    5. Skript funktionieren nicht nach Neustart - Gelöst
    • Svaggy
      Svaggy @Thomas Braun last edited by Svaggy
      Danke hier der Output:
      ========== Start marking the full check here ===========
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       12:49:05 up 5 min,  2 users,  load average: 0.23, 0.35, 0.32
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2024-11-08 12:49:05 CET
                 Universal time: Fri 2024-11-08 11:49:05 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Run 'iobroker fix' or use the system tools to create a user.
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.3G        1.7G        2.2G        110K        443M        2.6G
      Swap:           536M          0B        536M
      Total:          4.8G        1.7G        2.7G
      Active iob-Instances:   0
               4096 M total memory
               1619 M used memory
               1631 M active memory
                306 M inactive memory
               2053 M free memory
                  0 M buffer memory
                423 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 12:49:05 up 5 min,  2 users,  load average: 0.23, 0.35, 0.32
      Tasks:  49 total,   1 running,  48 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,   2052.4 free,   1620.7 used,    423.0 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2475.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.1G   55G   9% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      /var:
      485M    /var/
      251M    /var/cache
      247M    /var/cache/apt
      171M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 87.3M in the file system.
      /opt/iobroker/backups:
      62M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      945M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      ***For security reasons ioBroker should not be run or administrated as root.***
      By default only a user that is member of iobroker group can execute ioBroker commands.
      Please read the Documentation on how to set up such a user, if not done yet.
      Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
      Please note that this option may be disabled in the future, so please change your setup accordingly now.
      Hosts:
      Core adapters versions
      js-controller:
      admin:
      javascript:
      nodejs modules from github:     0
      Adapter State
      ioBroker-Repositories
      Installed ioBroker-Instances
      Objects and States
      Objects:        6
      States:         6
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          4982207    296/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       4982321    132/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       4982168    132/iobroker.js-con
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       4984251    453/io.shelly.1
      tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       4985750    558/io.fakeroku.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4979695    1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       4988116    633/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       4983861    307/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          4982208    296/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          4979697    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          4980604    1/init
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       4987065    543/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       4989203    663/io.homekit-cont
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       4985129    408/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4987930    588/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4985751    558/io.fakeroku.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4979696    1/init
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       4987066    543/io.harmony.0
      udp6       0      0 :::1900                 :::*                                1000       4987932    588/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       4987931    588/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          4979698    1/init
      2024-11-08 12:45:02.648  - info: homekit-controller.0 (663) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
      2024-11-08 12:45:03.365  - info: alexa2.0 (468) Initialization Done ...
      2024-11-08 12:45:03.553  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 693
      2024-11-08 12:45:04.203  - info: maxcul.0 (693) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 12:45:04.300  - info: maxcul.0 (693) using serial device /dev/ttyACM0@38400
      2024-11-08 12:45:04.306  - info: maxcul.0 (693) serialPort /dev/ttyACM0 is open!
      2024-11-08 12:45:07.344  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 708
      2024-11-08 12:45:08.154  - info: iot.0 (708) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 12:45:08.187  - info: iot.0 (708) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-11-08 12:45:08.600  - info: iot.0 (708) Connection changed: connect "xxxx_gmail_com"
      2024-11-08 12:45:12.841  - info: host.iobroker stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
      2024-11-08 12:45:12.843  - info: nuki-extended.0 (483) Got terminate signal TERMINATE_YOURSELF
      2024-11-08 12:45:12.843  - info: nuki-extended.0 (483) Adapter stopped und unloaded.
      2024-11-08 12:45:12.844  - info: nuki-extended.0 (483) terminating
      2024-11-08 12:45:12.844  - info: nuki-extended.0 (483) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-11-08 12:45:12.892  - info: host.iobroker stopInstance system.adapter.nuki-extended.0 send kill signal
      2024-11-08 12:45:13.345  - info: nuki-extended.0 (483) terminating
      2024-11-08 12:45:13.369  - info: host.iobroker instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-11-08 12:45:16.626  - info: host.iobroker instance system.adapter.nuki-extended.0 in version "2.7.0" started with pid 723
      2024-11-08 12:45:17.479  - info: nuki-extended.0 (723) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 12:45:17.548  - warn: nuki-extended.0 (723) Due to performance reasons, the refresh rate can not be set to less than 5 seconds. Using 5 seconds now for Nuki Web API.
      2024-11-08 12:45:17.549  - info: nuki-extended.0 (723) Polling Nuki Web API with a frequency of 5s.
      2024-11-08 12:45:17.554  - warn: nuki-extended.0 (723) Name, IP or API token missing for bridge ! Please go to settings and fill in IP and the API token first!
      2024-11-08 12:45:17.554  - info: nuki-extended.0 (723) No bridges are sufficiently defined! Name, IP or token missing or all bridges deactivated!
      2024-11-08 12:45:34.308  - info: maxcul.0 (693) Timeout on CUL connect, cul is available but not responding
      iob diag has finished.
