    4. [Problem] Dream btw. Enigma2 Adapter
    • Matten Matten
      Matten Matten last edited by
      Hab den enigma2 adapter noch mal aktualisiert:
      https://github.com/Matten-Matten/iobroker.enigma2
      ioBroker enigma2 Adapter
      Adapter für ioBroker um Informationen von einem enigma2 Receiver abzufragen.
      Funktionen
      • BOX_IP
      • CHANNEL_SERVICEREFERENCE
      • CHANNEL
      • EVENTDESCRIPTION
      • EVENTDURATION
      • EVENTREMAINING
      • HDD_CAPACITY
      • HDD_FREE
      • MESSAGE_ANSWER
      • MODEL
      • MUTED
      • PROGRAMM
      • PROGRAMM_INFO
      • STANDBY
      • VOLUME
      Version
      0.0.8 (2017-11-25)
      • (Matten-Matten) Fehlerbehebung in HDD Abfrage
      • (Matten-Matten) Fehlerbehebung wenn Box Heruntergefahren (nicht erreichbar)
      jetzt nur noch mit: info received error: connect ECONNREFUSED 192.168. …
      • (Matten-Matten) Konfigurations-Maske vereinfacht
      issues
      • kein Senden von Befehlen aus dem Adapter heraus.
        mrMuppet last edited by
         $ ./iobroker url "https://github.com/Matten-Matten/iobroker.enigma2"
        install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master
        npm install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master --production --prefix "/opt/iobroker" (System call)
        npm
         WARN excluding symbolic link node_modules/request/node_modules/.bin/har-validator -> ../har-validator/bin/har-validatornpm WARN excluding symbolic link node_modules/request/node_modules/.bin/uuid -> ../node-uuid/bin/uuid
        npm ERR! path /tmp/npm-1919-6804481b/unpack-0714f7a9/package.json
        npm ERR! code ENOENTnpm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-1919-6804481b/unpack-0714f7a9/package.json'npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2017-11-25T17_08_31_281Z-debug.log
        ERROR: host.iobroker Cannot install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master: 254
        ERROR: process exited with code 25
        Leider war ich nicht erfolgreich.
        • Matten Matten
          @Matten Matten:
          issues
          • keine Installation von Github möglich. (ZIP downloaden entpacken, den Ordner in "iobroker.enigma2" umbenennen und in "ioBroker\node_modules" einfügen) `
          Hatte ich auch geschrieben.
          Bitte ZIP downloaden entpacken, den Ordner in "iobroker.enigma2" umbenennen und in "ioBroker\node_modules" einfügen
          • Matten Matten
            @Matten Matten:
            @Matten Matten:
            issues
            Bitte ZIP downloaden entpacken, den Ordner in "iobroker.enigma2" umbenennen und in "ioBroker\node_modules" einfügen `
            falls einer nicht weiß wie folgendes
            Bei meinem RPI hab ich Samba-Server installiert
            sudo apt-get update
            sudo apt-get install samba samba-common smbclient
            1. Samba Passwort
            sudo smbpasswd -a pi
            PW eingeben
            wiederholen
            2. in der Konf. den eintrag machen und damit der
            Ordner übers Netzwerk sichtbar wird
            sudo nano /etc/samba/smb.conf
            dort folgendes einfügen:
            [ioBroker]
               comment = ioBroker
               path = /opt
               writeable = yes
               guest ok = no
               read only = no
            Strg+O speichern
            ENTER
            Strg+X verlassen
            3. ORDNER Freigabe
            sudo chown root:root /opt/iobroker
            sudo chmod 777 /opt/iobroker
            sudo chown root:root /opt/iobroker/node_modules
            sudo chmod 777 /opt/iobroker/node_modules
            4.SAMBA NEUSTART
            sudo service smbd restart
            sudo service nmbd restart
            dann ist der iobroker Ordner im Netzwerk erreichbar und beschreibbar.
            • kmxak
              woran scheitert es denn das es nicht über git hub geht?
              • Matten Matten
                @kmxak:
                woran scheitert es denn das es nicht über git hub geht? `
                Hallo Alex,
                Ich bin leider nicht der große Programmierer solcher Adapter und hab deshalb auch nicht mal einen Ansatz wo und wie man das Problem beheben kann. Sorry
                Gruß Matze
                • dslraser
                  Nabend,
                  ich habe den Adapter mal installiert und habe in den Objekten bei Volume die gleichen Felder eingefügt wie im VUPlus Adapter (0.1.0)https://github.com/vader722/ioBroker.vuplus. Da kann ich mit Alexa die Lautstärke einstellen usw. Das funktioniert mit dem enigma2 Adapter leider nicht. Ich kann kurz sehen wie die angesagte Lautsärke sich ändert in den Objekten, diese wird dann aber sofort wieder auf den Ausgangswert zurück gestellt und auch nicht an die VU weiter gegeben ?
