    4. npm Fehlermeldung
    npm Fehlermeldung
      MyMeyer @Thomas Braun last edited by MyMeyer
      Hmm...sieht für mich alles normal aus.
      ========== Start marking the full check here ===========
      Script v.2024-10-19
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-33-amd64
            Architecture: x86-64
      OS is similar to:
      model name	: Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
      CPU threads: 12
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2024-11-09 20:18:54 CET
                 Universal time: Sat 2024-11-09 19:18:54 UTC
                       RTC time: Sat 2024-11-09 19:18:55
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      michael
      HOME=/home/michael
      GROUPS=michael cdrom floppy sudo audio dip video plugdev netdev redis iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:             15G        4.1G        9.7G        0.0K        2.2G         11G
      Swap:           4.1G          0B        4.1G
      Total:           20G        4.1G         13G
      Active iob-Instances: 	52
              15996 M total memory
               4140 M used memory
               1089 M active memory
               4554 M inactive memory
               9699 M free memory
                481 M buffer memory
               1674 M swap cache
               4093 M total swap
                  0 M used swap
               4093 M free swap
      top - 20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
      Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.1 us,  1.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  1.1 st
      MiB Mem :  15996.4 total,   9699.5 free,   4140.7 used,   2156.2 buff/cache
      MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11524.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  560K  1.6G   1% /run
      /dev/sda1      ext4       28G   20G  6.6G  75% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Thu Oct 31 10:35:09 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Oct 31 10:35:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.1G	/var/
      993M	/var/cache
      984M	/var/cache/apt
      934M	/var/log
      915M	/var/cache/apt/archives
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      Archived and active journals take up 264.0M in the file system.
      /opt/iobroker/backups:
      84M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.8G	/opt/iobroker/iobroker-data/
      1.2G	/opt/iobroker/iobroker-data/files
      617M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      78M	/opt/iobroker/iobroker-data/objects.jsonl
      51M	/opt/iobroker/iobroker-data/states.json.old
      46M	/opt/iobroker/iobroker-data/objects.json.migrated
      46M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.0
      /usr/bin/node 		v20.18.0
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Hosts:
      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 38811)
      iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 812218)
      Core adapters versions
      js-controller: 	6.0.11
      admin: 		7.1.5
      javascript: 	8.8.3
      nodejs modules from github: 	7
      +-- iobroker.blink4home@0.1.1 invalid: "https://github.com/Flashy-GER/ioBroker.blink4home/tarball/37aaf54baf0ac76931d00a71459bcb4e47d96b43" from the root project
      +-- iobroker.broadlink@0.1.5 invalid: "https://github.com/hieblmedia/ioBroker.broadlink/tarball/master" from the root project
      +-- iobroker.fully-tablet-control@0.3.3-beta.0 invalid: "https://github.com/xXBJXx/ioBroker.fully-tablet-control/tarball/e8c40673053e31ce4621d33e3ad38bcaae6b452d" from the root project
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      +-- iobroker.repetierserver@0.0.3 invalid: "https://github.com/Baumert7269/ioBroker.repetierserver/tarball/256b927316a6394475c990026b7ce27c5d32abe8" from the root project
      | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
          `-- @rjsf/bootstrap-5@4.2.0 invalid: "https://github.com/nurikk/fileshare/blob/main/rjsf-bootstrap-5-4.2.0.tgz?raw=true" from node_modules/zigbee2mqtt-frontend
      Adapter State
      + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.39, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-slave                           -  enabled
      + system.adapter.egigeozone2.0            : egigeozone2           : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
        system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.2          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.1.39
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
        system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.39
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.1.39, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : iobroker-slave                           -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.39
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.175:6638
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alarm"        : 3.6.2    , installed 3.6.2
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "egigeozone2"  : 1.0.7    , installed 1.0.6  [Updatable]
      Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
      Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "ring"         : 6.2.1    , installed 5.1.0  [Updatable]
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.1.0    , installed 3.1.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
      Objects and States
      Objects: 	47876
      States: 	41930
      Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
      Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11528      741/sshd: /usr/sbin
      tcp        0      0 192.168.1.39:8087       0.0.0.0:*               LISTEN      1001       22880486   3440656/io.simple-a
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13006      734/exim4
      tcp        0      0 0.0.0.0:1082            0.0.0.0:*               LISTEN      1000       23807780   3845793/nc
      tcp        0      0 192.168.1.39:2010       0.0.0.0:*               LISTEN      1001       22875511   3438603/io.hm-rpc.1
      tcp        0      0 192.168.1.39:1883       0.0.0.0:*               LISTEN      1001       22874812   3438557/io.sonoff.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       22870917   3437481/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       22870918   3437481/io.mqtt.0
      tcp        0      0 192.168.1.39:1888       0.0.0.0:*               LISTEN      1001       22874750   3437564/io.mqtt.1
      tcp        0      0 192.168.1.39:1889       0.0.0.0:*               LISTEN      1001       22874751   3437564/io.mqtt.1
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22867654   3435624/iobroker.js
      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        14138      444/redis-server 0.
