    4. Neuer Adapter: Daikin (Klimaanlagen)
      jf62 last edited by
        apollon77 last edited by
        kannst Du da in das "api.php" bei https://github.com/ael-code/daikin-cont … api.php#L7 mal logging von $aRequest einbauen ... die machen es faktisch nicht sonderlich anders als ich :-((
        ODER
        Bitte starte nmal den Adapter neu und schicke nochmal das Debug Log, ABER bitte vollständig (waren zuletzt Zeilen in der Länge abgeschnitten). ALso am besten aus dem ioBroker Logfile nehmen (/opt/iobroker/log/...)
        Und mach mal ein
        curl http://192.168.10.235/aircon/get_control_info
        Das bitte auch.
          jf62 last edited by
          CURL:
          ! curl http://192.168.10.235/aircon/get_control_info
          ! ret=OK,pow=1,mode=4,adv=,stemp=21.0,shum=0,dt1=25.0,dt2=M,dt3=25.0,dt4=21.0,dt5=21.0,dt7=25.0,dh1=AUTO,dh2=0,dh3=0,dh4=0,dh5=0,dh7=AUTO,dhh=50,b_mode=4,b_stemp=21.0,b_shum=0,alert=255,f_rate=A,f_dir=1,b_f_rate=A,b_f_dir=1,dfr1=5,dfr2=5,dfr3=5,dfr4=A,dfr5=A,dfr6=5,dfr7=5,dfrh=5,dfd1=0,dfd2=3,dfd3=0,dfd4=1,dfd5=1,dfd6=0,dfd7=0,dfdh=0p
          LOG nach Neustart
          ! daikin.0 2018-01-11 16:31:28.205 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.lastResult {"val":"OK","ack":true,"ts":1515684687924,"q":0,"from":"system.adapter.daikin.0","lc":1515681987471}
          ! daikin.0 2018-01-11 16:31:28.204 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.fanDirection {"val":1,"ack":true,"ts":1515684687886,"q":0,"from":"system.adapter.daikin.0","lc":1515683252770}
          ! daikin.0 2018-01-11 16:31:28.202 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.fanRate {"val":"A","ack":true,"ts":1515684687886,"q":0,"from":"system.adapter.daikin.0","lc":1515683011824}
          ! daikin.0 2018-01-11 16:31:28.202 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.targetHumidity {"val":0,"ack":true,"ts":1515684687885,"q":0,"from":"system.adapter.daikin.0","lc":1515589734331}
          ! daikin.0 2018-01-11 16:31:28.201 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.targetTemperature {"val":21,"ack":true,"ts":1515684687884,"q":0,"from":"system.adapter.daikin.0","lc":1515684036280}
          ! daikin.0 2018-01-11 16:31:28.200 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.mode {"val":4,"ack":true,"ts":1515684687883,"q":0,"from":"system.adapter.daikin.0","lc":1515683011819}
          ! daikin.0 2018-01-11 16:31:28.193 debug redis pmessage io.daikin.0.control.* io.daikin.0.control.power {"val":true,"ack":true,"ts":1515684687882,"q":0,"from":"system.adapter.daikin.0","lc":1515678414912}
          ! daikin.0 2018-01-11 16:31:27.764 info 78 Values updated
          ! daikin.0 2018-01-11 16:31:27.763 info Set State sensorInfo.cmpfreq: "0"
          ! daikin.0 2018-01-11 16:31:27.763 debug Old value sensorInfo.cmpfreq: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.762 debug Create State sensorInfo.cmpfreq
          ! daikin.0 2018-01-11 16:31:27.762 info Set State sensorInfo.error: "0"
          ! daikin.0 2018-01-11 16:31:27.761 debug Old value sensorInfo.error: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.761 debug Create State sensorInfo.error
          ! daikin.0 2018-01-11 16:31:27.760 info Set State sensorInfo.outdoorTemperature: "7.5"
          ! daikin.0 2018-01-11 16:31:27.760 debug Old value sensorInfo.outdoorTemperature: old="undefined", new="7.5"
          ! daikin.0 2018-01-11 16:31:27.759 debug Create State sensorInfo.outdoorTemperature
          ! daikin.0 2018-01-11 16:31:27.755 info Set State sensorInfo.indoorHumidity: "null"
          ! daikin.0 2018-01-11 16:31:27.754 debug Old value sensorInfo.indoorHumidity: old="undefined", new="null"
          ! daikin.0 2018-01-11 16:31:27.753 debug Create State sensorInfo.indoorHumidity
          ! daikin.0 2018-01-11 16:31:27.752 info Set State sensorInfo.indoorTemperature: "22"
          ! daikin.0 2018-01-11 16:31:27.751 debug Old value sensorInfo.indoorTemperature: old="undefined", new="22"
