    3. Einsteigerfragen
    4. Iobroker weder über WebAdmin und ssh erreichbar…
      Thomas Braun Most Active @SirTiGer last edited by
      @sirtiger
      iob diag
      und
      ip a
      sagt
        SirTiGer @Thomas Braun last edited by
        Sollte ich irgendwelche Daten der Diagnose unkenntlich machen?
          @sirtiger
          Besser nicht.
            crunchip Forum Testing Most Active @SirTiGer last edited by
            @sirtiger war eher dein Betriebssystem damit gemeint, aber das sieht man ja gleich mit iob diag
              iob diag
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.6.17-v8+
                    Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               15:02:15 up 1 day, 15:59,  2 users,  load average: 1.73, 0.84, 0.63
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Sun 2024-11-10 15:02:15 CET
                         Universal time: Sun 2024-11-10 14:02:15 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth docker gpio i2c spi
              iobroker
              HOME=/home/iobroker
              A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
              A root login is not required in most Linux Distributions.
              Run 'iobroker fix' or use the system tools to create a user.
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.8G        1.9G        1.3G        1.0M        4.6G        5.8G
              Swap:            99M          0B         99M
              Total:          7.9G        1.9G        1.4G
              Active iob-Instances:   17
                       7808 M total memory
                       1882 M used memory
                       4988 M active memory
                       1275 M inactive memory
                       1329 M free memory
                        131 M buffer memory
                       4465 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 15:02:15 up 1 day, 15:59,  2 users,  load average: 1.91, 0.89, 0.65
              Tasks: 196 total,   2 running, 194 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 35.3 us,  4.4 sy,  0.0 ni, 57.4 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
              MiB Mem :   7809.0 total,   1329.2 free,   1882.6 used,   4597.2 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5803.3 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              [sudo] password for iobroker:
              No critical errors detected
              *** FILESYSTEM ***
              /dev/root      ext4      235G   78G  148G  35% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
              /dev/sda1      vfat      255M   63M  193M  25% /boot
              tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
              [Fri Nov  8 23:02:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:34:5A:5D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d50f38b1-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): write access will be enabled during recovery
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): 1 orphan inode deleted
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): recovery complete
              [Fri Nov  8 23:02:36 2024] EXT4-fs (sda2): mounted filesystem 41c98998-6a08-4389-bf74-79c9efcf0739 ro with ordered data mode. Quota mode: none.
              [Fri Nov  8 23:02:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Fri Nov  8 23:02:38 2024] EXT4-fs (sda2): re-mounted 41c98998-6a08-4389-bf74-79c9efcf0739 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET  SOURCE    FSTYPE OPTIONS
              /       /dev/sda2 ext4   rw,noatime
              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              3.7G    /var/
              2.5G    /var/lib
              2.3G    /var/lib/influxdb/data
              1.6G    /var/lib/influxdb/data/telegraf/autogen
              Archived and active journals take up 45.0M in the file system.
              /opt/iobroker/backups:
              65G     /opt/iobroker/backups/
              4.0K    /opt/iobroker/backups/influxDB_2023_07_12-02_58_21_backupiobroker
              /opt/iobroker/iobroker-data:
              967M    /opt/iobroker/iobroker-data/
              847M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              31M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
              8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_c01b17e327d3eb119bbb38e8bf09e213-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.0
              /usr/bin/node           v20.18.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.3
              nodejs:
                Installed: 20.18.0-1nodesource1
                Candidate: 20.18.0-1nodesource1
                Version table:
               *** 20.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 143938)
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     1
              +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#f8df198f98f8731d37444fe604e7e0a36a5bba1d)
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.123.170, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.123.170
                system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
              + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.123.170, run as: admin
              + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "energiefluss" : 3.6.1    , installed 3.6.0  [Updatable]
              Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
              Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.4  [Updatable]
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "hmip"         : 1.24.3   , installed 1.24.3
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "viessmann"    : 1.4.9    , installed 1.4.9
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "worx"         : 3.1.0    , installed 3.1.0
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects:        7502
              States:         6309
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://download.docker.com/linux/debian bullseye InRelease
              Hit:7 https://dl.yarnpkg.com/debian stable InRelease
              Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:9 https://apt.grafana.com stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        821        965/influxd
              tcp        0      0 192.168.123.170:8081    0.0.0.0:*               LISTEN      1000       17426      1359/io.admin.0
              tcp        0      0 192.168.123.170:8082    0.0.0.0:*               LISTEN      1000       18831      1741/io.web.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          323        542/sshd: /usr/sbin
              tcp        0      0 192.168.123.170:2010    0.0.0.0:*               LISTEN      1000       17141      1498/io.hm-rpc.1
              tcp        0      0 192.168.123.170:1883    0.0.0.0:*               LISTEN      1000       17149      1536/io.mqtt.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       15437      1177/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5919       1177/iobroker.js-co
              tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          6205       577/vcontrold
              tcp6       0      0 :::22                   :::*                    LISTEN      0          325        542/sshd: /usr/sbin
              tcp6       0      0 :::8888                 :::*                    LISTEN      997        881        695/chronograf
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        15407      965/influxd