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13951      1/init
      tcp        0      0 192.168.1.39:2001       0.0.0.0:*               LISTEN      1001       22871328   3436705/io.hm-rpc.0
      tcp        0      0 192.168.1.39:8081       0.0.0.0:*               LISTEN      1001       22870433   3435654/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11530      741/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13007      734/exim4
      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       22878403   3439671/io.egigeozo
      tcp6       0      0 :::111                  :::*                    LISTEN      0          10224      1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22880563   3440933/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22883504   3441852/io.socketio
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       23790698   3838359/io.nuki-ext
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       22874451   3437357/io.mihome-v
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       22876614   3439250/io.mihome-v
      udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       22874993   3439302/io.mihome-v
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22877109   3441031/io.wled.0
      udp        0      0 192.168.1.39:5353       0.0.0.0:*                           1001       22876423   3438564/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        12925      438/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22875538   3438550/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22874839   3438565/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22874840   3438565/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       22870612   3436350/io.broadlin
      udp        0      0 0.0.0.0:48705           0.0.0.0:*                           1001       23628756   3436350/io.broadlin
      udp        0      0 0.0.0.0:57115           0.0.0.0:*                           1001       22866935   3436350/io.broadlin
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11336      1/init
      udp        0      0 0.0.0.0:33498           0.0.0.0:*                           107        12927      438/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                107        12926      438/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          1967       1/init
      udp6       0      0 :::42604                :::*                                107        12928      438/avahi-daemon: r
      2024-11-09 20:17:05.010  - info: labcom.0 (3842960) cleaned everything up...
      2024-11-09 20:17:05.015  - info: labcom.0 (3842960) Terminated (NO_ERROR): Without reason
      2024-11-09 20:17:05.527  - info: host.iobroker instance system.adapter.labcom.0 having pid 3842960 terminated with code 0 (NO_ERROR)
      2024-11-09 20:17:14.006  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3842976
      2024-11-09 20:17:14.772  - info: daswetter.0 (3842976) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
      2024-11-09 20:17:19.421  - info: daswetter.0 (3842976) still wrong data structure from server received! repaired...
      2024-11-09 20:17:20.002  - info: ring.0 (3440535) Device 45172445 ("Haustür"): Cronjob Auto save HD Snapshot starts
      2024-11-09 20:17:20.005  - info: ring.0 (3440535) Device 45172445 ("Haustür"): is offline --> won't take HD Snapshot
      2024-11-09 20:17:20.825  - info: daswetter.0 (3842976) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-11-09 20:17:21.329  - info: daswetter.0 (3842976) cleaned everything up...
      2024-11-09 20:17:21.336  - info: host.iobroker instance system.adapter.daswetter.0 having pid 3842976 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-11-09 20:18:04.051  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3843922
      2024-11-09 20:18:04.883  - info: labcom.0 (3843922) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
      2024-11-09 20:18:04.891  - info: labcom.0 (3843922) LabCom adapter - started
      2024-11-09 20:18:05.121  - info: labcom.0 (3843922) LabCom adapter - fetching data completed
      2024-11-09 20:18:05.121  - info: labcom.0 (3843922) cleaned everything up...