          ! daikin.0 2018-01-11 16:31:27.750 debug Create State sensorInfo.indoorTemperature
          ! daikin.0 2018-01-11 16:31:27.750 debug Create Channel sensorInfo
          ! daikin.0 2018-01-11 16:31:27.749 info Set State controlInfo.fanDirectionModeH: "0"
          ! daikin.0 2018-01-11 16:31:27.749 debug Old value controlInfo.fanDirectionModeH: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.748 debug Create State controlInfo.fanDirectionModeH
          ! daikin.0 2018-01-11 16:31:27.747 info Set State controlInfo.fanDirectionMode7: "0"
          ! daikin.0 2018-01-11 16:31:27.746 debug Old value controlInfo.fanDirectionMode7: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.745 debug Create State controlInfo.fanDirectionMode7
          ! daikin.0 2018-01-11 16:31:27.743 info Set State controlInfo.fanDirectionMode6: "0"
          ! daikin.0 2018-01-11 16:31:27.743 debug Old value controlInfo.fanDirectionMode6: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.742 debug Create State controlInfo.fanDirectionMode6
          ! daikin.0 2018-01-11 16:31:27.741 info Set State controlInfo.fanDirectionMode5: "1"
          ! daikin.0 2018-01-11 16:31:27.741 debug Old value controlInfo.fanDirectionMode5: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.740 debug Create State controlInfo.fanDirectionMode5
          ! daikin.0 2018-01-11 16:31:27.739 info Set State controlInfo.fanDirectionMode4: "1"
          ! daikin.0 2018-01-11 16:31:27.738 debug Old value controlInfo.fanDirectionMode4: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.738 debug Create State controlInfo.fanDirectionMode4
          ! daikin.0 2018-01-11 16:31:27.737 info Set State controlInfo.fanDirectionMode3: "0"
          ! daikin.0 2018-01-11 16:31:27.736 debug Old value controlInfo.fanDirectionMode3: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.736 debug Create State controlInfo.fanDirectionMode3
          ! daikin.0 2018-01-11 16:31:27.735 info Set State controlInfo.fanDirectionMode2: "3"
          ! daikin.0 2018-01-11 16:31:27.735 debug Old value controlInfo.fanDirectionMode2: old="undefined", new="3"
          ! daikin.0 2018-01-11 16:31:27.734 debug Create State controlInfo.fanDirectionMode2
          ! daikin.0 2018-01-11 16:31:27.733 info Set State controlInfo.fanDirectionMode1: "0"
          ! daikin.0 2018-01-11 16:31:27.733 debug Old value controlInfo.fanDirectionMode1: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.732 debug Create State controlInfo.fanDirectionMode1
          ! daikin.0 2018-01-11 16:31:27.731 info Set State controlInfo.fanRateModeH: "5"
          ! daikin.0 2018-01-11 16:31:27.731 debug Old value controlInfo.fanRateModeH: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.730 debug Create State controlInfo.fanRateModeH
          ! daikin.0 2018-01-11 16:31:27.728 info Set State controlInfo.fanRateMode7: "5"
          ! daikin.0 2018-01-11 16:31:27.728 debug Old value controlInfo.fanRateMode7: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.727 debug Create State controlInfo.fanRateMode7
          ! daikin.0 2018-01-11 16:31:27.725 info Set State controlInfo.fanRateMode6: "5"
          ! daikin.0 2018-01-11 16:31:27.724 debug Old value controlInfo.fanRateMode6: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.723 debug Create State controlInfo.fanRateMode6
          ! daikin.0 2018-01-11 16:31:27.722 info Set State controlInfo.fanRateMode5: "A"
          ! daikin.0 2018-01-11 16:31:27.721 debug Old value controlInfo.fanRateMode5: old="undefined", new="A"
          ! daikin.0 2018-01-11 16:31:27.721 debug Create State controlInfo.fanRateMode5
          ! daikin.0 2018-01-11 16:31:27.720 info Set State controlInfo.fanRateMode4: "A"
          ! daikin.0 2018-01-11 16:31:27.720 debug Old value controlInfo.fanRateMode4: old="undefined", new="A"
