    4. Homematic IP Cloud Adapter lässt sich nicht installieren
      lukas8519 @Thomas Braun last edited by
      Copy text starting here:
                              v.2024-10-19
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.15.61-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    28
      This system needs to be REBOOTED NOW!
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.18.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            3.8G        2.4G        412M         35M        964M        1.2G
      Swap:            99M         56M         43M
      Total:          3.9G        2.5G        456M
      Active iob-Instances:   31
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                26089
      States:                 20688
      Size of iob-Database:
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      37M     /opt/iobroker/iobroker-data/states.jsonl
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      === Mark text until here for copying ===
        Thomas Braun Most Active @lukas8519 last edited by Thomas Braun
        @lukas8519
        Ich wollte die Langfassung sehen, nicht die Zusammenfassung.
        Nach einem REBOOT:
          @thomas-braun habs gemerkt, moment
            @lukas8519
            Und das bringst du auch auf 0:
              um die letzten 6 Updates kümmere ich mich morgen.
              ========== Start marking the full check here ===========
              Script v.2024-10-19
              *** BASE SYSTEM ***
                       Icon name: computer
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               00:18:01 up 4 min,  2 users,  load average: 3.97, 2.63, 1.17
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Sun 2024-11-10 00:18:01 CET
                         Universal time: Sat 2024-11-09 23:18:01 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              lukas
              HOME=/home/lukas
              GROUPS=lukas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        2.0G        821M        1.0M        943M        1.7G
              Swap:            99M          0B         99M
              Total:          3.9G        2.0G        921M
                       3794 M total memory
                       2028 M used memory
                       2408 M active memory
                        415 M inactive memory
                        821 M free memory
                         71 M buffer memory
                        872 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 00:18:02 up 4 min,  2 users,  load average: 3.73, 2.60, 1.17
              Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  9.7 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3794.3 total,    821.5 free,   2028.4 used,    944.4 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1681.2 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              /dev/root      ext4      235G   14G  212G   6% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  1.2M  758M   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
              [Sun Nov 10 00:13:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Sun Nov 10 00:13:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Nov 10 00:13:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Nov 10 00:13:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              4.8G    /var/
              3.7G    /var/log
              3.6G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
              739M    /var/cache
              Archived and active journals take up 3.5G in the file system.
              /opt/iobroker/backups:
              1.7G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              548M    /opt/iobroker/iobroker-data/
              402M    /opt/iobroker/iobroker-data/files
              80M     /opt/iobroker/iobroker-data/backup-objects
              67M     /opt/iobroker/iobroker-data/files/echarts.admin
              61M     /opt/iobroker/iobroker-data/files/echarts
              38M     /opt/iobroker/iobroker-data/states.jsonl
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
              *** NodeJS-Installation ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Installed: 20.18.0-1nodesource1
                Candidate: 20.18.0-1nodesource1
                Version table:
               *** 20.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 289)
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.1.5
              javascript:     7.8.0
              nodejs modules from github:     1
              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
              + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
              + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
              + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
              + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
              + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
              Adapter    "bring"        : 1.8.4    , installed 1.8.4
              Adapter    "countdown"    : 2.3.0    , installed 2.3.0
              Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
              Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
              Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
              Adapter    "fullybrowser" : 3.0.12   , installed 2.1.1  [Updatable]
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
              Adapter    "hmip"         : 1.24.3   , installed 1.24.3
              Adapter    "hue"          : 3.12.0   , installed 3.12.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
              Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
              Adapter    "rpi2"         : 2.2.1    , installed 1.3.1  [Updatable]
              Adapter    "samsung"      : 0.6.1    , installed 0.6.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "withings"     : 0.0.13   , installed 0.0.13
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        26237
              States:         20884
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:6 https://repos.influxdata.com/debian stable InRelease
              Hit:7 https://apt.grafana.com stable InRelease
              Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        12227      623/influxd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1818       581/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15599      914/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15605      914/iobroker.js-con
              tcp        0      0 192.168.178.92:42011    0.0.0.0:*               LISTEN      1001       15855      1203/io.hm-rpc.1
              tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15823      1184/io.hm-rpc.0
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14199      545/cupsd
              tcp6       0      0 :::8086                 :::*                    LISTEN      116        16444      623/influxd
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18905      1797/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17521      1029/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18296      1731/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          1820       581/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14198      545/cupsd
              tcp6       0      0 :::3000                 :::*                    LISTEN      117        15592      913/grafana
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14656      476/dhcpcd
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16054      1334/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16055      1334/io.tuya.0
              udp        0      0 0.0.0.0:35422           0.0.0.0:*                           108        14136      401/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14134      401/avahi-daemon: r
              udp6       0      0 :::41151                :::*                                108        14137      401/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          14697      476/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        14135      401/avahi-daemon: r
              2024-11-10 00:19:17.540  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:17.541  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:17.542  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:17.597  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:21.597  - info: alexa2.0 (1139) Subscribing to states...
