    5. Skript funktionieren nicht nach Neustart - Gelöst
    • Svaggy
      Svaggy @BananaJoe last edited by
      Gerade mit einer eigenen Skript Instanz getestet:
      Svaggy 1 Reply Last reply Reply Quote 0
      • Svaggy
        Svaggy @Svaggy last edited by
        Wie/Wo kann ich ein iob diag machen?
          Thomas Braun Most Active @Svaggy last edited by
          @svaggy
          Im Terminal (aus einer Session innerhalb des LXCs)
          iob diag
          eingeben.
          • Svaggy
            Svaggy @Thomas Braun last edited by Svaggy
            Danke hier der Output:
            ========== Start marking the full check here ===========
            Script v.2024-10-19
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.8.12-2-pve
                Architecture: x86-64
            OS is similar to:
            model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             12:49:05 up 5 min,  2 users,  load average: 0.23, 0.35, 0.32
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2024-11-08 12:49:05 CET
                       Universal time: Fri 2024-11-08 11:49:05 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
            A root login is not required in most Linux Distributions.
            Run 'iobroker fix' or use the system tools to create a user.
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            4.3G        1.7G        2.2G        110K        443M        2.6G
            Swap:           536M          0B        536M
            Total:          4.8G        1.7G        2.7G
            Active iob-Instances:   0
                     4096 M total memory
                     1619 M used memory
                     1631 M active memory
                      306 M inactive memory
                     2053 M free memory
                        0 M buffer memory
                      423 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            top - 12:49:05 up 5 min,  2 users,  load average: 0.23, 0.35, 0.32
            Tasks:  49 total,   1 running,  48 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   4096.0 total,   2052.4 free,   1620.7 used,    423.0 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2475.3 avail Mem
            *** FAILED SERVICES ***
              UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
            * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            dmesg: read kernel buffer failed: Operation not permitted
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.1G   55G   9% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
            tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            Show mounted filesystems:
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
            /var:
            485M    /var/
            251M    /var/cache
            247M    /var/cache/apt
            171M    /var/cache/apt/archives
            146M    /var/lib
            Archived and active journals take up 87.3M in the file system.
            /opt/iobroker/backups:
            62M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            945M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.0
            /usr/bin/node           v20.18.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.3
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
             *** 20.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            ***For security reasons ioBroker should not be run or administrated as root.***
            By default only a user that is member of iobroker group can execute ioBroker commands.
            Please read the Documentation on how to set up such a user, if not done yet.
            Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
            Please note that this option may be disabled in the future, so please change your setup accordingly now.
            Hosts:
            Core adapters versions
            js-controller:
            admin:
            javascript:
            nodejs modules from github:     0
            Adapter State
            ioBroker-Repositories
            Installed ioBroker-Instances
            Objects and States
            Objects:        6
            States:         6
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          4982207    296/master
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       4982321    132/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       4982168    132/iobroker.js-con
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       4984251    453/io.shelly.1
            tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       4985750    558/io.fakeroku.0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4979695    1/init
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       4988116    633/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       4983861    307/io.admin.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          4982208    296/master
            tcp6       0      0 :::111                  :::*                    LISTEN      0          4979697    1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          4980604    1/init
            tcp6       0      0 :::61991                :::*                    LISTEN      1000       4987065    543/io.harmony.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       4989203    663/io.homekit-cont
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       4985129    408/io.shelly.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4987930    588/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4985751    558/io.fakeroku.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4979696    1/init
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       4987066    543/io.harmony.0
            udp6       0      0 :::1900                 :::*                                1000       4987932    588/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1000       4987931    588/io.deconz.0
            udp6       0      0 :::111                  :::*                                0          4979698    1/init
            2024-11-08 12:45:02.648  - info: homekit-controller.0 (663) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
            2024-11-08 12:45:03.365  - info: alexa2.0 (468) Initialization Done ...
            2024-11-08 12:45:03.553  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 693
            2024-11-08 12:45:04.203  - info: maxcul.0 (693) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 12:45:04.300  - info: maxcul.0 (693) using serial device /dev/ttyACM0@38400
            2024-11-08 12:45:04.306  - info: maxcul.0 (693) serialPort /dev/ttyACM0 is open!