          ! daikin.0 2018-01-11 16:31:27.719 debug Create State controlInfo.fanRateMode4
          ! daikin.0 2018-01-11 16:31:27.718 info Set State controlInfo.fanRateMode3: "5"
          ! daikin.0 2018-01-11 16:31:27.718 debug Old value controlInfo.fanRateMode3: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.717 debug Create State controlInfo.fanRateMode3
          ! daikin.0 2018-01-11 16:31:27.717 info Set State controlInfo.fanRateMode2: "5"
          ! daikin.0 2018-01-11 16:31:27.716 debug Old value controlInfo.fanRateMode2: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.716 debug Create State controlInfo.fanRateMode2
          ! daikin.0 2018-01-11 16:31:27.715 info Set State controlInfo.fanRateMode1: "5"
          ! daikin.0 2018-01-11 16:31:27.714 debug Old value controlInfo.fanRateMode1: old="undefined", new="5"
          ! daikin.0 2018-01-11 16:31:27.713 debug Create State controlInfo.fanRateMode1
          ! daikin.0 2018-01-11 16:31:27.712 info Set State controlInfo.fanDirectionB: "1"
          ! daikin.0 2018-01-11 16:31:27.712 debug Old value controlInfo.fanDirectionB: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.711 debug Create State controlInfo.fanDirectionB
          ! daikin.0 2018-01-11 16:31:27.710 info Set State controlInfo.fanRateB: "A"
          ! daikin.0 2018-01-11 16:31:27.709 debug Old value controlInfo.fanRateB: old="undefined", new="A"
          ! daikin.0 2018-01-11 16:31:27.708 debug Create State controlInfo.fanRateB
          ! daikin.0 2018-01-11 16:31:27.707 info Set State controlInfo.error: "255"
          ! daikin.0 2018-01-11 16:31:27.706 debug Old value controlInfo.error: old="undefined", new="255"
          ! daikin.0 2018-01-11 16:31:27.706 debug Create State controlInfo.error
          ! daikin.0 2018-01-11 16:31:27.705 info Set State controlInfo.targetHumidityB: "0"
          ! daikin.0 2018-01-11 16:31:27.705 debug Old value controlInfo.targetHumidityB: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.704 debug Create State controlInfo.targetHumidityB
          ! daikin.0 2018-01-11 16:31:27.703 info Set State controlInfo.targetTemperatureB: "21"
          ! daikin.0 2018-01-11 16:31:27.703 debug Old value controlInfo.targetTemperatureB: old="undefined", new="21"
          ! daikin.0 2018-01-11 16:31:27.702 debug Create State controlInfo.targetTemperatureB
          ! daikin.0 2018-01-11 16:31:27.702 info Set State controlInfo.modeB: "4"
          ! daikin.0 2018-01-11 16:31:27.701 debug Old value controlInfo.modeB: old="undefined", new="4"
          ! daikin.0 2018-01-11 16:31:27.701 debug Create State controlInfo.modeB
          ! daikin.0 2018-01-11 16:31:27.700 info Set State controlInfo.targetHumidityModeH: "50"
          ! daikin.0 2018-01-11 16:31:27.700 debug Old value controlInfo.targetHumidityModeH: old="undefined", new="50"
          ! daikin.0 2018-01-11 16:31:27.699 debug Create State controlInfo.targetHumidityModeH
          ! daikin.0 2018-01-11 16:31:27.698 info Set State controlInfo.targetHumidityMode7: "null"
          ! daikin.0 2018-01-11 16:31:27.698 debug Old value controlInfo.targetHumidityMode7: old="undefined", new="null"
          ! daikin.0 2018-01-11 16:31:27.698 debug Field type mismatch for targetHumidityMode7: val=AUTO vs. number - set null
          ! daikin.0 2018-01-11 16:31:27.697 debug Create State controlInfo.targetHumidityMode7
          ! daikin.0 2018-01-11 16:31:27.695 info Set State controlInfo.targetHumidityMode5: "0"
          ! daikin.0 2018-01-11 16:31:27.695 debug Old value controlInfo.targetHumidityMode5: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.694 debug Create State controlInfo.targetHumidityMode5
          ! daikin.0 2018-01-11 16:31:27.693 info Set State controlInfo.targetHumidityMode4: "0"
          ! daikin.0 2018-01-11 16:31:27.693 debug Old value controlInfo.targetHumidityMode4: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.692 debug Create State controlInfo.targetHumidityMode4
