    4. Homematic IP Cloud Adapter lässt sich nicht installieren
      lukas8519 @Homoran last edited by
      @homoran jaa
        Homoran Global Moderator Administrators @lukas8519 last edited by Homoran
        @lukas8519 dann bitte
        curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        chmod 744 iob_diag.sh
        ./iob_diag.sh
        ausführen
          Copy text starting here:
          ```bash
                                  v.2024-10-26 Raspbian
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.15.61-v8+
                Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     320
          Pending iob updates:    40
          Nodejs-Installation:
          nodejs:                 N/A
          /usr/bin/node           v16.19.0
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          /usr/bin/corepack       0.15.1
          Recommended versions are nodejs 20.18.0 and npm 10.8.2
          *** nodejs is NOT correctly installed ***
          Wrong installation path detected. This needs to be fixed.
          Please execute
          iob nodejs-update
          to fix these errors.
          MEMORY:
          Mem:            3.8G        510M        1.8G         35M        1.5G        3.3G
          Swap:            99M        1.0M         98M
          Total:          3.9G        511M        1.9G
          Active iob-Instances:   1
          Active repo(s): stable
          ioBroker Core:          js-controller           4.0.24
                                  admin                   7.1.5
          ioBroker Status:        iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                25596
          States:                 20358
          Size of iob-Database:
          21M     /opt/iobroker/iobroker-data/objects.jsonl
          5.9M    /opt/iobroker/iobroker-data/states.jsonl
          Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
          === Mark text until here for copying ===
          Thomas Braun L 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @lukas8519 last edited by
            @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
            Hatte ich mir schon gedacht, das da allgemeiner Update-Stau herrscht...
            iob stop
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Wenn die Kiste wieder greifbar ist:
            iob update
            iob upgrade
            iob stop
            iob upgrade self
            iob update
            iob upgrade
            iob nodejs-update
              lukas8519 @lukas8519 last edited by
              @lukas8519
              jetzt kommt das
              lukas@iobroker:/opt/iobroker $ iob stop
              lukas@iobroker:/opt/iobroker $ sudo apt update
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
              Get:5 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
              Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
              Err:5 https://repos.influxdata.com/debian stretch InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              Err:6 https://packages.grafana.com/oss/deb stable InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
              Reading package lists... Done
              W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
              lukas@iobroker:/opt/iobroker $ sudo apt full-upgrade
              Building dependency tree... Done
              Calculating upgrade... Done
              The following packages were automatically installed and are no longer required:
                libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
              Use 'sudo apt autoremove' to remove them.
              The following NEW packages will be installed:
                kms++-utils raspi-utils
              The following packages will be upgraded:
                adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez
                bluez-firmware bsdextrautils bsdutils chromium-browser chromium-browser-l10n
                chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client cups-common
                cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils
                cups-ppdc cups-server-common dbus dbus-user-session dbus-x11 debian-archive-keyring
                dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject exfatprogs fdisk
                ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
                firmware-realtek ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git
                git-man gldriver-test grafana grep gstreamer1.0-alsa gstreamer1.0-plugins-bad
                gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0
                libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev
                libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7
                libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin
                libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev libcamera-apps
                libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0
                libexpat1 libexpat1-dev libext2fs2 libfdisk1 libflac8 libfontembed1 libgbm1
                libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
                libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common
                libgssapi-krb5-2 libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
                libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0
                libkrb5-3 libkrb5support0 libksba8 liblapack3 libmagic-mgc libmagic1 libmount-dev
                libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1 libnghttp2-14
                libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55
                libprotobuf-lite23 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5
                libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5widgets5 libqt5xml5
                libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient
                libsqlite3-0 libss2 libssh-gcrypt-4 libssh2-1 libssl1.1 libswresample3 libswscale5
                libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1 libuuid1
                libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0
                libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev
                libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev locales logrotate logsave
                lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers
                mesa-vdpau-drivers mount mutter mutter-common nano ncurses-base ncurses-bin ncurses-term
                net-tools nfs-common nftables nodejs ntfs-3g openssh-client openssh-server
                openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt
                python3-cryptography python3-flask python3-idna python3-kms++ python3-libcamera
                python3-picamera2 python3-pil python3-pkg-resources python3-renderpm python3-reportlab
                python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel
                raspberrypi-sys-mods raspberrypi-ui-mods raspi-config raspinfo realvnc-vnc-server rfkill
                rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd systemd-sysv
                systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data
                vlc-l10n vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
                vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter
                vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core xwayland
              321 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
              Need to get 212 MB/700 MB of archives.
