    4. iobroker nach Einspielen Backup nicht mehr erreichbar
      Homoran Global Moderator Administrators @Tombir last edited by Homoran
      @tombir
      mach bitte was da im Post steht
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
      chmod 744 iob_diag.sh
      ./iob_diag.sh
        Tombir @Homoran last edited by
        @homoran said in iobroker nach Einspielen Backup nicht mehr erreichbar:
        ./iob_diag.sh
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-26 Raspbian
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
                  Kernel: Linux 6.6.51+rpt-rpi-v8
            Architecture: arm64
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         13:02:20 up  1:13,  1 user,  load average: 0.68, 0.75, 0.65
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2024-11-06 13:02:21 CET
                   Universal time: Wed 2024-11-06 12:02:21 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.0G        1.1G        2.3G        1.2M        706M        2.9G
        Swap:           209M          0B        209M
        Total:          4.2G        1.1G        2.5G
        Active iob-Instances:   21
                 3791 M total memory
                 1007 M used memory
                  971 M active memory
                  437 M inactive memory
                 2187 M free memory
                   80 M buffer memory
                  593 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 13:02:21 up  1:13,  1 user,  load average: 0.68, 0.75, 0.65
        Tasks: 183 total,   2 running, 181 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3792.0 total,   2186.9 free,   1007.6 used,    674.4 buff/cache
        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2784.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/mmcblk0p2 ext4       29G  5.8G   22G  22% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/mmcblk0p1 vfat      510M   97M  414M  19% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Wed Nov  6 11:48:29 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:EA:20:D4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1f7ac24d-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Nov  6 11:48:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem da446b36-5471-4511-8f90-c08e4ba7eb83 ro with ordered data mode. Quota mode: none.
        [Wed Nov  6 11:48:33 2024] EXT4-fs (mmcblk0p2): re-mounted da446b36-5471-4511-8f90-c08e4ba7eb83 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        541M    /var/
        160M    /var/cache
        155M    /var/cache/apt
        108M    /var/lib
        79M     /var/cache/apt/archives
        Archived and active journals take up 72.0M in the file system.
        /opt/iobroker/backups:
        102M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        939M    /opt/iobroker/iobroker-data/
        886M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
        18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2+rpi1 500
                500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 6.0.11, hostname: raspberrypi   , alive, uptime: 1413)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.ds18b20.0                : ds18b20               : raspberrypi                              -  enabled
          system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : raspberrypi                              -  enabled
        + system.adapter.fronius-wattpilot.1      : fronius-wattpilot     : raspberrypi                              -  enabled
        + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 192.168.178.22
        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
          system.adapter.ocpp.0                   : ocpp                  : raspberrypi                              - disabled, port: 9220
          system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
        + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "parser"       : 2.2.4    , installed 2.2.4
        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        2292
        States:         1749
        W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6358       671/sshd: /usr/sbin
        tcp        0      0 192.168.178.22:1884     0.0.0.0:*               LISTEN      1001       25682      3514/io.mqtt.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       24487      3380/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24482      3380/iobroker.js-co
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27751      3583/io.sonoff.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6360       671/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23436      3398/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28003      3782/io.web.0
        udp        0      0 0.0.0.0:45008           0.0.0.0:*                           104        6050       481/avahi-daemon: r
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       27821      3620/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       27822      3620/io.tuya.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6048       481/avahi-daemon: r
        udp6       0      0 fe80::a43:7c3b:eb47:546 :::*                                0          4901       616/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        6049       481/avahi-daemon: r
        udp6       0      0 :::34047                :::*                                104        6051       481/avahi-daemon: r
        2024-11-06 13:02:51.685  - info: influxdb.0 (3450) Connecting http://localhost:8086/ ...
        2024-11-06 13:02:51.685  - info: influxdb.0 (3450) Influx DB Version used: 1.x
        2024-11-06 13:02:51.690  - error: influxdb.0 (3450) AggregateError
        2024-11-06 13:02:58.590  - warn: ds18b20.0 (3656) Error reading sensor 28-0000058675a4: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0000058675a4/w1_slave'
        2024-11-06 13:02:58.622  - warn: ds18b20.0 (3656) Error reading sensor 28-000005869946: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005869946/w1_slave'
        2024-11-06 13:02:58.670  - warn: ds18b20.0 (3656) Error reading sensor 28-000005866a64: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005866a64/w1_slave'
        2024-11-06 13:02:58.706  - warn: ds18b20.0 (3656) Error reading sensor 28-000005867310: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005867310/w1_slave'
        2024-11-06 13:03:00.005  - info: javascript.0 (3469) script.js.Heizstab_für_Warmwasser: WW-Merker0
        2024-11-06 13:03:00.006  - info: javascript.0 (3469) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2
        2024-11-06 13:03:00.006  - info: javascript.0 (3469) script.js.Heizstab_für_Warmwasser: Heizstab aus
        2024-11-06 13:03:00.006  - info: javascript.0 (3469) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 2740.6
        2024-11-06 13:03:00.010  - info: javascript.0 (3469) script.js.Nulleinspeisung_Garage2: Netzleistung 2741
        2024-11-06 13:03:00.010  - info: javascript.0 (3469) script.js.Nulleinspeisung_Garage2: PV-Garage 62
        2024-11-06 13:03:00.010  - info: javascript.0 (3469) script.js.Nulleinspeisung_Garage2: Batterie-Leistung -1
        2024-11-06 13:03:00.010  - info: javascript.0 (3469) script.js.Nulleinspeisung_Garage2: Batterie-Kapazität 10
        2024-11-06 13:03:01.690  - info: influxdb.0 (3450) Connecting http://localhost:8086/ ...
