    4. Neuer Adapter für Roborock-Staubsauger
      myssv @da_Woody last edited by
      @da_woody stimmt 😉
      https://github.com/copystring/ioBroker.roborock/issues/695
      myssv created this issue in copystring/ioBroker.roborock
      closed [BUG] Neues Modell: Roborock Qrevo Curv #695
      • da_Woody
        da_Woody @myssv last edited by
        @myssv 👍 ist aber kein Bug, eher request.
        Die Jungs werden das schon einordnen. 😉
          Taddy81 last edited by
          Ich bekomme den Updater irgendwie nicht installiert, wo ist denn hier der Fehler?
           iobroker url https://github.com/copystring/ioBroker.roborock --host IOBroker --debug
          install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd
          Installing copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd... (System call)
          npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.git
          npm warn deprecated npmlog@7.0.1: This package is no longer supported.
          npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.
          npm warn deprecated gauge@5.0.2: This package is no longer supported.
          npm warn deprecated sinon@9.2.4: 16.1.1
          > node dist/install.js
          RequestError: getaddrinfo EAI_AGAIN github.com
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.log
          npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.gitnpm warn deprecated npmlog@7.0.1: This package is no longer supported.npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.npm warn deprecated gauge@5.0.2: This package is no longer supported.npm warn deprecated sinon@9.2.4: 16.1.1RequestError: getaddrinfo EAI_AGAIN github.comnpm error code 1npm error path /opt/iobroker/node_modules/go2rtc-staticnpm error command failednpm error command sh -c node dist/install.jsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.loghost.IOBroker Cannot install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd: 1
          ERROR: Process exited with code 25
            Thomas Braun Most Active @Taddy81 last edited by
            @taddy81
            Grundsätzlich funktioniert das.
            $ iobroker url copystring/ioBroker.roborock --host chet --debug
            Installing copystring/ioBroker.roborock... (System call)
            Support for loading ES Module in require() is an experimental feature and might change at any time(Use `node --trace-warnings ...` to show where the warning was created)
            > go2rtc-static@1.9.4 install> node dist/install.js
            > node install.js
            added 223 packages, and changed 1 package in 1m227 packages are looking for funding run `npm fund` for details
            upload [13] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [12] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/jsonConfig.json jsonConfig.json application/json
            upload [1] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
            Updating objects from io-package.json for adapter "roborock" with version "0.6.17"
            Process exited with code 0
            Ist immer ein Hinweis auf Netzwerk-Trouble. github.com kann nicht erreicht werden.
              @taddy81
              Verwende
              iobroker url copystring/ioBroker.roborock --host IOBroker --debug
              auf dem System...
                Danke,
                hat funktioniert.
                Dein Code hat geklappt, warum hat denn der GitHub Repo nicht geklappt hat?
                Ein Problem war bei mir noch, dass meine Firewall die URL von Roborock blockiert hat. Ist nun aber gefixt und ich kann auf die Instanz zugreifen.
                Vielen Dank
                  @taddy81 sagte in Neuer Adapter für Roborock-Staubsauger:
                  Was genau hast du denn wo ausgewählt?
                    breaksrmine last edited by
                    Seit 2 Tagen gabs in iOS ein Update der Roborock App sieht auch optisch anders aus. Seitdem funktioniert in ioBroker die Steuerung nicht mehr. Ich bekomm werte soweit alles gut aber keine Reaktion beim z.b starten des Saugers.
                    Jemand das gleiche Problem ?
                    C H 2 Replies Last reply Reply Quote 0
                      chuck2941 @breaksrmine last edited by
                      @breaksrmine Also ich habe kein Update, die App sieht immer noch gleich aus und die Steuerung über ioBroker funktioniert.
