    4. Test Adapter iobroker.Zigbee 1.10.10
      Shadowhunter23 @Neuschwansteini last edited by
      @ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
      @amg_666
      Bei mir läuft der zigbee Adapter 1.10.12 mit js-Controller 7.0.2
      Bei mir auch, bisher keine Probleme.
      • amg_666
        amg_666 @Neuschwansteini last edited by
        @ilovegym
        Also bei mir ist 1.10.3 installiert, das Update auf 1.10.12 über admin oberfläche läuft durch und dann kommen jede Menge Fehler im Log und die Instanz bleibt rot.
        Habs jetzt grade nochmal probiert:
        host.iobroker
        	2024-11-06 21:15:11.538	info	instance system.adapter.ical.3 having pid 150600 terminated with code 0 (NO_ERROR)
        host.iobroker
        	2024-11-06 21:15:00.055	info	instance system.adapter.ical.3 in version "1.16.1" started with pid 150600
        host.iobroker
        	2024-11-06 21:14:49.552	info	Restart adapter system.adapter.zigbee.2 because enabled
        host.iobroker
        	2024-11-06 21:14:49.551	error	instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[5]: at processImmediate (node:internal/timers:485:21)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[5]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:305:29)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[5]: at Array.forEach (<anonymous>)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[5]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:309:51
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[5]: TypeError: Cannot read properties of undefined (reading 'deleteDeviceStates')
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[4]: at processImmediate (node:internal/timers:485:21)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[4]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:293:47)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[4]: TypeError: Cannot read properties of undefined (reading 'updateState')
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[3]: at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[3]: at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        host.iobroker
        	2024-11-06 21:14:49.551	error	Caught by controller[3]: at ClientRequest.emit (node:domain:488:12)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at ClientRequest.emit (node:events:531:35)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at Object.onceWrapper (node:events:634:26)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/follow-redirects/index.js:91:12)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at RedirectableRequest._processResponse (/opt/iobroker/node_modules/follow-redirects/index.js:398:10)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at RedirectableRequest.emit (node:domain:488:12)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at RedirectableRequest.emit (node:events:519:28)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at RedirectableRequest.handleResponse (/opt/iobroker/node_modules/axios/lib/adapters/http.js:547:9)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[3]: AxiosError: Request failed with status code 404
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[1]: TICMeter: Exposes: No endpoint
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[0]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[0]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
        host.iobroker
        	2024-11-06 21:14:49.550	error	Caught by controller[0]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
        zigbee.2
        	2024-11-06 21:14:49.369	error	Cannot read properties of undefined (reading 'deleteDeviceStates')
        zigbee.2
        	2024-11-06 21:14:49.369	error	TypeError: Cannot read properties of undefined (reading 'deleteDeviceStates') at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:309:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:305:29) at processImmediate (node:internal/timers:485:21)
        zigbee.2
        	2024-11-06 21:14:49.369	error	uncaught exception: Cannot read properties of undefined (reading 'deleteDeviceStates')
        zigbee.2
        	2024-11-06 21:14:49.305	error	Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.305	error	TypeError: Cannot read properties of undefined (reading 'updateState') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:293:47) at processImmediate (node:internal/timers:485:21)
        zigbee.2
        	2024-11-06 21:14:49.305	error	uncaught exception: Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.303	error	Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.303	error	TypeError: Cannot read properties of undefined (reading 'updateState') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:293:47) at processImmediate (node:internal/timers:485:21)
        zigbee.2
        	2024-11-06 21:14:49.303	error	uncaught exception: Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.298	error	Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.298	error	TypeError: Cannot read properties of undefined (reading 'updateState') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:293:47) at processImmediate (node:internal/timers:485:21)
        zigbee.2
        	2024-11-06 21:14:49.297	error	uncaught exception: Cannot read properties of undefined (reading 'updateState')
        zigbee.2
        	2024-11-06 21:14:49.187	info	Zigbee: disabling joining new devices.
        zigbee.2
        	2024-11-06 21:14:49.183	info	cleaned everything up...