      Press any key for a summary
      v.2024-10-19
      Virtualization: lxc
      Installation: lxc
      Kernel: x86_64
      Userland: 64 bit
      Timezone: Europe/Berlin (CET, +0100)
      User-ID: 0
      Boot Target: graphical.target
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation:
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      Recommended versions are nodejs
      Please note that this option may be disabled in the future, so please change your setup accordingly now. and npm
      nodeJS installation is correct
      MEMORY:
      total used free shared buff/cache available
      Swap: 536M 0B 536M
      ioBroker Core: js-controller
      admin
      ioBroker Status:
      Objects: 6
      States: 6
      Size of iob-Database:
      21M /opt/iobroker/iobroker-data/objects.jsonl
      2.6M /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      paul53 Thomas Braun 2 Replies Last reply Reply Quote 0
        paul53 @Svaggy last edited by paul53
        @svaggy sagte:
        Objects and States
        Objects:        6
        States:         6
        Das kann nicht sein und passt nicht zu:
          Thomas Braun Most Active @Svaggy last edited by
          @svaggy
          Dann den
          iob fix
          und die angemeckerten Punkte wie 'root' und graphical.target
          korrigieren.
          Svaggy 1 Reply Last reply Reply Quote 0
          • Svaggy
            Danke, erledigt. Funktioniert leider immer noch nicht.
            Hier der erneute iob diag output:
            Script v.2024-10-19
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             13:14:43 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
            CPU threads: 4
                           Local time: Fri 2024-11-08 13:14:43 CET
                       Universal time: Fri 2024-11-08 12:14:43 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            svaggy
            HOME=/home/svaggy
            GROUPS=svaggy adm dialout sudo audio video plugdev users iobroker
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            4.3G        1.7G        2.2G        114K        468M        2.6G
            Swap:           536M          0B        536M
            Active iob-Instances:   25
                     4096 M total memory
                     1599 M used memory
                     1576 M active memory
                      321 M inactive memory
                     2049 M free memory
                        0 M buffer memory
                      446 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            top - 13:14:44 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
            Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   4096.0 total,   2048.3 free,   1601.2 used,    446.7 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2494.8 avail Mem
            *** FILESYSTEM ***
            tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
            /var:
            493M    /var/
            251M    /var/cache
            247M    /var/cache/apt
            146M    /var/lib
            Archived and active journals take up 95.3M in the file system.
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 196)
            admin:          7.1.5
            javascript:     8.8.3
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8080
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
            + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
            + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
            + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled
            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
            + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            Active repo(s): stable
            Upgrade policy: none
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.6
            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
            Adapter    "deconz"       : 1.4.1    , installed 1.4.1
            Adapter    "eusec"        : 1.3.3    , installed 1.3.3
            Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
            Adapter    "harmony"      : 1.5.0    , installed 1.5.0
            Adapter    "homekit-controller": 0.5.10, installed 0.5.10
            Adapter    "hue"          : 3.12.0   , installed 3.12.0
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
            Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
            Adapter    "nuki"         : 2.0.0    , installed 2.0.0
            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        10290
            States:         6704
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5074162    1448/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5074157    1448/iobroker.js-co
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5066049    296/master
            tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       5077678    1733/io.fakeroku.0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5065778    1/init
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       5074725    1628/io.shelly.1
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5066050    296/master
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5078488    1808/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5075216    1466/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          5065378    1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          5065780    1/init
            tcp6       0      0 :::61991                :::*                    LISTEN      1000       5077623    1718/io.harmony.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       5079643    1838/io.homekit-con
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       5074578    1583/io.shelly.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5078315    1763/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5077679    1733/io.fakeroku.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5065779    1/init
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       5077624    1718/io.harmony.0
            udp6       0      0 :::1900                 :::*                                1000       5078317    1763/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1000       5078316    1763/io.deconz.0
            udp6       0      0 :::111                  :::*                                0          5065781    1/init
            2024-11-08 13:12:58.868  - info: vis.0 (1853) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 13:12:59.476  - info: vis.0 (1853) Terminated (NO_ERROR): Without reason
            2024-11-08 13:13:00.002  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            2024-11-08 13:13:01.400  - warn: homekit-controller.0 (1838) IP-58:03:3A:5D:47:0C Could not initialize device: connect EHOSTUNREACH 192.168.2.88:60274 Error: connect EHOSTUNREACH 192.168.2.88:60274
                at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
            2024-11-08 13:13:02.491  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 1868
            2024-11-08 13:13:03.119  - info: maxcul.0 (1868) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 13:13:03.215  - info: maxcul.0 (1868) using serial device /dev/ttyACM0@38400
            2024-11-08 13:13:03.221  - info: maxcul.0 (1868) serialPort /dev/ttyACM0 is open!