                  Was/wie kann ich das ändern ? Nur die ist Werte angezeigt zu bekommen ist nicht so nützlich :roll:
                  PS: müssten nicht hier schon andere Werte drinn stehen womit die Objekte wie beim VUplus Adapter angelegt werden ? (Screenshoot von der Datei enigma2.js in der Mitte)
                  PPS: und im ersten Screenshot ist die Geschichte auskommentiert, funktioniert das nicht ?
                  LG Heiko
                    mikiline last edited by
                    Token Einstellungen der Dreambox (Enigma2) mal prüfen! Einstellungen–->Netzwerk--->WebInterface
                    Hijack sollte auch auf "aus" sein!
                    message sollte auch per Browser abgesetzt werden können mit einer "true" Meldung.....
                    und dann schauen ob das hier eine Ausgabe gibt, dann geht es auch mit der Message
                    http://ip.der.dreambox/web/about
                    oder eben
                    http://dreambox/web/message?text=test&type=1&timeout=10
                      knopers1 last edited by
                      habe gerade eben zum Test den Vu+Adapter installiert.
                      Unter Objekte bekomme ich einige zu sehen wie Sender,Volum,Muted, Hdd Kapazität…
                      Es scheint zu laufen und die States werden aktualisiert.
                      Leider spuckt es im Log alle paar se. das hier:
                      vuplus.0	2018-01-10 20:57:56.392	error	No e2state found
                      vuplus.0	2018-01-10 20:57:51.356	error	No e2state found
                      vuplus.0	2018-01-10 20:57:46.407	error	No e2state found
                      vuplus.0	2018-01-10 20:57:41.311	error	No e2state found
                      jemand eine Ahnung was dort nicht stimmt?
                        FoxMulder last edited by
                        Zitat aus diesen Github https://github.com/vader722/ioBroker.vuplus/issues/7 um den fehler zu beseitigen :
                        Das hatte ich auch. Jemand hat eine Abfrage GETDOWNMIX eingebaut, was anscheinend nur bei einigen Boxen funktioniert. Du kannst testweise mal folgende Zeile in der Datei vuplus.js auskommentieren (zwei // davor schreiben):
                        Also aus:
                        getResponse('GETDOWNMIX', deviceId, PATH_DOWNMIX, evaluateCommandResponse);
                        wird
                        // getResponse('GETDOWNMIX', deviceId, PATH_DOWNMIX, evaluateCommandResponse);
                        und dann den Adapter neu starten. Schau mal ob es "ruhiger" wird ;)
                        Bei mir hat es funktioniert und bekomme keinen fehler mehr angezeigt .
                        Gesendet von meinem SM-G950F mit Tapatalk
                        GermanBluefox created this issue in vader722/ioBroker.vuplus
                        open Publish on npm #7
                        • dslraser
                          @knopers1:
                          jemand eine Ahnung was dort nicht stimmt? `
                          Hatte ich beim VU+Adapter auch mal.(jetzt läuft er schon sehr lange ohne irgendwelche Fehler)
                          Ich hatte in der Datei vuplus.js was verändert, aber ich kriege nicht mehr zusammen was das war ?
                          (Ich hänge die hier mal mit drann, ich hoffe es war die richtige die ich aufgehoben habe, ansonsten kann ich die auch nochmal von meinem System kopieren, oder besser, mache vorher ein Backup von Deiner Datei)
                          Die Datei liegt bei mir auf einer Synology unter /docker/iobroker_mount/node_modules/iobroker.vuplus
                          3822_vuplus.js
                            Danke Euch beiden…
                            dies war die Lösung!