          ! daikin.0 2018-01-11 16:31:27.691 info Set State controlInfo.targetHumidityMode3: "0"
          ! daikin.0 2018-01-11 16:31:27.690 debug Old value controlInfo.targetHumidityMode3: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.690 debug Create State controlInfo.targetHumidityMode3
          ! daikin.0 2018-01-11 16:31:27.689 info Set State controlInfo.targetHumidityMode2: "0"
          ! daikin.0 2018-01-11 16:31:27.688 debug Old value controlInfo.targetHumidityMode2: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.688 debug Create State controlInfo.targetHumidityMode2
          ! daikin.0 2018-01-11 16:31:27.687 info Set State controlInfo.targetHumidityMode1: "null"
          ! daikin.0 2018-01-11 16:31:27.687 debug Old value controlInfo.targetHumidityMode1: old="undefined", new="null"
          ! daikin.0 2018-01-11 16:31:27.686 debug Field type mismatch for targetHumidityMode1: val=AUTO vs. number - set null
          ! daikin.0 2018-01-11 16:31:27.686 debug Create State controlInfo.targetHumidityMode1
          ! daikin.0 2018-01-11 16:31:27.685 info Set State controlInfo.targetTemperatureMode7: "25"
          ! daikin.0 2018-01-11 16:31:27.685 debug Old value controlInfo.targetTemperatureMode7: old="undefined", new="25"
          ! daikin.0 2018-01-11 16:31:27.684 debug Create State controlInfo.targetTemperatureMode7
          ! daikin.0 2018-01-11 16:31:27.683 info Set State controlInfo.targetTemperatureMode5: "21"
          ! daikin.0 2018-01-11 16:31:27.683 debug Old value controlInfo.targetTemperatureMode5: old="undefined", new="21"
          ! daikin.0 2018-01-11 16:31:27.682 debug Create State controlInfo.targetTemperatureMode5
          ! daikin.0 2018-01-11 16:31:27.682 info Set State controlInfo.targetTemperatureMode4: "21"
          ! daikin.0 2018-01-11 16:31:27.681 debug Old value controlInfo.targetTemperatureMode4: old="undefined", new="21"
          ! daikin.0 2018-01-11 16:31:27.681 debug Create State controlInfo.targetTemperatureMode4
          ! daikin.0 2018-01-11 16:31:27.680 info Set State controlInfo.targetTemperatureMode3: "25"
          ! daikin.0 2018-01-11 16:31:27.679 debug Old value controlInfo.targetTemperatureMode3: old="undefined", new="25"
          ! daikin.0 2018-01-11 16:31:27.679 debug Create State controlInfo.targetTemperatureMode3
          ! daikin.0 2018-01-11 16:31:27.678 info Set State controlInfo.targetTemperatureMode2: "null"
          ! daikin.0 2018-01-11 16:31:27.678 debug Old value controlInfo.targetTemperatureMode2: old="undefined", new="null"
          ! daikin.0 2018-01-11 16:31:27.677 debug Field type mismatch for targetTemperatureMode2: val=M vs. number - set null
          ! daikin.0 2018-01-11 16:31:27.676 debug Create State controlInfo.targetTemperatureMode2
          ! daikin.0 2018-01-11 16:31:27.675 info Set State controlInfo.targetTemperatureMode1: "25"
          ! daikin.0 2018-01-11 16:31:27.673 debug Old value controlInfo.targetTemperatureMode1: old="undefined", new="25"
          ! daikin.0 2018-01-11 16:31:27.672 debug Create State controlInfo.targetTemperatureMode1
          ! daikin.0 2018-01-11 16:31:27.670 info Set State controlInfo.adv: ""
          ! daikin.0 2018-01-11 16:31:27.665 debug Old value controlInfo.adv: old="undefined", new/>! daikin.0 2018-01-11 16:31:27.661 debug Create State controlInfo.adv
          ! daikin.0 2018-01-11 16:31:27.657 debug Create Channel controlInfo
          ! daikin.0 2018-01-11 16:31:27.644 info Set State control.fanDirection: "1"
          ! daikin.0 2018-01-11 16:31:27.644 debug Old value control.fanDirection: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.643 debug Create State control.fanDirection
          ! daikin.0 2018-01-11 16:31:27.643 info Set State control.fanRate: "A"
          ! daikin.0 2018-01-11 16:31:27.642 debug Old value control.fanRate: old="undefined", new="A"