      2024-11-09 20:18:05.126  - info: labcom.0 (3843922) Terminated (NO_ERROR): Without reason
      2024-11-09 20:18:05.637  - info: host.iobroker instance system.adapter.labcom.0 having pid 3843922 terminated with code 0 (NO_ERROR)
      2024-11-09 20:19:04.006  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3845502
      2024-11-09 20:19:04.901  - info: labcom.0 (3845502) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
      2024-11-09 20:19:04.908  - info: labcom.0 (3845502) LabCom adapter - started
      2024-11-09 20:19:05.147  - info: labcom.0 (3845502) LabCom adapter - fetching data completed
      2024-11-09 20:19:05.147  - info: labcom.0 (3845502) cleaned everything up...
      2024-11-09 20:19:05.152  - info: labcom.0 (3845502) Terminated (NO_ERROR): Without reason
      2024-11-09 20:19:05.662  - info: host.iobroker instance system.adapter.labcom.0 having pid 3845502 terminated with code 0 (NO_ERROR)
      [/s]
        Thomas Braun Most Active @MyMeyer last edited by
        @mymeyer
        Sieht für mich nicht normal aus, da fehlt nämlich mindestens 90% der Ausgabe.
          @thomas-braun Sorry jetzt aber...
            Homoran Global Moderator Administrators @MyMeyer last edited by
            @mymeyer sagte in npm Fehlermeldung:
              @mymeyer
              Die ganzen
              Einträge deuten auf eine verschobene npm-Struktur hin.
              Installier mal einen der dort genannten Adapter ordentlich, d.h. nicht als GitHub-Installation.
                MyMeyer last edited by Homoran
                @thomas-braun ich habe jetzt mal alle mit Fehler neuinstalliert "nicht über Git". Nun sagt Diag das:
                 2024-11-09 20:41:31.387  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-11-09 20:41:31.387  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                2024-11-09 20:42:01.669  - info: host.iobroker instance system.adapter.blink4home.0 in version "0.1.1" started with pid 3864381
                2024-11-09 20:42:02.189  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.blink4home/main.js:24
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		this.log.debug('begin setup adapter');
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		         ^
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'debug')
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: Node.js v20.18.0
                2024-11-09 20:42:02.190  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-11-09 20:42:02.190  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                2024-11-09 20:42:04.007  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3864665
                2024-11-09 20:42:05.124  - info: labcom.0 (3864665) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
                2024-11-09 20:42:05.132  - info: labcom.0 (3864665) LabCom adapter - started
                2024-11-09 20:42:05.354  - info: labcom.0 (3864665) LabCom adapter - fetching data completed
                2024-11-09 20:42:05.355  - info: labcom.0 (3864665) cleaned everything up...
                2024-11-09 20:42:05.359  - info: labcom.0 (3864665) Terminated (NO_ERROR): Without reason
                2024-11-09 20:42:05.870  - info: host.iobroker instance system.adapter.labcom.0 having pid 3864665 terminated with code 0 (NO_ERROR)
                  @thomas-braun sagte in npm Fehlermeldung:
                  @mymeyer
                  Die ganzen
                  Sach wie kann denn sowas passieren das sich die Struktur verschoben hat ? Habe eigentlich nichts grosses in letzter Zeit gemacht außer die Update. Selbst das deinstallieren von den Adapter geht nicht mehr. Auch manuell nicht.
                  Was kann man jetzt machen ? Neuinstallation ?
                  michael@iobroker:/opt/iobroker$ iob del egigeozone
                  Delete adapter "egigeozone"
                  host.iobroker object egigeozone deleted
                  host.iobroker object egigeozone.admin deleted
                  host.iobroker Deleting 1 object(s).
                  Error deleting adapter egigeozone from disk: Cannot find module 'iobroker.egigeozone/io-package.json'
                  Require stack:
                  - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupInstall.js
                  You might have to delete it yourself!
                    Durch übermäßige Verwendung von GitHub-Installationen...
