    5. Skript funktionieren nicht nach Neustart - Gelöst
      paul53 @Svaggy last edited by paul53
      @svaggy sagte:
      Objects and States
      Objects:        6
      States:         6
      Das kann nicht sein und passt nicht zu:
      Size of iob-Database:
      21M /opt/iobroker/iobroker-data/objects.jsonl
      2.6M /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun Most Active @Svaggy last edited by
        @svaggy
        Dann den
        iob fix
        und die angemeckerten Punkte wie 'root' und graphical.target
        korrigieren.
        Svaggy 1 Reply Last reply Reply Quote 0
        • Svaggy
          Svaggy @Thomas Braun last edited by
          Danke, erledigt. Funktioniert leider immer noch nicht.
          Hier der erneute iob diag output:
          ========== Start marking the full check here ===========
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-2-pve
              Architecture: x86-64
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           13:14:43 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
          *** TIME AND TIMEZONES ***
                         Local time: Fri 2024-11-08 13:14:43 CET
                     Universal time: Fri 2024-11-08 12:14:43 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          svaggy
          HOME=/home/svaggy
          GROUPS=svaggy adm dialout sudo audio video plugdev users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            4.3G        1.7G        2.2G        114K        468M        2.6G
          Swap:           536M          0B        536M
          Total:          4.8G        1.7G        2.7G
          Active iob-Instances:   25
                   4096 M total memory
                   1599 M used memory
                   1576 M active memory
                    321 M inactive memory
                   2049 M free memory
                      0 M buffer memory
                    446 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          top - 13:14:44 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
          Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   4096.0 total,   2048.3 free,   1601.2 used,    446.7 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2494.8 avail Mem
          *** FAILED SERVICES ***
            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          2 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.1G   55G   9% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
          tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
          /var:
          493M    /var/
          251M    /var/cache
          247M    /var/cache/apt
          171M    /var/cache/apt/archives
          146M    /var/lib
          Archived and active journals take up 95.3M in the file system.
          /opt/iobroker/backups:
          62M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          945M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.0
          /usr/bin/node           v20.18.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.18.0-1nodesource1
            Version table:
           *** 20.18.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 196)
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8080
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
          + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled
          + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.6
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "deconz"       : 1.4.1    , installed 1.4.1
          Adapter    "eusec"        : 1.3.3    , installed 1.3.3
          Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "fhem"         : 3.0.0    , installed 3.0.0
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "homekit-controller": 0.5.10, installed 0.5.10
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
          Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        10290
          States:         6704
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5074162    1448/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5074157    1448/iobroker.js-co
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5066049    296/master
          tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       5077678    1733/io.fakeroku.0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5065778    1/init
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       5074725    1628/io.shelly.1
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5066050    296/master
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5078488    1808/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5075216    1466/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          5065378    1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          5065780    1/init
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       5077623    1718/io.harmony.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       5079643    1838/io.homekit-con
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       5074578    1583/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5078315    1763/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5077679    1733/io.fakeroku.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5065779    1/init
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       5077624    1718/io.harmony.0
          udp6       0      0 :::1900                 :::*                                1000       5078317    1763/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1000       5078316    1763/io.deconz.0
          udp6       0      0 :::111                  :::*                                0          5065781    1/init
          2024-11-08 13:12:58.868  - info: vis.0 (1853) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
          2024-11-08 13:12:59.476  - info: vis.0 (1853) Terminated (NO_ERROR): Without reason
          2024-11-08 13:13:00.002  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
          2024-11-08 13:13:01.400  - warn: homekit-controller.0 (1838) IP-58:03:3A:5D:47:0C Could not initialize device: connect EHOSTUNREACH 192.168.2.88:60274 Error: connect EHOSTUNREACH 192.168.2.88:60274
              at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
          2024-11-08 13:13:02.491  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 1868
          2024-11-08 13:13:03.119  - info: maxcul.0 (1868) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
          2024-11-08 13:13:03.215  - info: maxcul.0 (1868) using serial device /dev/ttyACM0@38400
          2024-11-08 13:13:03.221  - info: maxcul.0 (1868) serialPort /dev/ttyACM0 is open!
          2024-11-08 13:13:03.224  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
          2024-11-08 13:13:03.228  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
          2024-11-08 13:13:03.229  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
          2024-11-08 13:13:04.622  - info: homekit-controller.0 (1838) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
          2024-11-08 13:13:04.792  - warn: homekit-controller.0 (1838) IP-D2:B6:84:EF:1D:70 Could not initialize device: connect EHOSTUNREACH 192.168.2.65:61818 Error: connect EHOSTUNREACH 192.168.2.65:61818
          2024-11-08 13:13:05.224  - info: maxcul.0 (1868) CUL FW Version: V 1.66_nocredits CUL868
          2024-11-08 13:13:06.255  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1883
          2024-11-08 13:13:07.061  - info: iot.0 (1883) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
          2024-11-08 13:13:07.099  - info: iot.0 (1883) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2024-11-08 13:13:07.679  - info: iot.0 (1883) Connection changed: connect "xxxxx_gmail_com"
          2024-11-08 13:13:07.784  - info: alexa2.0 (1643) Initialization Done ...