          ! daikin.0 2018-01-11 16:31:27.642 debug Create State control.fanRate
          ! daikin.0 2018-01-11 16:31:27.641 info Set State control.targetHumidity: "0"
          ! daikin.0 2018-01-11 16:31:27.641 debug Old value control.targetHumidity: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.640 debug Create State control.targetHumidity
          ! daikin.0 2018-01-11 16:31:27.639 info Set State control.targetTemperature: "21"
          ! daikin.0 2018-01-11 16:31:27.639 debug Old value control.targetTemperature: old="undefined", new="21"
          ! daikin.0 2018-01-11 16:31:27.638 debug Create State control.targetTemperature
          ! daikin.0 2018-01-11 16:31:27.636 info Set State control.mode: "4"
          ! daikin.0 2018-01-11 16:31:27.636 debug Old value control.mode: old="undefined", new="4"
          ! daikin.0 2018-01-11 16:31:27.635 debug Create State control.mode
          ! daikin.0 2018-01-11 16:31:27.635 info Set State control.power: "true"
          ! daikin.0 2018-01-11 16:31:27.634 debug Old value control.power: old="undefined", new="true"
          ! daikin.0 2018-01-11 16:31:27.634 debug Create State control.power
          ! daikin.0 2018-01-11 16:31:27.633 debug Create Channel control
          ! daikin.0 2018-01-11 16:31:27.632 info Set State modelInfo.enScdltmr: "1"
          ! daikin.0 2018-01-11 16:31:27.632 debug Old value modelInfo.enScdltmr: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.631 debug Create State modelInfo.enScdltmr
          ! daikin.0 2018-01-11 16:31:27.630 info Set State modelInfo.sFanDirection: "1"
          ! daikin.0 2018-01-11 16:31:27.630 debug Old value modelInfo.sFanDirection: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.629 debug Create State modelInfo.sFanDirection
          ! daikin.0 2018-01-11 16:31:27.628 info Set State modelInfo.mid: "NA"
          ! daikin.0 2018-01-11 16:31:27.628 debug Old value modelInfo.mid: old="undefined", new="NA"
          ! daikin.0 2018-01-11 16:31:27.627 debug Create State modelInfo.mid
          ! daikin.0 2018-01-11 16:31:27.627 info Set State modelInfo.cpv: "0"
          ! daikin.0 2018-01-11 16:31:27.626 debug Old value modelInfo.cpv: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.626 debug Create State modelInfo.cpv
          ! daikin.0 2018-01-11 16:31:27.625 info Set State modelInfo.pv: "0"
          ! daikin.0 2018-01-11 16:31:27.625 debug Old value modelInfo.pv: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.624 debug Create State modelInfo.pv
          ! daikin.0 2018-01-11 16:31:27.623 info Set State modelInfo.type: "N"
          ! daikin.0 2018-01-11 16:31:27.623 debug Old value modelInfo.type: old="undefined", new="N"
          ! daikin.0 2018-01-11 16:31:27.622 debug Create State modelInfo.type
          ! daikin.0 2018-01-11 16:31:27.622 info Set State modelInfo.model: "NOTSUPPORT"
          ! daikin.0 2018-01-11 16:31:27.621 debug Old value modelInfo.model: old="undefined", new="NOTSUPPORT"
          ! daikin.0 2018-01-11 16:31:27.621 debug Create State modelInfo.model
          ! daikin.0 2018-01-11 16:31:27.620 debug Create Channel modelInfo
          ! daikin.0 2018-01-11 16:31:27.619 info Set State deviceInfo.enGroup: "0"
          ! daikin.0 2018-01-11 16:31:27.619 debug Old value deviceInfo.enGroup: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.618 debug Create State deviceInfo.enGroup
          ! daikin.0 2018-01-11 16:31:27.617 info Set State deviceInfo.groupName: ""
          ! daikin.0 2018-01-11 16:31:27.617 debug Old value deviceInfo.groupName: old="undefined", new/>! daikin.0 2018-01-11 16:31:27.617 debug Create State deviceInfo.groupName
          ! daikin.0 2018-01-11 16:31:27.616 info Set State deviceInfo.enHol: "0"
          ! daikin.0 2018-01-11 16:31:27.616 debug Old value deviceInfo.enHol: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.615 debug Create State deviceInfo.enHol
          ! daikin.0 2018-01-11 16:31:27.614 info Set State deviceInfo.adapterMode: "run"