        zigbee.2
        	2024-11-06 21:14:49.168	error	Exception-Code: ERR_BAD_REQUEST: Request failed with status code 404
        zigbee.2
        	2024-11-06 21:14:49.168	error	AxiosError: Request failed with status code 404 at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12) at RedirectableRequest.handleResponse (/opt/iobroker/node_modules/axios/lib/adapters/http.js:547:9) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:488:12) at RedirectableRequest._processResponse (/opt/iobroker/node_modules/follow-redirects/index.js:398:10) at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/follow-redirects/index.js:91:12) at Object.onceWrapper (node:events:634:26) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:488:12) at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5)
        zigbee.2
        	2024-11-06 21:14:49.168	error	unhandled promise rejection: Request failed with status code 404
        zigbee.2
        	2024-11-06 21:14:49.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.2
        	2024-11-06 21:14:49.045	info	debug devices set to []
        zigbee.2
        	2024-11-06 21:14:48.952	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
        zigbee.2
        	2024-11-06 21:14:48.905	info	Zigbee started
        zigbee.2
        	2024-11-06 21:14:48.904	info	0xa4c13857375d7b75 (addr 44818): TS0502B - Tuya Light controller (Router)
        zigbee.2
        	2024-11-06 21:14:48.904	info	0x804b50fffe20319a (addr 29559): E1746 - IKEA TRADFRI signal repeater (Router)
        zigbee.2
        	2024-11-06 21:14:48.903	info	0x00158d000232cbea (addr 22263): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.903	info	0xa4c138ff5d8ed635 (addr 14773): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:48.902	info	0x842e14fffe163f01 (addr 21016): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.901	info	0xa4c138fb6312d1ea (addr 49596): L1(ZW) - Tuya Light dimmer 0-10V (Router)
        zigbee.2
        	2024-11-06 21:14:48.900	info	0x00158d0006d50943 (addr 15532): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.900	info	0x00158d0006e49411 (addr 24941): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.899	info	0x00158d0006d667b4 (addr 37207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.899	info	0x00158d0006e3bb69 (addr 60535): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.899	info	0x00124b00234cdf26 (addr 54690): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:48.898	info	0x84fd27fffecf6567 (addr 53920): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
        zigbee.2
        	2024-11-06 21:14:48.897	info	0x00158d00024905e0 (addr 31049): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.896	info	0xa4c13896f124a5e3 (addr 45147): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:48.895	info	0xbc33acfffe8663a9 (addr 4579): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.894	info	0x54ef44100025ce21 (addr 5858): MCCGQ14LM - Aqara Door and window sensor E1 (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.894	info	0x84fd27fffe9b5e43 (addr 13249): E1746 - IKEA TRADFRI signal repeater (Router)
        zigbee.2
        	2024-11-06 21:14:48.893	info	0xa4c138442eb7c935 (addr 6635): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:48.891	info	0x00158d00024375aa (addr 74): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.891	info	0x00158d000232979b (addr 4151): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.890	info	0x04cf8cdf3c7d7c69 (addr 20132): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.889	info	0x04cf8cdf3c7dcc26 (addr 29290): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.888	info	0x5c0272fffe96fa2a (addr 7999): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
        zigbee.2
        	2024-11-06 21:14:48.886	info	0x00124b00234c6ba9 (addr 60438): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:48.886	info	0x00124b00235279d6 (addr 3321): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:48.885	info	0x00124b0023528715 (addr 35049): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:48.883	info	0x54ef44100017a66e (addr 57020): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.883	info	0x842e14fffe602b98 (addr 14854): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.881	info	0xa4c1388e4fb7d6d8 (addr 59225): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
        zigbee.2
        	2024-11-06 21:14:48.877	info	0x54ef4410001c5ee0 (addr 4247): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:48.813	info	Currently 30 devices are joined:
        zigbee.2
        	2024-11-06 21:14:48.665	info	--> transmitPower : high+
        zigbee.2
        	2024-11-06 21:14:48.655	info	Unable to disable LED, unsupported function.
        zigbee.2
        	2024-11-06 21:14:48.654	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
        zigbee.2
        	2024-11-06 21:14:47.125	info	Installed Version: iobroker.zigbee@1.10.12
        zigbee.2
        	2024-11-06 21:14:46.876	info	Starting Zigbee npm ...
