    4. [Gelöst] "Objekte" Tab bleibt leer
      Ahnungsbefreit @Thomas Braun last edited by
      @thomas-braun said in "Objekte" Tab bleibt leer:
      Ich würde da im esphome-Umfeld mal schauen. Schaut mich seltsam aus.
      So, esphome ist jetzt komplett (Adapter und Instanz) gelöscht, ioB läuft auch 🙂
      Ich werde mal ein paar Loglevel wieder umstellen, das müllt ja das Log zu...
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: ioBVM-prod3
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-26-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       17:18:41 up  4:58,  2 users,  load average: 1.12, 0.62, 0.37
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2024-10-28 17:18:41 CET
                 Universal time: Mon 2024-10-28 16:18:41 UTC
                       RTC time: Mon 2024-10-28 16:18:41
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      thomas
      HOME=/home/thomas
      GROUPS=thomas cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            6.2G        3.6G        2.0G        524K        834M        2.6G
      Swap:           1.0G        315M        706M
      Total:          7.2G        3.9G        2.7G
      Active iob-Instances:   48
               5925 M total memory
               3451 M used memory
                821 M active memory
               2887 M inactive memory
               1926 M free memory
                123 M buffer memory
                672 M swap cache
                974 M total swap
                301 M used swap
                673 M free swap
      top - 17:18:41 up  4:58,  2 users,  load average: 1.12, 0.62, 0.37
      Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   5925.2 total,   1926.8 free,   3451.6 used,    796.1 buff/cache
      MiB Swap:    975.0 total,    673.6 free,    301.3 used.   2473.6 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs          tmpfs     593M  576K  592M   1% /run
      /dev/sda1      ext4       62G  7.3G   52G  13% /
      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     534M     0  534M   0% /run/user/1000
      [Mon Oct 28 12:20:39 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Oct 28 12:20:39 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      462M    /var/
      250M    /var/cache
      243M    /var/cache/apt
      173M    /var/lib
      166M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      28M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      65M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100JQ7-if03
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100JQ7-if00
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBVM-prod3         ioBVM-prod3 (version: 6.0.11, hostname: ioBVM-prod3   , alive, uptime: 17871)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     4
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#c904199ffc910cb1326aadcf1dc23ba5f197f05f)
      +-- iobroker.vw-connect@0.5.1 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#29ef72ba0568014661f431d5fc0908619fff89c2)
      +-- iobroker.yahoo-stock-market@0.0.7 (git+ssh://git@github.com/Newan/ioBroker.yahoo-stock-market.git#d64a80e7d0e8fc2be195923775ccba3f78738a43)
      `-- iobroker.zigbee@1.10.10 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#40073e03301995ffa45471b6b32204a37c9d6743)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBVM-prod3                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBVM-prod3                              -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBVM-prod3                              - disabled
      + system.adapter.backitup.0               : backitup              : ioBVM-prod3                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBVM-prod3                              -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBVM-prod3                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : ioBVM-prod3                              -  enabled
        system.adapter.devices.0                : devices               : ioBVM-prod3                              - disabled
      + system.adapter.discovery.0              : discovery             : ioBVM-prod3                              -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBVM-prod3                              -  enabled
      + system.adapter.echarts.0                : echarts               : ioBVM-prod3                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBVM-prod3                              -  enabled
      + system.adapter.email.0                  : email                 : ioBVM-prod3                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBVM-prod3                              -  enabled
        system.adapter.fahrplan.0               : fahrplan              : ioBVM-prod3                              - disabled
        system.adapter.feiertage.0              : feiertage             : ioBVM-prod3                              -  enabled
      + system.adapter.followthesun.0           : followthesun          : ioBVM-prod3                              -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : ioBVM-prod3                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : ioBVM-prod3                              -  enabled
      + system.adapter.ham.0                    : ham                   : ioBVM-prod3                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBVM-prod3                              -  enabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBVM-prod3                              -  enabled, port: 12010
      + system.adapter.hm-rpc.3                 : hm-rpc                : ioBVM-prod3                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : ioBVM-prod3                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : ioBVM-prod3                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBVM-prod3                              -  enabled
      + system.adapter.javascript.0             : javascript            : ioBVM-prod3                              -  enabled
      + system.adapter.javascript.9             : javascript            : ioBVM-prod3                              -  enabled
        system.adapter.lametric.0               : lametric              : ioBVM-prod3                              - disabled
      + system.adapter.logparser.0              : logparser             : ioBVM-prod3                              -  enabled
      + system.adapter.modbus.0                 : modbus                : ioBVM-prod3                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBVM-prod3                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : ioBVM-prod3                              -  enabled
      + system.adapter.ocpp.0                   : ocpp                  : ioBVM-prod3                              -  enabled, port: 9220
        system.adapter.pi-hole.0                : pi-hole               : ioBVM-prod3                              - disabled
      + system.adapter.ping.0                   : ping                  : ioBVM-prod3                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : ioBVM-prod3                              -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBVM-prod3                              -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : ioBVM-prod3                              -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : ioBVM-prod3                              -  enabled, port: 8002