          ! daikin.0 2018-01-11 16:31:27.614 debug Old value deviceInfo.adapterMode: old="undefined", new="run"
          ! daikin.0 2018-01-11 16:31:27.613 debug Create State deviceInfo.adapterMode
          ! daikin.0 2018-01-11 16:31:27.613 info Set State deviceInfo.macAddress: "409F38264647"
          ! daikin.0 2018-01-11 16:31:27.612 debug Old value deviceInfo.macAddress: old="undefined", new="409F38264647"
          ! daikin.0 2018-01-11 16:31:27.612 debug Create State deviceInfo.macAddress
          ! daikin.0 2018-01-11 16:31:27.605 info Set State deviceInfo.enSetzone: "1"
          ! daikin.0 2018-01-11 16:31:27.604 debug Old value deviceInfo.enSetzone: old="undefined", new="1"
          ! daikin.0 2018-01-11 16:31:27.603 debug Create State deviceInfo.enSetzone
          ! daikin.0 2018-01-11 16:31:27.602 info Set State deviceInfo.led: "true"
          ! daikin.0 2018-01-11 16:31:27.602 debug Old value deviceInfo.led: old="undefined", new="true"
          ! daikin.0 2018-01-11 16:31:27.601 debug Create State deviceInfo.led
          ! daikin.0 2018-01-11 16:31:27.600 info Set State deviceInfo.cpvMinor: "0"
          ! daikin.0 2018-01-11 16:31:27.582 debug Old value deviceInfo.cpvMinor: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.580 debug Create State deviceInfo.cpvMinor
          ! daikin.0 2018-01-11 16:31:27.579 info Set State deviceInfo.cpv: "0"
          ! daikin.0 2018-01-11 16:31:27.579 debug Old value deviceInfo.cpv: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.578 debug Create State deviceInfo.cpv
          ! daikin.0 2018-01-11 16:31:27.577 info Set State deviceInfo.pv: "0"
          ! daikin.0 2018-01-11 16:31:27.575 debug Old value deviceInfo.pv: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.575 debug Create State deviceInfo.pv
          ! daikin.0 2018-01-11 16:31:27.574 info Set State deviceInfo.adapterKind: "3"
          ! daikin.0 2018-01-11 16:31:27.573 debug Old value deviceInfo.adapterKind: old="undefined", new="3"
          ! daikin.0 2018-01-11 16:31:27.570 debug Create State deviceInfo.adapterKind
          ! daikin.0 2018-01-11 16:31:27.569 info Set State deviceInfo.lpwFlag: "0"
          ! daikin.0 2018-01-11 16:31:27.567 debug Old value deviceInfo.lpwFlag: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.566 debug Create State deviceInfo.lpwFlag
          ! daikin.0 2018-01-11 16:31:27.566 info Set State deviceInfo.password: ""
          ! daikin.0 2018-01-11 16:31:27.565 debug Old value deviceInfo.password: old="undefined", new/>! daikin.0 2018-01-11 16:31:27.564 debug Create State deviceInfo.password
          ! daikin.0 2018-01-11 16:31:27.564 info Set State deviceInfo.id: ""
          ! daikin.0 2018-01-11 16:31:27.563 debug Old value deviceInfo.id: old="undefined", new/>! daikin.0 2018-01-11 16:31:27.563 debug Create State deviceInfo.id
          ! daikin.0 2018-01-11 16:31:27.561 info Set State deviceInfo.port: "30050"
          ! daikin.0 2018-01-11 16:31:27.559 debug Old value deviceInfo.port: old="undefined", new="30050"
          ! daikin.0 2018-01-11 16:31:27.559 debug Create State deviceInfo.port
          ! daikin.0 2018-01-11 16:31:27.558 info Set State deviceInfo.method: "home only"
          ! daikin.0 2018-01-11 16:31:27.557 debug Old value deviceInfo.method: old="undefined", new="home only"
          ! daikin.0 2018-01-11 16:31:27.557 debug Create State deviceInfo.method
          ! daikin.0 2018-01-11 16:31:27.556 info Set State deviceInfo.icon: "9"
          ! daikin.0 2018-01-11 16:31:27.555 debug Old value deviceInfo.icon: old="undefined", new="9"
          ! daikin.0 2018-01-11 16:31:27.555 debug Create State deviceInfo.icon
          ! daikin.0 2018-01-11 16:31:27.554 info Set State deviceInfo.name: "Büro"
          ! daikin.0 2018-01-11 16:31:27.553 debug Old value deviceInfo.name: old="undefined", new="Büro"
          ! daikin.0 2018-01-11 16:31:27.552 debug Create State deviceInfo.name