        zigbee.2
        	2024-11-06 21:14:46.874	info	delete old Backup files. keep only last 10
        zigbee.2
        	2024-11-06 21:14:46.801	info	starting. Version 1.10.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 7.0.2
        host.iobroker
        	2024-11-06 21:14:43.672	info	instance system.adapter.zigbee.2 in version "1.10.12" started with pid 150585
        host.iobroker
        	2024-11-06 21:14:13.049	info	Restart adapter system.adapter.zigbee.2 because enabled
        host.iobroker
        	2024-11-06 21:14:13.049	error	instance system.adapter.zigbee.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at ClientRequest.emit (node:domain:488:12)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at ClientRequest.emit (node:events:531:35)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at Object.onceWrapper (node:events:634:26)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/follow-redirects/index.js:91:12)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at RedirectableRequest._processResponse (/opt/iobroker/node_modules/follow-redirects/index.js:398:10)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at RedirectableRequest.emit (node:domain:488:12)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at RedirectableRequest.emit (node:events:519:28)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at RedirectableRequest.handleResponse (/opt/iobroker/node_modules/axios/lib/adapters/http.js:547:9)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)
        host.iobroker
        	2024-11-06 21:14:13.049	error	Caught by controller[2]: AxiosError: Request failed with status code 404
        host.iobroker
        	2024-11-06 21:14:13.048	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        host.iobroker
        	2024-11-06 21:14:13.048	error	Caught by controller[1]: TICMeter: Exposes: No endpoint
        host.iobroker
        	2024-11-06 21:14:13.048	error	Caught by controller[0]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
        host.iobroker
        	2024-11-06 21:14:13.048	error	Caught by controller[0]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
        host.iobroker
        	2024-11-06 21:14:13.048	error	Caught by controller[0]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
        zigbee.2
        	2024-11-06 21:14:12.401	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.2
        	2024-11-06 21:14:12.401	info	terminating
        zigbee.2
        	2024-11-06 21:14:11.718	info	Zigbee: disabling joining new devices.
        zigbee.2
        	2024-11-06 21:14:11.714	info	cleaned everything up...
        zigbee.2
        	2024-11-06 21:14:11.666	error	Exception-Code: ERR_BAD_REQUEST: Request failed with status code 404
        zigbee.2
        	2024-11-06 21:14:11.666	error	AxiosError: Request failed with status code 404 at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12) at RedirectableRequest.handleResponse (/opt/iobroker/node_modules/axios/lib/adapters/http.js:547:9) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:488:12) at RedirectableRequest._processResponse (/opt/iobroker/node_modules/follow-redirects/index.js:398:10) at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/follow-redirects/index.js:91:12) at Object.onceWrapper (node:events:634:26) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:488:12) at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5)
        zigbee.2
        	2024-11-06 21:14:11.666	error	unhandled promise rejection: Request failed with status code 404
        zigbee.2
        	2024-11-06 21:14:11.665	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.2
        	2024-11-06 21:14:11.404	info	debug devices set to []
        zigbee.2
        	2024-11-06 21:14:11.312	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
        zigbee.2
        	2024-11-06 21:14:11.305	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
        zigbee.2
        	2024-11-06 21:14:11.298	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
        zigbee.2
        	2024-11-06 21:14:11.289	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
        zigbee.2
        	2024-11-06 21:14:11.281	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
        zigbee.2
        	2024-11-06 21:14:11.275	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
        zigbee.2
        	2024-11-06 21:14:11.269	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
        zigbee.2
        	2024-11-06 21:14:11.258	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
        zigbee.2
        	2024-11-06 21:14:11.253	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
        zigbee.2
        	2024-11-06 21:14:11.247	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
        zigbee.2
        	2024-11-06 21:14:11.232	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
        zigbee.2
        	2024-11-06 21:14:11.222	info	Zigbee started
        zigbee.2
        	2024-11-06 21:14:11.222	info	0xa4c13857375d7b75 (addr 44818): TS0502B - Tuya Light controller (Router)
        zigbee.2
        	2024-11-06 21:14:11.221	info	0x804b50fffe20319a (addr 29559): E1746 - IKEA TRADFRI signal repeater (Router)