      + system.adapter.simple-api.0             : simple-api            : ioBVM-prod3                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : ioBVM-prod3                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.sonoff.0                 : sonoff                : ioBVM-prod3                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sonos.0                  : sonos                 : ioBVM-prod3                              - disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBVM-prod3                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBVM-prod3                              -  enabled
      + system.adapter.telegram.0               : telegram              : ioBVM-prod3                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.1           : text2command          : ioBVM-prod3                              -  enabled
      + system.adapter.tr-064.3                 : tr-064                : ioBVM-prod3                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBVM-prod3                              -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : ioBVM-prod3                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : ioBVM-prod3                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBVM-prod3                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBVM-prod3                              - disabled
        system.adapter.vis-history.0            : vis-history           : ioBVM-prod3                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBVM-prod3                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBVM-prod3                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBVM-prod3                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBVM-prod3                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBVM-prod3                              - disabled
        system.adapter.vis-map.0                : vis-map               : ioBVM-prod3                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBVM-prod3                              - disabled
        system.adapter.vis.0                    : vis                   : ioBVM-prod3                              -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : ioBVM-prod3                              -  enabled
      + system.adapter.web.0                    : web                   : ioBVM-prod3                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : ioBVM-prod3                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : ioBVM-prod3                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBVM-prod3                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.1    , installed 0.5.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "lametric"     : 3.4.0    , installed 3.4.0
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
      Objects and States
      Objects:        30936
      States:         26372
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16720      517/sshd: /usr/sbin
      tcp        0      0 192.168.178.90:12010    0.0.0.0:*               LISTEN      1001       17707      977/io.hm-rpc.1
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12983      1/init
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15525      494/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16789      494/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18863      1185/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       16101      772/io.mqtt.0
      tcp        0      0 192.168.178.90:9292     0.0.0.0:*               LISTEN      1001       18447      992/io.hm-rpc.3
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16741      517/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12985      1/init
      tcp6       0      0 :::9220                 :::*                    LISTEN      1001       19422      1441/io.ocpp.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19975      1471/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19456      1456/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16873      553/io.admin.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       20963      1647/io.web.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20886      1623/io.web.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14569      386/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12984      1/init
      udp6       0      0 :::111                  :::*                                0          12986      1/init
      2024-10-28 16:30:26.498  - info: dwd.0 (10294) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 16:35:26.014  - info: dwd.0 (10473) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 16:35:26.416  - info: dwd.0 (10473) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 16:40:02.469  - info: admin.0 (553) ==> Connected system.user.admin from ::ffff:192.168.178.57
      2024-10-28 16:40:26.065  - info: dwd.0 (10636) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 16:40:26.455  - info: dwd.0 (10636) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 16:44:23.276  - info: zigbee.0 (1215) Device '0x001788010648a3ee' announced itself
      2024-10-28 16:45:26.008  - info: dwd.0 (10799) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 16:45:26.376  - info: dwd.0 (10799) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 16:50:26.156  - info: dwd.0 (10962) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 16:50:26.547  - info: dwd.0 (10962) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 16:55:26.013  - info: dwd.0 (11120) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 16:55:26.338  - info: dwd.0 (11120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 17:00:01.404  - warn: ical.0 (11267) Error reading "/home/iobroker/userdata/EFB_Abfuhrtermine_Stand_20231214.ICS": File does not exist: "/home/iobroker/userdata/EFB_Abfuhrtermine_Stand_20231214.ICS"
      2024-10-28 17:00:26.092  - info: dwd.0 (11298) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 17:00:26.466  - info: dwd.0 (11298) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 17:05:26.115  - info: dwd.0 (11477) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 17:05:26.484  - info: dwd.0 (11477) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 17:10:26.145  - info: dwd.0 (11634) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 17:10:26.489  - info: dwd.0 (11634) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 17:15:26.067  - info: dwd.0 (14026) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
      2024-10-28 17:15:26.519  - info: dwd.0 (14026) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-28 17:17:42.107  - info: admin.0 (553) <== Disconnect system.user.admin from ::ffff:192.168.178.57 admin
      2024-10-28 17:17:45.466  - info: admin.0 (553) ==> Connected system.user.admin from ::ffff:192.168.178.57
      2024-10-28 17:17:57.911  - info: admin.0 (553) <== Disconnect system.user.admin from ::ffff:192.168.178.57 admin
        Ahnungsbefreit @Ahnungsbefreit last edited by
        Hat keiner eine Idee, woran das noch liegen könnte?
        • MartinP
          MartinP last edited by
          @ahnungsbefreit Dein Beitrag hat Fehlinterpretationspotential - habe gedacht, dass es ohne Esphome läuft ...
          habe mich gerade mal durch den Diag output gewühlt, und mir ist leider nichts aufgefallen
            Ahnungsbefreit @MartinP last edited by
            @martinp Du hast Recht, deswegen habe ich ja noch einmal gefragt.