              After this operation, 539 MB of additional disk space will be used.
              Do you want to continue? [Y/n] y
              Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 kms++-utils arm64 0~git20221104~171243+adc05b6-1 [81.4 kB]
              Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspinfo all 20230123-1 [2,564 B]
              Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-utils arm64 20230123-1 [41.8 kB]
              Err:4 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 10.1.0
                404  Not Found [IP: 2a04:4e42:9::729 443]
              Fetched 126 kB in 0s (422 kB/s)
              E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_10.1.0_arm64.deb  404  Not Found [IP: 2a04:4e42:9::729 443]
              E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                das ist ja Steinzeit
                wie alt ist die Installation?
                  Halte deine Kiste immer auf einem aktuellen Stand...
                  Die hat noch nie ein Update gesehen. Davon ab betreibt man auch keine graphische Oberfläche auf einem Server.
                  Was willste mit vlc auf dem Ding?
                  Richte grafana und influx neu ein:
                  https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                    lukas8519 @Thomas Braun last edited by
                    ja die ist schon älter und ich habe tatsächlich nicht viel daran gemacht.
                    Und Grafana benutze ich auch schon lange nicht mehr ...
                    was sind denn nun die extenziell wichtigen schritte?
                    sorry für meine Unwissenheit
                      Die habe ich dir schon geschrieben.
                        @Homoran, @Thomas-Braun,
                        ich bin nun wieder up to date und alles läuft, inklusive der HmIP Installation.
                        Ich danke euch für euern Support und eure Geduld.
                        Danke das Ihr durch euer Engagement auch Leuten wie mir helft sich ein wenig zu recht zu finden und am Iobroker teil haben zu können!
                        Danke!
                          @lukas8519
                          Dann lass jetzt mal die Langfassung von
                          iob diag
                          sehen.
                                                    v.2024-10-19
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            Pending OS-Updates:     0
                            Pending iob updates:    28
                            This system needs to be REBOOTED NOW!
                            /usr/bin/nodejs         v20.18.0
                            /usr/bin/node           v20.18.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.3
                            nodeJS installation is correct
                            MEMORY:
                            Mem:            3.8G        2.4G        412M         35M        964M        1.2G
                            Swap:            99M         56M         43M
                            Total:          3.9G        2.5G        456M
                            Active iob-Instances:   31
                            Upgrade policy: none
                            ioBroker Core:          js-controller           6.0.11
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                26089
                            States:                 20688
                            24M     /opt/iobroker/iobroker-data/objects.jsonl
                            37M     /opt/iobroker/iobroker-data/states.jsonl
                            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                              Thomas Braun Most Active @lukas8519 last edited by Thomas Braun
                              @lukas8519
                              Ich wollte die Langfassung sehen, nicht die Zusammenfassung.
                              Nach einem REBOOT:
                                @thomas-braun habs gemerkt, moment
                                  @lukas8519
                                  Und das bringst du auch auf 0:
                                    um die letzten 6 Updates kümmere ich mich morgen.