              2024-11-10 00:19:21.608  - info: alexa2.0 (1139) Deleting the following states: ["Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7","Smart-Home-Devices.003aedb7-567e-4c34-a57c-a07ff842976c.#query","Smart-Home-Devices.012f1123-14fe-45de-b7ad-e96d7d2418f5.#query","Smart-Home-Devices.0373ad50-6d67-4d7d-8cf1-25c5ca3a8a6f.#query","Smart-Home-Devices.0558f2c7-04f3-466b-bc3d-5eeb9537fc83.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#delete","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#enabled","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.active","Smart-Home-Devices.0a175031-bd4e-467f-bcf7-a317bfc179eb.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#delete","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#enabled","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity-reason","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.powerState","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#delete","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#enabled","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#query","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-hue","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-saturation","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorRgb","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureInKelvin","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity-reason","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.powerState","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#delete","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#enabled","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#query","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity-reason","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.powerState","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#delete","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#enabled","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#query","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.active","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#delete","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#enabled","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#query","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.brightness","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity-reason","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.powerState","Smart-Home-Devices.196e2f4f-23ff-4419-9398-55823800ccae.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#delete","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#enabled","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-hue","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-saturation","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorRgb","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureInKelvin","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.powerState","Smart-Home-Devices.1eaa8074-65f2-4b2f-8aa0-18a0bd21252a.#query","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#delete","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#enabled","Smart-Home-Devices.2ad5f69c-0316-4394-b033-ea4f1d17a11a.#query","Smart-Home-Devices.2b7f4876-d82c-42d6-b302-20a0ae5d5d39.#query","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#delete","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#enabled","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#query","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-hue","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-saturation","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorRgb","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureInKelvin","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.powerState","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#delete","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#enabled","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#query","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-hue","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-saturation","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorName","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorRgb","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity-reason","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.powerState","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#delete","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#enabled","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#query","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-hue","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-saturation","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorRgb","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureInKelvin","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.powerState","Smart-Home-Devices.3ac22223-0447-4d99-b624-1ed607a5848f.#query","Smart-Home-Devices.414afebe-9a0c-4dfb-a60d-d69324daa9ba.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#delete","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#enabled","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity-reason","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.powerState","Smart-Home-Devices.41d1bfc2-f0c9-41f5-993d-7f3090c0c015.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#delete","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#enabled","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity-reason","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.powerState","Smart-Home-Devices.45734c42-2ddc-4bdb-b4fb-053417c9fb29.#query","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#delete","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#enabled","Smart-Home-Devices.4843643a-6b91-48c5-9b27-21b8f1354a6d.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#delete","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#enabled","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.active","Smart-Home-Devices.4ffbe9f1-4adc-45e2-b00c-1d5cbb171c6f.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#delete","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#enabled","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.powerState","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#delete","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#enabled","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.powerState","Smart-Home-Devices.5b3e8fe1-a2e8-47fc-ac3f-9ae3e3715a59.#query","Smart-Home-Devices.60abe88c-de46-42fb-93a6-a84fbc400e20.#query","Smart-Home-Devices.62173163-c184-4f87-9284-60cb53677d3b.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#delete","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#enabled","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity-reason","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.powerState","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#delete","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#enabled","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#query","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.powerState","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#delete","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#enabled","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#query","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity-reason","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.powerState","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#delete","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#enabled","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#query","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-hue","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-saturation","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorRgb","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureInKelvin","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity-reason","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.powerState","Smart-Home-Devices.7ccaaf08-b038-4713-b431-eeb8500c3790.#query","Smart-Home-Devices.81d78b2e-d706-4162-84cf-44c8e38310da.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#delete","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#enabled","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity-reason","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.powerState","Smart-Home-Devices.888412a0-610a-46d4-9f2b-d260c44ab80b.