                    Wie schaut denn nun
                    cd /opt/iobroker && npm ls
                    aus?
                      michael@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
                      [sudo] Passwort f�r michael:
                      iobroker.inst@1.1.2 /opt/iobroker
                      +-- @iobroker-javascript.0/country-list-js@npm:country-list-js@3.1.8
                      +-- @iobroker-javascript.0/exec@npm:exec@0.2.1
                      +-- @iobroker-javascript.0/ffmpeg@npm:ffmpeg@0.0.4
                      +-- @iobroker-javascript.0/fs@npm:fs@0.0.1-security
                      +-- @iobroker-javascript.0/node-hue-api@npm:node-hue-api@5.0.0-beta.16
                      +-- @iobroker-javascript.0/require@npm:require@2.4.20
                      +-- @iobroker-javascript.0/simple-ssh@npm:simple-ssh@1.1.1
                      +-- @iobroker-javascript.0/suncalc@npm:suncalc@1.9.0
                      +-- iobroker.adguard@0.0.8
                      +-- iobroker.admin@7.1.5
                      +-- iobroker.alarm@3.6.2
                      +-- iobroker.alexa2@3.26.5
                      +-- iobroker.alias-manager@1.2.6
                      +-- iobroker.apsystems-ecu@0.2.1 invalid: "github:npeter/ioBroker.apsystems-ecu#9d583384f1d72f0147fde2abcd67d4e9281b7347" from the root project
                      +-- iobroker.backitup@3.0.25
                      +-- iobroker.binance@1.1.3 invalid: "github:Kartax/ioBroker.binance#54f362ef6e0775d7cd696a3dff701e2dd6de2404" from the root project
                      +-- iobroker.bosch-ebike@0.1.7 invalid: "github:TA2k/ioBroker.bosch-ebike" from the root project
                      +-- iobroker.broadlink2@2.3.0
                      +-- iobroker.cloud@5.0.1
                      +-- iobroker.daswetter@3.1.16
                      +-- iobroker.egigeozone2@1.0.6
                      +-- iobroker.energiefluss@3.6.1
                      +-- iobroker.feiertage@1.2.0
                      +-- iobroker.flot@1.12.0
                      +-- iobroker.fritzbox@0.6.0
                      +-- iobroker.fullybrowser@3.0.12
                      +-- iobroker.heatingcontrol@2.12.10
                      +-- iobroker.hm-rega@5.1.0
                      +-- iobroker.hm-rpc@2.0.2
                      +-- iobroker.hue@3.12.0
                      +-- iobroker.ical@1.15.0
                      +-- iobroker.icons-addictive-flavour-png@0.1.0
                      +-- iobroker.icons-fatcow-hosting@0.1.0
                      +-- iobroker.icons-icons8@0.0.1
                      +-- iobroker.icons-material-png@0.1.0
                      +-- iobroker.icons-material-svg@0.1.0
                      +-- iobroker.icons-mfd-png@1.2.1
                      +-- iobroker.icons-mfd-svg@1.2.0
                      +-- iobroker.icons-open-icon-library-png@0.1.2
                      +-- iobroker.icons-ultimate-png@1.0.1
                      +-- iobroker.influxdb@4.0.2
                      +-- iobroker.iot@3.3.0
                      +-- iobroker.javascript@8.8.3
                      +-- iobroker.js-controller@6.0.11
                      +-- iobroker.labcom@0.1.4 invalid: "github:100prznt/ioBroker.labcom#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75" from the root project
                      +-- iobroker.landroid@1.0.3
                      +-- iobroker.lgtv11@1.0.5
                      +-- iobroker.life360@0.2.22 invalid: "github:MiGoller/ioBroker.life360#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1" from the root project
                      +-- iobroker.linkeddevices@1.5.5
                      +-- iobroker.linux-control@1.1.5
                      +-- iobroker.logparser@2.2.2
                      +-- iobroker.mihome-vacuum@4.2.0
                      +-- iobroker.mihome@1.4.0
                      +-- iobroker.modbus@6.3.2
                      +-- iobroker.mqtt@6.1.2
                      +-- iobroker.nina@0.0.25
                      +-- iobroker.nuki-extended@2.7.0
                      +-- iobroker.nuki@2.0.0
                      +-- iobroker.nut@1.6.0
                      +-- iobroker.octoprint@5.1.0
                      +-- iobroker.opendtu@2.0.0
                      +-- iobroker.ph803w@1.2.0
                      +-- iobroker.primelab@1.0.2 invalid: "github:Apollon77/iobroker.primelab#95f1af76d05d464b08b8ee3cb40ceb2b20d778d3" from the root project