                                    ========== Start marking the full check here ===========
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    OS is similar to:
                                    Model           : Raspberry Pi 4 Model B Rev 1.1
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    Systemuptime and Load:
                                     00:18:01 up 4 min,  2 users,  load average: 3.97, 2.63, 1.17
                                    CPU threads: 4
                                    *** LIFE CYCLE STATUS ***
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Sun 2024-11-10 00:18:01 CET
                                               Universal time: Sat 2024-11-09 23:18:01 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    lukas
                                    HOME=/home/lukas
                                    GROUPS=lukas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                    *** DISPLAY-SERVER SETUP ***
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        2.0G        821M        1.0M        943M        1.7G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.0G        921M
                                             3794 M total memory
                                             2028 M used memory
                                             2408 M active memory
                                              415 M inactive memory
                                              821 M free memory
                                               71 M buffer memory
                                              872 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    top - 00:18:02 up 4 min,  2 users,  load average: 3.73, 2.60, 1.17
                                    Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  9.7 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3794.3 total,    821.5 free,   2028.4 used,    944.4 buff/cache
                                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1681.2 avail Mem
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** DMESG CRITICAL ERRORS ***
                                    No critical errors detected
                                    *** FILESYSTEM ***
                                    /dev/root      ext4      235G   14G  212G   6% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                    [Sun Nov 10 00:13:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Sun Nov 10 00:13:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sun Nov 10 00:13:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sun Nov 10 00:13:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    4.8G    /var/
                                    3.7G    /var/log
                                    3.6G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                                    739M    /var/cache
                                    Archived and active journals take up 3.5G in the file system.
                                    /opt/iobroker/backups:
                                    1.7G    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    548M    /opt/iobroker/iobroker-data/
                                    402M    /opt/iobroker/iobroker-data/files
                                    80M     /opt/iobroker/iobroker-data/backup-objects
                                    67M     /opt/iobroker/iobroker-data/files/echarts.admin
                                    61M     /opt/iobroker/iobroker-data/files/echarts
                                    38M     /opt/iobroker/iobroker-data/states.jsonl
                                    28M     /opt/iobroker/iobroker-data/objects.jsonl
                                    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Installed: 20.18.0-1nodesource1
                                      Candidate: 20.18.0-1nodesource1
                                      Version table:
                                     *** 20.18.0-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u5 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 289)
                                    Core adapters versions
                                    js-controller:  6.0.11
                                    admin:          7.1.5
                                    javascript:     7.8.0
                                    nodejs modules from github:     1
                                    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                                    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                                    + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                    + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
                                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
                                    + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                                      system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
                                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                    + instance is alive
                                    ioBroker-Repositories
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                    Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
                                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                    Adapter    "countdown"    : 2.3.0    , installed 2.3.0
                                    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                    Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
                                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                    Adapter    "fullybrowser" : 3.0.12   , installed 2.1.1  [Updatable]
                                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                    Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                                    Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                                    Adapter    "hue"          : 3.12.0   , installed 3.12.0
                                    Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                    Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
                                    Controller "js-controller": 6.0.11   , installed 6.0.11
                                    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                    Adapter    "rpi2"         : 2.2.1    , installed 1.3.1  [Updatable]
                                    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                    Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                    Objects and States
                                    Objects:        26237
                                    States:         20884
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                                    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                                    Hit:7 https://apt.grafana.com stable InRelease
                                    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        12227      623/influxd
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1818       581/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15599      914/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15605      914/iobroker.js-con
                                    tcp        0      0 192.168.178.92:42011    0.0.0.0:*               LISTEN      1001       15855      1203/io.hm-rpc.1
                                    tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15823      1184/io.hm-rpc.0
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14199      545/cupsd
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      116        16444      623/influxd
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18905      1797/io.simple-api.
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17521      1029/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18296      1731/io.web.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          1820       581/sshd: /usr/sbin
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14198      545/cupsd
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        15592      913/grafana
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14656      476/dhcpcd
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16054      1334/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16055      1334/io.tuya.0
                                    udp        0      0 0.0.0.0:35422           0.0.0.0:*                           108        14136      401/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14134      401/avahi-daemon: r
                                    udp6       0      0 :::41151                :::*                                108        14137      401/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          14697      476/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        14135      401/avahi-daemon: r
                                    2024-11-10 00:19:17.540  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:17.541  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:17.542  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:17.597  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:21.597  - info: alexa2.0 (1139) Subscribing to states...
