    3. Einsteigerfragen
    4. Iobroker weder über WebAdmin und ssh erreichbar…
      SirTiGer @crunchip last edited by SirTiGer
      @crunchip
      Es läuft der nur der Iobroker drauf…
      Ich verstehe auch das zu Stande kommen des Fehlers nichts. Ich arbeite nicht ipv6… Der Ordner /etc/iptables/ existiert auch gar nicht…
      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @SirTiGer last edited by
        @sirtiger
        iob diag
        und
        ip a
        sagt
          SirTiGer @Thomas Braun last edited by
          Sollte ich irgendwelche Daten der Diagnose unkenntlich machen?
            @sirtiger
            Besser nicht.
              crunchip Forum Testing Most Active @SirTiGer last edited by
              @sirtiger war eher dein Betriebssystem damit gemeint, aber das sieht man ja gleich mit iob diag
                iob diag
                ```bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.6.17-v8+
                      Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 15:02:15 up 1 day, 15:59,  2 users,  load average: 1.73, 0.84, 0.63
                CPU threads: 4
                *** LIFE CYCLE STATUS ***
                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                               Local time: Sun 2024-11-10 15:02:15 CET
                           Universal time: Sun 2024-11-10 14:02:15 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth docker gpio i2c spi
                iobroker
                HOME=/home/iobroker
                A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                A root login is not required in most Linux Distributions.
                Run 'iobroker fix' or use the system tools to create a user.
                *** DISPLAY-SERVER SETUP ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        1.9G        1.3G        1.0M        4.6G        5.8G
                Swap:            99M          0B         99M
                Total:          7.9G        1.9G        1.4G
                Active iob-Instances:   17
                         7808 M total memory
                         1882 M used memory
                         4988 M active memory
                         1275 M inactive memory
                         1329 M free memory
                          131 M buffer memory
                         4465 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 15:02:15 up 1 day, 15:59,  2 users,  load average: 1.91, 0.89, 0.65
                Tasks: 196 total,   2 running, 194 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 35.3 us,  4.4 sy,  0.0 ni, 57.4 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
                MiB Mem :   7809.0 total,   1329.2 free,   1882.6 used,   4597.2 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5803.3 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                [sudo] password for iobroker:
                No critical errors detected
                *** FILESYSTEM ***
                /dev/root      ext4      235G   78G  148G  35% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                /dev/sda1      vfat      255M   63M  193M  25% /boot
                tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
                [Fri Nov  8 23:02:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:34:5A:5D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d50f38b1-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): write access will be enabled during recovery
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): 1 orphan inode deleted
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): recovery complete
                [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): mounted filesystem 41c98998-6a08-4389-bf74-79c9efcf0739 ro with ordered data mode. Quota mode: none.
                [Fri Nov  8 23:02:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Fri Nov  8 23:02:38 2024] EXT4-fs (sda2): re-mounted 41c98998-6a08-4389-bf74-79c9efcf0739 r/w. Quota mode: none.
                Show mounted filesystems:
                TARGET  SOURCE    FSTYPE OPTIONS
                /       /dev/sda2 ext4   rw,noatime
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                3.7G    /var/
                2.5G    /var/lib
                2.3G    /var/lib/influxdb/data
                1.6G    /var/lib/influxdb/data/telegraf/autogen
                Archived and active journals take up 45.0M in the file system.
                /opt/iobroker/backups:
                65G     /opt/iobroker/backups/
                4.0K    /opt/iobroker/backups/influxDB_2023_07_12-02_58_21_backupiobroker
                /opt/iobroker/iobroker-data:
                967M    /opt/iobroker/iobroker-data/
                847M    /opt/iobroker/iobroker-data/files
                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                31M     /opt/iobroker/iobroker-data/objects.jsonl
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                USB-Devices by-id:
                /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_c01b17e327d3eb119bbb38e8bf09e213-if00-port0
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.18.0
                /usr/bin/node           v20.18.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Candidate: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                        100 /var/lib/dpkg/status
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     12.22.12~dfsg-1~deb11u5 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 143938)
                Core adapters versions
                js-controller:  6.0.11
                admin:          7.1.5
                javascript:     8.8.3
                nodejs modules from github:     1
                +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#f8df198f98f8731d37444fe604e7e0a36a5bba1d)
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.123.170, run as: admin
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                  system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.123.170
                  system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                  system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
                + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.123.170, run as: admin
                + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Upgrade policy: none
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "energiefluss" : 3.6.1    , installed 3.6.0  [Updatable]
                Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.4  [Updatable]
                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Controller "js-controller": 6.0.11   , installed 6.0.11
                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                Adapter    "viessmann"    : 1.4.9    , installed 1.4.9
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "worx"         : 3.1.0    , installed 3.1.0
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Objects and States
                Objects:        7502
                States:         6309
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Hit:6 https://download.docker.com/linux/debian bullseye InRelease
                Hit:7 https://dl.yarnpkg.com/debian stable InRelease
                Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:9 https://apt.grafana.com stable InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        821        965/influxd
                tcp        0      0 192.168.123.170:8081    0.0.0.0:*               LISTEN      1000       17426      1359/io.admin.0
                tcp        0      0 192.168.123.170:8082    0.0.0.0:*               LISTEN      1000       18831      1741/io.web.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          323        542/sshd: /usr/sbin
