.0 (1897241) Open Connection...
                    2024-11-04 07:48:51.198 - info: sun2000.0 (1897241) Connected Modbus TCP to 192.168.178.129:502
                    2024-11-04 07:48:53.108 - info: sun2000.0 (1897241) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
                    2024-11-04 07:48:54.518 - info: sun2000.0 (1897241) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 2
                    2024-11-04 07:50:46.036 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":3,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":1,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":1}}
                    2024-11-04 07:51:46.035 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":6,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":3}}
                    2024-11-04 07:52:46.035 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":9,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":9,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4}}
                    Und im SMARTFOX werden weiterhin weder LEISTUNG noch SOC angezeigt.
                      bolliy Developer @leonundjulie last edited by bolliy
                      @leonundjulie im Log wird vom modbus-proxy kein Fehler angezeigt. Das Screenshot zeigt aber doch Werte - nur kein SOC?!
                      Was am Morgen im Winter durchaus normal ist.
                      Der Screenshot ist doch vom smartfox - oder nicht?
                      Stephan
                      L M 2 Replies Last reply Reply Quote 0
                        @bolliy Hallo Stephan.
                        Meine LUNA2000 ist so eingestellt, dass sie bei 5% abschaltet.
                        Hier drei Fotos - die ich vor einer Minute machte:
                        • Die Werte der Batterie in Fusion Solar
                        • Die Werte der Batterie im iOBroker
                        • Die Werte der Batterie im SMARTFOX
                        FusionSolar und IOBroker passen ungefähr zusammen (das Delta erklärt sich sicherlich aus dem Delay, welches sich aus der Datenübertragung in die Cloud und zurück ergibt. Und der SMARTFOX zeigt halt gar nichts zur Batterie.
                        Da stimmt doch etwas nicht … aber was?
                        Also habe ich iOBroker den HUAWEI Adapter deaktiviert und den SMARTFOX direkt auf die IP des SDONGLES gelegt … dann müsste der SMARTFOX ja eigentlich alles richtig anzeigen - tut er aber nicht. Die Batterie zeigt weiterhin nichts und die von der Batterie abgegebene Leistung wird im SMARTTFOX als PRODUKTION angezeigt. Damit werde ich erstmal die Hotline des SMARTFOX konfrontireren.
                          mhuber @bolliy last edited by
                          Hallo zusammen, ich bekomme vom Adapter laufen folgende Meldungen:
                          "Not all data can be read! Please inspect the sun2000 log."
                          Welches Log muss ich da wo auslesen und auf was muss ich achten?
                          B T 2 Replies Last reply Reply Quote 0
                            @leonundjulie vielleicht sind falsche Register hinterlegt:
                            Hier findest du Definitionen
                            https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/definitions.md
                            LG Stephan
                              bolliy Developer @mhuber last edited by
                              @mhuber die Logs findest unter im ioBroker unter Protokolle! Auf den sun2000 abgrenzen und die Fehler hier posten.
                              Das Video ist zwar etwas älter, aber vielleicht dennoch hilfreich:
                              https://www.youtube.com/watch?v=-1PCHancttc
                              Stephan
                              B M 2 Replies Last reply Reply Quote 0
                                Thofri @mhuber last edited by
                                @mhuber Was auf jeden Fall sichergestellt sein muss, ist die aktuelle Firmware
                                beim Dongle. Seit dem neusten Update (PC121) habe ich keine Warnungen mehr und alle Daten werden
                                ausgelesen. Vielleicht hilft das auch bei dir? 👍
                                  bolliy Developer @bolliy last edited by bolliy
                                  @bolliy dann bitte für alle Geräteeinheiten einen Firmwareupdate machen!
                                  M L 2 Replies Last reply Reply Quote 0
                                    @leonundjulie kann ich das selbst beeinflussen? Hab nichts geändert....
                                      mhuber @Thofri last edited by
                                      @thofri ist drauf, halte immer alles aktuell
                                        mhuber @bolliy last edited by mhuber
                                        @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                                        Stephan
                                        @bolliy ah eh einfach Adapter auf Debug stellen, dachte es ist ein anderes Log (ev direkt vom WR) gemeint.
                                        So sieht das Debug log aus, immer wenn der Fehler kommt
                                        sun2000.0
                                        2024-11-05 06:43:40.803	debug	Fetched inverter.0.activePower, val=-0.069
                                        sun2000.0
                                        2024-11-05 06:43:40.706	debug	Try to read data from id/address 1/38229/low/battery Pack1 information
                                        sun2000.0
                                        2024-11-05 06:43:39.739	debug	Try to read data from id/address 1/38317/high/Battery Pack3 Charge And Discharge Power
                                        sun2000.0
                                        2024-11-05 06:43:37.244	debug	Try to read data from id/address 1/38275/high/Battery Pack2 Charge And Discharge Power
                                        sun2000.0
                                        2024-11-05 06:43:35.659	debug	Try to read data from id/address 1/38233/high/Battery Pack1 Charge And Discharge Power
                                        sun2000.0
                                        2024-11-05 06:43:34.772	debug	Try to read data from id/address 1/37113/high/meter activePower
                                        sun2000.0
                                        2024-11-05 06:43:32.804	debug	Try to read data from id/address 1/32064/high/Input Power
                                        sun2000.0
                                        2024-11-05 06:43:32.372	warn	Not all data can be read! Please inspect the sun2000 log.
                                        sun2000.0
                                        2024-11-05 06:43:32.372	debug	{"timeout":10000,"delay":0,"connectDelay":5000,"modbusAdjust":false,"min":0,"max":6000,"stat":{"successSumCounter":73,"errorSumCounter":0},"adjust":{"successLevel":0,"successCounter":3,"errorCounter":0,"lastLength":2,"SuccessDelay":0,"ErrorDelay":0}}
                                        sun2000.0
                                        2024-11-05 06:43:32.371	debug	### Watchdog: time since last update 2.368 sec
                                        Aja zur Info: Further battery register data hab ich beide schon ein und ausgeschalten, bringt aber nichts.
                                          bolliy Developer @mhuber last edited by bolliy
                                          @mhuber die Fehlermeldung besagt, dass nicht alle Daten gelesen werden können. Das Log des Adapters auf info einstellen oder das Protokoll auf info filtern, damit ich auch die errors und warn sehen kannst. Das Log bitte dann hier posten.
                                          Denn im Log müssten Fehler oder weitere Warnmeldung aufgetaucht sein und die sind für uns interessant und entscheidend für eine Diagnose 😉
                                          Das Debug Log ist für eine Ersteinschätzung hinderlich, da zuviele Einträge im Log erscheinen.
                                          Übrigens: DIe Batteriedaten unit und Pack können anscheinend vom Adapter ohne Fehlermeldung gelesen werden. Es müsste ein anderes Problem vorliegen.
                                            Also bei mir kommt da nichts ausser:
                                            sun2000.0
                                            2024-11-05 08:59:20.982	warn	Not all data can be read! Please inspect the sun2000 log.
                                            sun2000.0
                                            2024-11-05 08:53:20.974	warn	Not all data can be read! Please inspect the sun2000 log.
                                            sun2000.0
                                            2024-11-05 08:52:20.973	warn	Not all data can be read! Please inspect the sun2000 log.
                                            Adapter auf Info gestellt und im Protokoll kommt nur das, oder muss ich wo anders noch schaun?
                                            adapter emma huawei inverter luna2000 modbus tcp modbus-proxy sdongle smartlogger sun2000
                                            84
                                            1041
                                            272814
