    3. Einsteigerfragen
    4. Installation
    5. Umzug von raspi Installation auf lxc proxmox container
      A Former User @lunatikk last edited by
      @lunatikk
      Installier mal den Container neu , dann User anlegen, updates von Bookworm drauf, dann Iobroker installieren und dann mal ein iob diag posten.
      Nicht dass schon mit dem Container was nicht stimmt.
        lunatikk @Guest last edited by lunatikk
        @ilovegym
        hier der diag output:
                                v.2024-10-19
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.4-2-pve
            Architecture: x86-64
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                0
        Display-Server:         false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        Recommended versions are nodejs
        ***For security reasons ioBroker should not be run or administrated as root.***
        By default only a user that is member of iobroker group can execute ioBroker commands.
        Please read the Documentation on how to set up such a user, if not done yet.
        Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
        Please note that this option may be disabled in the future, so please change your setup accordingly now. and npm
        nodeJS installation is correct
        MEMORY:
        Mem:            2.1G        309M        1.5G        102K        345M        1.8G
        Swap:           536M          0B        536M
        Total:          2.7G        309M        2.0G
        Active iob-Instances:   0
        ioBroker Core:          js-controller
                                admin
        ioBroker Status:
        Objects:                6
        States:                 6
        Size of iob-Database:
        5.0M    /opt/iobroker/iobroker-data/objects.jsonl
        48K     /opt/iobroker/iobroker-data/states.jsonl
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        habe vorher den iobroker beendet und "iobroker fix" aufgerufen. bekam folgende ausgabe: "By default only a user that is member of iobroker group can execute ioBroker commands".
        Das kannte ich so noch nicht von meinem raspberry. Habe das command mit --allow-root ausgeführt und einen neuen user "admin" angelegt (root und iobroker ging ja nicht). Der user ist nun angelegt. Das fix command habe ich trotzdem mit root ausgeführt:
          @ilovegym said in Umzug von raspi Installation auf lxc proxmox container:
          Bookworm drauf, dan
          Bookworm sagt mir leider garnix. Habe für die Installation die VR Helper scripts genutzt:
          https://tteck.github.io/Proxmox/#iobroker-lxc
          viele Grüße
          lunatikk
            Thomas Braun Most Active @lunatikk last edited by
            @lunatikk sagte in Umzug von raspi Installation auf lxc proxmox container:
            Du sollst da aber eben NICHTS mit root-Rechten machen.
              lunatikk @Thomas Braun last edited by
              @thomas-braun said in Umzug von raspi Installation auf lxc proxmox container:
              Okay, nur verständnishalber: weshalb soll ich das nicht mit "root-Rechten" machen?
              Iobroker läuft ja bereits in dem lxc container. Soll ich mich dann mit dem "iobroker" user anmelden oder mit dem von mir während dem "fix" neu erstellten user?
              Viele Grüße
              • Codierknecht
                Codierknecht Developer Most Active @lunatikk last edited by
                Weil Du Dir damit die Rechte verbiegst.
                Du legst Dir einen eigenen User an. Entweder sowas wie "lunatikk" oder auch Dein Vorname.
                Mit dem arbeitest Du in der Konsole. Niemals als root. Wenn Root-Rechte erforderlich sind, kommt ein sudo vorweg.
                  @lunatikk
                  Na, der fehler sagt dein filesystem ist schreibgeschützt..
                  evtl Iobroker nicht richtig installiert im lxc?
                  Lass mal iob fix laufen und poste bitte die Ausgabe von iob diag hier in codetags.
                  also, nach erneutem rollback auf den stand nachdem der iobroker lxc installiert wurde (vor backup wiederherstellung) habe ich einen benutzer "admin" angelegt und mit diesem user iobroker fix und im anschluss iob diag ausgeführt. Hier die Ausgabe:
                                          v.2024-10-19
                    Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1001
                  Boot Target:            multi-user.target
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.18.0 and npm 10.8.2
                  MEMORY:
                  Mem:            2.1G         63M        1.7G        106K        352M        2.1G
                  Swap:           536M          0B        536M
                  Total:          2.7G         63M        2.3G
                  Active iob-Instances:   1
                  Upgrade policy: none
                  ioBroker Core:          js-controller           6.0.11
                                          admin                   7.1.5
                  ioBroker Status:        iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                    system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  Objects:                148
                  States:                 78
                  4.9M    /opt/iobroker/iobroker-data/objects.jsonl
                  36K     /opt/iobroker/iobroker-data/states.jsonl
                  • Codierknecht
                    Und warum nicht über den "offiziellen" Weg?
                    https://www.iobroker.net/#de/documentation/install/proxmox.md
                    Hatten wir doch hier zuletzt noch.