        zigbee.2
        	2024-11-06 21:14:11.220	info	0x00158d000232cbea (addr 22263): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.220	info	0xa4c138ff5d8ed635 (addr 14773): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:11.219	info	0x842e14fffe163f01 (addr 21016): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.218	info	0xa4c138fb6312d1ea (addr 49596): L1(ZW) - Tuya Light dimmer 0-10V (Router)
        zigbee.2
        	2024-11-06 21:14:11.218	info	0x00158d0006d50943 (addr 15532): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.217	info	0x00158d0006e49411 (addr 24941): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.217	info	0x00158d0006d667b4 (addr 37207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.217	info	0x00158d0006e3bb69 (addr 60535): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.216	info	0x00124b00234cdf26 (addr 54690): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:11.216	info	0x84fd27fffecf6567 (addr 53920): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
        zigbee.2
        	2024-11-06 21:14:11.215	info	0x00158d00024905e0 (addr 31049): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.214	info	0xa4c13896f124a5e3 (addr 45147): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:11.213	info	0xbc33acfffe8663a9 (addr 4579): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.213	info	0x54ef44100025ce21 (addr 5858): MCCGQ14LM - Aqara Door and window sensor E1 (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.212	info	0x84fd27fffe9b5e43 (addr 13249): E1746 - IKEA TRADFRI signal repeater (Router)
        zigbee.2
        	2024-11-06 21:14:11.211	info	0xa4c138442eb7c935 (addr 6635): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.2
        	2024-11-06 21:14:11.210	info	0x00158d00024375aa (addr 74): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.210	info	0x00158d000232979b (addr 4151): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.209	info	0x04cf8cdf3c7d7c69 (addr 20132): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.208	info	0x04cf8cdf3c7dcc26 (addr 29290): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.207	info	0x5c0272fffe96fa2a (addr 7999): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
        zigbee.2
        	2024-11-06 21:14:11.206	info	0x00124b00234c6ba9 (addr 60438): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:11.206	info	0x00124b00235279d6 (addr 3321): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:11.205	info	0x00124b0023528715 (addr 35049): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
        zigbee.2
        	2024-11-06 21:14:11.204	info	0x54ef44100017a66e (addr 57020): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.203	info	0x842e14fffe602b98 (addr 14854): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.202	info	0xa4c1388e4fb7d6d8 (addr 59225): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
        zigbee.2
        	2024-11-06 21:14:11.198	info	0x54ef4410001c5ee0 (addr 4247): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
        zigbee.2
        	2024-11-06 21:14:11.137	info	Currently 30 devices are joined:
        zigbee.2
        	2024-11-06 21:14:11.001	info	--> transmitPower : high+
        zigbee.2
        	2024-11-06 21:14:10.991	info	Unable to disable LED, unsupported function.
        zigbee.2
        	2024-11-06 21:14:10.990	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
        zigbee.2
        	2024-11-06 21:14:09.485	info	Installed Version: iobroker.zigbee@1.10.12
        zigbee.2
        	2024-11-06 21:14:09.252	info	Starting Zigbee npm ...
        zigbee.2
        	2024-11-06 21:14:09.251	info	delete old Backup files. keep only last 10
        zigbee.2
        	2024-11-06 21:14:09.152	info	starting. Version 1.10.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 7.0.2
        host.iobroker
        	2024-11-06 21:14:06.443	info	iobroker exit 0
        host.iobroker
        	2024-11-06 21:14:05.781	info	instance system.adapter.zigbee.2 in version "1.10.12" started with pid 150554
        host.iobroker
        	2024-11-06 21:14:05.102	info	"system.adapter.zigbee.2" enabled
        host.iobroker
        	2024-11-06 21:14:05.094	info	iobroker host.iobroker Adapter "system.adapter.zigbee.2" is started
        host.iobroker
        	2024-11-06 21:14:05.089	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
        host.iobroker
        	2024-11-06 21:14:05.085	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
        host.iobroker
        	2024-11-06 21:14:05.080	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
        host.iobroker
        	2024-11-06 21:14:05.073	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
        host.iobroker
        	2024-11-06 21:14:05.069	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
        host.iobroker
        	2024-11-06 21:14:05.064	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
        host.iobroker
        	2024-11-06 21:14:05.059	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
        host.iobroker