                                    2024-11-10 00:19:21.608  - info: alexa2.0 (1139) Deleting the following states: ["Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7","Smart-Home-Devices.003aedb7-567e-4c34-a57c-a07ff842976c.#query","Smart-Home-Devices.012f1123-14fe-45de-b7ad-e96d7d2418f5.#query","Smart-Home-Devices.0373ad50-6d67-4d7d-8cf1-25c5ca3a8a6f.#query","Smart-Home-Devices.0558f2c7-04f3-466b-bc3d-5eeb9537fc83.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#delete","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#enabled","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.active","Smart-Home-Devices.0a175031-bd4e-467f-bcf7-a317bfc179eb.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#delete","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#enabled","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity-reason","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.powerState","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#delete","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#enabled","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#query","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-hue","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-saturation","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorRgb","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureInKelvin","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity-reason","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.powerState","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#delete","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#enabled","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#query","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity-reason","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.powerState","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#delete","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#enabled","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#query","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.active","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#delete","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#enabled","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#query","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.brightness","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity-reason","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.powerState","Smart-Home-Devices.196e2f4f-23ff-4419-9398-55823800ccae.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#delete","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#enabled","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-hue","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-saturation","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorRgb","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureInKelvin","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.powerState","Smart-Home-Devices.1eaa8074-65f2-4b2f-8aa0-18a0bd21252a.#query","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#delete","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#enabled","Smart-Home-Devices.2ad5f69c-0316-4394-b033-ea4f1d17a11a.#query","Smart-Home-Devices.2b7f4876-d82c-42d6-b302-20a0ae5d5d39.#query","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#delete","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#enabled","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#query","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-hue","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-saturation","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorRgb","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureInKelvin","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.powerState","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#delete","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#enabled","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#query","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-hue","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-saturation","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorName","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorRgb","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity-reason","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.powerState","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#delete","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#enabled","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#query","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-hue","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-saturation","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorRgb","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureInKelvin","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.powerState","Smart-Home-Devices.3ac22223-0447-4d99-b624-1ed607a5848f.#query","Smart-Home-Devices.414afebe-9a0c-4dfb-a60d-d69324daa9ba.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#delete","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#enabled","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity-reason","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.powerState","Smart-Home-Devices.41d1bfc2-f0c9-41f5-993d-7f3090c0c015.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#delete","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#enabled","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity-reason","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.powerState","Smart-Home-Devices.45734c42-2ddc-4bdb-b4fb-053417c9fb29.#query","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#delete","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#enabled","Smart-Home-Devices.4843643a-6b91-48c5-9b27-21b8f1354a6d.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#delete","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#enabled","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.active","Smart-Home-Devices.4ffbe9f1-4adc-45e2-b00c-1d5cbb171c6f.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#delete","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#enabled","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.powerState","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#delete","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#enabled","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.powerState","Smart-Home-Devices.5b3e8fe1-a2e8-47fc-ac3f-9ae3e3715a59.#query","Smart-Home-Devices.60abe88c-de46-42fb-93a6-a84fbc400e20.#query","Smart-Home-Devices.62173163-c184-4f87-9284-60cb53677d3b.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#delete","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#enabled","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity-reason","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.powerState","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#delete","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#enabled","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#query","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.powerState","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#delete","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#enabled","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#query","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity-reason","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.powerState","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#delete","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#enabled","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#query","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-hue","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-saturation","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorRgb","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureInKelvin","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity-reason","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.powerState","Smart-Home-Devices.7ccaaf08-b038-4713-b431-eeb8500c3790.#query","Smart-Home-Devices.81d78b2e-d706-4162-84cf-44c8e38310da.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#delete","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#enabled","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity-reason","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.powerState","Smart-Home-Devices.888412a0-610a-46d4-9f2b-d260c44ab80b.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#delete","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#enabled","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.active","Smart-Home-Devices.8d73aba0-1cb0-40fd-aca7-a4aae639b1eb.#query","Smart-Home-Devices.92fa9139-72ae-4950-939f-264e9edd93d6.