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#delete","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#enabled","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.active","Smart-Home-Devices.8d73aba0-1cb0-40fd-aca7-a4aae639b1eb.#query","Smart-Home-Devices.92fa9139-72ae-4950-939f-264e9edd93d6.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#delete","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#enabled","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity-reason","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.powerState","Smart-Home-Devices.97fd57e9-16e9-471c-ba20-4629356240d2.#query","Smart-Home-Devices.9a0904f8-5dbe-469e-8b8d-e90d23494a36.#query","Smart-Home-Devices.9f34de1c-8ae8-4308-8d38-c4ac8270c1ad.#query","Smart-Home-Devices.a25e4279-c22e-44ca-b75a-54a54f0b2e3d.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#delete","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#enabled","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.active","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#delete","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#enabled","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#query","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.detectionState","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#delete","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#enabled","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#query","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity-reason","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.powerState","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#delete","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#enabled","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#query","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-hue","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-saturation","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorRgb","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureInKelvin","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity-reason","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.powerState","Smart-Home-Devices.b9aa977c-7173-4465-bc76-9bb35ea78a15.#query","Smart-Home-Devices.bdc08478-6398-4a62-8104-a87e3e841e8b.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#delete","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#enabled","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.active","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#delete","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#enabled","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#query","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity-reason","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.powerState","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#delete","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#enabled","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#query","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity-reason","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.powerState","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#delete","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#enabled","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity-reason","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.powerState","Smart-Home-Devices.c6b5fe24-e2e3-43a5-9625-1f3de08a9117.#query","Smart-Home-Devices.c7767a90-9305-4ad8-a194-b8d11cf068d5.#query","Smart-Home-Devices.c911652c-82d7-47ac-9148-b693698cd15c.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#delete","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#enabled","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity-reason","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.powerState","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#delete","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#enabled","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#query","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.detectionState","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#delete","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#enabled","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#query","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-hue","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-saturation","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorName","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorRgb","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity-reason","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.powerState","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#delete","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#enabled","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#query","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity-reason","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.detectionState","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#delete","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#enabled","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#query","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-hue","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-saturation","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorName","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorRgb","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity-reason","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.powerState","Smart-Home-Devices.d31fdee0-9261-45b2-b762-7601510e5bfa.#query","Smart-Home-Devices.d4c058d6-1454-4364-8044-024fa2b9015b.#query","Smart-Home-Devices.d567e065-a853-4cdb-90fa-637e858dba16.#query","Smart-Home-Devices.d735eab4-e4d9-4e27-9422-c66a413a945d.#query","Smart-Home-Devices.da69e1db-05a1-46b4-8113-b856e832d92a.#query","Smart-Home-Devices.e150b646-c923-4c38-8cd9-2d7dab656b06.#query","Smart-Home-Devices.e198978a-397d-431e-a5c3-014ba600f4b1.#query","Smart-Home-Devices.e2af59b6-6e34-4109-80aa-72e4c9c9531c.#query","Smart-Home-Devices.e4bb56f4-7aa9-447c-8f7b-e4594561ede3.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#delete","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#enabled","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.brightness","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity-reason","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.powerState","Smart-Home-Devices.e6371aa7-760a-4134-bd48-64a0534aa373.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#delete","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#enabled","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity-reason","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.powerState","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#delete","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#enabled","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#query","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity-reason","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.powerState","Smart-Home-Devices.e7b8b085-a5bb-43c9-b058-4f2906769370.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#delete","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#enabled","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-hue","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-saturation","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorRgb","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureInKelvin","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.powerState","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#delete","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#enabled","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#query","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.active","Smart-Home-Devices.e82d4546-299a-4161-b46e-61433fe3ccca.#query","Smart-Home-Devices.e98459e4-06bb-45dd-b5c3-84a2dcba87ff.#query","Smart-Home-Devices.e9bdc49a-b74d-4a31-99fc-7685187590d9.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#delete","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#enabled","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity-reason","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.powerState","Smart-Home-Devices.ead6cf64-5555-4eeb-8861-258621a8d286.#query","Smart-Home-Devices.f0cb5405-3842-4b18-9863-5c031c74a409.#query","Smart-Home-Devices.f3dcc4b4-74eb-45b4-b677-62bd5dbcaa46.