            2024-11-08 12:45:07.344  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 708
            2024-11-08 12:45:08.154  - info: iot.0 (708) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 12:45:08.187  - info: iot.0 (708) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2024-11-08 12:45:08.600  - info: iot.0 (708) Connection changed: connect "xxxx_gmail_com"
            2024-11-08 12:45:12.841  - info: host.iobroker stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
            2024-11-08 12:45:12.843  - info: nuki-extended.0 (483) Got terminate signal TERMINATE_YOURSELF
            2024-11-08 12:45:12.843  - info: nuki-extended.0 (483) Adapter stopped und unloaded.
            2024-11-08 12:45:12.844  - info: nuki-extended.0 (483) terminating
            2024-11-08 12:45:12.844  - info: nuki-extended.0 (483) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-11-08 12:45:12.892  - info: host.iobroker stopInstance system.adapter.nuki-extended.0 send kill signal
            2024-11-08 12:45:13.345  - info: nuki-extended.0 (483) terminating
            2024-11-08 12:45:13.369  - info: host.iobroker instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-08 12:45:16.626  - info: host.iobroker instance system.adapter.nuki-extended.0 in version "2.7.0" started with pid 723
            2024-11-08 12:45:17.479  - info: nuki-extended.0 (723) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 12:45:17.548  - warn: nuki-extended.0 (723) Due to performance reasons, the refresh rate can not be set to less than 5 seconds. Using 5 seconds now for Nuki Web API.
            2024-11-08 12:45:17.549  - info: nuki-extended.0 (723) Polling Nuki Web API with a frequency of 5s.
            2024-11-08 12:45:17.554  - warn: nuki-extended.0 (723) Name, IP or API token missing for bridge ! Please go to settings and fill in IP and the API token first!
            2024-11-08 12:45:17.554  - info: nuki-extended.0 (723) No bridges are sufficiently defined! Name, IP or token missing or all bridges deactivated!
            2024-11-08 12:45:34.308  - info: maxcul.0 (693) Timeout on CUL connect, cul is available but not responding
            iob diag has finished.
            Press any key for a summary
            v.2024-10-19
            Virtualization: lxc
            Installation: lxc
            Kernel: x86_64
            Userland: 64 bit
            Timezone: Europe/Berlin (CET, +0100)
            User-ID: 0
            Boot Target: graphical.target
            Pending OS-Updates: 0
            Pending iob updates: 0
            Nodejs-Installation:
            /usr/bin/npm 10.8.2
            /usr/bin/npx 10.8.2
            Recommended versions are nodejs
            Please note that this option may be disabled in the future, so please change your setup accordingly now. and npm
            nodeJS installation is correct
            MEMORY:
            total used free shared buff/cache available
            Swap: 536M 0B 536M
            ioBroker Core: js-controller
            admin
            ioBroker Status:
            Objects: 6
            States: 6
            Size of iob-Database:
            21M /opt/iobroker/iobroker-data/objects.jsonl
            2.6M /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            paul53 Thomas Braun 2 Replies Last reply Reply Quote 0
              paul53 @Svaggy last edited by paul53
              @svaggy sagte:
              Objects and States
              Objects:        6
              States:         6
              Das kann nicht sein und passt nicht zu:
                @svaggy
                Dann den
                iob fix
                und die angemeckerten Punkte wie 'root' und graphical.target
                korrigieren.
                • Svaggy
                  Danke, erledigt. Funktioniert leider immer noch nicht.
