    5. Skript funktionieren nicht nach Neustart - Gelöst
    • Svaggy
      Svaggy @Thomas Braun last edited by
      Danke, erledigt. Funktioniert leider immer noch nicht.
      Hier der erneute iob diag output:
      ========== Start marking the full check here ===========
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       13:14:43 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2024-11-08 13:14:43 CET
                 Universal time: Fri 2024-11-08 12:14:43 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      svaggy
      HOME=/home/svaggy
      GROUPS=svaggy adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            4.3G        1.7G        2.2G        114K        468M        2.6G
      Swap:           536M          0B        536M
      Total:          4.8G        1.7G        2.7G
      Active iob-Instances:   25
               4096 M total memory
               1599 M used memory
               1576 M active memory
                321 M inactive memory
               2049 M free memory
                  0 M buffer memory
                446 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 13:14:44 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
      Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,   2048.3 free,   1601.2 used,    446.7 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2494.8 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.1G   55G   9% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      /var:
      493M    /var/
      251M    /var/cache
      247M    /var/cache/apt
      171M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 95.3M in the file system.
      /opt/iobroker/backups:
      62M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      945M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 196)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8080
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
      + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.6
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
      Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fhem"         : 3.0.0    , installed 3.0.0
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
      Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        10290
      States:         6704
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5074162    1448/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5074157    1448/iobroker.js-co
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5066049    296/master
      tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       5077678    1733/io.fakeroku.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5065778    1/init
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       5074725    1628/io.shelly.1
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5066050    296/master
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5078488    1808/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5075216    1466/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5065378    1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          5065780    1/init
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       5077623    1718/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       5079643    1838/io.homekit-con
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       5074578    1583/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5078315    1763/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5077679    1733/io.fakeroku.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5065779    1/init
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       5077624    1718/io.harmony.0
      udp6       0      0 :::1900                 :::*                                1000       5078317    1763/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       5078316    1763/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          5065781    1/init
      2024-11-08 13:12:58.868  - info: vis.0 (1853) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 13:12:59.476  - info: vis.0 (1853) Terminated (NO_ERROR): Without reason
      2024-11-08 13:13:00.002  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
      2024-11-08 13:13:01.400  - warn: homekit-controller.0 (1838) IP-58:03:3A:5D:47:0C Could not initialize device: connect EHOSTUNREACH 192.168.2.88:60274 Error: connect EHOSTUNREACH 192.168.2.88:60274
          at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
      2024-11-08 13:13:02.491  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 1868
      2024-11-08 13:13:03.119  - info: maxcul.0 (1868) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 13:13:03.215  - info: maxcul.0 (1868) using serial device /dev/ttyACM0@38400
      2024-11-08 13:13:03.221  - info: maxcul.0 (1868) serialPort /dev/ttyACM0 is open!
      2024-11-08 13:13:03.224  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
      2024-11-08 13:13:03.228  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
      2024-11-08 13:13:03.229  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
      2024-11-08 13:13:04.622  - info: homekit-controller.0 (1838) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
      2024-11-08 13:13:04.792  - warn: homekit-controller.0 (1838) IP-D2:B6:84:EF:1D:70 Could not initialize device: connect EHOSTUNREACH 192.168.2.65:61818 Error: connect EHOSTUNREACH 192.168.2.65:61818
      2024-11-08 13:13:05.224  - info: maxcul.0 (1868) CUL FW Version: V 1.66_nocredits CUL868
      2024-11-08 13:13:06.255  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1883
      2024-11-08 13:13:07.061  - info: iot.0 (1883) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 13:13:07.099  - info: iot.0 (1883) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-11-08 13:13:07.679  - info: iot.0 (1883) Connection changed: connect "xxxxx_gmail_com"
      2024-11-08 13:13:07.784  - info: alexa2.0 (1643) Initialization Done ...
      2024-11-08 13:13:45.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
      2024-11-08 13:13:50.750  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
      2024-11-08 13:13:55.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
      2024-11-08 13:15:00.209  - error: host.iobroker cannot call visUtils: Not exists
      iob diag has finished.