                      +-- iobroker.pvforecast@3.0.0
                      +-- iobroker.ring@5.1.0
                      +-- iobroker.scenes@3.2.3
                      +-- iobroker.shelly@8.2.1
                      +-- iobroker.shuttercontrol@1.8.3
                      +-- iobroker.simple-api@2.8.0
                      +-- iobroker.smartcontrol@2.0.1
                      +-- iobroker.socketio@6.7.1
                      +-- iobroker.sonoff@3.1.2
                      +-- iobroker.sourceanalytix@0.4.15-alpha.1 invalid: "github:DrozmotiX/ioBroker.sourceanalytix#fd3b7f9f362a348741cbe18d70a130d2bfee6727" from the root project
                      +-- iobroker.synology@3.1.0
                      +-- iobroker.telegram@3.9.0
                      +-- iobroker.terminal@1.0.0
                      +-- iobroker.tr-064@4.3.0
                      +-- iobroker.tuya@3.16.0
                      +-- iobroker.unifi@0.7.0
                      +-- iobroker.vis-bars@0.1.4
                      +-- iobroker.vis-colorpicker@2.0.3
                      +-- iobroker.vis-fancyswitch@1.1.0
                      +-- iobroker.vis-google-fonts@1.0.4
                      +-- iobroker.vis-hqwidgets@1.5.1
                      +-- iobroker.vis-jqui-mfd@1.1.1
                      +-- iobroker.vis-justgage@2.1.0
                      +-- iobroker.vis-map@1.1.2
                      +-- iobroker.vis-material@0.1.3
                      +-- iobroker.vis-materialdesign@0.5.94 invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                      +-- iobroker.vis-metro@1.2.0
                      +-- iobroker.vis-players@0.1.6
                      +-- iobroker.vis-plumb@1.0.2
                      +-- iobroker.vis-rgraph@0.0.2
                      +-- iobroker.vis-timeandweather@1.2.2
                      +-- iobroker.vis@1.5.6
                      +-- iobroker.wallpanel@0.3.11
                      +-- iobroker.weatherunderground@3.7.0
                      +-- iobroker.web@6.2.5
                      +-- iobroker.wireguard@1.7.0
                      +-- iobroker.wled@0.7.2
                      +-- iobroker.worx@3.1.0 invalid: "github:iobroker-community-adapters/ioBroker.worx" from the root project
                      +-- iobroker.ws@2.6.2
                      +-- iobroker.zigbee@1.10.10 invalid: "github:ioBroker/ioBroker.zigbee#fedc314a875044c84ff790a19dfd42d7373bb61e" from the root project
                      `-- zigbee2mqtt@1.27.0 invalid: "github:Koenkk/zigbee2mqtt#a9b8808237554316c5c97e9d9c990048733779e8" from the root project
                      npm error code ELSPROBLEMS
                      npm error invalid: iobroker.apsystems-ecu@0.2.1 /opt/iobroker/node_modules/iobroker.apsystems-ecu
                      npm error invalid: iobroker.binance@1.1.3 /opt/iobroker/node_modules/iobroker.binance
                      npm error invalid: iobroker.blink4home@0.1.1 /opt/iobroker/node_modules/iobroker.blink4home
                      npm error invalid: iobroker.bosch-ebike@0.1.7 /opt/iobroker/node_modules/iobroker.bosch-ebike
                      npm error invalid: iobroker.broadlink@0.1.5 /opt/iobroker/node_modules/iobroker.broadlink
                      npm error invalid: iobroker.fully-tablet-control@0.3.3-beta.0 /opt/iobroker/node_modules/iobroker.fully-tablet-control
                      npm error invalid: iobroker.labcom@0.1.4 /opt/iobroker/node_modules/iobroker.labcom
                      npm error invalid: iobroker.life360@0.2.22 /opt/iobroker/node_modules/iobroker.life360
                      npm error invalid: iobroker.primelab@1.0.2 /opt/iobroker/node_modules/iobroker.primelab
                      npm error invalid: iobroker.repetierserver@0.0.3 /opt/iobroker/node_modules/iobroker.repetierserver
                      npm error invalid: iobroker.sourceanalytix@0.4.15-alpha.1 /opt/iobroker/node_modules/iobroker.sourceanalytix
                      npm error invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                      npm error invalid: iobroker.worx@3.1.0 /opt/iobroker/node_modules/iobroker.worx
                      npm error invalid: iobroker.zigbee@1.10.10 /opt/iobroker/node_modules/iobroker.zigbee
                      npm error invalid: zigbee2mqtt@1.27.0 /opt/iobroker/node_modules/zigbee2mqtt
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T20_47_47_845Z-debug-0.log
                        @mymeyer
                        Joh...