                tcp        0      0 192.168.123.170:2010    0.0.0.0:*               LISTEN      1000       17141      1498/io.hm-rpc.1
                tcp        0      0 192.168.123.170:1883    0.0.0.0:*               LISTEN      1000       17149      1536/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       15437      1177/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5919       1177/iobroker.js-co
                tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          6205       577/vcontrold
                tcp6       0      0 :::22                   :::*                    LISTEN      0          325        542/sshd: /usr/sbin
                tcp6       0      0 :::8888                 :::*                    LISTEN      997        881        695/chronograf
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        15407      965/influxd
                tcp6       0      0 :::3000                 :::*                    LISTEN      110        15035      1176/grafana
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4510       694/dhcpcd: [master
                udp        0      0 0.0.0.0:54264           0.0.0.0:*                           108        4052       403/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        4050       403/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          356        694/dhcpcd: [master
                udp6       0      0 :::5353                 :::*                                108        4051       403/avahi-daemon: r
                udp6       0      0 :::38442                :::*                                108        4053       403/avahi-daemon: r
                2024-11-10 15:00:35.105  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247235104_8143
                2024-11-10 15:00:47.819  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
                2024-11-10 15:00:48.020  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
                2024-11-10 15:01:01.648  - info: smartmeter.1 (1608) Received 5 values, 2 updated
                2024-11-10 15:01:04.110  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:01:10.521  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
                2024-11-10 15:01:10.531  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247270531_1576
                2024-11-10 15:01:34.146  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:01:35.093  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
                2024-11-10 15:01:35.103  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247295102_5053
                2024-11-10 15:01:47.819  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
                2024-11-10 15:01:48.019  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
                2024-11-10 15:02:02.641  - info: smartmeter.1 (1608) Received 5 values, 2 updated
                2024-11-10 15:02:04.146  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:02:10.521  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
                2024-11-10 15:02:10.559  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247330558_9306
                2024-11-10 15:02:28.599  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: Shelly Dimmer - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:02:28.601  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:02:35.119  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
                2024-11-10 15:02:35.127  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247355126_9498
                2024-11-10 15:02:47.823  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
                2024-11-10 15:02:48.024  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
                2024-11-10 15:02:58.577  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: Shelly Dimmer - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:03:00.499  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
                2024-11-10 15:03:03.651  - info: smartmeter.1 (1608) Received 5 values, 2 updated
                  ```bash
                                          v.2024-10-19
                           Icon name: computer
                        Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    2
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.18.0 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            7.8G        2.0G        1.2G        1.0M        4.6G        5.7G
                  Swap:            99M          0B         99M
                  Total:          7.9G        2.0G        1.3G
                  ioBroker Core:          js-controller           6.0.11
                                          admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                7502
                  States:                 6309
                  Size of iob-Database:
                  8.6M    /opt/iobroker/iobroker-data/states.jsonl
                    ip a
                    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                        inet 127.0.0.1/8 scope host lo
                           valid_lft forever preferred_lft forever
                        inet6 ::1/128 scope host
                    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                        link/ether e4:5f:01:34:5a:5d brd ff:ff:ff:ff:ff:ff
                        inet 192.168.123.170/24 brd 192.168.123.255 scope global noprefixroute eth0
                        inet6 fd00::c3b9:3fce:1ea:8dbf/64 scope global dynamic mngtmpaddr noprefixroute
                           valid_lft 7149sec preferred_lft 3549sec
                        inet6 fe80::a93e:6396:fedd:3170/64 scope link
                    3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
                        link/ether 02:42:d0:08:ab:07 brd ff:ff:ff:ff:ff:ff
                        inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
                      @sirtiger sagte in Iobroker weder über WebAdmin und ssh erreichbar…:
                      bullseye
                      dacht ich mir schon
                        Thomas Braun Most Active @crunchip last edited by
                        @crunchip
                        Und ich dachte mir schon:
                        docker0
                        Denn das Kernelmodul br_netfilter wird da oft verwendet.
                        Da bin ich dann aber raus.
                          crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                          @thomas-braun vllt hilft dieses weiter
                          https://serverfault.com/questions/963759/docker-breaks-libvirt-bridge-network
                          jedoch vllt löst sichs Problem ja von allein, mit einer Neuinstallation auf bookworm😊
                            Erst einmal schönen Dank für eure Hilfe.
                            Das System läuft jetzt auf Bookworm. Bin gespannt, ob der Fehler beseitigt ist.
                              JimmyBondi @SirTiGer last edited by
                              @sirtiger
                              Darf ich fragen, ob sich das Problem bei Dir erledigt hat ?
                              Mein Pi4 zeigt seit einiger Zeit exakt das gleiche Verhalten, und das ohne Docker und auf Bookworm.
                                Thomas Braun Most Active @JimmyBondi last edited by
                                @jimmybondi sagte in Iobroker weder über WebAdmin und ssh erreichbar…:
                                Mach am besten einen eigenen Thread auf, dann auch mit den eigenen Daten, die ein eigenes
                                iob diag
                                auf deinem eigenen System ausspuckt.
                                iobroker nicht erreichbar ssh webadmin
                                1025