                  Hier der erneute iob diag output:
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   13:14:43 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
                  CPU threads: 4
                                 Local time: Fri 2024-11-08 13:14:43 CET
                             Universal time: Fri 2024-11-08 12:14:43 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  svaggy
                  HOME=/home/svaggy
                  GROUPS=svaggy adm dialout sudo audio video plugdev users iobroker
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            4.3G        1.7G        2.2G        114K        468M        2.6G
                  Swap:           536M          0B        536M
                  Active iob-Instances:   25
                           4096 M total memory
                           1599 M used memory
                           1576 M active memory
                            321 M inactive memory
                           2049 M free memory
                              0 M buffer memory
                            446 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  top - 13:14:44 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
                  Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   4096.0 total,   2048.3 free,   1601.2 used,    446.7 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2494.8 avail Mem
                  *** FILESYSTEM ***
                  tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
                  /var:
                  493M    /var/
                  251M    /var/cache
                  247M    /var/cache/apt
                  146M    /var/lib
                  Archived and active journals take up 95.3M in the file system.
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 196)
                  admin:          7.1.5
                  javascript:     8.8.3
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8080
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
                  + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
                  + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                  + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                  + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled
                  + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                  + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                  + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Active repo(s): stable
                  Upgrade policy: none
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.6
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                  Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                  Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
                  Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                  Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                  Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                  Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                  Adapter    "hue"          : 3.12.0   , installed 3.12.0
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                  Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
                  Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                  Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Objects and States
                  Objects:        10290
                  States:         6704
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5074162    1448/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5074157    1448/iobroker.js-co
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5066049    296/master
                  tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       5077678    1733/io.fakeroku.0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5065778    1/init
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       5074725    1628/io.shelly.1
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5066050    296/master
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5078488    1808/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5075216    1466/io.admin.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          5065378    1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          5065780    1/init
                  tcp6       0      0 :::61991                :::*                    LISTEN      1000       5077623    1718/io.harmony.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       5079643    1838/io.homekit-con
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       5074578    1583/io.shelly.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5078315    1763/io.deconz.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5077679    1733/io.fakeroku.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5065779    1/init
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       5077624    1718/io.harmony.0
                  udp6       0      0 :::1900                 :::*                                1000       5078317    1763/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1000       5078316    1763/io.deconz.0
                  udp6       0      0 :::111                  :::*                                0          5065781    1/init
                  2024-11-08 13:12:58.868  - info: vis.0 (1853) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                  2024-11-08 13:12:59.476  - info: vis.0 (1853) Terminated (NO_ERROR): Without reason
                  2024-11-08 13:13:00.002  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                  2024-11-08 13:13:01.400  - warn: homekit-controller.0 (1838) IP-58:03:3A:5D:47:0C Could not initialize device: connect EHOSTUNREACH 192.168.2.88:60274 Error: connect EHOSTUNREACH 192.168.2.88:60274
                      at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
                  2024-11-08 13:13:02.491  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 1868
                  2024-11-08 13:13:03.119  - info: maxcul.0 (1868) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
                  2024-11-08 13:13:03.215  - info: maxcul.0 (1868) using serial device /dev/ttyACM0@38400
                  2024-11-08 13:13:03.221  - info: maxcul.0 (1868) serialPort /dev/ttyACM0 is open!
                  2024-11-08 13:13:03.224  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
                  2024-11-08 13:13:03.228  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
                  2024-11-08 13:13:03.229  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
                  2024-11-08 13:13:04.622  - info: homekit-controller.0 (1838) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
                  2024-11-08 13:13:04.792  - warn: homekit-controller.0 (1838) IP-D2:B6:84:EF:1D:70 Could not initialize device: connect EHOSTUNREACH 192.168.2.65:61818 Error: connect EHOSTUNREACH 192.168.2.65:61818
                  2024-11-08 13:13:05.224  - info: maxcul.0 (1868) CUL FW Version: V 1.66_nocredits CUL868
                  2024-11-08 13:13:06.255  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1883
                  2024-11-08 13:13:07.061  - info: iot.0 (1883) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
                  2024-11-08 13:13:07.099  - info: iot.0 (1883) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                  2024-11-08 13:13:07.679  - info: iot.0 (1883) Connection changed: connect "xxxxx_gmail_com"
                  2024-11-08 13:13:07.784  - info: alexa2.0 (1643) Initialization Done ...