                        Siehste selber, oder?
                        Installier alle Adapter bei denen das möglich ist eine Version aus einem Repo, NICHT aus GitHub.
                        Warum haste da eigentlich so viel Alpha-Versions-Zeuch drin? Hast du das alles vom Maintainer zum testen gegeben bekommen? Wenn nein, fahr da stabile Versionen.
                          Kann ich dir gar nicht sagen. Habe vor 3 -4 Jahren angefangen mit iob. Da versucht man schon einiges 🙂 Ich werde mir mal die Tage gedanken machen wie ich die Sache angehe.
                          Vielleicht einfach mal bei NULL anfangen und das rüber holen was so geht.
                          Danke Dir erstmal und schönen Abend noch...
                            @mymeyer
                            Sauber muss das so aussehen:
                            echad@chet:~ $ cd /opt/iobroker/ && npm ls
                            (node:50931) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
                            Support for loading ES Module in require() is an experimental feature and might change at any time
                            (Use `node --trace-warnings ...` to show where the warning was created)
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├── iobroker.admin@7.2.6
                            ├── iobroker.alexa2@3.26.7
                            ├── iobroker.alias-manager@2.0.0
                            ├── iobroker.awtrix-light@1.3.0
                            ├── iobroker.backitup@3.0.26
                            ├── iobroker.cloud@5.0.1
                            ├── iobroker.devices@1.1.5
                            ├── iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
                            ├── iobroker.echarts@1.9.2
                            ├── iobroker.firetv@2.1.0
                            ├── iobroker.followthesun@0.5.1
                            ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                            ├── iobroker.govee-local@0.2.7
                            ├── iobroker.history@3.0.1
                            ├── iobroker.ical@1.16.1
                            ├── iobroker.iceroad@1.2.1
                            ├── iobroker.iot@3.4.3
                            ├── iobroker.javascript@8.8.3
                            ├── iobroker.js-controller@7.0.2
                            ├── iobroker.kisshome-research@1.1.1
                            ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                            ├── iobroker.mihome-cloud@0.1.1
                            ├── iobroker.mihome-vacuum@4.2.0
                            ├── iobroker.mihome@1.4.0
                            ├── iobroker.mqtt@6.1.2
                            ├── iobroker.nina@0.0.26
                            ├── iobroker.notification-manager@1.3.0
                            ├── iobroker.nuki-extended@2.7.0
                            ├── iobroker.nuki@2.0.0
                            ├── iobroker.nut@1.6.0
                            ├── iobroker.opendtu@3.0.1
                            ├── iobroker.openweathermap@1.1.2
                            ├── iobroker.parcel@0.2.8
                            ├── iobroker.sainlogic@0.11.4
                            ├── iobroker.samsung_tizen@1.1.0
                            ├── iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
                            ├── iobroker.simple-api@2.8.0
                            ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                            ├── iobroker.tado@0.6.1
                            ├── iobroker.tankerkoenig@3.4.0
                            ├── iobroker.tr-064@4.3.0
                            ├── iobroker.tradfri@3.1.3
                            ├── iobroker.trashschedule@3.4.0
                            ├── iobroker.tuya@3.16.0
                            ├── iobroker.weather-warnings@0.6.7
                            ├── iobroker.web@6.3.1
                            ├── iobroker.whatsapp-cmb@0.3.0
                            └── iobroker.zigbee@1.10.12
                            echad@chet:/opt/iobroker $
                            Adapter aus dem GitHub sind nicht invalid und es gibt lediglich Einträge in der Form iobroker.adaptername@1.2.3
                            install install adapter update npm err
                            574