            2024-11-08 13:13:03.224  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
            2024-11-08 13:13:03.228  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
            2024-11-08 13:13:03.229  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
            2024-11-08 13:13:04.622  - info: homekit-controller.0 (1838) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
            2024-11-08 13:13:04.792  - warn: homekit-controller.0 (1838) IP-D2:B6:84:EF:1D:70 Could not initialize device: connect EHOSTUNREACH 192.168.2.65:61818 Error: connect EHOSTUNREACH 192.168.2.65:61818
            2024-11-08 13:13:05.224  - info: maxcul.0 (1868) CUL FW Version: V 1.66_nocredits CUL868
            2024-11-08 13:13:06.255  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1883
            2024-11-08 13:13:07.061  - info: iot.0 (1883) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
            2024-11-08 13:13:07.099  - info: iot.0 (1883) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2024-11-08 13:13:07.679  - info: iot.0 (1883) Connection changed: connect "xxxxx_gmail_com"
            2024-11-08 13:13:07.784  - info: alexa2.0 (1643) Initialization Done ...
            2024-11-08 13:13:45.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
            2024-11-08 13:13:50.750  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
            2024-11-08 13:13:55.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
            2024-11-08 13:15:00.209  - error: host.iobroker cannot call visUtils: Not exists
            ====================== SUMMARY =======================
            v.2024-10-19
            Virtualization: lxc
            Installation: lxc
            Kernel: x86_64
            Userland: 64 bit
            User-ID: 1001
            Boot Target: multi-user.target
            /usr/bin/npm 10.8.2
            /usr/bin/npx 10.8.2
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            MEMORY:
            Mem: 4.3G 1.8G 2.1G 114K 470M 2.5G
            Swap: 536M 0B 536M
            Total: 4.8G 1.8G 2.6G
            ioBroker Core: js-controller 6.0.11
            admin 7.1.5
            ioBroker Status: iobroker is running on this host.
            Objects type: jsonl
            States type: jsonl
            • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects: 10290
            States: 6704
            31M /opt/iobroker/iobroker-data/objects.jsonl
            2.8M /opt/iobroker/iobroker-data/states.jsonl
              @svaggy sagte in Skript funktionieren nicht nach Neustart:
              Aber jetzt ist die Ausgangsbasis eine andere.
              Objects: 10290
              States: 6704
              sieht schon mal anders aus.
              • Svaggy
                Habt ihr noch Ideen, was ich machen kann/ probieren sollte?
                Ro75 1 Reply Last reply Reply Quote 0
                • Ro75
                  Ro75 @Svaggy last edited by
                  @svaggy auf welcher Logstufe steht der JS-Adapter?
                  Ro75.
                  • Svaggy
                    Svaggy @Ro75 last edited by
                    @ro75 Meinst du die Protokollebene? Die steht auf "info"
                    • Ro75
                      @svaggy OK. Was taucht denn im Log nach einem Neustart vom Docker-Container bzgl. JS/JS-Adapter auf. Alos bei mir kommen auf alle Fälle ne Menge an Einträgen. Jeder Start eines Skriptes wird dokumentiert. Also, wie sieht es bei dir konkret aus?
                      Ro75.
                      • Svaggy
                        @ro75
                        Wenn ich die "Testinstanz" starte kommt das. Hierbei auch der untenstehende Fehler:
                        javascript.1
                        2024-11-08 18:24:21.401 error Cannot find view "script" for search "javascript"
                        javascript.1
                        2024-11-08 18:24:21.346 info received all objects
                        javascript.1
                        2024-11-08 18:24:21.124 info received all states
                        javascript.1
                        2024-11-08 18:24:20.698 info requesting all objects
                        javascript.1
                        2024-11-08 18:24:20.697 info requesting all states
                        javascript.1
                        2024-11-08 18:24:20.401 info starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                        Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Ro75
                          @svaggy bitte den Container neu starten lassen und dann das gesamte Log mal rein.
                          Ro75.
                            @svaggy
                            Das Log am besten aus
                            iob logs
                            nehmen und in CodeTags posten. Das ist besser formatiert und chronologisch sortiert.
                            • Svaggy
                              Bekomme den log hier nicht rein iob logs ist zeitlich abgeschnitten und für ein Reinkopieren hat er zu viel Zeichen..
                                Thomas Braun Most Active @Svaggy last edited by Thomas Braun
                                Nein, das ist eben nicht abgeschnitten, das ist immer das volle log seit 0 Uhr.
                                Es interessiert aber eh im Moment nur der Neustart des adapters.
                                • Svaggy
                                  Reicht das?
                                  2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
                                  2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
                                  2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
                                  2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
                                  2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
                                  2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
                                  2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
                                  2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
                                  2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                  2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
                                  2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
                                  2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
                                  2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
                                  2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
                                    @svaggy
                                    Und was ist mit javascript.0?
                                    Warum überhaupt zwei Instanzen?
                                    • Svaggy
                                      Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
                                      2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
                                      2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                      2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
                                      2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
                                      2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                                      2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
                                      2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
                                      2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
                                      2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                      2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
                                      2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
                                      2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
                                      2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
                                      2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
                                      • Ro75
                                        @svaggy zeig mal bitte bildlich deine Skripte / Blockly's
                                        Ro75.
                                        • Svaggy
                                          @ro75
                                          Ganz oben habe ich doch ein super simples aus der Instanz 1 gezeigt, was nicht funktioniert
                                          Hier was größeres aus der Instanz 0
                                          • Ro75
                                            @svaggy das meinte ich nicht. Eher so:
                                            Ro75.
                                            950