            • MartinP
              MartinP @Ahnungsbefreit last edited by
              @ahnungsbefreit Ich habe noch einmal genauer nachgeschaut, und meinen letzten iob diag Aufruf danebengehalten. Mir ist bei DIR nichts aufgefallen, aber bei MIR - gleich mal einen Thread aufmachen 😉
              Hast Du mal mit verschiedenen Browser versucht, das Objects Fenster aufzumachen, oder mit einem privaten Fenster?
              Vielleicht ist es ja auch ein Problem im Browser-Cache....
                Ahnungsbefreit @MartinP last edited by Ahnungsbefreit
                @martinp said in "Objekte" Tab bleibt leer:
                Ja, das habe ich auch schon probiert. Chrome, Firefox, Edge, Private Mode - immer das gleiche Ergebnis...
                Danke für's noch einmal anschauen!
                Edit: Ich habe eben noch einmal Firefox im Private Mode versucht, die Konsole ist etwas gesprächiger als bei Chrome:
                Es scheint also so, als ob da einige Resourcen (css, js) fehlen oder zerschossen sind. Wie kann man das denn reparieren?
                Edit2: Ich habe mal auf Verdacht "iob upload all" (und danach fix, reboot) gemacht aber auch das bringt nix. Hat keiner mehr eine Idee?
                A Homoran 2 Replies Last reply Reply Quote 0
                  Update: Ich habe gestern ein GitHub Issue dazu aufgemacht, aber scheinbar bin der Einzige mit diesem Problem.
                  Wenn sich daran nichts ändert, habe ich nur noch 2 Optionen:
                  1. Komplett neu aufsetzen, alle Devices neu anlernen etc.
                  2. Wechseln auf z.B. HomeAsssistant
                  In beiden Fällen wäre das ziemlich viel Arbeit, zumal ich ioBroker wirklich für das bessere System halte. Aber der jetzige Zustand ist nur tragbar, so lange alles läuft...
                  Hat noch jemand eine andere Idee?
                    Homoran Global Moderator Administrators @Ahnungsbefreit last edited by
                    @ahnungsbefreit sagte in "Objekte" Tab bleibt leer:
                    ja!
                    Aufgrund von Netzwerkproblemen
                      Ahnungsbefreit @Homoran last edited by
                      @homoran Aber nachdem ich ja komplett neu auf einer anderen VM installiert habe und "nur" das BackitUp von der alten übernommen habe, wie kann das sein?
                        wie kann das sein?
                        was hat die Neuinstallation mit deiner Netzwerkinfrastrukur zu tun?
                        Da scheint irgendwo der Wurm drin zu sein.
                          @homoran Wohl kaum. Meine Netzwerkinfrastruktur funktioniert, sonst könnte ich kaum auf alle anderen Tabs im ioBroker Admin sowie auf die VIS zugreifen. Und das gilt auch egal ob via PC mit Kabel oder Handy mit WLAN. An der Netzwerkinfrastruktur hat sich auch nichts geändert und bis vor X Wochen ging das ja auch.
                            aber irgendwo klemmt's
                              @homoran Ich kann mich irren, aber das bedeutet doch nur, dass der Browser das nicht über die spezifizierte Adresse laden konnte. Das würde auch passieren, wenn diese Ressource nicht existiert, oder?
                                @Homoran Ich habe jetzt zusätzlich vorübergehend den Remote-Zugriff auf den Admin geöffnet, um über einen anderen Netzwerkzugang zu testen. Das Ergebnis ist leider unverändert: Kein Zugriff auf die Objekte, Endlos-Ladeanimation....
                                  @ahnungsbefreit Dann muss dir ein Wissender helfen.
                                  Die vollständigen (??) Infos liegen ja jetzt vor
                                    @homoran Danke für Deine Hilfe. Damit die "Wissenden" sich das anschauen, habe ich ja ein GitHub Issue geöffnet (siehe oben), leider ohne Reaktion bis jetzt.
                                      im Moment laufen die letzten Vorbereitungen für das Usermeeting in Solingen am Samstag.
                                      Danach wird wieder mehr Luft sein
                                        @homoran das ist mir klar, das sollte auch keine Beschwerde sein. Bin gespannt, wenn man so alles da treffen wird...
                                          denbo last edited by
                                          Ich hatte die gleiche oder ähnliche Meldung. Bei mir lag es am Admin Adapter, bzw. an den Alias Anpassungen in einer der letzten Versionen. Ich hatte in meinen Alias Objekten Zwischen-Ordner angelegt. Diese scheinen sich mit der aktueller Version des Adapters nicht mehr zu vertragen. Das Löschen dieser Ordner (sind eigentlich auch unnötig) hat bei mir das Problem gelöst.
                                            Ahnungsbefreit @denbo last edited by
                                            @denbo Also jetzt hast Du keine Struktur mehr in den Aliassen wie alias.0.kueche und dann darunter alias.0.kueche.lampe und alias.0.kueche.schalter usw.??
                                            Das wäre ja fürchterlich, wenn das überhaupt nicht mehr gehen würde! Ich habe da locker 50 Geräte mit Alias, das wäre sehr unübersichtlich...
                                            Aber danke für den Hinweis! Hast Du die Meldung noch, ist das genau die gleiche?
                                            A D 2 Replies Last reply Reply Quote 0
                                            1426