          ! daikin.0 2018-01-11 16:31:27.551 info Set State deviceInfo.location: "0"
          ! daikin.0 2018-01-11 16:31:27.551 debug Old value deviceInfo.location: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.550 debug Create State deviceInfo.location
          ! daikin.0 2018-01-11 16:31:27.549 info Set State deviceInfo.error: "0"
          ! daikin.0 2018-01-11 16:31:27.548 debug Old value deviceInfo.error: old="undefined", new="0"
          ! daikin.0 2018-01-11 16:31:27.547 debug Create State deviceInfo.error
          ! daikin.0 2018-01-11 16:31:27.546 info Set State deviceInfo.adapterVersion: "1_2_48"
          ! daikin.0 2018-01-11 16:31:27.540 debug Old value deviceInfo.adapterVersion: old="undefined", new="1_2_48"
          ! daikin.0 2018-01-11 16:31:27.539 debug Create State deviceInfo.adapterVersion
          ! daikin.0 2018-01-11 16:31:27.538 info Set State deviceInfo.dst: "true"
          ! daikin.0 2018-01-11 16:31:27.538 debug Old value deviceInfo.dst: old="undefined", new="true"
          ! daikin.0 2018-01-11 16:31:27.537 debug Create State deviceInfo.dst
          ! daikin.0 2018-01-11 16:31:27.536 info Set State deviceInfo.region: "eu"
          ! daikin.0 2018-01-11 16:31:27.536 debug Old value deviceInfo.region: old="undefined", new="eu"
          ! daikin.0 2018-01-11 16:31:27.535 debug Create State deviceInfo.region
          ! daikin.0 2018-01-11 16:31:27.533 info Set State deviceInfo.type: "aircon"
          ! daikin.0 2018-01-11 16:31:27.533 debug Old value deviceInfo.type: old="undefined", new="aircon"
          ! daikin.0 2018-01-11 16:31:27.531 debug Create State deviceInfo.type
          ! daikin.0 2018-01-11 16:31:27.528 debug Create Channel deviceInfo
          ! daikin.0 2018-01-11 16:31:27.525 debug start update timeout
          ! daikin.0 2018-01-11 16:31:27.523 debug {"indoorTemperature":22,"indoorHumidity":null,"outdoorTemperature":7.5,"error":0,"cmpfreq":0}
          ! daikin.0 2018-01-11 16:31:27.398 debug Call GET http://192.168.10.235/aircon/get_sensor_info
          ! daikin.0 2018-01-11 16:31:27.396 debug {"power":true,"mode":4,"adv":"","targetTemperature":21,"targetHumidity":0,"targetTemperatureMode1":25,"targetTemperatureMode2":"M","targetTemperatureMode3":25,"targetTemperatureMode4":21,"targetTempe
          ! daikin.0 2018-01-11 16:31:27.284 debug Call GET http://192.168.10.235/aircon/get_control_info
          ! daikin.0 2018-01-11 16:31:27.282 info Set polling Intervall to 60s
          ! daikin.0 2018-01-11 16:31:27.282 info Daikin Device initialized successfully
          ! daikin.0 2018-01-11 16:31:27.280 debug {"model":"NOTSUPPORT","type":"N","pv":0,"cpv":0,"mid":"NA","sFanDirection":1,"enScdltmr":1}
          ! daikin.0 2018-01-11 16:31:27.165 debug Call GET http://192.168.10.235/aircon/get_model_info
          ! daikin.0 2018-01-11 16:31:27.163 debug {"type":"aircon","region":"eu","dst":true,"adapterVersion":"1_2_48","power":true,"error":0,"location":0,"name":"Büro","icon":9,"method":"home only","port":30050,"id":"","password":"","lpwFlag":0,"ada
          ! daikin.0 2018-01-11 16:31:26.982 debug Call GET http://192.168.10.235/common/basic_info
          ! daikin.0 2018-01-11 16:31:26.775 info starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.daikin, node: v6.12.3
          ! daikin.0 2018-01-11 16:31:26.720 info States connected to redis: 127.0.0.1:6379
          ! daikin.0 2018-01-11 16:31:26.709 debug statesDB connected
          ! daikin.0 2018-01-11 16:31:26.656 debug objectDB connected
          ! daikin.0 2018-01-11 16:31:22.556 info terminating
          ! daikin.0 2018-01-11 16:31:22.548 debug clear update timeout
          ! daikin.0 2018-01-11 16:31:22.547 debug Stopping update timeout
            Ok, jetzt weiss ich nimmer weter. Jetzt bräuchte ich doch