        	2024-11-06 21:14:05.055	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
        host.iobroker
        	2024-11-06 21:14:05.047	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
        host.iobroker
        	2024-11-06 21:14:05.041	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
        host.iobroker
        	2024-11-06 21:14:05.036	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
        host.iobroker
        	2024-11-06 21:14:05.030	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
        host.iobroker
        	2024-11-06 21:14:05.025	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
        host.iobroker
        	2024-11-06 21:14:05.017	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
        host.iobroker
        	2024-11-06 21:14:05.011	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
        host.iobroker
        	2024-11-06 21:14:05.006	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
        host.iobroker
        	2024-11-06 21:14:05.001	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
        host.iobroker
        	2024-11-06 21:14:04.997	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
        host.iobroker
        	2024-11-06 21:14:04.993	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
        host.iobroker
        	2024-11-06 21:14:04.988	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
        host.iobroker
        	2024-11-06 21:14:04.984	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
        host.iobroker
        	2024-11-06 21:14:04.955	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
        host.iobroker
        	2024-11-06 21:14:04.929	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
        host.iobroker
        	2024-11-06 21:14:04.898	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
        host.iobroker
        	2024-11-06 21:14:04.867	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
        host.iobroker
        	2024-11-06 21:14:04.806	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
        host.iobroker
        	2024-11-06 21:14:04.735	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
        host.iobroker
        	2024-11-06 21:14:04.680	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
        host.iobroker
        	2024-11-06 21:14:04.646	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
        host.iobroker
        	2024-11-06 21:14:04.453	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
        host.iobroker
        	2024-11-06 21:14:04.213	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
        host.iobroker
        	2024-11-06 21:14:04.075	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
        host.iobroker
        	2024-11-06 21:14:03.839	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
        host.iobroker
        	2024-11-06 21:14:03.732	info	iobroker upload [332] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
        host.iobroker
        	2024-11-06 21:14:02.115	info	iobroker Update "system.adapter.zigbee.2"
        host.iobroker
        	2024-11-06 21:14:01.919	info	iobroker Updating objects from io-package.json for adapter "zigbee" with version "1.10.12"
        host.iobroker
        	2024-11-06 21:14:01.881	info	iobroker added 9 packages, removed 10 packages, and changed 3 packages in 10s303 packages are looking for funding run `npm fund` for details
        host.iobroker
        	2024-11-06 21:14:01.879	info	iobroker
        host.iobroker
        	2024-11-06 21:13:52.580	info	instance system.adapter.zigbee.2 terminated with code null ()
        host.iobroker
        	2024-11-06 21:13:52.580	warn	instance system.adapter.zigbee.2 terminated due to SIGKILL
        host.iobroker
        	2024-11-06 21:13:52.310	info	stopInstance timeout system.adapter.zigbee.2 killing pid 135167
        zigbee.2
        	2024-11-06 21:13:51.774	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.2
        	2024-11-06 21:13:51.770	info	terminating
        host.iobroker
        	2024-11-06 21:13:51.483	info	iobroker NPM version: 10.8.2Installing iobroker.zigbee@1.10.12... (System call)
        zigbee.2
        	2024-11-06 21:13:51.248	info	Zigbee: disabling joining new devices.
        zigbee.2
        	2024-11-06 21:13:51.246	info	cleaned everything up...
        zigbee.2
        	2024-11-06 21:13:51.245	info	Got terminate signal TERMINATE_YOURSELF
        host.iobroker
        	2024-11-06 21:13:51.284	info	stopInstance system.adapter.zigbee.2 send kill signal
        host.iobroker
        	2024-11-06 21:13:51.234	info	stopInstance system.adapter.zigbee.2 (force=false, process=true)
        host.iobroker
        	2024-11-06 21:13:51.234	info	"system.adapter.zigbee.2" disabled
        host.iobroker
        	2024-11-06 21:13:51.218	info	iobroker host.iobroker Adapter "system.adapter.zigbee.2" is stopped.
        host.iobroker
        	2024-11-06 21:13:51.160	info	iobroker Update zigbee from @1.10.3 to @1.10.12
        host.iobroker
        	2024-11-06 21:13:49.295	info	iobroker upgrade zigbee@1.10.12 --debug
          arteck Developer Most Active @amg_666 last edited by
          @amg_666 du hst ein gruppen Problem....