                      Was aber immer im Log kommt wenn der Sauger läuft ist folgendes
                      roborock.0
                      2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapData" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:28.091	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.935	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.task_id" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.934	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_times" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.933	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dirty_replenish" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.manual_replenish" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.cleaned_area" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.931	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map_flag" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.wash_count" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.avoid_count" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dust_collection_status" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.finish_reason" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_type" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.start_type" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.927	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.complete" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.926	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.error" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.925	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.area" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.924	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.duration" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.end" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.begin" has no existing object, this might lead to an error in future versions
                      Ich kann die Einträge nicht finden in den Objekten
                        hansano @breaksrmine last edited by hansano
                        @breaksrmine
                        Das kann ich so bestätigen, ist bei mir auch so
                        Edit: nach Neustart des Adapters läuft es wieder
                          erickuttruff last edited by erickuttruff
                          Failed to execute get_map_v1 on robot 2BFDPXMouOnerH911HQrgP (roborock.vacuum.a51): TypeError: The "chunk" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Array at _write (node:internal/streams/writable:480:13) at Gzip.Writable.end (node:internal/streams/writable:821:17) at zlibBuffer (node:zlib:129:10) at Object.asyncBufferWrapper [as gzip] (node:zlib:776:12) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:70:11) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                          Ich habe immer sehr viele Fehler wie im Screenshot zu sehen... An was liegt es?
                            Thomas Braun Most Active @erickuttruff last edited by
                            @erickuttruff sagte in Neuer Adapter für Roborock-Staubsauger:
                            Text bitte auch als TEXT in CodeTags eingebettet posten. Mit bunte Bildchens kann man nix anfangen.
                              erickuttruff @Thomas Braun last edited by
                              @thomas-braun: Ich habe den Beitrag korrigiert...
                                breaksrmine @hansano last edited by
                                @hansano bei mir auch so jetzt 🙂
                                  RISSN last edited by
                                  unhandled promise rejection: Login returned empty userdata.
                                  Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  Error in getUserData: Login returned empty userdata.
                                  Diese Fehler bekomme ich nach dem Updaten auf Version:
                                  v0.6.17. Auch ein rücksetzen auf die Vorgängerversion bliebt ohne Erfolg. Hat das vielleicht noch jemand?
                                  • Jey Cee
                                    @rissn Meld dich mal in der App neu an, die hatte ein Update.
                                    Danach gehts wieder.
                                    R B 2 Replies Last reply Reply Quote 1
                                      RISSN @Jey Cee last edited by
                                      @jey-cee vielen Dank, dass war es 👍
                                        breaksrmine @Jey Cee last edited by breaksrmine
                                        @jey-cee danke geht wieder !
                                          chuck2941 last edited by
                                          Hallo, jedesmal wenn der S8 in Aktion ist wird mir der Log mit Warnungen vollgeschrieben, weiß jemand was das ist?
                                          In den Objekten gibt es keine Einträge dazu.
                                          24-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapData" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.432 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.begin" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.433 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.end" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.duration" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.area" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.435 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.error" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.complete" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.start_type" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.437 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.clean_type" has no existing object, this might lead to an error in future versions
                                          2024-11-26 08:09:04.438 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.finish_reason" has no existing object, this might lead to an error in future versions
                                          T E 2 Replies Last reply Reply Quote 0
                                          • Matzebhv
                                            Matzebhv last edited by
                                            Moin,
                                            ich habe seit heute den S8 MaxV Ultra.
                                            Hier kann anscheinend die Karte nicht mehr gezogen werden, das Log läuft über mit:
                                            Failed to execute get_map_v1 on robot xxxxxxxxxxT0dDsc9ju (roborock.vacuum.a97): Error: Failed to convert JavaScript value `Undefined` into rust type `String` at /opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:647:29 at Array.forEach (<anonymous>) at MapCreator.canvasMap (/opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:624:30) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:84:46)
                                            Wird das bei dem Modell noch nicht unterstützt?
                                            Bei dem Vorgänger S6MaxV Ultra hatte ich das Problem nicht.
                                            Habe die Karte jetzt erstmal deaktiviert.
                                            Matze
                                            916
                                            303785