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#delete","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#enabled","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity-reason","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.powerState","Smart-Home-Devices.97fd57e9-16e9-471c-ba20-4629356240d2.#query","Smart-Home-Devices.9a0904f8-5dbe-469e-8b8d-e90d23494a36.#query","Smart-Home-Devices.9f34de1c-8ae8-4308-8d38-c4ac8270c1ad.#query","Smart-Home-Devices.a25e4279-c22e-44ca-b75a-54a54f0b2e3d.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#delete","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#enabled","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.active","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#delete","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#enabled","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#query","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.detectionState","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#delete","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#enabled","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#query","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity-reason","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.powerState","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#delete","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#enabled","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#query","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-hue","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-saturation","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorRgb","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureInKelvin","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity-reason","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.powerState","Smart-Home-Devices.b9aa977c-7173-4465-bc76-9bb35ea78a15.#query","Smart-Home-Devices.bdc08478-6398-4a62-8104-a87e3e841e8b.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#delete","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#enabled","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.active","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#delete","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#enabled","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#query","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity-reason","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.powerState","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#delete","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#enabled","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#query","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity-reason","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.powerState","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#delete","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#enabled","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity-reason","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.powerState","Smart-Home-Devices.c6b5fe24-e2e3-43a5-9625-1f3de08a9117.#query","Smart-Home-Devices.c7767a90-9305-4ad8-a194-b8d11cf068d5.#query","Smart-Home-Devices.c911652c-82d7-47ac-9148-b693698cd15c.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#delete","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#enabled","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity-reason","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.powerState","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#delete","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#enabled","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#query","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.detectionState","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#delete","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#enabled","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#query","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-hue","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-saturation","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorName","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorRgb","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity-reason","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.powerState","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#delete","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#enabled","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#query","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity-reason","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.detectionState","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#delete","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#enabled","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#query","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-hue","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-saturation","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorName","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorRgb","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity-reason","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.powerState","Smart-Home-Devices.d31fdee0-9261-45b2-b762-7601510e5bfa.#query","Smart-Home-Devices.d4c058d6-1454-4364-8044-024fa2b9015b.#query","Smart-Home-Devices.d567e065-a853-4cdb-90fa-637e858dba16.#query","Smart-Home-Devices.d735eab4-e4d9-4e27-9422-c66a413a945d.#query","Smart-Home-Devices.da69e1db-05a1-46b4-8113-b856e832d92a.#query","Smart-Home-Devices.e150b646-c923-4c38-8cd9-2d7dab656b06.#query","Smart-Home-Devices.e198978a-397d-431e-a5c3-014ba600f4b1.#query","Smart-Home-Devices.e2af59b6-6e34-4109-80aa-72e4c9c9531c.#query","Smart-Home-Devices.e4bb56f4-7aa9-447c-8f7b-e4594561ede3.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#delete","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#enabled","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.brightness","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity-reason","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.powerState","Smart-Home-Devices.e6371aa7-760a-4134-bd48-64a0534aa373.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#delete","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#enabled","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity-reason","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.powerState","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#delete","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#enabled","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#query","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity-reason","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.powerState","Smart-Home-Devices.e7b8b085-a5bb-43c9-b058-4f2906769370.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#delete","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#enabled","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-hue","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-saturation","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorRgb","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureInKelvin","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.powerState","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#delete","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#enabled","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#query","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.active","Smart-Home-Devices.e82d4546-299a-4161-b46e-61433fe3ccca.#query","Smart-Home-Devices.e98459e4-06bb-45dd-b5c3-84a2dcba87ff.#query","Smart-Home-Devices.e9bdc49a-b74d-4a31-99fc-7685187590d9.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#delete","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#enabled","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity-reason","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.powerState","Smart-Home-Devices.ead6cf64-5555-4eeb-8861-258621a8d286.#query","Smart-Home-Devices.f0cb5405-3842-4b18-9863-5c031c74a409.#query","Smart-Home-Devices.f3dcc4b4-74eb-45b4-b677-62bd5dbcaa46.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#delete","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#enabled","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-hue","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-saturation","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorRgb","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureInKelvin","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity-reason","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.powerState","Smart-Home-Devices.f7648592-a2b4-4556-8985-53006fce51a7.#query","Smart-Home-Devices.f87eec87-46b6-4cd2-a389-b2407b1229c9.