              tcp6       0      0 :::3000                 :::*                    LISTEN      110        15035      1176/grafana
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4510       694/dhcpcd: [master
              udp        0      0 0.0.0.0:54264           0.0.0.0:*                           108        4052       403/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        4050       403/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          356        694/dhcpcd: [master
              udp6       0      0 :::5353                 :::*                                108        4051       403/avahi-daemon: r
              udp6       0      0 :::38442                :::*                                108        4053       403/avahi-daemon: r
              2024-11-10 15:00:35.105  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247235104_8143
              2024-11-10 15:00:47.819  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
              2024-11-10 15:00:48.020  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
              2024-11-10 15:01:01.648  - info: smartmeter.1 (1608) Received 5 values, 2 updated
              2024-11-10 15:01:04.110  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:01:10.521  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
              2024-11-10 15:01:10.531  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247270531_1576
              2024-11-10 15:01:34.146  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:01:35.093  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
              2024-11-10 15:01:35.103  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247295102_5053
              2024-11-10 15:01:47.819  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
              2024-11-10 15:01:48.019  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
              2024-11-10 15:02:02.641  - info: smartmeter.1 (1608) Received 5 values, 2 updated
              2024-11-10 15:02:04.146  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:02:10.521  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
              2024-11-10 15:02:10.559  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247330558_9306
              2024-11-10 15:02:28.599  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: Shelly Dimmer - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:02:28.601  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:02:35.119  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connection closed: timeout
              2024-11-10 15:02:35.127  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] connected with secret 1731247355126_9498
              2024-11-10 15:02:47.823  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] subscribes on "mqtt.0.Gas.raw"
              2024-11-10 15:02:48.024  - info: mqtt.0 (1536) Client [ESP-Gaszaehler] publishOnSubscribe
              2024-11-10 15:02:58.577  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: Shelly Dimmer - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:03:00.499  - info: javascript.0 (1415) script.js.Scripte.Shellys.Shelly_Gen1_auslesen: "Shelly 2.5 - Tresen Beleuchtung ausgelesen!
              2024-11-10 15:03:03.651  - info: smartmeter.1 (1608) Received 5 values, 2 updated
                ```bash
                                        v.2024-10-19
                         Icon name: computer
                      Architecture: arm64
                Installation:           native
                Kernel:                 aarch64
                Userland:               64 bit
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                Boot Target:            multi-user.target
                Pending OS-Updates:     0
                Pending iob updates:    2
                Nodejs-Installation:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                Recommended versions are nodejs 20.18.0 and npm 10.8.2
                nodeJS installation is correct
                MEMORY:
                Mem:            7.8G        2.0G        1.2G        1.0M        4.6G        5.7G
                Swap:            99M          0B         99M
                Total:          7.9G        2.0G        1.3G
                ioBroker Core:          js-controller           6.0.11
                                        admin                   7.1.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                7502
                States:                 6309
                Size of iob-Database:
                8.6M    /opt/iobroker/iobroker-data/states.jsonl
                  ip a
                  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                      inet 127.0.0.1/8 scope host lo
                         valid_lft forever preferred_lft forever
                      inet6 ::1/128 scope host
                  2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                      link/ether e4:5f:01:34:5a:5d brd ff:ff:ff:ff:ff:ff
                      inet 192.168.123.170/24 brd 192.168.123.255 scope global noprefixroute eth0
                      inet6 fd00::c3b9:3fce:1ea:8dbf/64 scope global dynamic mngtmpaddr noprefixroute
                         valid_lft 7149sec preferred_lft 3549sec
                      inet6 fe80::a93e:6396:fedd:3170/64 scope link
                  3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
                      link/ether 02:42:d0:08:ab:07 brd ff:ff:ff:ff:ff:ff
                      inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
                    @sirtiger sagte in Iobroker weder über WebAdmin und ssh erreichbar…:
                    bullseye
                    dacht ich mir schon
                      Thomas Braun Most Active @crunchip last edited by
                      @crunchip
                      Und ich dachte mir schon:
                      docker0
                      Denn das Kernelmodul br_netfilter wird da oft verwendet.
                      Da bin ich dann aber raus.
                        crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                        @thomas-braun vllt hilft dieses weiter
                        https://serverfault.com/questions/963759/docker-breaks-libvirt-bridge-network
                        jedoch vllt löst sichs Problem ja von allein, mit einer Neuinstallation auf bookworm😊
                          SirTiGer @crunchip last edited by
                          Erst einmal schönen Dank für eure Hilfe.
                          Das System läuft jetzt auf Bookworm. Bin gespannt, ob der Fehler beseitigt ist.
                            JimmyBondi @SirTiGer last edited by
                            @sirtiger
                            Darf ich fragen, ob sich das Problem bei Dir erledigt hat ?
                            Mein Pi4 zeigt seit einiger Zeit exakt das gleiche Verhalten, und das ohne Docker und auf Bookworm.
                              Thomas Braun Most Active @JimmyBondi last edited by
                              @jimmybondi sagte in Iobroker weder über WebAdmin und ssh erreichbar…:
                              Mach am besten einen eigenen Thread auf, dann auch mit den eigenen Daten, die ein eigenes
                              iob diag
                              auf deinem eigenen System ausspuckt.
                              iobroker nicht erreichbar ssh webadmin
                              1025