          installier mal bitte
          https://github.com/ioBroker/ioBroker.zigbee/tarball/group-problem
          und Poste mal aus dem log
          PROBLEM1
          und PROBLEM2
          oder am besten das LOG nach dem Adapter start
          amg_666 2 Replies Last reply Reply Quote 0
          • amg_666
            amg_666 @arteck last edited by amg_666
            @arteck Jetzt ist 1.10.12 drauf und scheint zu funktionieren (Adapter grün, Test an einem Schalter ging)
            zigbee.2
            	2024-11-07 12:36:20.064	warn	DeviceAvailability:Failed to ping 0xa4c1388e4fb7d6d8 TS011F
            zigbee.2
            	2024-11-07 12:36:13.288	warn	DeviceAvailability:Failed to ping 0x84fd27fffe9b5e43 TRADFRI Signal Repeater
            admin.0
            	2024-11-07 12:36:03.348	info	==> Connected system.user.admin from ::ffff:192.168.1.3
            zigbee.2
            	2024-11-07 12:36:01.595	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
            zigbee.2
            	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
            zigbee.2
            	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
            zigbee.2
            	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
            zigbee.2
            	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
            zigbee.2
            	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
            zigbee.2
            	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
            zigbee.2
            	2024-11-07 12:36:01.459	warn	PROBLEM2: group_901 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
            zigbee.2
            	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
            zigbee.2
            	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
            zigbee.2
            	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
            zigbee.2
            	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
            zigbee.2
            	2024-11-07 12:36:01.439	warn	PROBLEM2: group_1 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
            zigbee.2
            	2024-11-07 12:36:01.439	warn	PROBLEM2: group_1 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
            zigbee.2
            	2024-11-07 12:36:01.398	warn	PROBLEM1: {"1":"Gartenlampe","901":"Group 901","902":"Wuerfel"}
            zigbee.2
            	2024-11-07 12:36:01.396	info	debug devices set to []
            zigbee.2
            	2024-11-07 12:36:01.313	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
            zigbee.2
            	2024-11-07 12:36:01.306	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.2
            	2024-11-07 12:36:01.300	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
            zigbee.2
            	2024-11-07 12:36:01.291	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.2
            	2024-11-07 12:36:01.283	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.2
            	2024-11-07 12:36:01.276	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
            zigbee.2
            	2024-11-07 12:36:01.270	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.2
            	2024-11-07 12:36:01.259	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.2
            	2024-11-07 12:36:01.254	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.2
            	2024-11-07 12:36:01.248	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.2
            	2024-11-07 12:36:01.234	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
            zigbee.2
            	2024-11-07 12:36:01.224	info	Zigbee started
            Gruppen:
            Die 901 habe ich -zumindest nicht wissentlich- angelegt...
            BananaJoe Asgothian 2 Replies Last reply Reply Quote 0
            • BananaJoe
              BananaJoe Most Active @amg_666 last edited by
              @amg_666 sagte in Test Adapter iobroker.Zigbee 1.10.10:
              Die erscheint bei mir auch alle Naselang wieder ... auch wenn ich diese gelöscht hatte (ich verwende keine Gruppen)
              • Asgothian
                Asgothian Developer @amg_666 last edited by Asgothian
                Die Gruppe 901 kommt üblicherweise durch verschiedene Ikea Geräte ins Spiel (kann aber auch durch andere Geräte angelegt werden) die diese anlegen um intern zu kommunizieren. Da der Adapter vom Koordinator die vorhandenen Gruppen abfragt kommen diese durchaus vor.
                A
                BananaJoe 1 Reply Last reply Reply Quote 2
                • BananaJoe
                  BananaJoe Most Active @Asgothian last edited by
                  @asgothian ok, das macht sinn, da sind einige Ikea-Geräte, Taster und Lautstärkeregler
                  • amg_666
                    @arteck Also ich habe jetzt die Gruppe 901 gelöscht (k.A. ob das was bringt, weil IKEA Devices habe ich auch) und dann habe ich die anderen Gruppen gelöscht, danach neu angelegt und Devices den Gruppen wieder zugeordnet, das hat aber nix gebracht:
                    zigbee.2
                    	2024-11-07 15:08:30.594	warn	DeviceAvailability:Failed to ping 0x84fd27fffe9b5e43 TRADFRI Signal Repeater
                    zigbee.2
                    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
                    zigbee.2
                    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
                    zigbee.2
                    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
                    zigbee.2
                    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
                    zigbee.2
                    	2024-11-07 15:08:18.788	warn	PROBLEM2: group_2 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
                    zigbee.2
                    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
                    zigbee.2
                    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
                    zigbee.2
                    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
                    zigbee.2
                    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
                    zigbee.2
                    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
                    zigbee.2
                    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
                    zigbee.2
                    	2024-11-07 15:08:18.759	warn	PROBLEM1: {"1":"Gartenlampe","2":"Wuerfel"}
                    zigbee.2
                    	2024-11-07 15:08:18.754	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                    zigbee.2
                    	2024-11-07 15:08:18.656	info	debug devices set to []
                    zigbee.2
                    	2024-11-07 15:08:18.572	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                    zigbee.2
                    	2024-11-07 15:08:18.525	info	Zigbee started
                    Noch eine Frage: Er meckert ja auch diverse fehlende icons an, gibts da eine elegante Methode, die upzudaten oder muss ich das einzeln manuell machen?
                      arteck Developer Most Active @amg_666 last edited by arteck
                      @amg_666 ok die gruppen scheinen ok zu sein.. dann wird nur das icon download schuld an der miesere sein .. ich korrigier das mal..
                      kannst dann wieder auf die Normale version...