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#delete","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#enabled","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.active","Smart-Home-Devices.fb458fac-5057-47bb-a16c-0e195adfc1c0.#query","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#delete","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#enabled","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.powerState","Smart-Home-Devices.fe7d453e-663d-4092-9069-91ad6c11169e.#query","Smart-Home-Devices.ff1203b1-c4be-4892-aef1-9c7a3aa0d40e.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#includeInAllQuery","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#includeInAllQuery","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#includeInAllQuery","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#includeInAllQuery","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#includeInAllQuery","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#includeInAllQuery","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#includeInAllQuery","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#includeInAllQuery","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#includeInAllQuery","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#includeInAllQuery","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#includeInAllQuery","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#includeInAllQuery","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#includeInAllQuery","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#includeInAllQuery","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#includeInAllQuery","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#includeInAllQuery","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#includeInAllQuery","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#includeInAllQuery","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#includeInAllQuery","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#includeInAllQuery","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#includeInAllQuery","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#includeInAllQuery","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#includeInAllQuery","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#includeInAllQuery","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#includeInAllQuery","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#includeInAllQuery","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#includeInAllQuery","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#includeInAllQuery","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#includeInAllQuery","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.humanPresenceDetectionState","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#query","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#includeInAllQuery","Smart-Home-Devices.2deb04a8-7e12-4a66-b6f1-8b24bf3caa95.humanPresenceDetectionState","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity-reason","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity-reason","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity-reason","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity-reason","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity-reason","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity-reason","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#enabled","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#delete","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.powerState","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureInKelvin","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-hue","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-saturation","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorRgb","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#query","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#includeInAllQuery","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#enabled","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#delete","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.powerState","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.brightness","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity-reason","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#query","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#includeInAllQuery","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#enabled","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#delete","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.powerState","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorName","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-hue","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-saturation","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorRgb","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity-reason","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#query","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#includeInAllQuery","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#enabled","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#delete","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.powerState","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureInKelvin","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-hue","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-saturation","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorRgb","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity-reason","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#query","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#includeInAllQuery","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#enabled","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#delete","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.powerState","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorName","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-hue","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-saturation","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorRgb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity-reason","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#query","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#includeInAllQuery"]
                                    2024-11-10 00:19:23.423  - info: alexa2.0 (1139) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                    2024-11-10 00:19:25.809  - warn: bring.0 (1451) Error on login: Cannot Login: 401 - "{\"message\":\"email password combination not existing\",\"error\":\"unauthorized\",\"error_description\":\"Not authorized to access this resource\",\"errorcode\":200}"
                                    2024-11-10 00:19:25.809  - info: bring.0 (1451) [LOGIN] Reconnection in 30 seconds
                                    2024-11-10 00:19:26.829  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.833  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.837  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.839  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.858  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.860  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.862  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:26.876  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.243  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.302  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.349  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.350  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.409  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.410  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.434  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                    2024-11-10 00:19:27.441  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                      @Homoran @Thomas-Braun
                                      könnt ihr mir nochmal helfen?
                                      ich habe in JS meine Blocklys angepasst und dann aus Unwissenheit irgendwas "DEBUG ...." oben über die Menüleiste gestartet.
                                      Jetzt ist es so das alles läuft, ich aber nicht mehr über den Browser zum Iobroker komme...
                                      danke
                                        @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                                        iob diag
                                        anschauen.
                                          Homoran Global Moderator Administrators @lukas8519 last edited by
                                          im Javascript editor?