            > kannst Du da in das "api.php" bei [https://github.com/ael-code/daikin-cont](https://github.com/ael-code/daikin-cont) … api.php#L7 mal logging von $aRequest einbauen ... die machen es faktisch nicht sonderlich anders als ich :-((
            So wie ich den code verstehe müssten die EXAKT den gleichen Request schicken wie ich …
              jf62 last edited by
              Gibt noch ne ganz neue Branch in Github:
              https://github.com/bendews/smartthings- … tem.groovy
                jf62 last edited by
                @apollon77:
                So wie ich den code verstehe müssten die EXAKT den gleichen Request schicken wie ich … `
                Wie soll Zeile 7 dann aussehen, damit ich dir da was schicken kann? - Bin nicht so der php Guru 😉
                  Und die lassen maximal shum weg, sollte also
                  curl http://192.168.10.235/aircon/set_control_info -d "pow=1&mode=4&stemp=26.0&f_rate=A&f_dir=1"
                  geben
                    @jf62:
                    Wie soll Zeile 7 dann aussehen, damit ich dir da was schicken kann? - Bin nicht so der php Guru 😉 `
                    Ohne es getestet zu haben vor oder hinter Zeile 7 das hier einfügen. Zeile 7 muss bleiben wie sie ist!!:
                    file_put_contents('/absolter/pfad/zum/log.txt', $aRequest, FILE_APPEND);
                      @apollon77:
                      geben `
                      Korrigiere mich selbst. NEIN, die hängfen selbst "shum=0" fest wieder hinten dran … also sind wir beim gleichen Request wie der Adapter schickt.
                      Aber nochmal: Wirklich kein Firmware Update da in der Daikin Handy App?? 🙂
                        jf62 last edited by
                        @apollon77:
                        geben `
                        Nop kommt NG zurück
                          SIehe meine Selbst-Korrektur oben … die hängen shum=0 hart noch hintend ran 🙂
                            ALso doch Logging : http://forum.iobroker.net/viewtopic.php … 18#p113114
                              Oooook eine allerletzte Idee habe ich noch was effektiv anders läuft.
                              Mach mal:
                              curl "http://192.168.10.235/aircon/set_control_info?pow=1&mode=4&stemp=26.0&shum=0&f_rate=A&f_dir=1"
                              Geht das?
                                jf62 last edited by
                                JAAAAA
                                  jf62 last edited by
                                  in dem Logging steht nicht auch wirklich viel drin…
                                  Eine Änderung der Temperatur auf 22 Grad ergibt: 14220A1
                                    Ja logging kann jetzt wieder raus …. Grund ist ja gefunden.
                                    FW-Update verfügbar? 🙂 Das wäre die einfachste Lösung!!
                                      jf62 last edited by
                                      Da gibt es keines… Die App bietet zumindest nichts an
                                        😞 naja ich schau mal wie ich Zeit finde.
                                        • wendy2702
                                          wendy2702 last edited by
                                          Off Topic:
                                          Darf ich mal fragen welche Klimaanlagen ihr habt?
                                          Überlege für nächsten Sommer auch die Anschaffung und wenn die dann direkt mit iobroker funktionieren 😄
                                            jf62 last edited by
                                            @apollon77:
                                            😞 naja ich schau mal wie ich Zeit finde. `
                                            Trotzdem schon jetzt mal ein dickes Dankeschön für die Hilfe. Ist ja nicht selbstverständlich.
                                            31.7k
                                            79.8k
                                            78
                                            22520