      Press any key for a summary
      ====================== SUMMARY =======================
      v.2024-10-19
      Virtualization: lxc
      Installation: lxc
      Kernel: x86_64
      Userland: 64 bit
      Timezone: Europe/Berlin (CET, +0100)
      User-ID: 1001
      Boot Target: multi-user.target
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation:
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      Recommended versions are nodejs 20.18.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      total used free shared buff/cache available
      Mem: 4.3G 1.8G 2.1G 114K 470M 2.5G
      Swap: 536M 0B 536M
      Total: 4.8G 1.8G 2.6G
      ioBroker Core: js-controller 6.0.11
      admin 7.1.5
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 10290
      States: 6704
      Size of iob-Database:
      31M /opt/iobroker/iobroker-data/objects.jsonl
      2.8M /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun Most Active @Svaggy last edited by
        @svaggy sagte in Skript funktionieren nicht nach Neustart:
        Aber jetzt ist die Ausgangsbasis eine andere.
        Objects: 10290
        States: 6704
        sieht schon mal anders aus.
        Svaggy 1 Reply Last reply Reply Quote 0
        • Svaggy
          Habt ihr noch Ideen, was ich machen kann/ probieren sollte?
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            Ro75 @Svaggy last edited by
            @svaggy auf welcher Logstufe steht der JS-Adapter?
            Ro75.
            • Svaggy
              Svaggy @Ro75 last edited by
              @ro75 Meinst du die Protokollebene? Die steht auf "info"
              • Ro75
                @svaggy OK. Was taucht denn im Log nach einem Neustart vom Docker-Container bzgl. JS/JS-Adapter auf. Alos bei mir kommen auf alle Fälle ne Menge an Einträgen. Jeder Start eines Skriptes wird dokumentiert. Also, wie sieht es bei dir konkret aus?
                Ro75.
                • Svaggy
                  @ro75
                  Wenn ich die "Testinstanz" starte kommt das. Hierbei auch der untenstehende Fehler:
                  javascript.1
                  2024-11-08 18:24:21.401 error Cannot find view "script" for search "javascript"
                  javascript.1
                  2024-11-08 18:24:21.346 info received all objects
                  javascript.1
                  2024-11-08 18:24:21.124 info received all states
                  javascript.1
                  2024-11-08 18:24:20.698 info requesting all objects
                  javascript.1
                  2024-11-08 18:24:20.697 info requesting all states
                  javascript.1
                  2024-11-08 18:24:20.401 info starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                  Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Ro75
                    @svaggy bitte den Container neu starten lassen und dann das gesamte Log mal rein.
                    Ro75.
                      @svaggy
                      Das Log am besten aus
                      iob logs
                      nehmen und in CodeTags posten. Das ist besser formatiert und chronologisch sortiert.
                      • Svaggy
                        Bekomme den log hier nicht rein iob logs ist zeitlich abgeschnitten und für ein Reinkopieren hat er zu viel Zeichen..
                          Thomas Braun Most Active @Svaggy last edited by Thomas Braun
                          Nein, das ist eben nicht abgeschnitten, das ist immer das volle log seit 0 Uhr.
                          Es interessiert aber eh im Moment nur der Neustart des adapters.
                          • Svaggy
                            Reicht das?
                            2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
                            2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
                            2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
                            2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
                            2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
                            2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
                            2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
                            2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
                            2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                            2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
                            2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
                            2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
                            2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
                            2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
                              @svaggy
                              Und was ist mit javascript.0?
                              Warum überhaupt zwei Instanzen?
                              • Svaggy
                                Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
                                2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
                                2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
                                2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
                                2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                                2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
                                2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
                                2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
                                2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                                2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
                                2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
                                2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
                                2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
                                2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
                                • Ro75
                                  @svaggy zeig mal bitte bildlich deine Skripte / Blockly's
                                  Ro75.
                                  • Svaggy
                                    @ro75
                                    Ganz oben habe ich doch ein super simples aus der Instanz 1 gezeigt, was nicht funktioniert
                                    Hier was größeres aus der Instanz 0
                                    • Ro75
                                      @svaggy das meinte ich nicht. Eher so:
                                      Ro75.
                                      • Svaggy
                                        @ro75 Ah.. 🙂
                                          crunchip Forum Testing Most Active @Svaggy last edited by
                                          nach einem Neustart
                                          nur ein einfacher Neustart, oder vllt doch das ein odere andere Update gemacht?
                                          mach mal im terminal ein
                                          iob upload all
                                          • Svaggy
                                            Svaggy @crunchip last edited by
                                            @crunchip
                                            Yeah 🙂 Das hat´s gebracht!! Vielen Dank!!
                                            Kannst du mir noch sagen, was der Befehl gemacht hat/ wo mein Problem war?
                                            950