                                          inkognito versuchen
                                            Script v.2024-10-19
                                            *** BASE SYSTEM ***
                                               Static hostname: iobroker
                                                     Icon name: computer
                                              Operating System: Debian GNU/Linux 11 (bullseye)
                                                  Architecture: arm64
                                            OS is similar to:
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : 64 bit
                                             15:05:24 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                            CPU threads: 4
                                            Current issues:
                                                           Local time: Sun 2024-11-10 15:05:24 CET
                                                       Universal time: Sun 2024-11-10 14:05:24 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            lukas
                                            HOME=/home/lukas
                                            iobroker
                                            HOME=/home/iobroker
                                            Display-Server: false
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.8G        2.1G        695M        1.0M        1.0G        1.6G
                                            Swap:            99M          0B         99M
                                            Total:          3.9G        2.1G        795M
                                            Active iob-Instances:   29
                                                     3794 M total memory
                                                     2095 M used memory
                                                     2434 M active memory
                                                      483 M inactive memory
                                                      695 M free memory
                                                      101 M buffer memory
                                                      901 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            top - 15:05:25 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                            Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3794.3 total,    695.1 free,   2096.1 used,   1003.1 buff/cache
                                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1621.6 avail Mem
                                            *** FILESYSTEM ***
                                            /dev/root      ext4      235G   15G  211G   7% /
                                            [Sun Nov 10 14:45:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                            [Sun Nov 10 14:45:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [Sun Nov 10 14:45:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [Sun Nov 10 14:45:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                            /var:
                                            4.8G    /var/
                                            3.7G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                                            3.7G    /var/log
                                            739M    /var/cache
                                            Archived and active journals take up 3.6G in the file system.
                                            4.0K    /opt/iobroker/backups/influxDB_2024_11_10-01_00_25_backupiobroker
                                            1.1G    /opt/iobroker/iobroker-data/
                                            963M    /opt/iobroker/iobroker-data/files
                                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                            33M     /opt/iobroker/iobroker-data/objects.jsonl
                                            28M     /opt/iobroker/iobroker-data/states.jsonl
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                              Version table:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Hosts:
                                            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1200)
                                            admin:          7.1.5
                                            javascript:     8.8.3
                                            Adapter State
                                              system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                              system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
                                            + instance is alive
                                            Active repo(s): stable
                                            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                            Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                                            Objects and States
                                            Objects:        26218
                                            States:         20791
                                            Reading package lists...
                                            Pending Updates: 0
                                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15664      622/influxd
                                            tcp        0      0 192.168.178.92:42010    0.0.0.0:*               LISTEN      1001       16648      1142/io.hm-rpc.1
                                            tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15188      1127/io.hm-rpc.0
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      885/iobroker.js-con
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14947      885/iobroker.js-con
                                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13826      536/cupsd
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12059      576/sshd: /usr/sbin
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18349      1729/io.web.0
                                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17391      1974/io.simple-api.
                                            tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      622/influxd
                                            tcp6       0      0 :::3000                 :::*                    LISTEN      117        16489      884/grafana
                                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13825      536/cupsd
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12061      576/sshd: /usr/sbin
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16172      1218/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16173      1218/io.tuya.0
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12001      403/avahi-daemon: r
                                            udp        0      0 0.0.0.0:50606           0.0.0.0:*                           108        12003      403/avahi-daemon: r
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12134      467/dhcpcd
                                            udp6       0      0 :::546                  :::*                                0          12212      467/dhcpcd
                                            udp6       0      0 :::5353                 :::*                                108        12002      403/avahi-daemon: r
                                            udp6       0      0 :::49079                :::*                                108        12004      403/avahi-daemon: r
                                            2024-11-10 15:06:16.682  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.068  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.071  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.081  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.129  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.585  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.586  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.589  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.590  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.591  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.626  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.627  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.628  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:26.933  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.053  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.099  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.102  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.104  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            2024-11-10 15:06:27.122  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                            1438