                  2024-11-08 13:13:45.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
                  2024-11-08 13:13:50.750  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
                  2024-11-08 13:13:55.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
                  2024-11-08 13:15:00.209  - error: host.iobroker cannot call visUtils: Not exists
                  ====================== SUMMARY =======================
                  v.2024-10-19
                  Virtualization: lxc
                  Installation: lxc
                  Kernel: x86_64
                  Userland: 64 bit
                  User-ID: 1001
                  Boot Target: multi-user.target
                  /usr/bin/npm 10.8.2
                  /usr/bin/npx 10.8.2
                  Recommended versions are nodejs 20.18.0 and npm 10.8.2
                  MEMORY:
                  Mem: 4.3G 1.8G 2.1G 114K 470M 2.5G
                  Swap: 536M 0B 536M
                  Total: 4.8G 1.8G 2.6G
                  ioBroker Core: js-controller 6.0.11
                  admin 7.1.5
                  ioBroker Status: iobroker is running on this host.
                  Objects type: jsonl
                  States type: jsonl
                  • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects: 10290
                  States: 6704
                  31M /opt/iobroker/iobroker-data/objects.jsonl
                  2.8M /opt/iobroker/iobroker-data/states.jsonl
                    @svaggy sagte in Skript funktionieren nicht nach Neustart:
                    Aber jetzt ist die Ausgangsbasis eine andere.
                    Objects: 10290
                    States: 6704
                    sieht schon mal anders aus.
                    • Svaggy
                      Habt ihr noch Ideen, was ich machen kann/ probieren sollte?
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Ro75
                        Ro75 @Svaggy last edited by
                        @svaggy auf welcher Logstufe steht der JS-Adapter?
                        Ro75.
                        • Svaggy
                          Svaggy @Ro75 last edited by
                          @ro75 Meinst du die Protokollebene? Die steht auf "info"
                          • Ro75
                            @svaggy OK. Was taucht denn im Log nach einem Neustart vom Docker-Container bzgl. JS/JS-Adapter auf. Alos bei mir kommen auf alle Fälle ne Menge an Einträgen. Jeder Start eines Skriptes wird dokumentiert. Also, wie sieht es bei dir konkret aus?
                            Ro75.
                            • Svaggy
                              @ro75
                              Wenn ich die "Testinstanz" starte kommt das. Hierbei auch der untenstehende Fehler:
                              javascript.1
                              2024-11-08 18:24:21.401 error Cannot find view "script" for search "javascript"
                              javascript.1
                              2024-11-08 18:24:21.346 info received all objects
                              javascript.1
                              2024-11-08 18:24:21.124 info received all states
                              javascript.1
                              2024-11-08 18:24:20.698 info requesting all objects
                              javascript.1
                              2024-11-08 18:24:20.697 info requesting all states
                              javascript.1
                              2024-11-08 18:24:20.401 info starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                              Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                              • Ro75
                                @svaggy bitte den Container neu starten lassen und dann das gesamte Log mal rein.
                                Ro75.
                                  @svaggy
                                  Das Log am besten aus
                                  iob logs
                                  nehmen und in CodeTags posten. Das ist besser formatiert und chronologisch sortiert.
                                  • Svaggy
                                    Bekomme den log hier nicht rein iob logs ist zeitlich abgeschnitten und für ein Reinkopieren hat er zu viel Zeichen..
                                      Thomas Braun Most Active @Svaggy last edited by Thomas Braun
                                      Nein, das ist eben nicht abgeschnitten, das ist immer das volle log seit 0 Uhr.
                                      Es interessiert aber eh im Moment nur der Neustart des adapters.
                                      • Svaggy
                                        Reicht das?
                                        2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
                                        2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
                                        2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
                                        2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
                                        2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
                                        2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
                                        2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
                                        2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
                                        2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                        2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
                                        2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
                                        2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
                                        2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
                                        2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
                                          @svaggy
                                          Und was ist mit javascript.0?
                                          Warum überhaupt zwei Instanzen?
                                          • Svaggy
                                            Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
                                            2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
                                            2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                            2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
                                            2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
                                            2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                                            2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
                                            2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
                                            2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
                                            2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                            2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
                                            2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
                                            2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
                                            2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
                                            2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
                                            950