        2024-11-06 13:03:01.690  - info: influxdb.0 (3450) Influx DB Version used: 1.x
        2024-11-06 13:03:01.694  - error: influxdb.0 (3450) AggregateError
        2024-11-06 13:03:08.591  - warn: ds18b20.0 (3656) Error reading sensor 28-0000058675a4: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0000058675a4/w1_slave'
        2024-11-06 13:03:08.623  - warn: ds18b20.0 (3656) Error reading sensor 28-000005869946: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005869946/w1_slave'
        2024-11-06 13:03:08.671  - warn: ds18b20.0 (3656) Error reading sensor 28-000005866a64: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005866a64/w1_slave'
        2024-11-06 13:03:08.706  - warn: ds18b20.0 (3656) Error reading sensor 28-000005867310: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-000005867310/w1_slave'
        2024-11-06 13:03:11.695  - info: influxdb.0 (3450) Connecting http://localhost:8086/ ...
        2024-11-06 13:03:11.695  - info: influxdb.0 (3450) Influx DB Version used: 1.x
        2024-11-06 13:03:11.701  - error: influxdb.0 (3450) AggregateError
          Tombir @Tombir last edited by
          und hier das Summary
                 Icon name: computer
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               32 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          Recommended versions are nodejs 20.18.0 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            4.0G        1.1G        2.3G        1.2M        717M        2.9G
          Swap:           209M          0B        209M
          ioBroker Core:          js-controller           6.0.11
                                  admin                   7.1.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                2292
          States:                 1749
          Size of iob-Database:
          7.6M    /opt/iobroker/iobroker-data/objects.jsonl
          5.4M    /opt/iobroker/iobroker-data/states.jsonl
            @tombir und dein iobroker läuft nicht?
            kann dazu keine Probleme sehen?
              Thomas Braun Most Active @Tombir last edited by
              @tombir sagte in iobroker nach Einspielen Backup nicht mehr erreichbar:
              Kernel: aarch64
              Userland: 32 bit
              Das kann schon mal nicht sauber als reine 64Bit-Version aufgesetzt worden sein. Denn dann wäre das 'userland' ebenfalls 64-bittig.
              nodejs ist auch in der 32-Bit-Version installiert.
              Mach es neu.
              Und leg dir dann einen individuellen user an. Weder 'pi' noch 'iobroker'. Nimm halt 'tombir' oder deinen Vornamen.
              Und auch
              sollte eigentlich in einer frischen Installation nicht erscheinen.
                Doch, jetzt läuft alles.
                Danke für deine Hilfe!
                @thomas-braun said in iobroker nach Einspielen Backup nicht mehr erreichbar:
                Ich habe alles frisch als reine 64-Bit-Version aufgesetzt.
                nodejs wurde, wenn ich es richtig gesehen habe, im Zuge von iobroker mit installiert. Warum nodejs in 32-Bit installiert wurde, ist mir ein Rätsel.
                  Tombir @Thomas Braun last edited by
                  Mach es neu.
                  Und auch
                  Ich werde deinen Rat befolgen und alles noch einmal neu installieren und einen neuen user anlegen.
                  Da ich jetzt erst mal weg muss, evtl heute Abend oder morgen.
                    Mach es neu.
                    Und auch
                    Ich habe deinen Vorschlag umgesetzt und Bookworm komplett neu aufgesetzt (nach deiner Anleitung zur Installation von iobroker).
                    Leider bin ich nicht weit gekommen, den sudo apt update bringt bereits die ersten Fehler
                    tompi@raspberrypi:~ $ sudo apt update
                    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Reading package lists... Error!
                    E: Unable to parse package file /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages (1)
                    E: Unable to parse package file /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_i18n_Translation-en (1)
                    W: You may want to run apt-get update to correct these problems
                    E: The package cache file is corrupted
                    Auch sudo apt-get update brachte keine Änderung, sondern die gleichen Fehlermeldungen.
                    Ich kann leider nicht erkennen, wo der Fehler liegen könnte.
                      sudo rm /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_*
                      sudo apt update
                        Danke!
                        Ist sauber durch gelaufen.
                        Als nächstes installiere ich iobroker.
                        632