                    Du holst Dir zunächst das passende CT-Template und erzeugst damit einen LXC-Container:
                    Danach:
                    • Updates installieren
                    • User anlegen
                    • ioBroker installieren
                      lunatikk @Codierknecht last edited by lunatikk
                      @codierknecht said in Umzug von raspi Installation auf lxc proxmox container:
                      habe eigentlich erwartet, dass es mit den sog. "helper scripts" noch etwas einfacher geht.
                      Selbst nach dem fix mit dem neu angelegten user bekomme ich das gleiche Ergebnis nach der wiederherstellung vom backup. Iobroker ist nach kurzer Zeit (1-2m) nicht mehr aufrufbar und startet auch nicht mehr neu.
                      Codierknecht 2 Replies Last reply Reply Quote 0
                      • Codierknecht
                        Codierknecht Developer Most Active @lunatikk last edited by Codierknecht
                        Du siehst ja, wie "einfach" solche Scripte die Sache machen.
                        Am längsten dauert noch das herunterladen des passenden Image - wenn man das noch nicht hat.
                        Der Rest dauert lediglich ein paar Minuten. Versuch's einfach mal ... das übt 😉
                        • Codierknecht
                          Fang nochmal von vorne an ... mit der "offiziellen" Vorgehensweise.
                          Was einmal so richtig verstrubbelt ist, kriegt man auch mit Prügel nicht mehr sauber hin.
                            @codierknecht
                            Werde ich versuchen.
                            Bitte nicht falsch verstehen, aber dieser ganze Umgang mit Linux geht mir fürchterlich auf die Eier. Ich sitze alle 1-2 Jahre immer an System und versuche irgendwelche Probleme zu fixen. Man bekommt es stets hin - besonders auch aufgrund der guten Unterstützung in der Community - dennoch nervt es tierisch. Wenn man nicht regelmäßig damit arbeitet (und das tue ich eben nicht) dann vergisst man vieles und man muss immer wieder erneut in das Thema reinkommen - da geht richtig Zeit drauf. So, genug geheult.
                            Vielen Dank & Grüße
                            Thomas Braun Codierknecht amg_666 3 Replies Last reply Reply Quote 0
                              Dann meine Bitte: Lass die Finger davon. Bringt keinem was, wenn du mit dem System nicht arbeiten kannst und willst.
                              • Codierknecht
                                @lunatikk
                                Schreib Dir auf was Du brauchst.
                                Soooo viel ist das ja nicht.
                                  So einfach ist das halt nicht. Ich möchte eben iobroker nutzen und damit arbeiten (tue ich ja shcon seit Jahren), aber das drunterliegende System macht's einem eben nicht einfach.
                                  Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                    @lunatikk
                                    Linux ist total einfach. Nur nicht für jeden.
                                    Man kann nämlich bei Interesse alles nachlesen.
                                    'Linux' ist auch nicht komplexer als andere Systeme. Kann man sich alles aneignen. Musstest du bei anderen Systemen auch.
                                    • Codierknecht
                                      MS-DOS war auch nicht einfacher 😁
                                      Wie @Thomas-Braun schon schreibt: Das ist eigentlich total einfach.
                                      Eigentlich muss man sich nur einige wenige Befehle merken (aufschreiben).
                                      Der Vorteil eines unter Linux laufenden Servers gegenüber dem Klicki-Bunti-Kram: Kommandozeile bleibt Kommandozeile. Da ändert sich prinzipiell nix dran.
                                      Und ressourcensparender ist es auch noch. Läuft eben einfach besser und stabiler.
                                      • amg_666
                                        amg_666 @lunatikk last edited by
                                        Das "Problem" kenne ich. Solange alles läuft ist es ja gut, aber wenn mal etwas nicht läuft und man sich in Unix gar nicht auskennt, hat man ein Problem.
                                        Aber: Wie bereits geschrieben, sooo viele Unix Kommandos braucht man nicht und man kann viele Probeme einfach bei google eingeben und findet Forenbeiträge. Ich schreib mir die Lösungen dann immer auf und habe so ein Nachschlagewerk, falls mal wieder was nicht stimmt.
                                        backitup lxc-container umzug
                                        1152