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#delete","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#enabled","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-hue","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-saturation","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorRgb","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureInKelvin","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity-reason","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.powerState","Smart-Home-Devices.f7648592-a2b4-4556-8985-53006fce51a7.#query","Smart-Home-Devices.f87eec87-46b6-4cd2-a389-b2407b1229c9.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#delete","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#enabled","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.active","Smart-Home-Devices.fb458fac-5057-47bb-a16c-0e195adfc1c0.#query","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#delete","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#enabled","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.powerState","Smart-Home-Devices.fe7d453e-663d-4092-9069-91ad6c11169e.#query","Smart-Home-Devices.ff1203b1-c4be-4892-aef1-9c7a3aa0d40e.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#includeInAllQuery","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#includeInAllQuery","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#includeInAllQuery","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#includeInAllQuery","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#includeInAllQuery","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#includeInAllQuery","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#includeInAllQuery","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#includeInAllQuery","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#includeInAllQuery","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#includeInAllQuery","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#includeInAllQuery","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#includeInAllQuery","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#includeInAllQuery","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#includeInAllQuery","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#includeInAllQuery","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#includeInAllQuery","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#includeInAllQuery","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#includeInAllQuery","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#includeInAllQuery","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#includeInAllQuery","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#includeInAllQuery","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#includeInAllQuery","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#includeInAllQuery","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#includeInAllQuery","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#includeInAllQuery","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#includeInAllQuery","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#includeInAllQuery","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#includeInAllQuery","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#includeInAllQuery","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.humanPresenceDetectionState","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#query","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#includeInAllQuery","Smart-Home-Devices.2deb04a8-7e12-4a66-b6f1-8b24bf3caa95.humanPresenceDetectionState","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity-reason","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity-reason","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity-reason","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity-reason","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity-reason","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity-reason","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#enabled","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#delete","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.powerState","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureInKelvin","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-hue","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-saturation","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorRgb","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#query","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#includeInAllQuery","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#enabled","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#delete","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.powerState","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.brightness","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity-reason","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#query","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#includeInAllQuery","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#enabled","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#delete","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.powerState","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorName","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-hue","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-saturation","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorRgb","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity-reason","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#query","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#includeInAllQuery","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#enabled","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#delete","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.powerState","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureInKelvin","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-hue","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-saturation","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorRgb","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity-reason","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#query","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#includeInAllQuery","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#enabled","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#delete","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.powerState","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorName","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-hue","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-saturation","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorRgb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity-reason","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#query","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#includeInAllQuery"]
              2024-11-10 00:19:23.423  - info: alexa2.0 (1139) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2024-11-10 00:19:25.809  - warn: bring.0 (1451) Error on login: Cannot Login: 401 - "{\"message\":\"email password combination not existing\",\"error\":\"unauthorized\",\"error_description\":\"Not authorized to access this resource\",\"errorcode\":200}"
              2024-11-10 00:19:25.809  - info: bring.0 (1451) [LOGIN] Reconnection in 30 seconds
              2024-11-10 00:19:26.829  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.833  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.837  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.839  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.858  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.860  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.862  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:26.876  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.243  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.302  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.349  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.350  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.409  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.410  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.434  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
              2024-11-10 00:19:27.441  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                @Homoran @Thomas-Braun
                könnt ihr mir nochmal helfen?
                ich habe in JS meine Blocklys angepasst und dann aus Unwissenheit irgendwas "DEBUG ...." oben über die Menüleiste gestartet.