                            • Vumer
                              Vumer last edited by
                              so weit alles OK, nur wenn der DUO² aus ist wird der Log mit
                              vuplus.0	2018-03-08 11:43:25.212	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:25.210	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:25.209	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:25.207	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:20.185	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:20.184	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:20.182	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:20.180	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:15.161	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:15.160	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:15.158	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:15.156	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:10.137	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:10.136	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:10.135	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:10.133	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:05.112	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:05.111	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:05.110	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:05.107	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:00.104	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:00.103	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:00.101	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:43:00.099	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:55.058	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:55.057	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:55.056	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:55.054	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:51.100	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:51.098	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:51.097	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:51.083	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:09.842	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:09.841	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:09.840	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:09.837	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:04.816	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:04.815	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:04.814	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:42:04.812	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:59.791	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:59.789	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:59.788	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:59.786	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:54.768	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:54.767	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:54.765	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:54.763	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:49.757	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:49.755	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:49.754	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:49.748	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:44.716	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:44.715	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:44.714	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:44.712	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:39.689	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:39.688	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:39.686	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:39.684	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:34.664	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:34.663	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:34.661	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:34.659	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:29.657	error	Error for "GETCURRENT': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:29.656	error	Error for "GETVOLUME': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:29.654	error	Error for "GETINFO': received error: connect ECONNREFUSED "IP"
                              vuplus.0	2018-03-08 11:41:29.650	error	Error for "GETSTANDBY': received error: connect ECONNREFUSED "IP"
                              vollgestopft. Gibt es hier eine Lösung?
                              hab die v0.1.0
                              Schöne Grüße
                              • Matten Matten
                                Moin,
                                Ich möchte den Sender , Sender-info usw in meine CCU2 übertragen (in System Variablen).
                                Das ganze mache ich mit Blockly, das klappt auch ganz gut soweit, jedoch wenn ich Sender
                                Informationen Übertragen will und Sonderzeichen enthalten sind wird es nicht Übertragen.
                                Ich habe Festgestellt, das wenn man die Sonderzeichen inm HTML format also:
                                Ä= Ä
                                Ö= Ö
                                Ü= Ü
                                ä= ä
                                schreibt werden sie erfolgreich übertragen. Kann mir einer helfen wie ich in Blockly dekodieren
                                kann, bzw. wie das aussehen muss?
                                • wendy2702
                                  wendy2702 last edited by
                                  wie bekomme ich die Aktuelle Version 0.0.9 denn installiert?
                                  Habe das ZIP runtergeladen, umbenannt und in den angegebenen Ordner kopiert.
                                  Wenn ich dann eine Instanz hinzufügen will kommt das:
                                  • Matten Matten
                                    @wendy2702:
                                    Enigma1.jpg `
                                    @Matten Matten:
                                    @Matten Matten:
                                    @Matten Matten:
                                    issues
                                    sudo apt-get update
                                    1. Samba Passwort
                                    PW eingeben
                                    wiederholen
                                    [ioBroker]
                                       comment = ioBroker
                                       path = /opt
                                       writeable = yes
                                       guest ok = no
                                       read only = no
                                    Strg+O speichern
                                    ENTER
                                    Strg+X verlassen
                                    3. ORDNER Freigabe
                                    4.SAMBA NEUSTART
                                    dann ist der iobroker Ordner im Netzwerk erreichbar und beschreibbar. `
                                    • wendy2702
                                      sicher das ich eine Samba Freigabe haben muss um den "Adapter" nutzen zu können?
                                      Der lief bis vor kurzem auch ohne Samba Freigabe.
                                      • BBTown
                                        BBTown last edited by
                                        @wendy2702:
                                        sicher das ich eine Samba Freigabe haben muss um den "Adapter" nutzen zu können? ` der SAMBA wird - so habe ich es zumindest verstanden - nur benötigt wenn du nicht sicher bist wie Du anders den Ordner erstellen/umbenennen oder kopieren kannst …
                                        • wendy2702
                                          OK. Dann hatte ich mich vielleicht nicht deutlich ausgedrückt.
                                          Der Ordner "iobroker.enigma2" liegt schon an der richtigen Stelle in iobroker:
                                          Aber wenn ich dann eine Instanz hinzufügen will erhalte ich halt den Fehler den ich oben gepostet habe.
                                          Dazu jemand eine Idee?
                                          • Ralla66
                                            Ralla66 Most Active last edited by
                                            Habe mal ein Backup aufgespielt wo es lief.
                                            npm -v ist 3.10.10
                                            node -v ist 6.13.1
                                            admin.0 ist 2.09 installiert
                                            ohne samba
                                            bei geht nicht :
                                            npm -v ist 3.10.10
                                            node -v ist 6.13.1
                                            admin.0 ist 3.3.1 installiert
                                            ohne samba
                                            Mit welchem Kommando kann ich die Version des js.controllers rausfinden ?
                                            Log anbei mit admin.0 3.3.1
                                            739
                                            189666