                      Die Icons werden automaschtisch nac dem Namen gesucht und runtergeladen aus dem zigbee2mqtt.. kann aber sein dass da der Name anders ist .. dann kommt kein icon runnter
                      ich kann die manuell nachpflegen, muss aber dazu die info Kachel haben
                      • amg_666
                        @arteck ich hab mittlerweile mal "iob file sync" gemacht, im Adapter werden mir alle Kacheln mit Symbol angezeigt. Soll ich mal die "normale" zigbee Version ausprobieren? Ich hab jetzt noch die von dir bereitgestellte Testversion am laufen
                          @amg_666 es kommt morgen eine .13 nimm die
                          sonst müllt der adapter dir das LOG file zu
                          • amg_666
                            @arteck Alles klar, Ergebnis werde ich hier posten...
                            • amg_666
                              amg_666 @amg_666 last edited by amg_666
                              @arteck Die 10.13 hab ich heute installiert, lief durch und Adapter ist grün, aber er meckert immer noch ein paar fehlende Icons an
                              zigbee.2
                              	2024-11-11 10:33:30.313	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                              zigbee.2
                              	2024-11-11 10:33:30.093	info	debug devices set to []
                              zigbee.2
                              	2024-11-11 10:33:29.978	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
                              zigbee.2
                              	2024-11-11 10:33:29.970	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                              zigbee.2
                              	2024-11-11 10:33:29.963	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                              zigbee.2
                              	2024-11-11 10:33:29.953	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                              zigbee.2
                              	2024-11-11 10:33:29.945	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                              zigbee.2
                              	2024-11-11 10:33:29.939	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
                              zigbee.2
                              	2024-11-11 10:33:29.932	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                              zigbee.2
                              	2024-11-11 10:33:29.915	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                              zigbee.2
                              	2024-11-11 10:33:29.910	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                              zigbee.2
                              	2024-11-11 10:33:29.903	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                              zigbee.2
                              	2024-11-11 10:33:29.883	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
                              zigbee.2
                              	2024-11-11 10:33:29.873	info	Zigbee started
                              Ich setze mehrere LED Controller ein, hier zum Beispiel
                              Und hier wird derselbe Controller verwendet, aber das Icon ist offensichtlich nicht da (da steht auch ein falscher Model-Typ in der Kachel)
                              Neuschwansteini Asgothian 2 Replies Last reply Reply Quote 0
                              • Neuschwansteini
                                Neuschwansteini @amg_666 last edited by
                                @arteck
                                version 1.10.13 laeuft hier einwandfrei, ich musste nach der Installation ein "iob upload zigbee"' machen, damit er sich die Icons in der Objectansicht holt, da hatten ein paar gefehlt.
                                Danach etwas gewartet, die Objectansicht neu aktualisiert, und die Icons sind alle da.
                                • Asgothian
                                  @amg_666 zeig mal die Info - Seite der beiden kacheln.
                                  • amg_666
                                    amg_666 @Asgothian last edited by
                                    @asgothian Die stehen oben in meinem Post, beides sind "WZ1 Zigbee 2CH LED Controller":
                                    Hier ist alles ok, wobei mir das Modell TS0502B nichts sagt:
                                    Hier meckert er im Protokoll die Grafik an (L1(ZW) not found) ist aber derselbe Devicetyp, auch ein WZ1 LED Controller:
                                    • Asgothian
                                      @amg_666 nein, die sind nicht gemeint, auf den Kacheln ist das blaue (i). Ich will sehen was kommt wenn du da drauf gehst.
                                      A.
                                      • amg_666
                                        @asgothian
                                        "Nicht ok Device"
                                        "ok Device"
                                        Asgothian arteck 2 Replies Last reply Reply Quote 0
                                        • Asgothian
                                          @amg_666 ein Blick drauf zeigt das es sich nicht um baugleiche Geräte handelt - sie melden sich mit unterschiedlichen manufacturer tags am Netz an.
                                          Willkommen in der Welt von TuYa.
                                            @amg_666 nur weil die gleich aussehen heisst es nicht das diese gleich sind..
                                            31.7k
                                            79.8k
                                            190
                                            17351