                Jetzt ist es so das alles läuft, ich aber nicht mehr über den Browser zum Iobroker komme...
                danke
                  @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                  iob diag
                  anschauen.
                    Homoran Global Moderator Administrators @lukas8519 last edited by
                    im Javascript editor?
                    inkognito versuchen
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       15:05:24 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                      CPU threads: 4
                      Current issues:
                                     Local time: Sun 2024-11-10 15:05:24 CET
                                 Universal time: Sun 2024-11-10 14:05:24 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      lukas
                      HOME=/home/lukas
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        2.1G        695M        1.0M        1.0G        1.6G
                      Swap:            99M          0B         99M
                      Total:          3.9G        2.1G        795M
                      Active iob-Instances:   29
                               3794 M total memory
                               2095 M used memory
                               2434 M active memory
                                483 M inactive memory
                                695 M free memory
                                101 M buffer memory
                                901 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 15:05:25 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                      Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3794.3 total,    695.1 free,   2096.1 used,   1003.1 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1621.6 avail Mem
                      *** FILESYSTEM ***
                      /dev/root      ext4      235G   15G  211G   7% /
                      [Sun Nov 10 14:45:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sun Nov 10 14:45:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Nov 10 14:45:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun Nov 10 14:45:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      /var:
                      4.8G    /var/
                      3.7G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                      3.7G    /var/log
                      739M    /var/cache
                      Archived and active journals take up 3.6G in the file system.
                      4.0K    /opt/iobroker/backups/influxDB_2024_11_10-01_00_25_backupiobroker
                      1.1G    /opt/iobroker/iobroker-data/
                      963M    /opt/iobroker/iobroker-data/files
                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                      28M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1200)
                      admin:          7.1.5
                      javascript:     8.8.3
                      Adapter State
                        system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
                      + instance is alive
                      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                      Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                      Objects and States
                      Objects:        26218
                      States:         20791
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15664      622/influxd
                      tcp        0      0 192.168.178.92:42010    0.0.0.0:*               LISTEN      1001       16648      1142/io.hm-rpc.1
                      tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15188      1127/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      885/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14947      885/iobroker.js-con
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13826      536/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12059      576/sshd: /usr/sbin
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18349      1729/io.web.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17391      1974/io.simple-api.
                      tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      622/influxd
                      tcp6       0      0 :::3000                 :::*                    LISTEN      117        16489      884/grafana
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13825      536/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12061      576/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16172      1218/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16173      1218/io.tuya.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12001      403/avahi-daemon: r
                      udp        0      0 0.0.0.0:50606           0.0.0.0:*                           108        12003      403/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12134      467/dhcpcd
                      udp6       0      0 :::546                  :::*                                0          12212      467/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        12002      403/avahi-daemon: r
                      udp6       0      0 :::49079                :::*                                108        12004      403/avahi-daemon: r
                      2024-11-10 15:06:16.682  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.068  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.071  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.081  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.129  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.585  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.586  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.589  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.590  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.591  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.626  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.627  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.628  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:26.933  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.053  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.099  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.102  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.104  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                      2024-11-10 15:06:27.122  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                        lukas8519 @Homoran last edited by
                        ja im Editor...
                        inkogito Browser?
                          Thomas Braun Most Active @lukas8519 last edited by
                          @lukas8519
                          iob start admin
                            lukas8519 @Thomas Braun last edited by
                            @thomas-braun sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                            @lukas8519
                            iob start admin
                            Danke!!!!!!!!!!!!
                            1438