          2024-11-08 13:13:45.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
          2024-11-08 13:13:50.750  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
          2024-11-08 13:13:55.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
          2024-11-08 13:15:00.209  - error: host.iobroker cannot call visUtils: Not exists
          iob diag has finished.
          Press any key for a summary
          ====================== SUMMARY =======================
          v.2024-10-19
          Virtualization: lxc
          Installation: lxc
          Kernel: x86_64
          Userland: 64 bit
          Timezone: Europe/Berlin (CET, +0100)
          User-ID: 1001
          Boot Target: multi-user.target
          Pending OS-Updates: 0
          Pending iob updates: 0
          Nodejs-Installation:
          /usr/bin/npm 10.8.2
          /usr/bin/npx 10.8.2
          Recommended versions are nodejs 20.18.0 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          total used free shared buff/cache available
          Mem: 4.3G 1.8G 2.1G 114K 470M 2.5G
          Swap: 536M 0B 536M
          Total: 4.8G 1.8G 2.6G
          ioBroker Core: js-controller 6.0.11
          admin 7.1.5
          ioBroker Status: iobroker is running on this host.
          Objects type: jsonl
          States type: jsonl
          • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects: 10290
          States: 6704
          31M /opt/iobroker/iobroker-data/objects.jsonl
          2.8M /opt/iobroker/iobroker-data/states.jsonl
            @svaggy sagte in Skript funktionieren nicht nach Neustart:
            Aber jetzt ist die Ausgangsbasis eine andere.
            Objects: 10290
            States: 6704
            sieht schon mal anders aus.
            • Svaggy
              Habt ihr noch Ideen, was ich machen kann/ probieren sollte?
              Ro75 1 Reply Last reply Reply Quote 0
              • Ro75
                Ro75 @Svaggy last edited by
                @svaggy auf welcher Logstufe steht der JS-Adapter?
                Ro75.
                • Svaggy
                  Svaggy @Ro75 last edited by
                  @ro75 Meinst du die Protokollebene? Die steht auf "info"
                  • Ro75
                    @svaggy OK. Was taucht denn im Log nach einem Neustart vom Docker-Container bzgl. JS/JS-Adapter auf. Alos bei mir kommen auf alle Fälle ne Menge an Einträgen. Jeder Start eines Skriptes wird dokumentiert. Also, wie sieht es bei dir konkret aus?
                    Ro75.
                    • Svaggy
                      @ro75
                      Wenn ich die "Testinstanz" starte kommt das. Hierbei auch der untenstehende Fehler:
                      javascript.1
                      2024-11-08 18:24:21.401 error Cannot find view "script" for search "javascript"
                      javascript.1
                      2024-11-08 18:24:21.346 info received all objects
                      javascript.1
                      2024-11-08 18:24:21.124 info received all states
                      javascript.1
                      2024-11-08 18:24:20.698 info requesting all objects
                      javascript.1
                      2024-11-08 18:24:20.697 info requesting all states
                      javascript.1
                      2024-11-08 18:24:20.401 info starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                      Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                      • Ro75
                        @svaggy bitte den Container neu starten lassen und dann das gesamte Log mal rein.
                        Ro75.
                          @svaggy
                          Das Log am besten aus
                          iob logs
                          nehmen und in CodeTags posten. Das ist besser formatiert und chronologisch sortiert.
                          • Svaggy
                            Bekomme den log hier nicht rein iob logs ist zeitlich abgeschnitten und für ein Reinkopieren hat er zu viel Zeichen..
                              Thomas Braun Most Active @Svaggy last edited by Thomas Braun
                              Nein, das ist eben nicht abgeschnitten, das ist immer das volle log seit 0 Uhr.
                              Es interessiert aber eh im Moment nur der Neustart des adapters.
                              • Svaggy
                                Reicht das?
                                2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
                                2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
                                2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
                                2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
                                2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
                                2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
                                2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
                                2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
                                2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
                                2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
                                2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
                                2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
                                2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
                                  @svaggy
                                  Und was ist mit javascript.0?
                                  Warum überhaupt zwei Instanzen?
                                  • Svaggy
                                    Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
                                    2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
                                    2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                    2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
                                    2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
                                    2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                                    2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
                                    2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
                                    2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
                                    2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                    2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
                                    2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
                                    2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
                                    2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
                                    2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
                                    • Ro75
                                      @svaggy zeig mal bitte bildlich deine Skripte / Blockly's
                                      Ro75.
                                      • Svaggy
                                        @ro75
                                        Ganz oben habe ich doch ein super simples aus der Instanz 1 gezeigt, was nicht funktioniert
                                        Hier was größeres aus der Instanz 0
                                        • Ro75
                                          @svaggy das meinte ich nicht. Eher so:
                                          Ro75.
                                          • Svaggy
                                            @ro75 Ah.. 🙂
                                            950
